Golf 6 gti 2011 ABS long code help (MK60EC1)
tolunay
C?ID=254125
Hi all,
In the past few months i did some extra retrofits ( see auto scan ! )
They are all working fine ( allmost then ) but the last thing to do is code the new ABS module.
With a few friend and some long coding helping labels we tried some coding but all not working.
Is there a smarter person that could help me out with the flashing lights on the dashboard, that gets me crazy when driving :mad:
Here is the Auto scan, did remove some unnecessary error messages that are irrelevant for this problem
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: 0000000000000000000000000000000000000000
Shop #: WSC 19427 133 00001
VCID: 04444230879646643C-8050
Thursday,07,June,2018,21:03:15:36185
VCDS Version: 18.2.0.3  HEX-NET CB: 0.4422.4
Dealer/Shop Name: 7
VIN: WVWGD7AJ9BW289978   License Plate:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 25 2B 3C 42 44 46 47 52
          55 5F 62 65 69 72 A5
VIN: WVWGD7AJ9BW289978   Mileage: 56850km-35324miles
17-Instruments -- Status: Status: OK 0000
Address 01: Engine (CBF)       Labels:. 06J-907-115-CBF.clb
   Part No SW: 1K0 907 115 AT    HW: 1K0 907 115 AK
   Component: 2.0l R4/4V TFSI     0040
   Revision: E3H25---    Serial number:
   Coding: 040301081C070960
   Shop #: WSC 00191 264 15243
   VCID: 78BC26C00B5E128420-802C
10 Faults Found:
002129 - Park/Neutral Switch Input Circuit
               P0851 - 000 - Short to Ground - MIL ON
008568 - Bank 1; System Too Rich off Idle
               P2178 - 000 -  - Intermittent
000257 - Mass Air Flow Sensor (G70)
               P0101 - 000 - Implausible Signal - MIL ON
               U1017 - 007 -  - Intermittent
049441 - No Communication with ABS Brake Control Module
               U0121 - 000 -  - Intermittent
Readiness: 0010 1100
   Part No SW: 02E 300 057 C    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2716
   Revision: 05351113    Serial number: 00001105300653
   VCID: 197A0344D014EB8CFF-804C
   Revision: 00H46001
                    Reset counter: 73
                    Date: 2018.06.07
                    Time: 20:11:04
                    Count: 2
                    Count: 12
                    Count: 20992
                    Count: 195
                    Count: 48896
                    Count: 65280
   Part No SW: 5K0 959 434 A    HW: 5K0 959 434 A
   Component: VWKESSYPQ35GP 085 0802
   Revision: 00085000    Serial number: 0144798723
   Coding: 030C1C
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_KESSY_PQ35GP A01018
   ROD: EV_KESSY_PQ35GP.rod
   VCID: 3326D1EC9AB831DCD5-8066
   Part No SW: 1K8 907 044 AC    HW: 1K8 907 044 AC
   Component: Climatronic   H05 0304
   Revision: 00001K03
   Coding: 001801C002
   Shop #: WSC 00219 123 12345
   VCID: 70AC1EE0AB2E4AC4E8-8024
   Part No SW: 5K0 937 087 Q    HW: 5K0 937 087 Q
   Component: BCM PQ35 H+   111 0148
   Revision: BL111001
   Coding: 67080AB7EC33E5C41058028970000B8443FD0011557D8D90E4806824A040
   VCID: 43C6812CC218815C45-8016
   Component: Wischer 11031  26  0512
   Coding: 009FB5
   Component: RLS 070712 05  54  0403
   Coding: 0730AD
   Part No SW: 1K8 919 475 D    HW: 5Q0 919 298
   Component: PARKHILFE PLA 011 0480
   Coding: 0031167111
   Shop #: WSC 00099 780 00200
   ASAM Dataset: EV_EPHVA2CVW364GP00 001010
   ROD: EV_EPHVA2CVW364GP00_VW36.rod
   VCID: 3B36F9CCB2E8F99C0D-806E
12658720 - Databus
          [Steuergerät für elektrische Park-/Handbremse-J540 - mEPB_1 - kein Signal/keine Kommunikation]
                    Reset counter: 73
                    Mileage: 56854 km
                    Date: 2018.06.07
                    Time: 20:11:05
   Part No SW: 3C0 907 376     HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0069
   Revision: 00000000    Serial number: 13020800690002
   Coding: 000180
   Shop #: WSC 00219 000 00000
   VCID: 668078B891EA947482-8032
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 73
                    Mileage: 56854 km
                    Date: 2018.06.07
                    Time: 20:32:40
                    Bin. Bits: 00000000 00001000
   Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
   Component: AirbagVW10G   021 0706
   Serial number: 003C4R02280F
   Coding: 00003031
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 393AE3C4B8D4CB8C1F-806C
