Seat Ibiza 6F Crash Mode deactivation
Rainesh
C?ID=315283
im trying to deactivate the crashmode of the steering assist (module 44) on a brand new Seat Ibiza 6F. Car was crashed and repaired, i only need to fix the steering assist so i can do calibration.
I tried the same procedure as EPS_TRW_Alow (but with different security access: 19249).
I tried it with Odis, VCP and VCDS but all the systems say "pre conditions not met". What are those conditions?
Wednesday,13,June,2018,16:25:27:55204
VCDS Version: 18.2.1.2 (x64)  HEX-V2 CB: 0.4411.4
VIN: VSSZZZKJZJRxxxxx  License Plate: SEAT6F
Mileage: 1372km-852mi   Repair Order:
Chassis Type: KJ-SE27 (3Q0)
Scan: 01 03 05 08 09 10 13 14 15 16 17 19 2B 44 47 55 5F CA
VIN: VSSZZZKJZJRxxxxx   Mileage: 1372km-852miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CHZJ)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 026 BQ    HW: 04C 907 309 AT
   Component: R3 1.0l TFS   H21 5155
   Revision: WXH21---
   Coding: 01190032234405081000
   Shop #: WSC 00049 770 00137
   ASAM Dataset: EV_ECM10TFS01104C906026BQ 002001
   ROD: EV_ECM10TFS01104C906026BF.rod
   VCID: 71BE24EB912460CF8E9-8024
   CAN Converter 01:
21472 - Databus
          U1122 00 [039] - Implausible Message
                    Mileage: 1372 km
                    Date: 2018.06.13
                    Time: 15:16:49
                    Coolant temperature: 59 °C
                    Intake air temperature: 27 °C
                    Voltage terminal 30: 11.897 V
                    Acceleration: 0.000 m/s²
                    Cruise Control System (CCS): status-Bits 0-7: 7
                    Cruise_control_shutoff_conditions_irreversible-Bits 0-7: 0
                    Cruise_control_shutoff_conditions_irreversible-Bits 0-7: 1
                    Cruise control system: temporary deactivation-Bits 0-7: 255
                    Cruise control switch actuation-Bits 0-7: 49
                    Cruise control switch actuation-Bits 0-7: 129
17165 - Databus
          U1123 00 [039] - Received Error Message
                    Mileage: 1372 km
                    Date: 2018.06.13
                    Time: 15:16:49
          U0428 00 [039] - -
                    Mileage: 1372 km
                    Date: 2018.06.13
                    Time: 15:16:49
                    Outside air temperature: 21 °C
                    Absolute intake pressure: 101 kPa abs
                    Engine torque: 0.0 Nm
                    Fuel: tank fill level: 5.0 l
                    Oxygen sensor bank 1 sensor 1: specified value: 1.0000
Readiness: 1110 0001
   Part No SW: 2Q0 614 517 AA    HW: 2Q0 614 517 N
   Component: ESC_base_vFGS H23 0222
   Serial number: 08506823180106
   Coding: 510D4C5735428AB532FDAC1E24DF42A649124D26224A242444541254452442659248B26444522424222A482AA249D6427D926B42BE
   Shop #: WSC 00049 770 00140
   ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004032
   ROD: EV_Brake1BOSCHESPMQBA0.rod
   VCID: 6D86389B8D1C842FAA1-8038
1141 - Implausible Data Received from Steering Angle Sensor Module (G85)
          U0428 00 [137] - -
          [Scl_LWI_Lenkradwinkel_Error]
                    Reset counter: 111
                    Mileage: 1372 km
                    Date: 2018.06.13
                    Time: 15:16:56
   Component: VWKESSYMQB    037 0907
   Revision: 00037000    Serial number: 0466522578
   Coding: 112E0E0603
   Shop #: WSC 00049 770 00020
   VCID: 3E24CFD790FACFB743B-806A
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 6F0 907 044 A    HW: 6F0 907 044 A
   Component: Climatronic   H03 0401
   Coding: 0100000108000100110008000240010D0000000000000000000000000000
   ASAM Dataset: EV_ACClimaBHBMQBA0 004017
   ROD: EV_ACClimaBHBMQBA0.rod
   VCID: 251600BB156C7C6F221-8070
   Part No SW: 2Q0 937 090     HW: 2Q0 937 090
   Component: BCM A0 Std+   H97 0915
   Serial number: 07001801500442
   ASAM Dataset: EV_BCMA0 204001
