Car: 2011 Audi A4 B8 Premium Plus S-Line
Manufacture Date 01/11
Mileage 130938kms
Problem: Alternator seems to only charge when VCDS is connected prior to starting. Reads 13.2v at idle when VCDS is plugged in but drops to battery voltage 12.xxV once car is restarted without VCDS plugged in. If I disconnect VCDS it will stay at 13.2 until I turn car off again.
Problem started after i did an oil change and used a snap on scanner to reset service interval. Maybe affected car?? I didnt go into long coding on that POS.
What Ive changed:
Battery X3 , (2 New Varta and one Optima Red top to be sure)
Coding serial # changed every time another was put in.
Alternator x3 , 1 New Audi, My original rebuilt, and a salvage one.
Battery ground cable with management module x2 1new, 1 salvage
DIAG: (Please disregard the audio codes...I have a custom setup which ive disconnected for all intensive purposes)
IM STUMPED.
If anyone can help Id appreciate it.
It almost seems live VCDS is waking up the part of the computer that initiates the charging.
ALSO: Signal wire at alternator 8.4v not charging 10.0v when awake.
Mileage 130938kms
What Ive changed:
Wednesday,20,June,2018,18:12:15:37798
VCDS Version: 18.2.1.2 (x64) HEX-V2 CB: 0.4411.4
VIN: WAUKFCFL7BN0xxxx0 License Plate:
Mileage: 130930km-81356mi Repair Order:
Chassis Type: FL-AU48 (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 36 3C 42 46 47 52 53 55 56
62 72 77
VIN: WAUKFCFL7BN0xxxx0 Mileage: 130930km-81356miles
Address 01: Engine (0-----CAEB) Labels:| 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 AG HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H19 0002
Revision: E1H19---
Coding: 0104010A290F0160
Shop #: WSC 41810 001 1048576
ASAM Dataset: EV_ECM20TFS0118K2907115AG 001002
ROD: EV_ECM20TFS0118K2907115AG.rod
VCID: 74B1201BDE3215C765F-8020
Readiness: 0010 0101
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 8K0 927 158 K HW: 0BK 927 156 N
Component: 0BK 20TFSIUSA H08 0010
Revision: --H08---
Coding: 001112
Shop #: WSC 02145 785 00200
ASAM Dataset: EV_TCMAL551211 001013
ROD: EV_TCMAL551211_001.rod
VCID: 3E25C233A0FE8F9743B-806A
Part No SW: 8K0 907 379 BG HW: 8K0 907 379 BG
Component: ESP8 quattro H04 0020
Coding: 1D0500
Shop #: WSC 02391 823 56573
VCID: 7F5BFF37E7F4469F08D-802A
Part No SW: 8K0 907 064 CG HW: 8K0 907 064 CG
Component: BCM2 2.0 H05 0435
Coding: 0D0100
Shop #: WSC 02399 823 56573
VCID: 77AB1717CFC47EDF40D-8022
Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 2310000084433007
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
Component: KLIMA 3 ZONEN H08 0180
Revision: C1000000 Serial number: 01211220101752
Coding: 64002000
VCID: 00597CCB9A0A3967717-8054
Reset counter: 68
Mileage: 130934 km
Date: 2010.01.22
Time: 00:02:37
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H30 0392
Revision: 10030001 Serial number: 00000000743334
Coding: 26001097443CAF010001080300003D0D4F1C530802010161000000
Shop #: WSC 09550 758 180955
VCID: 3C21C83BB6629D876DF-8068
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 211210 H06 0070
Serial number: SWF10120215400
Coding: 00FD11
Component: RLS H04 0003
Serial number: 11194728
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Serial number: 00000000002511101139
Subsystem 4 - Part No SW: 8K0 907 410 C HW: 8K0 907 410 C
Component: HOMELINK H01 0010
Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
Part No SW: 8K0 959 655 K HW: 8K0 959 655 K
Component: AirbagVW-AU10 H44 0610
Serial number: 003GLD0N0RP%
Coding: 30453735423030303030554A304C384B3053
VCID: 45D7ADDFC528DC4F021-8010
Serial number: 6334MSME5A62757ET
Serial number: 6344MSME59530F23G
Serial number: 6352QSME3E7F4D24$
Serial number: 6362QSME007E2B10D
Serial number: 63732SME687C4728A
Serial number: 63832SME067E502C3
Component: Lenks.Modul H17 0014
Revision: -------- Serial number: 90372JLH000PO
Coding: 000036
VCID: 3D27C53FAD78948F5A1-8068
Component: E221 - MFL H02 0010
Part No SW: 8K0 920 930 M HW: 8K0 920 930 M
Component: KOMBIINSTR. H27 0258
Revision: 00200000 Serial number: EJ857UMDA
Coding: 8B06090002000008020000
VCID: 372BD7178F44BEDF80D-8062
Part No SW: 8T0 907 468 AC HW: 8T0 907 468 J
Component: GW-BEM 6CAN H06 0117
