DPF Regeneration failure on 2012 VW Touareg TDI
   #41
Also need to go in Adaptation and find something like " Reset after Replace DPF". To reset ASH level.
I suppose that would be:
IDE00275 -- Particle filter initialization
amizan
C?ID=340128
this requires me to enter "security access" first but I don't have a code. the only code that pops up on the balloon is the one for DPF emergency regeneration... not initialization...
can you help?
   #43
Have you tried it? It may be applicable to both.
amizan
C?ID=340128
yes I just tried it and it failed.
I did a new autoscan and I got the following - no errors related to DPF any more (although i do have issues with the MAF still - I will try cleaning it)
does this mean I am in the clear when it comes to the DPF at least ?
Wednesday,15,August,2018,21:47:58:45649
VCDS Version: 18.2.1.2 (x64)  HEX-V2 CB: 0.4411.4
VIN: WVGEK9BP1CD005604   License Plate:
Mileage: 315679km-196153mi   Repair Order:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 46 52 53 55 56 5F 62 65
          69 6C 6D 72
VIN: WVGEK9BP1CD005604   Mileage: 315679km-196153miles
Address 01: Engine (J623-CATA)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P0 907 401 J    HW: 7P0 907 401 E
   Component: 3.0TDI EDC17  H17 0005
   Revision: 56H17---
   Coding: 292A4012233600050000
   Shop #: WSC 02330 444 92460
   ASAM Dataset: EV_ECM30TDI0117P0907401J 001005
   ROD: EV_ECM30TDI0117P0907401J_001.rod
   VCID: 3635DA6018CC58A79BB-8062
4795 - Mass Air Flow Sensor (G70)
          P0101 00 [039] - Implausible Signal
                    Mileage: 315678 km
                    Date: 2018.08.14
                    Time: 23:39:36
                    Engine speed: 1272.00 /min
                    Vehicle speed: 43 km/h
                    Coolant temperature: 87 °C
                    Intake air temperature: 30 °C
                    Voltage terminal 30: 14.400 V
                    Mean injection quantity: 0.00 mg/stroke
                    Control Module temperature: 42.5 °C
                    EGR_governor_deviation: -262.9 mg/stroke
                    Inj Ctl q Curr: 0.00 mg/stroke
                    Mass_air_flow_sensor_drift: 0.7456
                    Air_Flow_Rate_from_Mass_Air_Flow_Sensor_kg_h: 168.3 kg/h
                    Actual charge pressure: 1120 hPa
5171 - Boost Pressure Regulation
          P0299 00 [167] - Control Range Not Reached
                    Mileage: 315678 km
                    Date: 2018.08.14
                    Time: 23:40:33
                    Engine speed: 2903.50 /min
                    Normed load value: 99.6 %
                    Vehicle speed: 64 km/h
                    Coolant temperature: 86 °C
                    Intake air temperature: 32 °C
                    Voltage terminal 30: 14.420 V
                    Charge Pressure Actuator: activation: 75.22 %
                    Charge Pressure Actuator: acknowledgment: 75.32 %
                    Ambient temperature: 24.6 °C
                    Charge air pressure specified value: 2599 hPa
                    Accelerator pedal travel: 100.00 %
                    Air mass: actual value (mg/stroke): 832.3 mg/stroke
                    Actual charge pressure: 1767 hPa
12896 - Boost Pressure Regulation
          P0299 00 [039] - Control Range Not Reached
                    Mileage: 315678 km
                    Date: 2018.08.14
                    Time: 23:40:33
                    Charge Pressure Actuator: activation: 75.16 %
5258 - Exhaust Gas Temperature Sensor 4 Bank 1
          P246E 00 [039] - Electrical Malfunction
                    Mileage: 315675 km
                    Date: 2018.08.14
                    Time: 23:26:36
                    Engine speed: 779.50 /min
                    Normed load value: 27.5 %
                    Coolant temperature: 54 °C
                    Intake air temperature: 33 °C
                    Voltage terminal 30: 14.300 V
                    Exh.gas temp.sen 1: 179.5 °C
                    Exh.gas temp.sen 2: 145.2 °C
                    Exh.gas temp.sen 3: 140.2 °C
                    Exh.gas temp.sen 4: 1000.0 °C
                    Shut-off timer: last engine shut-off time: 9999 s
   Part No SW: 0C8 927 750 G    HW: 0C8 927 750 G
   Component: AL1000 AISIN  001 1857
   Coding: 001368
   Shop #: WSC 42005 002 1048576
   ASAM Dataset: EV_TCMAL991031 001001
   ROD: EV_TCMAL991031_001_VW52.rod
   VCID: 3039EC78FAA87697C17-8064
Address 03: ABS Brakes (J104)       Labels:| 7P0-907-379.clb
   Part No SW: 7P0 907 379 J    HW: 7P0 907 379 A
