Audi A4/S4 (8K Headlights/ tail lights brightness increase
mkmagade
South Africa
C?ID=339484
Good day
I recently bought myself the VCDS cable and I am experimenting to see all the cool stuff I can do.
I saw in another post that the headlight brightness can be increased. Is this possible on the Audi A4 (8K)? If so, how?
Thanks in advance
I suspect that what is and isn't possible in this respect may depend on how your car is equipped, i.e. halogen vs. xenon headlights, and conventional vs. LED tails, as well as exactly which control modules are in your car. So please post an Auto-Scan. This show people all the relevant details.
mkmagade
South Africa
C?ID=339484
Sorry still new here:
VIN: WAUZZZ8K99A224816   License Plate:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 03 05 08 09 15 16 17 19 42 46 47 52 53 55 56 62 69 72 77
VIN: WAUZZZ8K99A224816   Mileage: 259200km-161059miles
69-Trailer -- Status: Cannot be reached 1100
Address 01: Engine (------CDHB)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8K1 907 115 K    HW: 8K1 907 115
   Component: 1.8l R4/4V TF H07 0002
   Revision: A5H07---
   Coding: 0104001018070920
   Shop #: WSC 04632 996 94821
   ASAM Dataset: EV_ECM18TFS8K1907115K A01003
   ROD: EV_ECM18TFS_AU48.rod
   VCID: 3634D0ECF8CE6C879BB-8062
4865 - No Communication with Towing System Control Module (J345)
          U1003 00 [039] - -
          [J345 - Towing Recognition Control ModuleNo Communication]
                    Mileage: 259203 km
                    Date: 2018.07.13
                    Time: 20:28:35
                    Coolant temperature: 33 °C
                    Intake air temperature: 33 °C
                    Voltage terminal 30: 11.638 V
Readiness: 1110 0101
   Part No SW: 8K0 907 379 AE    HW: 8K0 907 379 AE
   Component: ESP8 front    H04 0240
   Coding: 038500
   VCID: 7CA002C486E276D72DF-8028
   Part No SW: 8K0 907 064 C    HW: 8K0 907 064 C
   Component: BCM2 1.1      H80 0145
   Coding: 031100
   Shop #: WSC 06325 000 00000
   VCID: 3038E6F41A2A42B7C17-8064
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Serial number: 0509000014032020
   Component: J764 ELV MLB  H36 0042
   Serial number: 0209000018487002
   Part No SW: 8T2 820 043 Q    HW: 8T2 820 043 Q
   Component: KLIMA 1 ZONE  H06 0150
   Revision: B0000000    Serial number: 01270320091300
   Coding: 64040000
   VCID: 40D8B634AA8AD237317-8014
   Part No SW: 8K0 907 063 C    HW: 8K0 907 063 C
   Component: BCM1 1.0      H24 0253
   Revision: 04024001    Serial number: 00000000227751
   Coding: 2600D8914134AF310001000000001D0D0F1D230800010101000000
   Shop #: WSC 01234 444 262143
   VCID: 2F3AE58807145D4FD8D-807A
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 240309  H05 0070
   Serial number: SWF09030240361
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10428295
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 Q    HW: 8K0 941 531 Q
   Component: E1 - LDS  H07 0090
   Serial number: 00000000002303090277
03110 - Active Steering Control Module (J792)
                    Reset counter: 236
                    Mileage: 259203 km
                    Date: 2018.07.13
                    Time: 20:56:00
01517 - Control Module for Trailer/Towing Sensor (J345)
                    Reset counter: 236
                    Mileage: 259203 km
                    Date: 2018.07.13
                    Time: 20:28:00
03207 - Charisma Switch Module
                    Reset counter: 236
                    Mileage: 259203 km
                    Date: 2018.07.13
                    Time: 20:56:00
   Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