   ROD: EV_BCMA0_104_VW27.rod
   VCID: 6FBA22938710763F98D-803A
   Subsystem 1 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  047 0105
   Serial number: S7Y18M01D17H15M04S18
   Coding: 00194D
   Drivers Door Control Module:
   Subsystem 2 - Part No SW: 2Q1 959 881 B    HW: 2Q1 959 881 B
   Component: FHSG_DRV  001 0001
   Serial number: 00000000000018215488
   Coding: 13000F
   Subsystem 3 - Part No SW: 2Q1 959 882 D    HW: 2Q1 959 882 D
   Component: FHSG_PSG  001 0002
   Serial number: 00000000000018299897
   Coding: 09000F
   Subsystem 4 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY173381ZKD
   Serial number: 00000000000039711994
   Subsystem 6 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
   Component: FOND_FHSG_DRV  006 0007
   Serial number: 00000000000018665854
   Subsystem 7 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
   Component: FOND_FHSG_PSG  006 0007
   Serial number: 00000000000018331723
   Coding: 190000
   Serial number: 000308418618016
   Coding: 0471151001
   ROD: EV_EPHVA18AU3700000_009_VW27.rod
   VCID: 4BC29603D3486A1FD45-801E
13679372 - Databus
          [Steuergerät für Lenkhilfe-J500 - LWI_01.LWI_Lenkradwinkel - Fehlerspeicher auslesen]
                    Reset counter: 111
                    Mileage: 1372 km
                    Date: 2018.06.13
                    Time: 15:17:01
13637426 - Databus
                    Reset counter: 111
                    Mileage: 1372 km
                    Date: 2018.06.13
                    Time: 15:17:01
   Part No SW: 2Q0 907 572 M    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H02 0233
   Coding: 2A00608140FF8728749C8145604085
7 Faults Found:
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
                    Reset counter: 111
                    Mileage: 1372 km
                    Date: 2018.06.13
                    Time: 15:16:58
                    Voltage terminal 15: 11.7 V
                    Control Module temperature: 43 °C
                    Longitudinal_acceleration_vehicle_reference: -0.03 m/s²
                    Status_ACC_System: ACC_irreversible error
2068 - Databus
          [FAULT_TSK_IRREV_FAIL]
                    Reset counter: 111
                    Mileage: 1372 km
                    Date: 2018.06.13
                    Time: 15:18:15
                    Control Module temperature: 45 °C
2062 - Databus
          [FAULT_MAINSWITCH_FAIL]
                    Reset counter: 111
                    Mileage: 1372 km
                    Date: 2018.06.13
                    Time: 15:16:58
1116 - Databus
          U1122 00 [009] - Implausible Message
          [FAULT_TSK_CODING_IN_PLAUS_PHASE_FAIL]
                    Reset counter: 111
                    Mileage: 1372 km
                    Date: 2018.06.13
                    Time: 15:16:58
                    Voltage terminal 15: 11.8 V
                    Longitudinal_acceleration_vehicle_reference: -0.06 m/s²
2052 - Databus
          [FAULT_ALP_STEERINGWHEEL_FAIL]
                    Reset counter: 111
                    Mileage: 1372 km
                    Date: 2018.06.13
                    Time: 15:16:58
2049 - Databus
          [FAULT_ALP_DT_STEERING_WHEEL_FAIL]
                    Reset counter: 111
                    Mileage: 1372 km
                    Date: 2018.06.13
                    Time: 15:16:58
2127 - Databus
          [FAULT_OP_FAIL]
                    Reset counter: 111
                    Mileage: 1372 km
                    Date: 2018.06.13
                    Time: 15:16:58
Address 14: Susp. Elect. (J250)       Labels:. 6C0-907-359.clb
   Part No SW: 6C0 907 359     HW: 6C0 907 359
   Component: DAEMPFUNGS-SG H04 0007
   Serial number: 27111702000249
   Coding: 81
   ASAM Dataset: EV_SwitcDampeContiTemic 001004
   ROD: EV_SwitcDampeContiTemic.rod
   VCID: 6A8C3387BCF29317CF3-803E
   Part No SW: 5QF 959 655 L    HW: 5QF 959 655 L
