Hello all. I've recently run into a strange issue and was hoping someone here could help. A couple years ago, I installed a euro switch in my 2009 GTI. With this, I disabled the DRL's (which disabled the light in my instrument cluster) and everything has worked fine. Recently, I was tinkering around with my CECM coding and somehow managed to make it so that my DRL light remains on in my instrument cluster (even with the parking brake up, turns off when my headlights/parking lights are on). Now, my DRL's are most certainly disabled in my coding, and enabling them does nothing to make my DRL's work. The xenons never turn on, even though the DRL light on the cluster works normally (off with parking brake up, on when parking brake released). I have tried enabling the DRL's and setting the fogs as DRL, and the fogs work.
I'm really lost at this point, and I'm starting to wonder if I have damaged my CECM. Any suggestions would be very helpful.
Wednesday,20,June,2018,20:35:34:27072
VCDS Version: 18.2.0.3 (x64)
VIN: WVWEV71K59W068949 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 65
VIN: WVWEV71K59W068949 Mileage: 131780km-81884miles
Address 01: Engine (CCT) Labels:. 06J-906-026-CCT.clb
Part No SW: 1K0 907 115 AE HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0030
Revision: AAH03--- Serial number: VWX7Z0H63NH8NH
Coding: 0403010A18070160
Shop #: WSC 01279 785 00200
VCID: 69F748874010220CAF-803C
Readiness: 0110 0101
Part No SW: 1K0 907 379 AN HW: 1K0 907 379 AN
Component: ESP MK60EC1 H45 0109
Revision: 00H45001
Coding: 113B600D49280002881406E8922200413000
Shop #: WSC 42406 001 1048576
VCID: 7EDD0BDBE99EB5B46A-802A
Fault Status: 00101101
Reset counter: 187
Mileage: 131667 km
Count: 16386
Count: 2
Count: 13056
Count: 8196
Count: 43520
Count: 2560
Part No SW: 1K0 820 047 JM HW: 1K0 820 047 JM
Component: Climatic PQ35 142 1212
Revision: 00142032 Serial number: 00000000000000
VCID: 78D11DC30BBA8B8420-802C
Revision: 00H54000 Serial number: 00000008670655
Coding: E72D8A07000000004714000000140000000900096400010C000000000000
Shop #: WSC 12345 785 00200
VCID: 334BEAEF525CA8DCD5-8066
Component: Wischer 070708 021 0501
Coding: 00038837
Shop #: WSC 12345
Component: RLS 130315 054 0403
Coding: 00404397
Shop #: WSC 12345
Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
Component: SDAR SIRIUS H07 0150
Revision: 00000000 Serial number: AUZ4Z7H0353303
Coding: 0000000
Reset counter: 21
Mileage: 128742 km
Time: 12:13:22
01304 - Radio
Reset counter: 193
Mileage: 131785 km
Time: 20:24:49
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6K AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D0BLJTR
Coding: 0013899
VCID: 6CF931934FE23724D4-8038
Subsystem 1 - Part No: 1K0 959 339 G
Component: BF-Gewichtsens. 007 0007
Subsystem 2 - Serial number: 6332MSME3D512F36J
Subsystem 3 - Serial number: 6342MSME387366016
Subsystem 4 - Serial number: 6352QSME7F0C2649W
Subsystem 5 - Serial number: 6362QSME7B17156DT
Subsystem 6 - Serial number: 63727SME17455726/
Subsystem 7 - Serial number: 63827SME173B0C31%
Part No SW: 1K0 953 549 BP HW: 1K0 953 549 BP
Component: J0527 051 0101
Coding: 0002022
VCID: 012770275860CA4C17-8054
Component: E0221 002 0010
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
Part No SW: 1K6 920 974 H HW: 1K6 920 974 H
Component: KOMBIINSTRUMENT VDD 2416
Revision: V0003000 Serial number: VWX7Z0H63NH8NH
Coding: 0007103
Shop #: WSC 20156 444 53720
VCID: 3957D8C77030528C1F-806C
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 130708F1000845
Coding: E9811F070013020000
VCID: 354FD4F75C28B6ECFB-8060
01304 - Radio
Reset counter: 193
Mileage: 122495 km
Time: 16:55:27
Part No SW: 1K6 919 879 HW: 1K6 919 879
Component: Kompass 001 0003
Revision: 00001000 Serial number: 1225223T3JED03
VCID: 7DDF0CD72498AEAC73-8028
Component: IMMO VDD 2416
Shop #: WSC 07341 444 11203
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 1207
Coding: 0001077
VCID: 3851DDC34B3A4B84E0-806C
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.074 H08 1901
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0221
Revision: 00052000 Serial number: 00000000000000
Coding: 1A9006885103483F7C02058FB0080A04489C00
Shop #: WSC 07341 444 11204
VCID: 042979334772DF643C-8050
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0001076
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74C929F317D2EFE40C-8020
Address 56: Radio
Component: RDK 0450
Coding: 0100101
End-------------------------(Elapsed Time: 01:11)--------------------------