   Subsystem 1 - Part No SW: 5K0 959 339     HW: 5K0 959 339
   Component: BF-Gewichtss.  007 0002
   Serial number: ---0000R--0005LPJ600
   Serial number: 3572MSME4532205DZZZR
   Serial number: 3582MSME402E255DZZZ$
   Serial number: 3512QSME7419077CZZZ
   Serial number: 3522QSME5658097BZZZ0
   Serial number: 35527SME6C617526ZZZL
   Serial number: 35627SME1C617526ZZZH
   Part No SW: 5K0 953 521 BR    HW: 5K0 953 569 E
   Revision: FF010040    Serial number: 20110329301698
   Coding: 1012100000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7DB237D4EC7C37AC73-8028
   Component: E221__MFL-TAS  H06 0010
   Coding: 830000
   Part No SW: 1K8 920 885 H    HW: 1K8 920 885 H
   Component: KOMBI         H04 1018
   Coding: 171E230000
   Shop #: WSC 00020 999 12345
   VCID: 3C34FAD0B7E6FEA404-8068
   Part No SW: 7N0 907 530 BL    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1682
   Revision:   H56       Serial number: 21041600F13292
   Coding: 350002
   VCID: 7BB639CCFA68399C4D-802E
   Component: IMMO          H04 1018
   Coding: 000007
   VCID: 6A980C888DF2B014A6-803E
Address 2B: Steer. Col. Lock (J764)       Labels:| 5K0-905-861.clb
   Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
   Component: ELV-PQ35      H20 0230
   Revision: 00000000    Serial number: 11000077897004
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 2E10C098719A1C34BA-807A
   Component: HRE_Master    H11 0071
   Serial number: 0367435529
   Coding: 02012102
   Shop #: WSC 00046 123 12345
   ROD: EV_HREntryHella_VW27.rod
   Lane Change Assistant 2:
   Component: HRE_Slave  H11 0071
   Serial number: 0366681323
   Coding: 020121
   Part No SW: 5K0 959 701 C    HW: 5K0 959 701 C
   Component: Tuer-SG         009 2120
   Coding: 0005366
   Shop #: WSC 80093 222 69422
   VCID: 3228D4E8ADA238D4DE-8066
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 183    3201
   Revision: 00H20000
   VCID: 3424D2F057B636E4CC-8060
   Part No SW: 5K0 035 456     HW: 5K0 035 456
   Component: KonzernAmp 8K H06 0340
   Revision: --------    Serial number: BP218109117144
   VCID: 679E75BC9EE08D7CB9-8032
   Part No SW: 5K0 959 702 E    HW: 5K0 959 702 E
   Component: Tuer-SG         009 2151
   Coding: 0005622
   Shop #: WSC 46651 001 104857
   VCID: 3522EFF45CCC2FECFB-8060
   Coding: 1477724
   Component: AFS-Lst.-Modul l    0004
   Coding: 00000022
   Coding: 00000022
   Part No SW: 5L0 035 680 E    HW: 5L0 035 680 E
   Component: MU-S-ND-ER    X72 X346
   Serial number: SKZAZ2R1995438
   Coding: 03130601AA00000011111105C0880A021F0807C400210100CF
   Shop #: WSC 12345 102 209715
   ROD: EV_MUStd4CTSAT_VW36.rod
   VCID: 2C14CA9047866E2494-8078
7 Faults Found:
1543 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Reset counter: 73
                    Mileage: 56854 km
                    Date: 2018.06.07
                    Time: 20:38:32
                    Voltage terminal 30: 11.6 V
                    Byte_Coding_Condition-byte_0_condition: OK
                    Byte_Coding_Condition-byte_1_condition: OK
                    Byte_Coding_Condition-byte_10_condition: ERROR
                    Byte_Coding_Condition-byte_11_condition: ERROR
                    Byte_Coding_Condition-byte_12_condition: ERROR
                    Byte_Coding_Condition-byte_13_condition: ERROR
                    Byte_Coding_Condition-byte_14_condition: ERROR
                    Byte_Coding_Condition-byte_15_condition: ERROR
                    Byte_Coding_Condition-byte_16_condition: ERROR
                    Byte_Coding_Condition-byte_17_condition: ERROR
                    Byte_Coding_Condition-byte_18_condition: ERROR
                    Byte_Coding_Condition-byte_19_condition: ERROR
                    Byte_Coding_Condition-byte_2_condition: OK
                    Byte_Coding_Condition-byte_20_condition: ERROR
                    Byte_Coding_Condition-byte_21_condition: ERROR
                    Byte_Coding_Condition-byte_22_condition: ERROR
                    Byte_Coding_Condition-byte_23_condition: ERROR
                    Byte_Coding_Condition-byte_24_condition: ERROR
                    Byte_Coding_Condition-byte_25_condition: ERROR
                    Byte_Coding_Condition-byte_26_condition: ERROR
