- Joined
- May 21, 2018
- Messages
- 13
- Reaction score
- 17
- Location
- New Mexico, USA
- VCDS Serial number
- C?ID=337264
Do the Leuchte channels on the MQB platform support conditional logic, like an if/then statement? I know the "alpha pairs" (AB, CD, EF, GH) are applied in order of precedence, but I haven't found any information about whether functions can be activated based on the status of something else. Here's an example:
I want to change the way the cornering lights work from the stock AFS configuration. I don't like having them turn on at speed without the signal, and I don't like the delay between when the turn signal is activated and when the cornering light turns on (about 2 seconds). I want them to work the way cornering lights worked on old cars: signal on, light on. But only when the headlights are turned on.
I can sort of make this work by using the "Blinken links/rechts aktiv (beide Phasen)" setting with the cornering light outputs, but it activates the lights whether the headlights are on or off, as expected. Similarly, turning on the hazard flashers also causes the cornering lights to turn on, which I don't really want.
Is there a way to group the alpha channels, perhaps with other settings, to enable or restrict the lighting functionality depending on the condition of other parameters?
