Wednesday,08,August,2018,17:38:28:28853
VCDS Version: 18.2.1.2 (x64) HEX-V2 CB: 0.4411.4
VIN: WA1BV74L97D054434 License Plate: Q7
Mileage: 267990km-166521mi Repair Order:
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 28 34 36 37 3C 42 46
47 4F 52 55 56 61 62 65 67 6C 6D 6F 72 76 77
VIN: WA1BV74L97D054434 Mileage: 267990km-166521miles
Address 01: Engine Labels:. 079-907-560-BAR.clb
Part No SW: 4L0 910 560 C HW: 4L0 907 560 A
Component: 4.2l V8/4V 0060
Revision: 71H21--- Serial number:
Coding: 01210009190F0560
Shop #: WSC 03089 444 84152
VCID: 2809040C6EF41017197-807C
P0300 - 001 -
Fault Status: 01100001
Mileage: 267993 km
Date: 2018.08.08
Time: 17:24:41
RPM: 1823 /min
Load: 20.4 %
Speed: 67.0 km/h
Temperature: 96.0°C
Temperature: 43.0°C
Absolute Pres.: 980.0 mbar
Voltage: 14.097 V
000774 - Cylinder 6
P0306 - 001 - Misfire Detected
Mileage: 267993 km
Date: 2018.08.08
Time: 17:24:41
RPM: 1823 /min
Load: 20.4 %
Speed: 67.0 km/h
Temperature: 96.0°C
Temperature: 43.0°C
Voltage: 14.097 V
Address 02: Auto Trans Labels: 09D-927-750.clb
Part No SW: 09D 927 750 FH HW: 09D 927 750 FH
Component: AL 750 6A 0959
Revision: 00H52000 Serial number:
Coding: 0000504
Shop #: WSC 31414 790 00001
VCID: 79AF1148C5DE599F369-802C
Address 03: ABS Brakes Labels:. 4L0-910-517-V1.clb
Part No SW: 4L0 910 517 A HW: 4L0 614 517 A
Component: ESP ALLRAD MK25E1 0130
Revision: 00H21001
Coding: 0021553
Part No SW: 4F0 910 852 B HW: 4F0 905 852 F
Component: FBSAUDIC6 ELV H05 0130
Revision: 00H05000 Serial number: 10603401789549
Coding: 0000143
Shop #: WSC 03213 444 84058
VCID: 25170D3819E60D7F221-8070
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H28 0080
00190 - Driver's Door Handle Touch Sensor (G415)
007 - Short to Ground
Fault Status: 01110111
Reset counter: 22
00192 - Rear Left Door Handle Touch Sensor (G417)
Fault Status: 00110111
Reset counter: 89
Mileage: 256955 km
Date: 2018.06.13
Time: 18:26:30
00193 - Rear Right Door Handle Touch Sensor (G418)
Reset counter: 218
Mileage: 256955 km
Date: 2018.06.13
Time: 18:26:30
00191 - Passenger's Door Handle Touch Sensor (G416)
Reset counter: 218
Mileage: 256955 km
Date: 2018.06.13
Time: 18:26:30
Address 07: Control Head Labels: 4L0-910-7xx-07-H.clb
Part No SW: 4L0 910 731 HW: 4E0 035 729 A
Component: Interfacebox H43 2740
Revision: 00000000 Serial number: 354J 067509089
Coding: 0002003
VCID: 65974D385966CD7FE21-8030
Subsystem 1 - Part No: 4L0 910 609
Component: E0380 BedienteilH01 0060
Subsystem 2 - Serial number: 00000001977162
Subsystem 3 - Serial number: 0131.01.120000000100010766ÿ
Subsystem 4 - Serial number: 010766ÿ
02849 - Control Module for Lane Change Assistance (J769)
Reset counter: 105
Mileage: 267553 km
Date: 2018.08.06
Time: 15:58:26
00658 - Control Head
Fault Frequency: 89
Reset counter: 77
Mileage: 265205 km
Date: 2018.07.20
Time: 11:11:47
02244 - Button in Control Head is Stuck
Reset counter: 77
Mileage: 265210 km
Date: 2018.07.20
Time: 12:45:27
Bin. Bits: 10001000
Bin. Bits: 0000000
Bin. Bits: 100