   Component: MK25A         H36 0433
   Revision: --------    Serial number: 427310010EC010
   Coding: 5B7613C349242558DAFAC89392D6A4407300
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_MK25AXT 008001
   ROD: EV_ESPMK25A00800.rod
   VCID: 44D1B0A85E10FA3715F-8010
171010 - Supply voltage
          [Insuff. voltage]
                    Reset counter: 90
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 17:12:50
                    Standard Freeze  Frame Dynamic: 00 2C FF FD 20 00 00 07 00 00 01 00 80
   Part No SW: 4H0 907 064 BK    HW: 4H0 907 064 BK
   Coding: 09860000000000000000
   VCID: 73B323744BBE0D8F7C5-8026
   Subsystem 1 - Part No SW: 7P6 959 754 M    HW: 7P6 959 754 M
   Component: FBSTOUAREGIDG  H04 0051
   Serial number: 0511000056915016
   Serial number: 2311000221683004
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
                    Fault Frequency: 7
                    Reset counter: 89
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 16:41:18
                    Reset counter: 89
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 16:42:38
                    Fault Status: 00101101
                    Reset counter: 89
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 16:44:09
   Part No SW: 7P6 907 040 BK    HW: 7P6 907 040 BK
   Component: Klima 2 Zonen H20 1305
   Coding: B606200A80
   VCID: 7EA50240707C50E703B-802A
0235 - Supply voltage
                    Reset counter: 89
15360256 - Component Protection
          U1101 00 [008] - Active
                    Reset counter: 89
                    Mileage: 315630 km
                    Date: 2017.11.14
                    Time: 13:33:32
0243 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 85
                    Mileage: 315669 km
                    Date: 2018.06.28
                    Time: 21:46:33
0289 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 89
   Part No SW: 4H0 907 063 BD    HW: 4H0 907 063 D
   Component: BCM1 2.0      H12 0100
   Revision: 15012002    Serial number: 00000001111655
   Coding: 26001012973C5D010020180300005D0C431C660882010261000000020000
   VCID: 6B833B14138ED54FB45-803E
   Component: WWS    111021  31  0020
   Serial number: 90243400111028231403
   Coding: 004DBD
   Component: RLFS  H09 0011
   Serial number: 10264691
   Coding: 025223
   Component: E1 - LDS  H04 0031
   Serial number: 00000000001110110267
   Subsystem 4 - Part No SW: 4H0 907 410 A    HW: 4H0 907 410 A
   Component: USHL4.2  H30 0020
   Serial number: 0000001805569R0S3807
                    Reset counter: 43
                    Mileage: 315650 km
                    Date: 2018.05.28
                    Time: 21:36:00
                    Reset counter: 43
                    Mileage: 315650 km
                    Date: 2018.05.28
                    Time: 21:36:00
   Part No SW: 7P0 959 655 C    HW: 7P0 959 655 C
   Component: VW10Airbag025 H05 0025
   Revision: --------    Serial number: 003L0000JX0X
   Coding: 000000000000000000000000000000003235
   VCID: 41DFB9BC4102EF1F3E9-8014
   Subsystem 1 - Part No SW: 7P6 959 339     HW: 7P6 959 339
   Component: BF-Gewichtss.  003 0005
   Serial number: 5850000R1172706H59
   Serial number: 3575LRB40690T3R6A0UV
   Serial number: 3585LRB40690T3R69HP0
   Serial number: 3515RRB40550OPMK49H%
   Serial number: 3525RRB405B0OPMKH9NP
   Serial number: 3555NRB40590PIJQEGOO
   Serial number: 3565NRB40550PIJQKHEI
   Part No SW: 4H0 953 568 F    HW: 7P6 953 507 L
   Revision: --------    Serial number: 90815KJP0005S
   Coding: 000015
   VCID: 3635DA60184C58A79BB-8062
   Serial number: 0124203
                    Reset counter: 89
00532 - Supply Voltage B+
                    Reset counter: 89
   Part No SW: 7P6 920 980 N    HW: 7P6 920 980 N
   Component: Kombi         H13 0239
   Revision: 11240062    Serial number: 658221011593041
   Coding: 8B7733022B00CF05020004
   ASAM Dataset: EV_KombiUDSRBVW526 001013
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 47CBA7A46F26D12FF0D-8012
13635840 - Supply voltage
          [Supply voltage too low]
                    Reset counter: 89
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 16:42:37
   Part No SW: 7P6 907 530 C    HW: 7P6 907 530 A
   Component: GW-CAN-L-MOST H08 5202
   Revision: --------    Serial number: 00000000291319
   Coding: 0001037500
   ASAM Dataset: EV_GatewVW526UDS 001006
   ROD: EV_GatewUDS_VW52.rod
   VCID: 3829D45812D8AED7897-806C
   Serial number: 00000000005650843827
0267 - Optical data bus
          U1049 00 [008] - Open circuit
                    Reset counter: 89
