Retrofit question: Audi 8K facelift headlights retrofitted
ljbp
Portugal
I would really appreciate some help from you VAG coding experts.
Some workshop (not me) retrofitted this 2011 Audi A4 (8K) with facelift headlights and now when turning on the parking lights:
-the LEDs turn off
-warnings in cluster "Left side light/ daytime running light", "Right side light/ daytime running light"
-fault codes in central electronics control unit
Can someone help me code these facelift headlights?
I've gone through Cent. Elect. (J519) codings and adaptations and found nothing that could fix the issue.
I've copied the log below.
Thanks
Lino
Viking
C?ID=151455
You should update your VCDS first. Latest version is 18.2.1 and can be downloaded here.
:thumbs:
ljbp
Portugal
You are right :thumbs:
Here's the v18.2.1 log:
Monday,16,July,2018,11:13:59:25363
VCDS Version: 18.2.1.5
VIN: WAUZZZ8K1BA023580   License Plate:
Mileage: 97810km-60776mi   Repair Order:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 03 05 08 09 10 14 15 16 17 19 42 46 47 52 53 55 56 5F 62
          72
VIN: WAUZZZ8K1BA023580   Mileage: 97810km-60776miles
Address 01: Engine (J623-CAHA)       Labels:. 03L-906-019-CAG.clb
   Part No SW: 03L 906 022 NP    HW: 03L 906 019 AL
   Component: R4 2.0l TDI   H25 9978
   Revision: 25H25---
   Coding: 12194012232403080000
   Shop #: WSC 29515 002 1048576
   ASAM Dataset: EV_ECM20TDI03L906022NP A02012
   ROD: EV_ECM20TDI03L906022NP.rod
   VCID: 000BDC7F9B60104424-8054
   Part No SW: 8K0 907 379 BH    HW: 8K0 907 379 BH
   Component: ESP8 front    H04 0060
   Coding: 16050C
   Shop #: WSC 27918 001 104857
   VCID: 000BDC7F9360104424-8054
   Part No SW: 8K0 907 064 CP    HW: 8K0 907 064 CP
   Component: BCM2 2.0      H04 0430
   Coding: 036200
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Component: FBSAUDIB8 IDG  H50 0071
   Serial number: 0810000077745003
   Serial number: 0210000109995009
   Part No SW: 8T2 820 043 AF    HW: 8T2 820 043 AF
   Component: KLIMA 3 ZONEN H08 0180
   Revision: D0000000    Serial number: 01050720100162
   Coding: 34300000
   VCID: 76E7BAA7C1A42EF40E-8022
   Part No SW: 8K0 907 063 N    HW: 8K0 907 063 N
   Component: BCM1 1.0      H29 0392
   Revision: 09029001    Serial number: 00000000718628
   Coding: 260010114034AF211E00000000001D0D0F1C874806010141000000
   VCID: 3A7F6E97B53C8A942A-806E
   Component: WWS 300409  H06 0070
   Serial number: SWF09040305204
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10973914
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
   Component: E1 - LDS  H08 0090
   Serial number: 00000000002606102077
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
                    Fault Status: 00101100
                    Reset counter: 142
                    Mileage: 97812 km
                    Date: 2010.02.03
                    Time: 19:28:00
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
                    Fault Frequency: 6
                    Reset counter: 142
                    Mileage: 97812 km
                    Date: 2010.02.03
                    Time: 19:28:00
Address 10: Park/Steer Assist (J446)       Labels:. 8K0-919-475.clb
   Part No SW: 8K0 919 475 R    HW: 8K0 919 475 A
   Component: PARKHILFE 8K  H06 0070
   Revision: 11001001    Serial number: 50931019008021
   Coding: 100203
   Shop #: WSC 06335 000 00000
   VCID: 489B045FFBD0E804AC-801C
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 8R0 907 364 B    HW: 8K0 907 364
   Component: DAEMPFUNGS-SG H09 0053
   Revision: 00000000    Serial number: 05071007800002
   Coding: 010181
   VCID: 397D719BB03A818C23-806C
   Part No SW: 8K0 959 655 J    HW: 8K0 959 655 J
   Component: AirbagVW-AU10 H41 0610