   Component: AirbagVW-AU10 H27 0410
   Serial number: 0038JD1F2P00
   Coding: 30363435363030303030554A3052384B3053
   VCID: 3C20C2C4C6E2B6D76DF-8068
   Serial number: 6334MSME462036723
   Serial number: 6344MSME45206C1AE
   Serial number: 6352QSME351F1F38S
   Serial number: 6362QSME611C11022
   Serial number: 63732SME6F21260C0
   Serial number: 63832SME34200318L
   Revision: --------    Serial number: 90315ICU0005X
   Coding: 000016
   VCID: 3D26CFC0DD78BFDF5A1-8068
   Part No SW: 8K0 920 900     HW: 8K0 920 900
   Component: KOMBIINSTR.   H18 0224
   Revision: 00000000    Serial number: 9DL75DU39
   Coding: 2F0D080002000008010001
   VCID: 678A4DA8EF64C50FD0D-8032
   Part No SW: 8T0 907 468 M    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0095
   Revision: GB300043    Serial number: 4300G09318803D
   Coding: 000303
   VCID: 4BC2911893CC016FD45-801E
   Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
   Component: J367-BDM  H06 0160
   Serial number: 1906E1B4050309
                    Reset counter: 236
                    Mileage: 259203 km
                    Date: 2018.07.13
                    Time: 20:28:31
   Part No SW: 8K0 959 793 D    HW: 8K0 959 793 D
   Revision:             Serial number: 0000008719388
   Coding: 011C02204001410001
   VCID: 41DEB330A180DB3F3E9-8014
   Revision: 00002001    Serial number: 0117781492
   Coding: 017F062200390040013001
   Shop #: WSC 06325 123 12345
01403 - Glass-Break Sensors; Rear
                    Reset counter: 236
                    Mileage: 259203 km
                    Date: 2018.07.13
                    Time: 21:10:06
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
   Part No SW: 8T0 035 223 AB    HW: 8T0 035 223
   Component: DSP STD       H07 0220
   Revision: S2100000
   Coding: 0203010102
   VCID: 6E84388CC09E144793B-803A
   Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
   Revision:             Serial number: 0000008692094
   Part No SW: 8K0 907 801 G    HW: 8K0 907 801 G
   Component: EPB Audi B8   H08 0080
   Revision: 00000003    Serial number: 00000000337919
   VCID: 3332E9F8EB3C79AFBC5-8066
   Part No: 8K5 907 357
   Coding: 0000004
   Shop #: WSC 06324 000 00000
   VCID: 77AA1DE8B3C4558F40D-8022
   Part No SW: 8T2 035 186 P    HW: 8T2 035 186 P
   Component: Concert3      H01 0310
   Revision: 00000004    Serial number: AUZ5Z6I1192247
   Coding: 0502008201018D000159070000
   VCID: 45D6A720B5A8F71F021-8010
   Subsystem 1 - Part No SW: 8T0 919 603 G    HW: 8T0 919 603 G
   Component: Display
03138 - Input AUX IN
                    Reset counter: 236
                    Mileage: 259203 km
                    Date: 2018.07.13
                    Time: 20:33:02
   Part No SW: 4F0 959 795 N    HW: 8K0 959 795 C
   Revision:             Serial number: 0000008718818
   Coding: 010C02204001210001
   VCID: 44D0BA24BE92CE1715F-8010
Address 69: Trailer
   Revision:             Serial number: 0000008718850
   Part No SW: 8T0 862 335 D    HW: 8T0 862 335 C
   Component: FSE_256x BT     H33 0600
   Revision: 00000000    Serial number: 00000005063268
   Coding: 0010390
   Shop #: WSC 04632 996 89440
   VCID: 3B22C1D8CF6CB1EF645-806E
End----(Elapsed Time: 01:33, VBatt start/end: 11.0V/10.9V. VIgn 10.9V)-----
Ouch.
Maybe you need to replace this car's battery or fix its charging system before trying other means to make the lights brighter?
mkmagade
South Africa
C?ID=339484
That's odd. Changed the battery about 2/3 years ago. Anyway to trace whether its the battery or alternator?
[Applications]
[History Data]
Check the radio button for 19 and click:
[Start]
Post the resulting data here.
