2008 Jetta A/C Diag. question
fredgilb
Rockland County, NY, USA
C?ID=224483
A/c not working.
Trying to make sense of how to know if the control valve or the compressor is at fault
The shut off code =6
Compressor current (actual) = blank
Compressor current (specified) = 0.820 A
Comp. load 4.8Nm.
Refrig. pres. = 10.0 bar
I checked the resistance = 11 ohms
fredgilb
C?ID=224483
The A/C has no codes, but here's the scan;
Thursday,05,July,2018,19:47:00:34163
VCDS Version: 18.2.0.3
VIN: 3VWRA71K08M161709   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWRA71K08M161709   Mileage: 157710km-97996miles
62-Door, Rear Left -- Status: Sporadic communication error 1000
Address 01: Engine (CBF)       Labels:. 06J-907-115-CBF.clb
   Part No SW: 1K0 907 115 AD    HW: 1K0 907 115 AD
   Component: 2.0l R4/4V TFSI     0060
   Revision: E3H12---    Serial number: VWX7Z0H32430W3
   Coding: 040301081C070160
   VCID: 68DF98F15BF6A804B0-803C
   Part No SW: 02E 300 050 J    HW: 02E 927 770 AD
   Component: GSG DSG         082 1413
   Revision: 05108020    Serial number: 00001008301768
   Shop #: WSC 04940 001 00001
   VCID: 1939ED35D01CC18CFF-804C
   Revision: 00H11001
   Coding: 0021122
   VCID: 73E5FF9D12305BDC15-8026
   Part No SW: 1K0 820 047 HJ    HW: 1K0 820 047 HJ
   Component: Climatic PQ35   141 1010
   Revision: 00141028    Serial number: 00000000000000
   Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
   Revision: 00H54000    Serial number: 00000000895639
   Coding: 04058E230004150007140000001400008008730B5C000100000000000000
   Shop #: WSC 00066 123 12345
   VCID: 6FEDF3ED7E187F3CF1-803A
   Component: Wischer 050408 021  0501
   Coding: 00038805
   Shop #: WSC 00066
   Revision: 00000000    Serial number: AUZ4Z7H0304057
   Coding: 0000000
   VCID: 33653F9D52B01BDCD5-8066
                    Fault Frequency: 9
                    Reset counter: 234
                    Mileage: 145567 km
                    Time: 09:51:46
   Revision: 05034000    Serial number: 003B6M04V6B8
   Coding: 0013889
   VCID: 6CD7E4E14F0E8424D4-8038
   Subsystem 2 - Serial number: 6332MSME3676162CE
   Subsystem 3 - Serial number: 6342MSME34207A59C
   Subsystem 4 - Serial number: 6351HSME136D0D5AI
   Subsystem 5 - Serial number: 6361HSME136F2E4DQ
   Subsystem 6 - Serial number: 63727SME125B5443
   Subsystem 7 - Serial number: 63827SME126C053C2
02513 - Belt Force Sensor for Seat Occupied Recognition (G453)
   Part No SW: 1K0 953 549 BK    HW: 1K0 953 549 BK
   Coding: 0010021
   Shop #: WSC 06461 444 64437
   VCID: 7CF7D4A13F6E14A444-8028
   Part No SW: 1K0 920 954 P    HW: 1K0 920 954 P
   Component: KOMBIINSTRUMENT 3HL 1222
   Revision: V0002000    Serial number: VWX7Z0H32430W3
   Coding: 0021203
   VCID: 39790DB570DCE18C1F-806C
   Component: J533  Gateway   H07 0052
   Revision:   H07 01    Serial number: 210308F2002175
   Coding: ED807F070003021002
   VCID: 306F3091A3A620C4A8-8064
                    Fault Status: 00110100
                    Reset counter: 127
                    Mileage: 154640 km
                    Time: 11:00:59
   Component: IMMO            3HL 1222
   Shop #: WSC 08228 444 102997
   Component: J386  TUER-SG FT    1133
   Revision: 32008001    Serial number: 00000066288224
   Coding: 0001205
   VCID: 3B7517BD7AE0D39C0D-806E
                    Fault Status: 00101100
                    Fault Frequency: 115
                    Reset counter: 127
                    Fault Status: 00111000
                    Fault Frequency: 59
                    Reset counter: 127
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.070 H08 1901
   VCID: 356101855CC405ECFB-8060
   Coding: 0A900F880186683F0900858560880F0488DC80
   VCID: 0407AC41479E6C643C-8050
   Part No SW: 1K0 959 702 P    HW: 1K0 959 792 L
   Component: J387  TUER-SG BT    1133
   Revision: 32008001    Serial number: 00000667588317
   Coding: 0001204
   VCID: 3C7714A17FEED4A404-8068
   Component: Radio DE2       016 0020
   Revision: 00016000    Serial number: VWZ4Z7H2193200
   Coding: 0010401
   VCID: 2959DDF5807C510C6F-807C
   Part No SW: 1K0 959 703 Q    HW: 1K0 959 795 J
   Component: J388   TUER-SG HL   1120
   Revision: 12006001    Serial number: 00000002893143
   Coding: 0001168
   VCID: 3E731EA969F2C6B42A-806A
   Coding: 0100100
                    Reset counter: 100
                    Mileage: 131848 km
                    Time: 05:56:22
   Part No SW: 1K0 959 704 Q    HW: 1K0 959 794 J
   Component: J389   TUER-SG HR   1120
   Revision: 12006001    Serial number: 00000002935039
   Coding: 0001168
   VCID: 3F8D63AD6EF8CFBC21-806A
End---------------------(Elapsed Time: 02:22, udsna)-----------------------
Zenerdiode
Newcastle, England
C?ID=24330
Hmm, Shut Off code = 06 - appears to be "The compressor has been switched off by the 'Econ' function."
Do you want to try hitting the 'Auto' button, or the 'A/C' button, or whatever you have? Report back please.
fredgilb
C?ID=224483
The Code 6 is what I get when I turn the system off.........this is normal.
The line I'm confused on is; Compressor current (actual) = blank
The line that give me hope is: Comp. load 4.8Nm with A/C on.
BTW there is no change in the A/C gauges from A/C on to Off
Zenerdiode
Newcastle, England
C?ID=24330
Okay, I know, if you would do some more testing for us please. Does it go to '0' and stay at '0' for all of the time the A/C runs?
Does MVB 002.1 appear when A/C on?
Does MVB 003.1 change at all when A/C is on?
Using either intrusive current measurement or a hall-effect current clamp; does the current through the compressor control valve look anywhere near the Specified value?
fredgilb
C?ID=224483
Sorry for the late reply.....it has a Denso compressor. Paint a white stripe on the very center of the comp. Mine didn't move. Comp. seized.
DrPeter
16.4905° S, 151.7375° W
- Compressor failures are a common issue in many of these vehicles., almost as common as the failing N280 valve ;) ... you should have a close look at the refrigerant oil, if it is NOT clear or clean, you should replace the filter dryer and flush the system.
This Ross-Tech forum post linked below, maybe helpful in the future :)
https://forums.ross-tech.com/showthread.php?633-Tis%92-the-HVAC-Season
Hope this helps, stay cool!
drpeter