   Serial number: 003GKD0HSZNQ
   Coding: 30363435363030303030554A3052384B3053
   VCID: 4483106FCFF8CC6440-8010
   Serial number: 6334MSME55647557H
   Serial number: 6344MSME5561715FJ
   Serial number: 6352QSME756715008
   Serial number: 6362QSME77671028G
   Serial number: 63732SME461B2F566
   Serial number: 63832SME571B515E6
   Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
   Component: Lenks.Modul   H17 0014
   Revision: --------    Serial number: 90372LAB000ZG
   Coding: 000017
   Shop #: WSC 14749 000 1048576
   VCID: 3E776287A914A6B416-806A
   Component: E221 - MFL  H02 0010
   Part No SW: 8K0 920 981 D    HW: 8K0 920 981 D
   Component: KOMBIINSTR.   H21 0258
   Revision: 00000000    Serial number: EJD66AN6A
   Coding: 0F0610001A000008010100
   VCID: 346340AF97587CE4F0-8060
   Part No SW: 8T0 907 468 AJ    HW: 8T0 907 468 L
   Component: GW-BEM 5CAN-M H09 0120
   Revision: EC000056    Serial number: 5600E1082100AF
   Coding: 00C303
   Shop #: WSC 06325 000 00000
   VCID: 091DC15BA05A510C73-805C
   Component: J367-BDM  H07 0140
   Serial number: 00000000005659148119
   Part No SW: 8K0 959 793 M    HW: 8K0 959 793 M
   Component: TSG FA        H12 0357
   Revision:             Serial number: 0000106285908
   Coding: 011C02205000410001
   VCID: 4A9F3E57E5DC1A14BA-801E
   Revision: 00002001    Serial number: 0132510574
   Coding: 013B062220B904C08020023680000000
03156 - Sensor for Anti-Theft System (G578)
                    Reset counter: 142
                    Mileage: 97812 km
                    Date: 2010.02.03
                    Time: 19:28:40
01134 - Alarm Horn (H12)
                    Reset counter: 142
                    Mileage: 97812 km
                    Date: 2010.02.03
                    Time: 19:28:40
   Part No SW: 8T0 035 223 AN    HW: 8T0 035 223 AK
   Component: DSP Prem      H10 0190
   Revision: 00010001    Serial number: 34882004414901
   VCID: 7AFFAE97F5BC4A946A-802E
   Part No SW: 8K0 959 792 M    HW: 8K0 959 792 M
   Component: TSG BF        H12 0357
   Revision:             Serial number: 0000106238250
   VCID: 499D015BE0DA110CB3-801C
   Revision: 00000003    Serial number: 00000000685540
   Part No: 8K0 907 357 B
   Coding: 0000005
   Shop #: WSC 27918 001 1048576
   VCID: 346340AF57587CE4F0-8060
   Part No SW: 4F0 035 053 K    HW: 4F0 035 053
   Component: Radio U Basic H45 0074
   Revision: AB001007    Serial number: 341GS097611545
   Coding: 010003010000000001
   Shop #: WSC 06325 123 12345
   VCID: 2545ADEB2C82156C77-8070
   Part No SW: 8T1 035 666 M    HW: 8T1 035 666
   Component: H-BN-EU       H50 0187
   Revision: --------    Serial number: 321IM087530324
   Coding: 01010001000681ED01000B1E000000000001
   Shop #: WSC 00866 400 88369
   VCID: 4483106FC7F8CC6440-8010
   Subsystem 1 - Part No: 8R0 060 884 CH
   Component: EUR 2014  2004
   Component: DU7 High  H42 0104
   Serial number: A130L-0C2627249
   Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
   Component: E0380 Bedient  H08 0100
   Serial number: 00000001023843
   Part No SW: 8K0 959 795 F    HW: 8K0 959 795 F
   Component: TSG HL        H11 0357
   Revision:             Serial number: 0000106296549
   Coding: 010C02204000210001
   VCID: 45850D6BCCC2F56C57-8010
   Component: TSG HR        H11 0357
   Revision:             Serial number: 0000106291308
End-------------------------(Elapsed Time: 03:24)--------------------------
ljbp
Portugal
Problem is fixed.
Solution is as described in a youtube video I found:
"Facelift headlight retrofit is quite easy, just a small change with vcds: Module 09 -- security access -- adaptation -- channel 03 -- value 26"
Don't ask me how or why changing the channel 03 "turn signal dimming" fixes this issue, but it does.