Revision: HB800053 Serial number: 5300H10727810A
Coding: 103200
VCID: 025D76C394062B77673-8056
Address 2E: Media Player 3 (R199) Labels:. 8T0-035-785.clb
Part No SW: 8T0 035 785 A HW: 8T0 035 785
Component: SG ext.Player H08 0290
Revision: 00000000
Coding: 020302
VCID: 392FD12FB950A8AF769-806C
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Part No SW: 8K0 959 760 D HW: 8K0 959 760 D
Component: MEM-FS H06 0074
Revision: AA000000 Serial number: 00001002251840
Coding: 00581B00000000000000
VCID: 3B23CB27B36C9ABF645-806E
Part No SW: 8K0 907 566 H HW: 4L0 907 566 B
Component: J0769_SWA_MasterH01 0030
Revision: 00H01000 Serial number: 6PZ 009 014-82
VCID: 3C21C83BBA629D876DF-8068
Subsystem 1 - Part No: 8K0 907 568 H
Component: J0770_SWA_Slave_H01 0030
Subsystem 2 - Serial number: 6PZ 009 014-92
Subsystem 3 - Serial number: 5F09.12.1000H010003C321474ÿ
Subsystem 4 - Serial number: 321474ÿ
Part No SW: 8T0 959 793 M HW: 8T0 959 793 D
Component: TSG FA H08 1401
Coding: 011C13204E00410001
VCID: 53F383873BFC72FF9C5-8006
Revision: 00002001 Serial number: 0141378858
Coding: 01061E3A00FA440583B0013200000000
Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0050
Serial number: 00000000000000335817
Subsystem 3 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
Component: J245 PS039 H07 0041
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOC.clb
Part No SW: 8T0 035 223 AR HW: 8T0 035 223 AJ
Component: DSP Prem H19 0320
Revision: 00019001 Serial number: 34803000565201
Coding: 0203010302
Shop #: WSC 93168 999 13806
VCID: 7EA50233E0FE4F9703B-802A
7 Faults Found:
Reset counter: 28
Mileage: 130938 km
Date: 2010.01.22
Time: 23:25:02
Voltage: 12.70 V
Temperature: 36.0°C
Temperature: 41.0°C
Bin. Bits: 00000100
Reset counter: 28
Mileage: 130938 km
Date: 2010.01.22
Time: 23:25:02
Voltage: 12.70 V
Temperature: 36.0°C
Temperature: 40.0°C
Bin. Bits: 00000100
00420 - Front Right DSP Midrange Speaker (R104)
Reset counter: 28
Mileage: 130938 km
Date: 2010.01.22
Time: 23:25:02
Voltage: 12.80 V
Temperature: 36.0°C
Temperature: 41.0°C
Bin. Bits: 00000100
02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
Reset counter: 28
Mileage: 130938 km
Date: 2010.01.22
Time: 23:25:02
Voltage: 12.80 V
Temperature: 36.0°C
Temperature: 40.0°C
Bin. Bits: 00000100
02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
Reset counter: 28
Mileage: 130938 km
Date: 2010.01.22
Time: 23:25:02
Voltage: 12.80 V
Temperature: 36.0°C
Temperature: 40.0°C
Bin. Bits: 00000100
02247 - Subwoofer (R148/R157)
Reset counter: 28
Mileage: 130938 km
Date: 2010.01.22
Time: 23:25:03
Voltage: 12.70 V
Temperature: 36.0°C
Temperature: 40.0°C
Bin. Bits: 00000100
00422 - Rear Right DSP Midrange Speaker (R106)
Reset counter: 28
Mileage: 130938 km
Date: 2010.01.22
Time: 23:25:02
Voltage: 12.80 V
Temperature: 36.0°C
Temperature: 40.0°C
Bin. Bits: 00000100
Part No SW: 8T0 959 792 M HW: 8T0 959 792 D
Component: TSG BF H08 1401
VCID: 52FD868304E67BF7973-8006
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000694308
VCID: 3431E01B9E3255C7A5F-8060
Part No: 8K5 907 357 B
Component: Dynamische LWR H02 0010
Coding: 0000004
VCID: 392FD12FB550A8AF769-806C
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 R HW: 8T1 035 186 R
Component: Con3 Sirius H06 0351
Revision: 00000009 Serial number: AUZ5Z6J1514965
Coding: 240300020101870003D9270800
VCID: 46D5AAD3F8AED7570BB-8012
02259 - Information Display and Control Head (Front) (J685)
Reset counter: 27
Mileage: 130934 km
Date: 2010.01.22
Time: 00:02:47
Reset counter: 68
Mileage: 130939 km
Date: 2010.01.22
Time: 17:35:17
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 10000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Part No SW: 8T0 959 795 N HW: 8T0 959 795 B
Component: TSG HL H06 1401
Coding: 010C13204000210001
VCID: 56F57A93280E67D77BB-8002
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb
Component: TSG HR H06 1401
Part No SW: 8T0 862 336 E HW: 8T0 862 336 E
Component: FSE_256x BT H42 0650
Revision: 00000000 Serial number: 00000005104215
Coding: 0010370
Shop #: WSC 02335 785 00200
VCID: 3D27C53FA178948F5A1-8068
End----------(Elapsed Time: 01:48, VBatt start/end: 12.6V/12.5V)-----------
IM STUMPED.
