Case Study: B10C6 Running-in regulation : No Basic Settings
Jef
HQ
ST?ID=82652
Model Audi A7 Sportback
Quattro 3.0
A7
Date of production 26.07.2011
Year 2012
Sales type 4GA51A
Engine Code CGXB
Transmission Code NEU
HVAC:
Part No SW: 4G0 820 043 L HW: 4G0 820 043 L
Component: KLIMA 4 ZONEN H12 0062
0292 - Running-in regulation
B10C6 54 [009] - Missing Calibration / Basic Setting
Backstory is some work was performed on the HVAC, details unclear, but the system was pulled down to vacuum for +15 minutes then recharged as per factory specs. No AC operations now, has DTC B10C6. Code gets reflagged if cleared out.
With engine at idle perform the two Basic Settings:
Adapt flap end stops - Finished Correctly!
Compressor run-in and A/C power test - Finished Correctly!
Now able to clear DTC and AC is working to design.
FandaTDI
Czech Republic
C?ID=204559
I´ve seen simmillar strange thing in A3 2016 that came to me for refill after change of condensator and AFAIR(-emember) no DTC but the AC not running (checking all possible conditions to met) till I have performed (with engine running at idle and AC switched on) basic settings of AC compressor (was original but needs this to start working again...). Don´t get the purpose or what exactly this procedure do (when commonly the "run-out" of a new compressor is usually "just" max.cooling at idle for about ten minutes...) but takes just a moment and then it starts to work again ...