mkmagade
South Africa
C?ID=339484
Tuesday,17,July,2018,17:49:49:37139
VCDS Version: Release 18.2.1 (x64)
Control Module Part Number: 8T0 907 468 M
  Component and/or Version: GW-BEM 5CAN   H06 0095
           Software Coding: 000303
            Work Shop Code: WSC 06325
History Data
Record 1/16: No-load voltage underranging
2018-07-17-14:29*21.3*03*00148***
2018-07-13-06:17*00.0*03**
2018-07-09-17:45*00.0*03**
2018-07-05-21:20*00.0*03**
2018-06-28-23:14*04.3*03**
2018-06-27-11:08*01.5*03**
2018-06-22-12:10*00.2*03**
2018-07-17-14:29*00.3*03*00032***
2016-07-10-07:05*00.1*03**
2016-05-05-05:57*00.7*03**
2016-04-26-12:28*01.1*03**
2016-04-22-03:05*07.1*03**
2016-04-20-06:52*06.9*03**
2016-04-19-06:33*09.5*03**
2016-05-05-05:57*00.2*03*00000***
2000-01-01-00:00*00.0*00**
Record 2/16: No-load current overranging
2016-03-14-01:09*0005*018*-00.26*0-0-0-0-0-0*0*01*00011**
2013-10-11-13:37*0002*044*-01.25*0-1-0-0-0-0*0*01**
2013-10-11-09:36*0004*049*-01.25*0-1-0-0-0-0*0*01**
2000-01-01-00:00*0000*000*+00.00*0-0-0-0-0-0*0*00**
Record 3/16: Shut-off stage history
2016-05-05-05:57*3*0*005*000*-02.61*0-0-0-0-0-0*0*0*00.0*10.4**
2016-05-05-04:57*2*0*024*002*-04.40*0-0-0-0-0-0*0*0*00.0*10.4**
2016-05-05-04:30*1*0*028*006*-04.52*0-0-0-0-0-0*0*0*00.0*09.9**
2016-04-21-23:04*2*0*018*003*-04.13*0-0-0-0-0-0*0*0*00.0*04.9**
2016-04-21-22:25*1*0*021*006*-04.90*0-0-0-0-0-0*0*0*00.0*04.3**
2016-04-19-23:28*2*0*019*003*-04.12*0-0-0-0-0-0*0*0*00.0*07.0**
2016-04-19-22:58*1*0*022*006*-04.46*0-0-0-0-0-0*0*0*00.0*06.6**
2016-04-16-01:09*2*0*021*003*-03.65*0-0-0-0-0-0*0*0*00.0*07.7**
2016-04-16-00:37*1*0*025*006*-04.47*0-0-0-0-0-0*0*0*00.0*07.2**
2016-04-05-12:00*3*0*014*000*-04.11*0-0-0-0-0-0*0*0*00.0*00.0**
2016-04-05-11:57*2*0*024*001*-07.90*0-0-0-0-0-0*0*0*02.7*02.9**
2016-04-05-11:50*1*0*031*006*-08.22*0-0-0-0-0-0*0*0*02.6*02.7**
2016-04-01-14:08*3*0*006*000*-02.56*0-0-0-0-0-0*0*0*00.0*05.8**
2016-04-01-13:08*2*0*028*003*-03.62*0-0-0-0-0-0*0*0*00.0*05.8**
2016-04-01-12:36*1*0*035*006*-03.96*0-0-0-0-0-0*0*0*00.0*05.3**
Record 4/16: Battery change history
2016-04-07-16:15*03*4F0915105C *VAO*0987654321*09986*07095*0000*0000*0000**
2008-05-27-00:09*02*000915105DH*VAO*A0151114E0*09985*00104*0000*0000*0000**
2009-04-03-01:44*01*8K0915105D *MLA*190326QB6X*09982*12414*0000*0000*0000**
2000-01-01-00:00*00*-----------*XXX*----------*10000*00000*0000*0000*0000**
2000-01-01-00:00*00*-----------*XXX*----------*00000*00000*0000*0000*0000**
Record 5/16: Energy-critical vehicle states
2016-05-05-05:57*-00.02*-03.51*-02.61*11.60*000*18*-41.3*00626*09963*
181351*0-0-0-0-0-0*0*00.0*10.4*001.0*63*00*01**
2016-04-01-14:08*-00.01*-03.39*-02.56*12.10*000*30*-23.8*12364*09980*
176849*0-0-0-0-0-0*0*00.0*05.8*001.0*35*00*01**
2000-01-01-00:00*+00.00*+00.00*+00.00*00.00*000*00*+00.0*00000*00000*
000000*0-0-0-0-0-0*0*00.0*00.0*000.0*00*00*00**
Record 6/16: Energy balances (last 20 trips)
2018-07-15-19:32*064*+18*+000.3*00.04**
2018-07-15-19:25*065*+18*+000.3*00.07**
2018-07-15-15:01*064*+17*+001.0*00.48**
2018-07-15-14:37*064*+16*+000.1*00.04**
2018-07-15-13:17*064*+16*+000.2*00.05**
2018-07-15-12:29*063*+16*+000.1*00.03**
2018-07-15-12:24*063*+16*+000.1*00.03**
2018-07-15-11:47*063*+16*+013.2*00.58**
