Tuesday 19, June, 2018.15: 48: 14: 51,522
VCDS - Windows based VAG / VAS emulator - Runs on Windows 10 x64
VCDS version: NEZ 18.2.0.3 HEX-NET CB: 0.4411.4
Data Version: 20180301 DS287.0
www.vcds.dk
Frame number: WAUZZZ8V7GA122633 Registration number:
Model Type: 8V-AU37 (5Q0)
Searched on: 01 02 03 08 09 15 16 17 19 20 42 44 47 52 55 5F 6C BB BC
Frame Number: WAUZZZ8V7GA122633 Drive Range: 50955km
01-Motor - Status: Ok 0000
02-Automatic - Status: Ok 0000
03-ABS Brakes - Status: Ok 0000
08-Air conditioner - Status: Ok 0000
09-Centralelectric - Status: Ok 0000
15-Airbags - Status: Ok 0000
16-Ratelektronik - Status: Ok 0000
17-Instrument - Status: Ok 0000
19-CAN Gateway - Status: Ok 0000
20-Distance Assistant - Status: Ok 0000
42-Dørelektr. V for - Status: Ok 0000
44-Power Steering - Status: Ok 0000
47-Soundsystem - Status: Ok 0000
52-Dørelektr. H for - Status: Ok 0000
55-Lyslængdereg. - Status: Ok 0000
5F-Informationselek. - Status: Ok 0000
6C Back Camera - Status: Fault Function 0010
BB-Rear door driver's side - Status: Ok 0000
BC-Rear door passenger side - Status: Ok 0000
Control unit 01: Motor (J623-CZEA) Explanation file :. NEZ \ 04E-907-309-V1.clb
Control unit number: SW: 04E 906 027 HF HW: 04E 907 309 BJ
Component: R4 1.4l TFS H23 2489
Revision: R6H23 ---
Coding: 02250012242401082000
Dealer: WSC 05296 002 1048576
ASAM dataset: EV_ECM14TFS01104E906027HF 001005
RED: EV_ECM14TFS01104E906027HF.rod
VCID: EFAEA1F73654CE3C71-80BA
Control unit center console 1:
No error codes found.
Control unit 02: Automatic (J743) Explanation file: NEZ \ 0CW-927-769.clb
Control unit no: SW: 0CW 300 040 H HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 0610
Revision: 00005005 Serial Number: CU501601255842
Dealer: WSC 17734 418 534600
ASAM dataset: EV_TCMDQ200021 001001
ROD: EV_TCMDQ200021_VW27.rod
VCID: B93A5FAF3890508C9F-80EC
Control unit 03: ABS brake (J104) Explanation file :. NEZ \ 5Q0-907-379-IPB-V1.clb
Control unit number: SW: 3Q0 907 379 AA HW: 3Q0 907 379 F
Component: ESC H42 0623
Revision: 00000000 Serial Number: 60246000002233
Encoding: 12F16AA22422126E037D060341C62948562448C0608294F3022100748608
ASAM dataset: EV_Brake1UDSContiMK100IPB 034036
RED: EV_Brake1UDSContiMK100IPB_034.rod
VCID: F9BA9FAF7810908CDF-80AC
Control unit 08: Air conditioner (E87) Explanation file: | NEZ \ 8V0-820-043.clb
Control unit no: SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automatic H14 0060
Revision: 20028000 Serial Number: 00000000850144
Coding: 03000004000000011000000000001100
Dealer: WSC 06314 790 00021
ASAM dataset: EV_AirCondiFrontVaAU37X 008020
RED: EV_AirCondiFrontVaAU37X.rod
VCID: B3266D871AFCAADC55-80E6
Sensor for humidity: Exterior:
Subsystem 1 - Control unit no: SW: 4H0 907 658 HW: 4H0 907 658
Serial Number: E8A94D08000000000001
Control unit 09: Centralelectric (J519) Explanation file: | NEZ \ 5Q0-937-08X-HV1.clb
Control unit number: SW: 5Q0 937 084 CL HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0175
Serial Number: 01061602303725
Coding: 04041B46C24122FD43844004001C07A80000000000000000000000000000
ASAM dataset: EV_BCMMQB 015001
ROD: EV_BCMBOSCH_015.rod
VCID: 8444FE5B0FD2DD64BC-80D0
Wiper motor control unit:
Subsystem 1 - Control unit no: SW: 8V1 955 119 A HW: 8V1 955 119 Explanation file: NEZ \ 1KX-955-119.CLB
Component: WWS370 151229 043 0580
Serial Number: 160119041317
Coding: 0A47F7Rain and light sensor:
Subsystem 2 - Control unit no: SW: 8U0 955 559 C HW: 8U0 955 559 B Explanation file: NEZ \ 8U0-955-559.CLB
Component: G397_RLFS H06 0004
Serial Number: 61295343
Coding: 00006C