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 16:56:50
                    Voltage terminal 30: 9.2 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 38 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
0017 - Supply voltage
          [Versorgungsspannung unterer Grenzwert unterschritten]
                    Reset counter: 89
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 16:42:37
                    Voltage terminal 30: 8.0 V
                    Voltage terminal 15: 8.0 V
                    Control Module temperature: 33 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
12290 - Quiescent Current
          U1406 00 [008] - Too High
                    Reset counter: 87
                    Mileage: 315672 km
                    Date: 2018.07.09
                    Time: 17:12:54
                    Voltage terminal 30: 12.1 V
                    Control Module temperature: 31 °C
                    System status: LIN_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
          U140B 00 [008] - -
          [Powermanagement active]
                    Fault Frequency: 28
                    Reset counter: 89
                    Mileage: 315672 km
                    Date: 2018.07.26
                    Time: 14:00:46
                    Voltage terminal 30: 11.4 V
                    Control Module temperature: 27 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 3
   Revision: AA000000    Serial number: 00000016937431
   Coding: 0058130000004001000001010101202020202121202020
   VCID: 3431E0680E304AB7A5F-8060
03776 - Motor for Lumbar Support Adjustment
                    Fault Status: 01100101
                    Reset counter: 195
                    Mileage: 288200 km
                    Date: 2017.05.10
                    Time: 16:03:52
            000 -  -  - Intermittent
                    Reset counter: 89
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 16:43:18
                    Fault Frequency: 7
                    Reset counter: 89
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 16:45:36
   Part No SW: 4H0 959 793 N    HW: 4H0 959 793 F
   Component: TSG FA        H07 0166
   Revision: --------    Serial number: 0000121063960
   Coding: 011D07205E00453005080000
   VCID: 44D1B0A85E90FA3715F-8010
   Revision: 00002001    Serial number: 0161545821
   Coding: 0186123A28B9509480A00620210000000000000000000000000000000000
   Subsystem 1 - Part No SW: 7P6 959 719     HW: 7P6 959 719
   Component: GTO BT  H19 0059
   Serial number: 284119591
   Subsystem 3 - Part No SW: 7P0 959 591 B    HW: 7P0 959 591 B
   Component: J245 PS30.055  H01 0008
   Serial number:     WOO13391685
   Coding: 191100
   Subsystem 4 - Part No SW: 7P0 959 591 C    HW: 7P0 959 591 C
   Component: J394 PS30.055  H01 0008
   Serial number:     WOO1336156%
   Coding: 191100
                    Reset counter: 89
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 16:44:09
   Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
   Component: TSG BF        H07 0166
   Revision: --------    Serial number: 0000121426575
   VCID: 3B23CB54236E85CF645-806E
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: A11A070021C
   Coding: 01040200
   ROD: EV_ParkbA7.rod
   Slave 3:
12656640 - Data Bus for Suspension
          U10A9 00 [008] - Defective
          [Keine Verbindung zu CAN]
                    Reset counter: 89
                    Voltage: 7.6 V
12652544 - Supply voltage
          [Insuff. voltage]
                    Reset counter: 89
                    Voltage: 8.8 V
   Part No SW: 7P6 907 357     HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0110
   Coding: 010A00010F000400
   VCID: 7CA10848666042F72DF-8028
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Coding: 130000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0006
   Coding: 130000
5275953 - Power Output Module for Left Headlamp
          C1081 31 [008] - No Signal
                    Fault Frequency: 82
                    Reset counter: 83
                    Mileage: 315630 km
                    Date: 2017.11.12
                    Time: 05:45:07
   Part No SW: 4G0 035 082 B    HW: 4G0 035 082
   Component: Radio U SIRIU H53 0076
   Revision: AB001007    Serial number: 156J20B7565751
   Coding: 020007020100000001
   VCID: 1F1B1FC497B6F9EF68D-804A
                    Reset counter: 89
                    Voltage: 9.60 V
                    Fault Status: 00101011
                    Reset counter: 79
                    Voltage: 11.90 V
                    Reset counter: 79