Part No SW: 4L0 910 043 HW: 4L0 820 043 F
Component: KLIMABETAETIGUNGH05 0060
Revision: 00---010 Serial number: 00000030006418
Coding: 0786472
VCID: 619F59284D4EA15F1E9-8034
00710 - Defroster Flap Positioning Motor (V107)
003 - Mechanical Failure
Fault Status: 01100011
Reset counter: 65
Mileage: 256955 km
Date: 2018.06.13
Time: 18:04:14
Voltage: 11.70 V
Temperature: 33.0°C
(no units): 63.0
(no units): 193.0
Temperature: 43.0°C
Fault Status: 00101010
Reset counter: 97
Mileage: 267179 km
Date: 2018.08.05
Time: 13:24:32
Temperature: 31.0°C
01230 - Left Footwell Vent Temperature Sensor (G261)
Reset counter: 77
Mileage: 265194 km
Date: 2018.07.20
Time: 10:37:57
Temperature: 24.0°C
Voltage: 13.70 V
Part No SW: 4F0 910 279 J HW: 4F0 907 279 A
Component: ILM Fahrer H17 0240
Coding: 0113123
VCID: 3039EC6C562458D7C17-8064
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H12 0080
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00150059
Shop #: WSC 31414
Part No SW: 4L0 910 111 A HW: 4L0 035 111
Component: CD-Changer H41 0100
Revision: 00000000 Serial number: AUZ5ZBF3048527
VCID: 1E6522D43CB0DEA763B-804A
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 D HW: 4E0 035 593
Component: SDAR SIRIUS H04 0670
Revision: 00000000 Serial number: AUZ4Z7F5032162
Reset counter: 218
Mileage: 256955 km
Date: 2018.06.13
Time: 18:04:08
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH39 0210
Revision: 03H39000 Serial number: 0038QD03AMA9
Coding: 0014131
VCID: 2B03FB007F023B0FF45-807E
Subsystem 1 - Part No: 4L0 910 339
Component: BF-Gewichtsens. H02 0020
Subsystem 2 - Serial number: 6332QSME127A22335
Subsystem 3 - Serial number: 6342QSME130B0B1BE
Subsystem 4 - Serial number: 6352QSME126B4275F
Subsystem 5 - Serial number: 6362QSME127B2945J
Subsystem 6 - Serial number: 63734SME1514206BV
Subsystem 7 - Serial number: 63834SME15162D47+
Part No SW: 4F0 910 549 A HW: 4F0 953 549 C
Component: J0527 0410
Revision: 00H03000 Serial number: 90026062490112
Coding: 0012242
VCID: 270B073063EA1F6F10D-8072
Component: E0221 H07 0090
Address 17: Instruments Labels:. 4L0-920-xxx-17.clb
Part No SW: 4L0 920 983 M HW: 4L0 920 983 M
Component: KOMBIINSTR. 0900
Revision: 00200000 Serial number: AYF01HN1A
Coding: 3697283
Shop #: WSC 03213 444 04841
VCID: 3C21C85C8A6CACB76DF-8068
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468 A
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0800D0691580E2
Coding: F5F7FE7F347A02
Shop #: WSC 03089 444 54655
VCID: 6C81381CBA8CFC37BDF-8038
Part No SW: 4L0 910 158 HW: 4L0 919 158 D
Revision: 00---007 Serial number: 00000000075462
Coding: 0000006
VCID: 6889440CAE74D017D97-803C
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 218
Mileage: 256955 km
Date: 2018.06.13
Time: 18:04:20
Address 34: Level Control Labels: None
Part No SW: 4L0 910 553 B HW: 4L0 907 553
Component: LUFTFDR.-CDC H03 7550
Revision: --H03001 Serial number: 15.1528-0095.2
Coding: 0015520
VCID: 290F010875FE291F069-807C
01780 - Sensor for Vehicle Leveling
Fault Status: 00100011