Light switch:
Subsystem 3 - Control unit no: SW: 8V0 941 531 AE HW: 8V0 941 531 AE
Component: E1 - LDS MQB H05 0032
Serial Number: 27 11 2015 00000754
Control unit 15: Airbags (J234) Explanation file: | NEZ \ 5Q0-959-655.clb
Control unit number: SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Component: AirbagVW20 012 0361
Serial Number: 003M2R1EK6R-
Coding: 98CCC0000C0000005C540000004800000065
ASAM dataset: EV_AirbaVW20SMEVW37X 002126
VCID: CBD61567620CD21C3D-809E
Driver Side Crash Sensor:
Subsystem 1 - Control unit no: SW: ----------- HW: 480 000 502 16
Serial Number: 357670000006F6A0191X
Encoding: 2D2D2D
Passenger Side Side Crash Sensor:
Subsystem 2 - Control unit no: SW: ----------- HW: 480 000 502 16
Serial Number: 35867000000F38A0191X
Encoding: 2D2D2D
Crash sensor for side airbag at the driver's side:
Subsystem 3 - Control unit no: SW: ----------- HW: 480 400 202 16
Serial Number: 3516502C918166C42300
Encoding: 2D2D2D
Crash sensor for side airbag in passenger side:
Subsystem 4 - Control unit no: SW: ----------- HW: 480 400 202 16
Serial Number: 3526502BB18166C2D32D
Encoding: 2D2D2D
Crash sensor for front passenger airbag:
Subsystem 5 - Control unit no: SW: ----------- HW: 480 400 712 15
Serial Number: 3556502B11E3EA9121BI
Encoding: 2D2D2D
Crash sensor for pedestrian protection on the driver's side:
Subsystem 6 - Control unit no: SW: ----------- HW: 480 400 501 16
Component: PedP_Sensor_D 001 6149
Serial Number: 2286502BD1E3EAA0228R
Encoding: 2D2D2D
Crash sensor for pedestrian protection in passenger side:
Subsystem 7 - Control unit no: SW: ----------- HW: 480 401 601 16
Component: PedP_Sensor_P 001 6149
Serial Number: 2296502C91E85EA0E2B /
Encoding: 2D2D2D
Crash sensor for pedestrian protection in the middle:
Subsystem 8 - Control unit no: SW: ----------- HW: 480 401 601 16
Component: PedP_Sensor_C 001 6149
Serial Number: 2306502B91E85EB3636N
Encoding: 2D2D2D
Control unit 16: Ratelektronik (J527) Explanation file: | NEZ \ 5Q0-953-549.clb
Control unit no: SW: 8V0 953 521 EC HW: 5Q0 953 549 E
Component: Lenks. Module 003 0120
Revision: -------- Serial Number: 30011604221122
Coding: A418
ASAM dataset: EV_SMLSKLOMQB 020001
RED: EV_SMLSKLOMQB_020_AU37.rod
VCID: 8248F84315C6D3548E-80D6
No error codes found.-------------------------------------------------- -----------------------------
Control unit 17: Instrument (J285) Explanation file: | NEZ \ 8V0-920-XXX-17.clb-SRI3
Control unit no: SW: 8V0 920 871 R HW: 8V0 920 871 R
Component: KOMBI H03 6423
Coding: 07A509082B8000080100E8001000000000000000
Dealer: WSC 18954 002 104857
ASAM dataset: EV_DashBoardVDDMQBAB 009051
Control unit 19: CAN Gateway (J533) Explanation file: | NEZ \ 5Q0-907-530-V1.clb
Control unit no: SW: 5Q0 907 530 AJ HW: 5Q0 907 530 F
Component: GW MQB High 128 1244
Revision: -------- Serial Number: 0004446227
Coding: 030100043F0857005B0002481C0B00000001010000000000000000000000
ASAM dataset: EV_GatewLear 013020
RED: EV_GatewLear_013_VW37.rod
Generator:
Multifunction Rat Control Unit:
Subsystem 2 - Control unit no: SW: 8U0 951 528 C HW: 8U0 951 528 C
Component: E221 - MFL H02 0014
Serial Number: 26 01 2016 E0077333
Battery Monitoring Control:
Component: J367-BDMConti H02 1011
Serial Number: 74185704001601251116
Control unit 20: Remote light assistant (J844) Explanation file: | NEZ \ 8S0-857-511.clb
Control unit number: SW: 8S0 857 511 C HW: 8S0 857 511 C
Component: FLA H09 0003
Revision: AA001001
Coding: 0202000700000000010001
ASAM dataset: EV_HighBeamAssisAU33X 001017
ROD: EV_HighBeamAssisAU33X_VW37.rod