                    Byte_Coding_Condition-byte_27_condition: ERROR
                    Byte_Coding_Condition-byte_3_condition: OK
                    Byte_Coding_Condition-byte_4_condition: OK
                    Byte_Coding_Condition-byte_5_condition: OK
                    Byte_Coding_Condition-byte_6_condition: OK
                    Byte_Coding_Condition-byte_7_condition: OK
                    Byte_Coding_Condition-byte_8_condition: OK
                    Byte_Coding_Condition-byte_9_condition: OK
          B201A 00 [009] -  -
                    Reset counter: 73
                    Mileage: 56854 km
                    Date: 2018.06.07
                    Time: 20:38:32
                    Status_Software_Version_Management-module_name:
13697024 - Component Protection
          U1100 00 [009] - No Basic Setting
          [Anti-theft protection - component protection: no basic setting or basic setting incorrect]
                    Reset counter: 73
                    Mileage: 56854 km
                    Date: 2018.06.07
                    Time: 20:38:32
          U1101 00 [009] - Active
          [Anti-theft protection - component protection active (0xEA6200)]
                    Reset counter: 73
                    Mileage: 56854 km
                    Date: 2018.06.07
                    Time: 20:38:32
0011 - Digital Radio Antenna
          B1103 13 [009] - Open Circuit
                    Reset counter: 73
                    Mileage: 56854 km
                    Date: 2018.06.07
                    Time: 20:59:05
                    Voltage terminal 30: 13.1 V
                    Status of digital radio antenna 1-Antenna current: 0 mA
                    Status of digital radio antenna 1-Connection between radio and antenna amplifier: Open circuit
                    Status of digital radio antenna 1-Connection between antenna amplifier and antenna: Not available
                    Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC: 0.000000
                    Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC: 0.000000
1552 - Expanded Bus Activity Active
          U1104 00 [009] - -
                    Reset counter: 73
                    Mileage: 56854 km
                    Date: 2018.06.07
                    Time: 20:38:32
          U11B8 00 [009] - No Communications
          [USB - communication error]
                    Reset counter: 73
                    Mileage: 56854 km
                    Date: 2018.06.07
                    Time: 20:38:33
                    Interface for external media: status-Status: Open circuit
   Coding: 0001232
   Shop #: WSC 01357 011 1012552
   Part No SW: 3AA 907 273 H    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0012
   Serial number: 30000000035684
   ROD: EV_RDKBERU30_006_VW36.rod
8397058 - Front Left TPMS Sensor
          C1050 31 [009] - No Signal
                    Reset counter: 136
                    Mileage: 49670 km
                    Date: 2017.11.29
                    Time: 19:11:05
                    Vehicle speed: 90 km/h
                    Outside air temperature: 2.0 °C
                    Reception level antenna 1: 620 mV
                    Offset level antenna 1: 300 mV
8397314 - Front Right TPMS Sensor
          C1051 31 [009] - No Signal
                    Reset counter: 136
                    Mileage: 49670 km
                    Date: 2017.11.29
                    Time: 19:11:05
                    Reception level antenna 1: 640 mV
8397570 - Rear Left TPMS Sensor
          C1052 31 [009] - No Signal
                    Reset counter: 136
                    Mileage: 49670 km
                    Date: 2017.11.29
                    Time: 19:11:05
                    Reception level antenna 1: 630 mV
8397826 - Rear Right TPMS Sensor
          C1053 31 [009] - No Signal
                    Reset counter: 136
                    Mileage: 49670 km
                    Date: 2017.11.29
                    Time: 19:11:05
                    Reception level antenna 1: 650 mV
   Revision: 3A001001    Serial number: 00000147679016
   Coding: 010D000202000000
   VCID: 302CDEE063AE0AC4A8-8064
   Coding: 0001232
   VCID: 3620E8F841CA24F4F2-8062
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 3AA-980-654.clb
