Monday,09,July,2018,13:12:40:27574
VCDS Version: 18.2.1.5 (x64)
VIN: WVWZZZ3CZGP016614 License Plate:
Mileage: 123342km-76641mi Repair Order:
Chassis Type 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F 65 6C
A5 BB BC CA
VIN: WVWZZZ3CZGP016614 Mileage: 123342km-76641miles
Address 01: Engine (J623-CRLB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 ET HW: 04L 907 309 R
Component: R4 2,0L EDC H22 1343
Revision: B5H22---
Coding: 011D0012036405083000
Shop #: WSC 00028 028 00030
ASAM Dataset: EV_ECM20TDI01104L906026ET 002001
ROD: EV_ECM20TDI01104L906026FL.rod
VCID: 000B6C479B68B54424-8054
Part No SW: 0D9 300 041 A HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4801
Revision: 06253104 Serial number: TFK01508180808
Shop #: WSC 00028 028 00025
ROD: EV_TCMDQ250021.rod
VCID: 16272A1FE9EC2BF4EE-8042
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 62805000001930
Coding: 0FEC6A8F34210B72077D060141C749F0562CD0E0608292F11862F0084202
ROD: EV_Brake1UDSContiMK100IPB_034.rod
VCID: 7AFF1EAFFDB4EF946A-802E
Part No SW: 3Q0 959 435 B HW: 3Q0 959 435 B
Component: VWKESSYMQB 026 0710
Revision: 00026000 Serial number: 0382651624
Coding: 000F0F0F03
VCID: 397DC1A3B832248C23-806C
Part No SW: 5G0 907 044 BG HW: 5G0 907 044 BG
Component: Climatronic H04 1202
Revision: 00001K10
Coding: 12020124202100011115500000101902
ASAM Dataset: EV_ACClimaBHBVW37X 005137
VCID: 6DD525F3BCFA482CFF-8038
Air quality sensor:
Part No SW: 5Q0 937 086 AK HW: 5Q0 937 086 AK
Revision: -------- Serial number: 86580810151068
Coding: 00951E46C24102FF4FC44084F11C07281880000000000000000000000000
Shop #: WSC 19460 666 12345
ROD: EV_BCMBOSCH_015.rod
VCID: 0301634B8A7EAE5C39-8056
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150813 042 0607
Serial number: 151004085956
Component: RLHS 037 0059
Serial number: S2Y15M10D17H10M37S57
Coding: 90A8DD
Subsystem 3 - Part No SW: 3G0 941 633 H HW: 3G0 941 633 H
Component: E1 - LDS MQB H01 0032
Serial number: 30 08 2015 10000329
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 006 0326
Serial number: 000000000ZY151772LB4
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000068354238
Part No SW: 5Q0 919 294 L HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0056
Revision: -------- Serial number: 39391528601234
Coding: 0071151811
ROD: EV_EPHVA18AU3700000_002_VW27.rod
VCID: 4483A057CFF0696440-8010
Part No SW: 3Q0 907 572 B HW: 3Q0 907 572 B
Component: ACC BOSCH MQB H04 0192
Coding: 3200678259FFC428949C804D
ASAM Dataset: EV_ACCBOSCHVW48X 001008
ROD: EV_ACCBOSCHVW48X.rod
VCID: 3463F0979F50D9E4F0-8060
Part No SW: 3Q0 959 655 BB HW: 3Q0 959 655 BB
Component: Airbag VW20 013 0195
Revision: -------- Serial number: 003STPLZQ6CD
Coding: 98CCC000000000005C5400CC000800000065
Shop #: WSC 00028 028 00007
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7F09EFBBE696CABC5D-802A
Subsystem 1 - Part No SW: ----------- HW: 454 000 510 15
Serial number: 3576U000000E6121B617
Subsystem 2 - Part No SW: ----------- HW: 454 000 810 15
Serial number: 3586U000000EE4D8A61-
Subsystem 3 - Part No SW: ----------- HW: 454 802 109 15
Serial number: 3516RA83D81080000007
Subsystem 4 - Part No SW: ----------- HW: 454 802 109 15
Serial number: 3526RB42D81080000004
Subsystem 5 - Part No SW: ----------- HW: 454 802 109 15
Serial number: 3556V16E87B08000000J
Part No SW: 3Q0 953 521 P HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20151014500252
Coding: 0C10
ROD: EV_SMLSVALEOMQB.rod
VCID: 3D75D5B3AC1A18AC0F-8068
Part No SW: 3G0 920 791 A HW: 3G0 920 791 A
Component: KOMBI 410 1340
Coding: 07A509986E84000801887B071000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009048
ROD: EV_DashBoardVDDMQBAB_VW48.rod
VCID: 275917DB5E86A27C45-8072
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 M
Component: GW MQB High 212 2227
Revision: -------- Serial number: 17101510803198
Coding: 030300045F087300FB00025A1C0F00010001070000000000000000000000
Shop #: WSC 00028 028 00213
ROD: EV_GatewConti_013_VW37.rod
VCID: 75E50D93D4AA80EC07-8020