Control unit 42: Door electronics. V for (J386) Explanation file: | NEZ \ 5QX-959-X93-42.clb
Control unit number: SW: 5Q0 959 593 E HW: 5Q0 959 593 B
Component: TSG FS 020 0041
Serial Number: 281015BJR10813
Coding: 005D0B204000040000001002
ASAM dataset: EV_DCUDriveSideEWMAXKLO 006003
VCID: C3C63D474A5C1A5CC5-8096
Control unit 44: Power steering (J500) Explanation file: | NEZ \ 5Q0-909-144.clb
Control unit number: SW: 5Q0 909 144 S HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 125 1063
Coding: 8103
ASAM dataset: EV_SteerAssisMQB 012140
VCID: C4C43E5B4F521D64FC-8090
Control unit 47: Soundsystem (J525) Explanation file: * None
Control unit no: SW: 8V0 035 465 D HW: 8V0 035 465
Component: MIBAMP1ALPINE H11 0420
Serial Number: AUZ8ZAFN901XHDO
Coding: 01030300AAAA2AAA01
ASAM dataset: EV_AMPMst16C1ALPI 004024
ROD: EV_AMPMst16C1ALPI_004_AU37.rod
Control unit 52: Door electronics. H for (J387) Explanation file: | NEZ \ 5QX-959-X92-52.clb
Control unit number: SW: 5Q0 959 592 E HW: 5Q0 959 592 B
Component: TSG BFS 020 0041
Serial Number: 301015BJT10421
Coding: 005D03204000040000001002
ASAM dataset: EV_DCUPasseSideEWMAXKLO 006003
RED: EV_DCUPasseSideEWMAXCONT.rod
VCID: C2C8384355461354CE-8096
Control unit 55: Light length. (J431) Explanation file: | NEZ \ 5Q0-907-357.clb
Control unit number: SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Revision: -------- Serial Number: --------------
Coding: 019A000001000000
ASAM dataset: EV_HeadlRegulVWLWRMQB 001110
VCID: F5A2939F5408F4ECBB-80A0
Control unit 5F: Information leak. (J794) Explanation file: | NEZ \ 8V0-035-MIB STD1.clb
Control unit no: SW: 8V0 035 864 C HW: 8V0 035 864 B
Component: MU-S-N-ER 042 0461
Serial Number: A3F02801160575
Coding: 017303010000000021110002000A00032F0002340100010006
Dealer: WSC 31136 677 00001
ASAM dataset: EV_MUStd4CPASE 002039
RED: EV_MUStd4CPASE_VW37.rod
VCID: BB3645A732AC629C8D-80EE
media:
Subsystem 1 - Control unit no: SW: 8V0 919 866 D HW: -----------
Component: ECE 2016 --- 0054
Display 1 for multimedia system:
Subsystem 2 - Control unit no: SW: 8V0 919 603 C HW: 8V0 919 603 C
Component: DU Std H49 0014
Serial Number: AUZ8Z9FY30FPBA
Multimedia System Controller:
Subsystem 3 - Control unit no: SW: 8V0 919 614 P HW: 8V0 919 614 P
Component: ControlUnit_B H41 0054
Serial Number: ALJAL116121500020242
Control unit 6C: Back camera (J772) Explanation file: | NEZ \ 5Q0-907-441.clb
Control unit number: SW: 5Q0 907 441 A HW: 5Q0 907 441 A
Component: MQB RVC Mid H07 0140
Coding: 027300012001000300
Dealer: WSC 12345 123 12345
ASAM dataset: EV_2CamSysRearPASE 006016
ROD: EV_2CamSysRearPASE.rod
VCID: B02C628BEBEA91C428-80E4
1 error found:
10489856 - Basic setting not completed
B2010 00 - - -
[RearView system not calibrated]
Verified - Tested page memory deletion
Error status: 00000001
Error priority: 2
Error rate: 1
Reset counter: 159
Driving distance: 50905 km
Date: 2018.06.18
Time: 21:47:38
passive
Control unit BB: Rear door driver's side (J388) Explanation file: | NEZ \ 5Q0-959-395.clb
Control unit number: SW: 5Q0 959 395 E HW: 5Q0 959 395 B
Component: TSG HFS 020 0041
Serial Number: 161215BLF04659
Coding: 004D03204000040000001002
ASAM dataset: EV_DCURearDriveMINKLO 006003
RED: EV_DCURearDriveMAXCONT.rod
Control unit BC: Rear door passenger side (J389) Explanation file: | NEZ \ 5Q0-959-395.clb
Component: TSG HBFS 020 0041
Serial Number: 161215BLF03059
ASAM dataset: EV_DCURearPasseMINKLO 006003
RED: EV_DCURearPasseMAXCONT.rod
Ending ------- (elapsed time: 01:48, VBat. Start / finish: 12.2V / 12.2V) --------
