ESI Resetting problem Skoda Octavia 5E
   #21
TBAx
C?ID=287144
Changing the first value will completely remove ESI warning... permanently. But I guess that would be more of a workaround.
Could you please check, if Resetting ESI with the aforementioned channel (currently „no warning“) does change anything?
   #22
Koszal
Poland
C?ID=327966
Gentlemen, one more time :-) What exactly should I change in these channels? I understand that bold values, but for which?
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms,5 s,18
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms,6 s,18
   #23
My guess is that those determine for how long the reminder message is displayed each time the ignition is turned on?
NEtech
C?ID=56995
Those are standard values.
I would not play that much you have, you have changed values minimum 15 times (like a service was made), since 33141 km 855 days!
If you really want to have service at fixed 15000km/365days, change to bad oil quality and change all other back to standard.
   #25
Koszal
Poland
C?ID=327966
Ok, then I'm not moving this.
The service was made on 02.07.2018... where did 855 days come from?
NEtech, can you tell me which values ​​should I bring back to standard? Do you think that restoring these values ​​will solve the problem with the displayed message?
   #26
NEtech
C?ID=56995
On 5 July, your car was 868 days old.
When it was 855 days, all the changing started.
If you have done it (or some of it), you can see the changes in log file, in VCDS Debug folder.
If I did not miss any, these should be like standard:
IDE00513-ESI: maximum value km-driving distance/inspection:      30000 km
IDE00514-ESI: maximum value of time between inspections:         730 d
IDE00515-ESI: oil quality:                                       poor oil quality
IDE03350-FIX: Maximum time until next time-dependent inspection: 730 d
For reseting all again:
IDE00342-ESI: Resetting ESI:                                            Reset
IDE03351-FIX: Distance covered since last mileage-dependent inspection: 0
IDE03352-FIX: Time since last time-dependent inspection:                0
I have no idea if this should correct the warnings Uwe showed you in post #7
Also maybe the message in instrument will stop after 500 km driving.
   #27
Koszal
Poland
C?ID=327966
I tried to Resetting ESI with the aforementioned channel, but it doesn't change anything.
NEtech
I set everything as you wrote above .. At the moment the warning has not disappeared ... we will see how it will be after driving 500 km - I will let you know.
   #28
Koszal
Poland
C?ID=327966
I driving over 500 km. since the changes that I made and unfortunately my car still showing information about the review and oil change for x km. on clocks and on the radio.
This is annoying ... you can have some ideas about what else I can do to make the message disappear.