                    Mileage: 315630 km
                    Date: 2017.11.14
                    Time: 13:38:40
                    Voltage: 12.00 V
   Part No SW: 7P6 035 664 B    HW: 7P6 035 664
   Component: H-BN-NA       H44 0319
   Revision: --------    Serial number: 445J 0B7521662
   Coding: 010200050040E1EE41022B0C00000003F0000101
   VCID: 372BD7641F46A1AF80D-8062
   Subsystem 1 - Part No: 8R0 060 884 AC
   Component: NAR 2011  0503
   Subsystem 2 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: DU8 SV Touch  H26 0045
   Serial number: VWZ8Z9L79004S3
   Subsystem 3 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: CD-Database  1886
03367 - Supply Voltage for Display Module
                    Reset counter: 89
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 16:58:20
                    Voltage: 5.80 V
   Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
   Component: TSG HL        H09 0167
   Revision: --------    Serial number: 0000121490349
   Coding: 011C07200000253005080000
   VCID: 3A2DCE502C54BCC77F3-806E
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
   Component: RDKBERU25     H09 0008
   Serial number: 10000000050575
   ROD: EV_RDKBERU25_VW52.rod
   VCID: 3FDBBF4437F699EF48D-806A
8393473 - TPMS Transceiver in Rear Left Wheel Well
          C104E 01 [008] - Electrical Failure
Address 69: Trailer (J345)       Labels: Redir Fail!
   Part No SW: 7P0 907 383 F    HW: 7P0 907 383 B
   Component: Anhaenger     H09 0110
   Revision: 5A001001    Serial number: 00000160938100
   Coding: 020D000000000000
                    Reset counter: 89
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 16:43:48
   Part No SW: 7P6 907 441 A    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0020
   Revision: 00H04000    Serial number: 525 PA8J192588
   Coding: 0110001
   VCID: 372BD7641346A1AF80D-8062
                    Reset counter: 89
                        Term 15 Off
                        Reverse OFF
                    Count: 3
   Part No SW: 7P6 959 107 A    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0620
   Revision: 22010001    Serial number: 294100187
   Coding: 0533314003
   ASAM Dataset: EV_HeckkTouar 202137
   ROD: EV_HeckkTouar.rod
   VCID: 3D27C54C3DFA8BFF5A1-8068
0014 - Supply voltage
          [Versorgungsspannung dauerhaft zu niedrig]
                    Reset counter: 89
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 16:46:22
                    Voltage terminal 30: 6.16 V
0011 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 89
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 17:01:38
                    Voltage terminal 30: 8.76 V
0077 - Pinch Protection Strip 1
          B11DB 02 [008] - Signal Failure
                    Fault Frequency: 115
                    Reset counter: 40
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 16:42:37
                    Voltage terminal 30: 7.92 V
   Component: TSG HR        H09 0167
   Revision: --------    Serial number: 0000121399453
End----------(Elapsed Time: 02:09, VBatt start/end: 14.2V/14.3V)-----------
Friday,17,August,2018,11:28:11:45649
          69 6C 6D 72
   Revision: 56H17---
          P0101 00 [101] - Implausible Signal
                    Mileage: 315678 km
                    Date: 2018.08.14
                    Time: 23:39:36
          P0299 00 [101] - Control Range Not Reached
                    Mileage: 315678 km
                    Date: 2018.08.14
                    Time: 23:40:33
                    Mileage: 315678 km
                    Date: 2018.08.14
                    Time: 23:40:33
          P246E 00 [175] - Electrical Malfunction
                    Mileage: 315675 km
                    Date: 2018.08.14
                    Time: 23:26:36
Readiness: 1 1 0 0 1
   Coding: 001368
          U1011 00 [072] - Voltage too Low
          [Insuff. voltage]
                    Reset counter: 90
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 17:12:50
                    Fault Frequency: 7
                    Reset counter: 89
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 16:41:18
                    Reset counter: 89
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 16:42:38
                    Reset counter: 89
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 16:44:09
   Coding: B606200A80
                    Reset counter: 89
                    Reset counter: 89
                    Mileage: 315630 km
                    Date: 2017.11.14
                    Time: 13:33:32
          U1113 00 [008] - -
                    Reset counter: 85