2018-07-14-23:23*065*+17*+000.3*00.17**
2018-07-14-23:21*064*+17*+000.1*00.01**
2018-07-14-23:01*065*+17*+000.9*00.32**
2018-07-14-22:45*064*+17*+000.4*00.11**
2018-07-14-17:10*066*+20*+000.3*00.13**
2018-07-14-16:58*066*+20*+000.3*00.12**
2018-07-14-15:21*066*+20*+000.3*00.12**
2018-07-14-15:00*066*+20*+000.4*00.14**
2018-07-14-14:18*066*+20*+004.0*00.49**
2018-07-14-12:44*065*+18*+000.0*00.01**
2018-07-14-12:34*065*+18*+000.5*00.15**
2018-07-14-12:13*065*+18*+000.7*00.19**
Record 7/16: Energy balances (last 20 standing times)
2018-07-15-19:29*064*-000.3*000.0*00.0*00.0**
2018-07-15-15:30*063*-000.8*003.8*00.0*00.0**
2018-07-15-14:39*064*-000.2*000.3*00.0*00.0**
2018-07-15-13:21*064*-000.2*001.2*00.0*00.0**
2018-07-15-12:32*063*-000.3*000.7*00.0*00.0**
2018-07-15-12:26*063*-000.1*000.0*00.0*00.0**
2018-07-15-12:22*062*-000.1*000.0*00.0*00.0**
2018-07-14-23:33*047*-014.2*012.1*00.8*00.7**
2018-07-14-23:22*064*-000.1*000.0*00.0*00.0**
2018-07-14-23:20*065*-000.2*000.0*00.0*00.0**
2018-07-14-22:52*062*-000.6*000.1*00.0*00.0**
2018-07-14-17:17*064*-000.7*005.4*00.0*00.0**
2018-07-14-17:06*066*-000.2*000.0*00.0*00.0**
2018-07-14-15:29*066*-000.4*001.4*00.0*00.0**
2018-07-14-15:09*066*-000.2*000.1*00.0*00.0**
2018-07-14-14:47*066*-000.2*000.1*00.0*00.0**
2018-07-14-12:44*062*-003.8*001.3*00.3*00.0**
2018-07-14-12:25*064*-000.2*000.1*00.0*00.0**
2018-07-14-11:38*063*-000.3*000.5*00.0*00.0**
2018-07-14-11:13*061*-000.1*000.0*00.0*00.0**
Record 8/16: Battery manipulation (e.g. charging)
2018-05-17-16:45*2*00*12*00*07*2000-01-01-00:00*03**
2018-05-17-05:26*2*00*12*00*07*2000-01-01-00:00*03**
2018-05-16-05:25*2*00*12*00*07*2000-01-01-00:00*03**
2018-04-16-07:06*2*00*12*00*07*2000-01-01-00:00*03**
2017-12-24-19:33*2*00*12*00*07*2000-01-01-00:00*03**
Record 9/16: Battery aging
2018-07-15-19:24*053*068*096*064*07074*12.70*+18*03**
2018-07-01-16:26*053*071*084*058*06954*12.60*+15*03**
2018-06-17-11:07*053*072*086*059*06849*12.60*+13*03**
2018-06-03-09:34*053*069*086*060*06806*12.60*+15*03**
2018-05-19-00:20*053*071*077*056*06702*12.50*+22*03**
2018-05-04-23:38*053*072*084*062*06660*12.60*+20*03**
2018-04-21-09:07*053*069*090*066*06581*12.60*+16*03**
2018-04-07-07:38*053*067*086*062*06469*12.60*+17*03**
2018-03-22-19:49*053*067*088*069*06409*12.60*+26*03**
2018-03-08-19:24*053*067*081*061*06349*12.50*+23*03**
2018-02-25-16:40*053*068*091*072*06310*12.60*+24*03**
2018-02-11-16:14*053*067*086*069*06235*12.60*+27*03**
Record 10/16: Dynamic energy management
2016-12-31-20:54*1*005.0*0*000.0*001.2**
2015-06-08-17:42*1*003.9*0*000.0*000.3**
2000-01-01-00:00*0*000.0*0*000.0*000.0**
2000-01-01-00:00*0*0*0*000.0**
2016-12-31-20:23*2*005.0*000.6**
2015-06-08-17:42*2*003.9*000.3**
2000-01-01-00:00*0*000.0*000.0**
Record 11/16: Recuperation
2000-01-01-00:00*000*000*000*000*0000*000*00.0*+00.0*000*000*000*000*00*00000*00000*00000**
2000-01-01-00:00*000*000*000*000*0000*000*00.0*+00.0*000*000*000*000*00**
Record 12/16: Start-Stop
Record 13/16: Sporadic alternator faults
2018-06-02-08:55*1-1-0-0-0*000.0*00048**
2018-04-26-16:39*1-1-0-0-0*000.9**
2018-04-20-19:11*1-1-0-0-0*000.2**
2018-03-17-09:23*1-1-0-0-0*000.0**
2018-03-16-16:48*1-1-0-0-0*000.5**
Record 15/16: Local activ.