   Part No SW: 3AA 980 654 D    HW: 3AA 980 654 A
   Component: MFK_Gen1      H08 0300
   Serial number: 0185616805
   Coding: 010001000102020F0200040001010000
   Shop #: WSC 06745 128 28888
   ASAM Dataset: EV_47X 001639
   ROD: EV_47X.rod
2621440 - Databus
          [ERR_CAN_PSD_01_TIMEOUT]
                    Reset counter: 73
                    Mileage: 56854 km
                    Date: 2018.06.07
                    Time: 21:02:56
2686976 - Databus
          [ERR_CAN_PSD_02_TIMEOUT]
                    Reset counter: 73
                    Mileage: 56854 km
                    Date: 2018.06.07
                    Time: 21:02:56
4456448 - Databus
          [ERR_CAN_CAN_MBREMSE_5_ERROR]
                    Reset counter: 73
                    Mileage: 56854 km
                    Date: 2018.06.07
                    Time: 21:02:56
End----------(Elapsed Time: 01:51, VBatt start/end: 13.7V/13.7V)-----------
Look what I found here:
Friday,28,October,2016,10:18:38:36185
VCDS Version: 16.8.3.1 (x64)  HEX-NET CB: 0.4323.4
Dealer/Shop Name: tolunay
[snip]
Address 01: Engine (CBF)       Labels: 06J-907-115-CBF.clb
   Part No SW: 1K0 907 115 AQ    HW: 1K0 907 115 AK
   Coding: 0403010818070160
   VCID: F5A2AFF49C4CEFEA1F-80A0
Readiness: 0000 1100
   Part No SW: 1K0 907 379 BG    HW: 1K0 907 379 BG
   Component: ESP MK60EC1   H31 0106
   Revision: 00H31001
   Coding: 114B800C492A0003881401EB922100413D0800
   VCID: F8BCA6C04B5E928204-80AC
Address 05: Acc/Start Auth. (J518)       Labels: 5K0-959-434.clb
   Coding: 030C1C
   VCID: B32651EC1AB8B1DAF1-80E6
However, it's somewhat puzzling that the old scan had no 02-Auto Trans while this one does? :confused:
tolunay
C?ID=254125
obviously i have the old coding saved, but the ABS pump is a different / new one with support for RTA and Side assit and has one byte extra. and the old coding is not accepted ( with added last byte )
And Yes 02 - DSG is new.. Did a retrofit from manual to DSG :)
OK, but I think it still has value to anyone who might try to help you build a coding for the new ABS.
And Yes 02 - DSG is new.. Did a retrofit from manual to DSG:)
Installs a DSG WTF!
FOD!
Banned to the land of Boogie for Retrofits!
tolunay
C?ID=254125
Yeah the DSG retrofit is weird story.. came accross a cheap DSG GTI with rear damage. so did a retrofit of DSG. My manual needed an upgraded clutch, so went full retard and built in the DSG :cool:
But back tot the main question, like i said, we tried several codings for the abs pump, but could not get the correct one.
Can it be because of the "different" VIN number compared to a RoW car's vin number?
does maybe someone have a clue about the coding with this VIN number.
m87a
Bosnia and Herzegovina
C?ID=156900
try this?
00008000092A0003001401EB90210041050800
iichel
Netherlands, eastern part
C?ID=284912
Looks like you replaced the engine ECU as well. Is it adapted to your VIN?
tolunay
C?ID=254125
try this?
Will try today and report back to you.
//Edit, apart from the missing last byte, its not a good coding unfortunately
No the ECU has been reflashed for easy OBD2 Tuning. Its been flashed and adapted with online odis so vin/immo is correct.
m87a
C?ID=156900
ok try this one
113B800D492A0003881401EB90210041BD180012
is this LHD, NAR or ROW?
tolunay
C?ID=254125
Will try tonight after Work.
Its a lhd Car from California, so its RoW.
I am driving the car with no abs coding, could that be a Problem for the coding problem ? I guess not right ?
iichel
C?ID=284912
I don't think your ABS will work so better not drive that much...
tolunay
C?ID=254125
Abs does not work i know
But i Have to get to Work somehow
tolunay
C?ID=254125
ok try this one
unfortunately this does not work also. but with this code i do get an coding rejected error. with other codes / changed the brake master cilinder size etc is does not give an error but just closes the window without an warning.
m87a
C?ID=156900
ok try these:
114B800D492A0003881401EB90210041BD180012
114B800C492A0003881401EB92210041BD180012
tolunay
C?ID=254125
ok try these:
Sorry to say but,, non of them work.
I am starting to think that my ecu is the problem, because of the different VIN number compared to EU cars ?
m87a
C?ID=156900
try this one, i'm pretty stubborn if you're ready to test it :)
F14B8016492A00038F1401EB92210041A1180012