                    Mileage: 315669 km
                    Date: 2018.06.28
                    Time: 21:46:33
          U1400 00 [008] - -
                    Reset counter: 89
   Coding: 004DBD
   Coding: 025223
                    Reset counter: 43
                    Mileage: 315650 km
                    Date: 2018.05.28
                    Time: 21:36:00
                    Reset counter: 43
                    Mileage: 315650 km
                    Date: 2018.05.28
                    Time: 21:36:00
   Coding: 000015
                    Reset counter: 89
                    Reset counter: 89
                    Reset counter: 89
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 16:42:37
   Coding: 0001037500
                    Reset counter: 89
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 16:56:50
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
                    Reset counter: 89
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 16:42:37
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 87
                    Mileage: 315672 km
                    Date: 2018.07.09
                    Time: 17:12:54
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
          U140B 00 [008] - -
                    Fault Frequency: 28
                    Reset counter: 89
                    Mileage: 315672 km
                    Date: 2018.07.26
                    Time: 14:00:46
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 3
                    Reset counter: 195
                    Mileage: 288200 km
                    Date: 2017.05.10
                    Time: 16:03:52
                    Reset counter: 89
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 16:43:18
                    Fault Frequency: 7
                    Reset counter: 89
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 16:45:36
   Coding: 191100
   Coding: 191100
                    Reset counter: 89
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 16:44:09
   Coding: 01040200
   ROD: EV_ParkbA7.rod
   Slave 3:
                    Reset counter: 89
                    Voltage: 7.6 V
          [Insuff. voltage]
                    Reset counter: 89
                    Voltage: 8.8 V
   Coding: 130000
   Coding: 130000
                    Fault Frequency: 82
                    Reset counter: 83
                    Mileage: 315630 km
                    Date: 2017.11.12
                    Time: 05:45:07
                    Reset counter: 89
                    Voltage: 9.60 V
                    Reset counter: 79
                    Voltage: 11.90 V
                    Reset counter: 79
                    Mileage: 315630 km
                    Date: 2017.11.14
                    Time: 13:38:40
                    Voltage: 12.00 V
                    Reset counter: 89
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 16:58:20
                    Voltage: 5.80 V
                    Reset counter: 89
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 16:43:48
   Coding: 0110001
                    Reset counter: 89
                        Term 15 Off
                        Reverse OFF
                    Count: 3
   Coding: 0533314003
                    Reset counter: 89
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 16:46:22
          U1400 00 [008] - -
                    Reset counter: 89
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 17:01:38
                    Reset counter: 40
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 16:42:37
End----------(Elapsed Time: 02:13, VBatt start/end: 13.6V/14.2V)-----------
I would definitely fix the other problems reported in 01-Engine. With those faults present, your ECU may decide not to do any active DPF regeneration, which may cause your replacement DPF to plug up again in relatively short order.
amizan
C?ID=340128
I fixed the MAF sensor (just needed cleaning) and now the boost pressure regulation issue went away. so now the only remaining issue is:
Mileage: 315675 km
Date: 2018.08.14
Time: 23:26:36
It says that it's an electrical malfunction but i'm not convinced... I did have the battery drained since the car was sitting but now it's charged up. I did get a lot of electical issues on the autoscan though since that happened that weren't there before. Any ideas where that Exhaust Temp sensor 4 is located, how to test it and see if it works or how to replace it? is it the sensor that was attached to the DPF? I am wondering that it might be bad because of that but not sure.... Help anyone?