Reset counter: 87
Mileage: 265024 km
Date: 2018.07.19
Time: 16:56:52
Error Code: 31
01577 - Turn-Off due to Over-Temp
Fault Status: 00100001
Fault Frequency: 195
Reset counter: 105
Mileage: 258735 km
Date: 2018.06.22
Time: 06:20:06
Error Code: 68
Part No SW: 4F0 910 760 HW: 4L0 959 760
Component: Sitzmemory FS H01 0100
Revision: 00000000 Serial number: 00000000896401
Coding: 0082954
Part No SW: 4E0 910 888 M HW: 4E0 919 887 D
Component: MNS US H48 1100
Revision: 00000000 Serial number: 313GJ067503840
VCID: 3829D44CBE548097897-806C
02927 - DVD Read Error
Reset counter: 100
Mileage: 267558 km
Date: 2018.08.06
Time: 16:09:39
Hex Value: 0x5B68
Hex Value: 0x72FE
Hex Value: 0x0401
Hex Value: 0x0000
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 A HW: 4L0 907 566 A
Component: J0769_SWA_MasterH06 0060
Revision: 00H06000 Serial number: 6PZ 009 014-00
Coding: 0000001
VCID: 2C01F81C7A0C3C37FDF-8078
Subsystem 1 - Part No: 4L0 910 568 A
Component: J0770_SWA_Slave_H05 0060
Subsystem 2 - Serial number: 6PZ 009 014-20
Subsystem 3 - Serial number: 3F28.09.0600H0500000010009ÿ
Subsystem 4 - Serial number: 010009ÿ
02850 - Control Module 2 for Lane Change Assistance (J770)
014 - Defective
Fault Status: 01101110
Reset counter: 239
Mileage: 259168 km
Date: 2018.06.24
Time: 11:22:52
Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
Component: TSG FA H12 0130
Revision: 00000000 Serial number: a
Coding: 0051915
VCID: 2F3BEF104B1A472FD8D-807A
02126 - Central Locking Button; Exterior Door Handle
Reset counter: 94
Mileage: 259492 km
Date: 2018.06.26
Time: 15:39:52
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 D HW: 4L0 907 289 A
Component: Komfortgeraet H05 0020
Revision: 0020 --- Serial number: 01021089900000
Coding: 7632925
VCID: 313FE9685D2E51DFCE9-8064
02956 - Lamp in Trunk/Hatch Lid; Left
Fault Status: 00101001
Reset counter: 93
Mileage: 266531 km
Date: 2018.08.01
Time: 16:25:28
Bin. Bits: 010 000
Address 47: Sound System Labels: 4L0-910-223-BO.lbl
Part No SW: 4L0 910 223 D HW: 4L0 035 223 A
Component: DSP-High AU716 H02 0110
Revision: PROD_01 Serial number: 00000000009593
Coding: 0000056
Shop #: WSC 21843 002 1048576
02247 - Subwoofer (R148/R157)
Fault Status: 00111011
Reset counter: 100
Mileage: 267569 km
Date: 2018.08.06
Time: 16:47:44
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000043549
Coding: 0012001
VCID: 5EE562D47C309EA723B-800A
Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
Component: TSG BF H12 0130
Revision: 00-00000
Coding: 0051915
Fault Frequency: 68
Reset counter: 88
Mileage: 265418 km
Date: 2018.07.23
Time: 05:55:15
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000022
Component: AFS-Modul links H06 0002
Subsystem 2 - Part No: 7L6 941 329 A
Component: AFS-Modul rechtsH06 0002
Part No SW: 4E0 910 541 M HW: 4E0 035 541 P
Component: TUNER EU/US/RDW H42 0570
Revision: 00000000 Serial number: 388I$067552149
VCID: 2A0DFE0470F822070F3-807E
Part No SW: 4L0 910 181 HW: 4L0 915 181
Component: J0644 BEM H12 0530