2000-01-01-00:00*000*00*00*000*00*00*000*00*00**
Record 16/16: Vehicle energy balance
259366**
11151*13563*01494*00237*00113**
26254*00300*00092*00030**
65535*12915*03045*00000**
04239*10677*04575*05820**
14276*09092*01943**
00000*00000*00000*00000**
21741*03963*03176*00145**
04894*00317*00087**
01510*00014*00004**
00230*00015*00003**
I'm not that skilled at interpreting this data, but it looks to me like:
  • Your battery was last changed on: 2016-04-07
  • You've had lots of no-load under-voltage incidents this month and last.
  • There are no recent no-load current overages.
  • You've had 20 "trips" and "standing time" in the last few days. I suspect these were actually times when you were playing with VCDS and pulled the state-of-charge to an unacceptably low level.
Have you got a battery charger?
mkmagade
South Africa
C?ID=339484
No, but I'm going to go for a drive now to see if there's any difference. Also, I don't go to work with the car so it's parked most of the week. Don't know whether that might influence the battery reading
Do you have a volt meter?
mkmagade
South Africa
C?ID=339484
Unfortunately. Just ran the scan again after the drive and it seems to be the same result. I'll take the car for battery testing at a battery shop over the weekend.
mkmagade
South Africa
C?ID=339484
Just a thought... Last time I had something draining my battery it turned out to be my tracker. Maybe the device's battery needs replacement? Fortunately my contract expired and I will do a new installation soon then monitor again
mkmagade
South Africa
C?ID=339484
So I activated the battery meter on my radio. Seems to drop due to playing around with vcds while ignition and radio on. Drove the the car and battery meter was back on 100% will check if it drops again
mkmagade
South Africa
C?ID=339484
@uwe I'd like to believe the battery charge decreased from having the ignition on while doing some mods with the vcds. If possible, could you please assist with headlight brightness (not drl)
Haven't had a chance to do another auto scan but I'll post it as soon as I can.
I don't see anything that would allow one to change the brightness of the headlights, sorry.
a4bill
Canada
C?ID=340446
I was looking into the same thing for my A4 b8. The ballasts and bulbs themselves cannot be brightened through vcds. If you have dim hid bulbs, they may just need replacement. If you turn the lights on and the bulbs go from a true white to a tint of yellow slowly over a few seconds it's a sign the bulb is on its way out and not providing good output.
They'll eventually fail completely. (I've replaced quite a few on cars).
Also, if your lenses are pitted like all of these cars pit...it'll diffuse the light differently and make it look like the bulb isn't producing enough. If that's the case, you can buy replacement lenses on crapbay from China and do a lens swap (the outer lens). It's a PITA.
Hope I helped at least a little.
mkmagade
South Africa
C?ID=339484
Thanks. Was really hoping it was possible.
mkmagade
South Africa
C?ID=339484
Hi Mate. I read somewhere that the lights are not set to 13V (their full potential) so thought I could increase mine for more light. I think they are still fairly bright so no need to replace yet. Thanks for the advice though at least now I know.