   #47
The fact that EGT sensor 4 is reading 1000.0 °C when the other three are reading 1xx °C is definitely indicative of a problem with that sensor or its wiring.
Or bad ECU maybe water ingress!
I would swap or jump out over EGT from other EGT or vario resistor tool & to see change in VCDS blocks.
   #49
amizan
C?ID=340128
thanks Jack & Uwe! I will check on the sensor (hopefully it is all sooted up and I don't have an ECU issue). Any pointers on where the sensor is? I am looking at VW diagrams and can't tell which one is sensor 4
   #50
Unplug each one at a time and ref location and DTC number to identify the wildcard number assigned and WD using VCDS or dead block value when observed.
Induce a DTC and back trace each sensor using VCDS as it is intended to aid in OBD data.........
:rolleyes:
or
Read SSP!
   #51
amizan
C?ID=340128
update for everyone:
the sensor 4 bank 1 is for the exhaust temp is the one that is going into the DPF. the cable is going all the way behind the firewall and I could not figure out where it plugs in or how to remove it from the pigtail (could not even see where the pigtail connector plugs in), so I cut it at the sensor, then used electrical tape to use the new sensor. VW had one for $150 and autozone one OEM standard for $90 and I bought the one from autozone due to shorter lead time.
i have not taken it on the road yet but It looks like I am all set no with no error codes or DTCs for the Engine module, so I am a happy camper !! thanks everyone.
Below is the latest autoscan so on a side note, all these error codes that were triggered when the battery ran out of juice and I had to jump start, does anyone know how to get rid of them? they are mostly low voltage supply.....
Thursday,30,August,2018,19:37:13:45649
Mileage: 315681km-196155mi   Repair Order:
          69 6C 6D 72
VIN: WVGEK9BP1CD005604   Mileage: 315681km-196155miles
   Revision: 56H17---
   Coding: 001368
          [Insuff. voltage]
                    Reset counter: 90
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 17:12:50
                    Fault Frequency: 7
                    Reset counter: 89
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 16:41:18
                    Reset counter: 89
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 16:42:38
                    Reset counter: 89
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 16:44:09
   Coding: B606200A80
                    Reset counter: 89
                    Reset counter: 89
                    Mileage: 315630 km
                    Date: 2017.11.14
                    Time: 13:33:32
          U1113 00 [008] - -
                    Reset counter: 85
                    Mileage: 315669 km
                    Date: 2018.06.28
                    Time: 21:46:33
          U1400 00 [008] - -
                    Reset counter: 89
   Coding: 004DBD
   Coding: 025223
                    Reset counter: 43
                    Mileage: 315650 km
                    Date: 2018.05.28
                    Time: 21:36:00
                    Reset counter: 43
                    Mileage: 315650 km
                    Date: 2018.05.28
                    Time: 21:36:00
   Coding: 000015
                    Reset counter: 89
                    Reset counter: 89
                    Reset counter: 89
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 16:42:37
   Coding: 0001037500
                    Reset counter: 89
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 16:56:50
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
                    Reset counter: 89
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 16:42:37
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 87
                    Mileage: 315672 km
                    Date: 2018.07.09
                    Time: 17:12:54
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
          U140B 00 [008] - -
                    Fault Frequency: 29
                    Reset counter: 91
                    Mileage: 315672 km
                    Date: 2018.07.26
                    Time: 14:00:46
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 3
                    Reset counter: 195
                    Mileage: 288200 km
                    Date: 2017.05.10
                    Time: 16:03:52
                    Reset counter: 89
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 16:43:18
                    Fault Frequency: 7
                    Reset counter: 89
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 16:45:36
   Coding: 191100
   Coding: 191100
                    Reset counter: 89
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 16:44:09
   Coding: 01040200
   ROD: EV_ParkbA7.rod
   Slave 3:
                    Reset counter: 89
                    Voltage: 7.6 V
          [Insuff. voltage]
                    Reset counter: 89
                    Voltage: 8.8 V
   Coding: 130000
   Coding: 130000
                    Fault Frequency: 82
                    Reset counter: 83
                    Mileage: 315630 km
                    Date: 2017.11.12
                    Time: 05:45:07
                    Reset counter: 89
                    Voltage: 9.60 V
                    Reset counter: 79
                    Voltage: 11.90 V
                    Reset counter: 79
                    Mileage: 315630 km
                    Date: 2017.11.14
                    Time: 13:38:40
                    Voltage: 12.00 V
                    Reset counter: 89
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 16:58:20
                    Voltage: 5.80 V
                    Reset counter: 89
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 16:43:48
   Coding: 0110001
                    Reset counter: 89
                        Term 15 Off
                        Reverse OFF
                    Count: 3
   Coding: 0533314003
                    Reset counter: 89
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 16:46:22
          U1400 00 [008] - -
                    Reset counter: 89
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 17:01:38
                    Reset counter: 40
                    Mileage: 315673 km
                    Date: 2018.08.13
                    Time: 16:42:37
End----------(Elapsed Time: 02:19, VBatt start/end: 13.2V/14.0V)-----------
AHHHHHHHHHHHHHHHHH
latest
Well at least it isn't this right?