Revision: -------- Serial number: 00000000052559
Shop #: WSC 03089 444 85777
VCID: 6491503C525CB477F5F-8030
Component: von VA0 0123456789
Coding: 344630393135313035442056413030313233343536373839
02256 - Quiescent Current
Fault Status: 00110001
Fault Frequency: 167
Reset counter: 102
Mileage: 235664 km
Date: 2018.02.19
Time: 03:18:49
Fault Frequency: 107
Mileage: 237654 km
Date: 2018.02.27
Time: 20:36:59
Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
Component: TSG HL H21 0050
Coding: 0051722
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000900033033
Coding: 0062424
VCID: 221D162408C8FA47473-8076
002 - Lower Limit Exceeded - MIL ON
Fault Status: 11100010
Reset counter: 239
Mileage: 259170 km
Date: 2018.06.24
Time: 11:26:25
(no units): 0.0
Voltage: 11.60 V
(no units): 19.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000609040267
Shop #: WSC 12336 024 394758
VCID: 3431E07CA23C64F7A5F-8060
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 A HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J6942CX
Coding: 1001001
VCID: 2411103C12DCF47735F-8070
Address 6D: Trunk Elect. Labels: None
Part No SW: 4L0 910 945 HW: 4L0 827 851 B
Component: ValeoHeckdeckel H21 0280
Revision: --H21001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
Subsystem 3 - Serial number: RD06.10.06--H21001001C0290ÿ
Subsystem 4 - Serial number: 1C0290ÿ
02242 - Rear Lid Lock Button in Luggage Compartment (E406)
Fault Frequency: 11
Reset counter: 105
Mileage: 260494 km
Date: 2018.06.30
Time: 16:59:22
02786 - Module 2 for Hatch / Trunk Lid (J756)
Reset counter: 89
Mileage: 266004 km
Date: 2018.07.29
Time: 16:24:58
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H05 0060
Revision: AAH05061 Serial number: 001005364-----
Coding: 0003595
VCID: 26150A3464E006672BB-8072
Subsystem 1 - Part No: 4L0 910 591
Component: J_245_EE15_SKB09H10 0180
Subsystem 2 - Part No: 4L0 910 591
Component: J_394_EE15_SKB09H10 0180
Subsystem 3 - Part No: 4L0 910 591
Component: J_392_EE15_SKB09H10 0180
03131 - Switch 2 for Roof Shade
Fault Status: 00101100
Reset counter: 77
Mileage: 265210 km
Date: 2018.07.20
Time: 12:07:41
02961 - Lamp in Bumper; Rear Right
Fault Status: 01101001
Reset counter: 222
Mileage: 235664 km
Date: 2018.02.18
Time: 20:50:21
Bin. Bits: 100 001
02906 - Control Module for Sliding Roof; Rear (J392)
Fault Status: 00100101
Reset counter: 77
Mileage: 265210 km
Date: 2018.07.20
Time: 16:23:03
Address 72: Door, Rear Right Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 794 B
Component: TSG HR H21 0050
Coding: 0051722
Fault Status: 01101000
Reset counter: 65
Mileage: 267926 km
Date: 2018.08.08
Time: 13:27:02
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
Component: Parkhilfe 4-Kan H09 0060
Revision: 00H09000 Serial number: 06230701511300
Coding: 0021246
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H16 1130
Revision: 00000000 Serial number: 00000007572868
Coding: 0010900
End----------(Elapsed Time: 02:29, VBatt start/end: 12.0V/12.1V)-----------