Serial number: 29150002033150115416
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 5256628103
Analog clock:
Subsystem 4 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 209 2002
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Component: ELV-MQBB H05 0031
Serial number: 15000089008008
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71ED3983A0C2ACCCDB-8024
Component: TSG FS 010 0031
Serial number: 0000170383267
Coding: 003F0B20D000020000001000
VCID: 4799B75BFEC6427CA5-8012
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 K HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2033
Revision: 00000000 Serial number: 0000440984
Coding: 01000011005001
ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
ROD: EV_SteerAssisVWBSMQBA_008_VW48.rod
VCID: 3B71DBABB20E169C31-806E
Component: TSG BFS 010 0031
Serial number: 0000170406570
Coding: 003F0120DE00020000001000
VCID: 4687BA5FF9CC5B745E-8012
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0110
Coding: 039A00000F210200
VCID: 3F89AFBBA6160ABC1D-806A
Subsystem 1 - Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H09 0003
Coding: E02400
Subsystem 2 - Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H09 0003
Coding: E02400
Subsystem 3 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _ Labels: 3D0-941-329.CLB
Component: LeiMo links H02 0003
Coding: E02400
Subsystem 4 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _ Labels: 3D0-941-329.CLB
Component: LeiMo rechts H02 0003
Coding: E02400
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH2.clb
Part No SW: 3G0 035 043 B HW: 3G0 035 043
Component: MU-H-N-EU H42 0343
Serial number: A599J0FB022330
Coding: 02840201FF00000051110001000808001F0100E401200000DF
VCID: 1B313B2B12CE769CD1-804E
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H62 0031
Serial number: VWZ8Z9RU303KSL
Subsystem 2 - Part No SW: V03 959 800 QM HW: -----------
Component: ECE 2015/2016 --- 0123
Component: Gracenote2 --- 1011
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 5Q0 907 273 B HW: 5Q0 907 273
Component: RDKBERU30 H04 0009
Serial number: 40000000009799
ROD: EV_RDKBERU30_006_VW48.rod
Part No SW: 5Q0 980 556 HW: 5Q0 980 556
Component: RVC Compact H07 0100
Coding: 0184020162002017000040
ROD: EV_CamSysRVRVCPANAMQBAB_005_VW37.rod
VCID: 77F9079BCEA6F2FC15-8022
Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
Component: MQB_B_MFK H07 0272
Serial number: 05011711P10491
Coding: 0004080200000401002223448050A10098000E300040
ROD: EV_MFKBoschMQBB_VW27.rod
VCID: 3C73D8B7B70011A438-8068
0660 - No Basic Setting
B2010 00 [009] - -
Reset counter: 52
Mileage: 123342 km
Date: 2018.07.09
Time: 13:05:04
Control Module temperature: 57 °C
Outside air temperature: 26.0 °C
Vehicle speed: 0.00 km/h
System run time: 181.0 s
Voltage terminal 15: 12.3 V
mid: 00 1E
Status of camera: System malfunction
Engine_Running_Info: 0
Software_Info_4: 2
Software_Info_3: 7
Software_Info_2: 2
Software_Info_1: 0
1122675 - Databus
Reset counter: 52
Mileage: 123342 km
Date: 2018.07.09
Time: 13:05:04
System run time: 181.5 s
Voltage terminal 15: 12.2 V
mid: 01 E0
Software_Info_4: 2
Software_Info_3: 7
Software_Info_2: 2
Software_Info_1: 0
1122597 - Databus
Reset counter: 52
Mileage: 123342 km
Date: 2018.07.09
Time: 13:05:04
mid: 01 43
Software_Info_4: 2
Software_Info_3: 7
Software_Info_2: 2
Software_Info_1: 0
0311 - Data Set Implausible
B2012 00 [009] - -
Reset counter: 52
Mileage: 123342 km
Date: 2018.07.09
Time: 13:05:04
mid: 00 51
Software_Info_4: 2
Software_Info_3: 7
Software_Info_2: 2
Software_Info_1: 0
Part No SW: 5Q4 959 595 E HW: 5Q4 959 595 B
Component: TSG HFS 011 0031
Serial number: 0000167108139
Coding: 000E01200100020000001000
ASAM Dataset: EV_DCURearDriveMAXCONT 006001
VCID: 499DB163E8D2B40CB3-801C
Component: TSG HBFS 011 0031
Serial number: 0000167108138
ASAM Dataset: EV_DCURearPasseMAXCONT 006001
Address CA: Sunroof
Interface not compatible.
End-------------------------(Elapsed Time: 06:47)--------------------------