   Component: Airbag VW22   006 0520
   Revision: --------    Serial number: 003XNPEY3ES5
   Coding: 88CCC0C000000000585400CF000C00000065
   ASAM Dataset: EV_AirbaVW22TS6VW48X 001028
   ROD: EV_AirbaVW22TS6VW48X.rod
   VCID: 5F9A525377B0E6BF28D-800A
   Subsystem 1 - Part No SW: -----------    HW: 454 001 001 18
   Serial number: 357000000000FBD0CB2-
   Subsystem 2 - Part No SW: -----------    HW: 454 001 001 18
   Serial number: 35800000000520FCCB2W
   Subsystem 3 - Part No SW: -----------    HW: 454 801 101 18
   Serial number: 351000FA803130000006
   Subsystem 4 - Part No SW: -----------    HW: 454 800 501 18
   Serial number: 352005C29D512000000G
   Subsystem 5 - Part No SW: -----------    HW: 454 801 412 17
   Component: FrontSensor_D  307 0189
   Serial number: 3550018AFA812000000P
1050117 - Databus
          [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
                    Reset counter: 111
                    Mileage: 1372 km
                    Date: 2018.06.13
                    Time: 15:16:57
   Part No SW: 5Q0 953 569 A    HW: 5Q0 953 569 A
   Revision: --------    Serial number: 20180301500093
   Coding: 6E10
   Shop #: WSC 01286 386 08256
   ASAM Dataset: EV_SMLSVALEOMQB 001016
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3C20C5DF86E6DDA76DF-8068
226843 - Turn Signal Switch
          B1144 13 [009] - Open Circuit
                    Reset counter: 111
                    Mileage: 1372 km
                    Date: 2018.06.13
                    Time: 15:17:00
                    Ubat 30 Voltage: 12.00 V
                    Ignition State: On
                    Terminal 15: 11.20 V
                    A/D #1: 97.65 %
                    A/D #2: 35.69 %
                    A/D #3: 0.00 %
          B1149 13 [009] - Open Circuit
                    Reset counter: 111
                    Mileage: 1372 km
                    Date: 2018.06.13
                    Time: 15:17:00
                    Ignition State: On
                    A/D #1: 97.65 %
                    A/D #2: 50.59 %
                    A/D #3: 0.00 %
229235 - Switch for ADR Distance Selection
          B1155 07 [009] - Mechanical Failure
                    Reset counter: 111
                    Mileage: 1372 km
                    Date: 2018.06.13
                    Time: 15:17:00
                    Ignition State: On
                    A/D #1: 65.49 %
                    A/D #2: 0.00 %
                    A/D #3: 0.00 %
Address 17: Instruments (J285)       Labels:* None-SRI3
   Part No SW: 6F0 920 740     HW: 6F0 920 740
   Component: KOMBI         206 0450
   Coding: 04A401103D800008018862011000000080000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001020
   ROD: EV_DashBoardVDDMQBA0_SE27.rod
   VCID: 629C5BA744C2CB57073-8036
   Component: GW MQB High   436 4326
   Revision: --------    Serial number: 0007323347
   Coding: 030100046F085700E9000258880F00010001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF_SE27.rod
   VCID: 3828D9CFB2DEF187897-806C
   Subsystem 2 - Part No SW: 5F0 959 537 E    HW: 5F0 959 537 E
   Serial number: 000000000G0212121217
   Coding: 002000
   Subsystem 3 - Part No SW: 2Q0 915 181     HW: 2Q0 915 181
   Component: J367-BDMBOSCH  H02 2011
   Serial number: 1003BA2F
8526363 - Unknown Error Code
          B189C F0 [009] - Unknown Error Elaboration
                    Reset counter: 111
                    Mileage: 1372 km
                    Date: 2018.06.13
                    Time: 15:16:57
                    Supply voltage: Terminal 30: 11.7 V
                    Terminal 15: On
   Part No SW: 2Q0 905 861     HW: 2Q0 905 861
   Component: ELV-MQBB      H06 0020
   Serial number: 17000252591005
   Coding: 0000000000000000
   ROD: EV_ELVMarqMQBA0.rod
   VCID: 70B821EF9A2E69C7817-8024
Address 44: Steering Assist (J792)       Labels:* None
   Part No SW: 2Q1 909 144 J    HW: 2Q1 909 144 F