   #53
amizan
C?ID=340128
update again: took it for a drive and as soon as I got to 40 mph, I got into limp mode again. no DTCs but
I have the following:
   Revision: 56H17---
                    Mileage: 315682 km
                    Date: 2018.08.29
                    Time: 23:58:00
                    Engine speed: 2285.00 /min
                    Normed load value: 85.1 %
                    Vehicle speed: 50 km/h
                    Coolant temperature: 63 °C
                    Voltage terminal 30: 13.840 V
                    Charge Pressure Actuator: activation: 93.32 %
                    Charge Pressure Actuator: acknowledgment: 93.26 %
                    Ambient temperature: 23.0 °C
                    Charge air pressure specified value: 2047 hPa
                    Accelerator pedal travel: 40.00 %
                    Air mass: actual value (mg/stroke): 749.8 mg/stroke
                    Actual charge pressure: 1413 hPa
                    Mileage: 315682 km
                    Date: 2018.08.29
                    Time: 23:58:00
                    Charge Pressure Actuator: activation: 93.20 %
I looked here:
http://wiki.ross-tech.com/wiki/index.php/16683/P0299/000665
and it looks it might be the turbocharger.... how do I check that with VCDS before I start taking things apart again...?
UMMMMM UMMMMMM
In addition to turbo theory......?
Hey you could have a boost leak from a popped clamp or pipe too, "but" since history is for DPF pile UP & EGT, you could have a restricted exhaust not allowing turbo charger to spin up from failed remediation too, right?
Check WG function or for N75 issue & with deviation tests for requested vs actual boost after clearing codes, right?
Beware of the unsafe future?
9k=
You do have VCDS, and VCDS can clear fault codes. ;)
amizan
C?ID=340128
I did a turbocharger test on VCDS IDE000457 and it was successful.
I am not sure how to test the Wastegate or the N75 on VCDS. the forums say that go to Basic Settings, and then Group 11 but I am not given that option in the software I have to go to Group 11...
any guidance?
   #57
That Group 11 stuff is old-school and applies only to pre-UDS ECUs.
If the turbo charger test passed, it's most likely good and another underlined condition exists, right?
You sure your car is not suffering from FOD?
JPPSG and FOD
Component: 3.0TDI EDC17 H17 0005<<<<<<<<<<<<<<<<<<<<<<< UPDATE FIRMWARE REQUIRED 0008 or HIGHER or car also possibly catches FIRE?
   #59
amizan
C?ID=340128
thanks Jack.
are you saying that since the turbocharger passed the VCDS test, it is neither the WG nor the N75 ?
I suppose I have to test all the hoses. I can't see any of them being cracked but then again, I don't have a visual on everything...
I will have to do a pressurized smoke check to see if there are any leaks.
if I have a backed up exhaust, how to I go about finding that out. any tests / ideas?
   #60
Would be most plausible right?
Ever hear of a vacuum gauge or using a photo or electronic thermometer gun?
Some samples........
RTFB!
