I recently had the CEL come on and scan my car and got the fault codes below. I am relatively new to Audi and tried to do as much research as i could but was not able to find much on these codes. i've posted just the fault codes and not the entire scan. please let me know if any of you have had these codes and how you had addressed them. im more interested in the thermostat for transmission fault codes. FYI i have cleared and the CEL has not come on again but when i scan the car i still get the Thermostat for transmission codes and boost pressure codes the others have not showed up again. any help is appreciated!
Monday,04,June,2018,21:53:38:21529
VCDS Version: 18.2.0.3 HEX-V2 CB: 0.4411.4
VIN: WAUHFAFL5DN043084 License Plate:
Mileage: 130000km-80778mi Repair Order:
Chassis Type: FL-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 2E 36 42 44 46 47 52 53 56 62 72
77
VIN: WAUHFAFL5DN043084 Mileage: 130000km-80778miles
Address 01: Engine (0-----CAEB) Labels:. 06H-907-115-CDN.clb
Part No SW: 8K5 907 115 C HW: 8K2 907 115 L
Component: 2.0l R4/4V TF H09 0007
Revision: ECH09---
Coding: 4A190013242600062000
Shop #: WSC 04842 002 1048576
ASAM Dataset: EV_ECM20TFS0118K5907115C 001008
ROD: EV_ECM20TFS0118K5907115C.rod
VCID: 323E13BC04AA2007B4C-8066
7 Faults Found:
5456 - Starter Will Not Turn
P3054 00 [032] - Jammed or Electrical Malfunction
Mileage: 128075 km
Date: 2018.05.06
Time: 18:14:49
Coolant temperature: 99 °C
Intake air temperature: 49 °C
Voltage terminal 30: 12.415 V
Unlearning counter according OBD: 8
10333 - Thermostat for Transmission
P19A2 00 [040] - Open Circuit
Fault Frequency: 16
Mileage: 129173 km
Date: 2018.05.18
Time: 09:15:13
Engine speed: 2332.50 /min
Normed load value: 31.8 %
Vehicle speed: 122 km/h
Coolant temperature: 83 °C
Intake air temperature: 21 °C
Voltage terminal 30: 14.324 V
selected gear-Bits 0-7: 6
10335 - Thermostat for Transmission
P19A0 00 [104] - Short to Plus
Mileage: 128846 km
Date: 2018.05.15
Time: 21:39:40
Engine speed: 1546.50 /min
Normed load value: 6.3 %
Vehicle speed: 81 km/h
Intake air temperature: 29 °C
Voltage terminal 30: 14.135 V
10336 - Thermostat for Transmission
P19A1 00 [032] - Short to GND
2754 - Throttle Valve Controller
P1545 00 [032] - Malfunction
5671 - Boost Pressure Regulation
P0299 00 [237] - Control Range Not Reached
Mileage: 129907 km
Date: 2018.05.27
Time: 14:18:17
Engine speed: 2940.00 /min
Normed load value: 89.8 %
Vehicle speed: 99 km/h
Coolant temperature: 98 °C
Intake air temperature: 50 °C
Voltage terminal 30: 13.805 V
Median injection timing: 5.471 ms
Engine operating condition: Part. load
Engine operating condition-Test_Program_Channel 87: 6
4012 - Cold Start Idle Air Control System
P050A 00 [096] - Malfunction