   Component: TRW_G4L_MQBA0 610 6030
   Serial number: 0317585CB4J0202
   Coding: 00000000000000010101020101000101000001
   ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 009014
   ROD: EV_SteerAssisTRWG4LMQBA0_009.rod
   VCID: 392EDCCB89D4E88F769-806C
15788544 - Crash Shut-Down Activated
          P1609 00 [137] - -
          [DEM_FRONT_CRASH_FAULT]
                    Mileage: 1372 km
                    Date: 2018.06.13
                    Time: 15:21:48
                    Engine speed: 959 /min
                    Terminal 15 status: On
                    Voltage terminal 30: 13.68 V
                    Power steering current consumption: 0.5 A
                    max.value: 0.5 A
                    End stage temperature: 215 °C
                    Steering assistance: engine output: 100 %
                    Engine angle: 65535 °
                    Electric motor speed: 45535 /min
                    Steering assistance: target engine torque: 0.0 Nm
                    Steering torque: 0.0 Nm
   Part No SW: 5Q6 035 456     HW: 5Q6 035 456
   Component: KonzernAmp 8K H01 2426
   Revision: --------    Serial number: A1117A00040379
   Coding: 0202000000AAAA00000000000000
   ASAM Dataset: EV_AMPCAN8C1PASE 001015
   ROD: EV_AMPCAN8C1PASE_VW27.rod
   VCID: 73B22EE3EB3852DF7C5-8026
   Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
   Component: AFS-ECU       H07 0070
   Coding: 078A000001200003
   ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
   ROD: EV_HeadlRegulAFSMQBMAX_VW27.rod
   VCID: 41DEB42BE104B04F3E9-8014
13705992 - Databus
          U1123 00 [137] - Received Error Message
          [Fehlerwert im Signal LWI_Lenkradwinkel]
                    Reset counter: 111
                    Mileage: 1372 km
                    Date: 2018.06.13
                    Time: 15:21:24
Address 5F: Information Electr. (J794)       Labels:| 5F0-035-MIB-STD2.clb
   Part No SW: 5QA 035 858 B    HW: 5QA 035 858 B
   Component: MU-S-ND-ER    H41 0468
   Serial number: SEZAZ2U0227551
   Coding: 047200010000000011110103008808232F0101D401200500C6
   ASAM Dataset: EV_MUStd4CTSAT 001001
   ROD: EV_MUStd4CTSAT_VW27.rod
   VCID: 46D4A737C82A97770BB-8012
   Subsystem 1 - Part No SW: 6F0 919 605 A    HW: 6F0 919 605 A
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: SEZ6ZHV0164009
   Subsystem 2 - Part No SW: 6P0 919 866 AB    HW: -----------
   Component: ECE1 2018  --- 0915
0008 - Connection between Antenna Amp 2 for Radio and Antenna
          B1273 13 [009] - Open Circuit
                    Reset counter: 111
                    Mileage: 1372 km
                    Date: 2018.06.13
                    Time: 15:16:56
                    Voltage terminal 30: 11.8 V
                    Status of antenna 2 for radio-Antenna current: 0 mA
                    Status of antenna 2 for radio-Connection between radio and antenna amplifier: Electrical OK
                    Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Open circuit
                    Status of antenna 2 for radio-Reception level antenna 2: 0 dBµV
   Part No SW: 4M0 907 594 H    HW: 4M0 907 594
   Coding: 408040527001
   ROD: EV_SunRoofCONTIAU736.rod
   VCID: 3B22C6C383E8DA9F645-806E
End----------(Elapsed Time: 01:30, VBatt start/end: 14.4V/14.4V)-----------
myounus
Northwest UK
C?ID=321059
Hi
It appears that you may have a damaged steering angle sensor. Have you tried re-calibrating it? If not it may require replacement.
FandaTDI
Czech Republic
C?ID=204559
For this purpose(/reset) it should be SA:10608
Rainesh
C?ID=315283
I replaced steering angle sensor with brand new one.
SA:10608 is incorrect
myounus
Northwest UK
C?ID=321059
Have you replaced the steering wheel?? Have you checked the clock spring? The errors are showing that there is a comms errors from the stalks/ steering depending on where your selection buttons are.
Rainesh
C?ID=315283
No original steeringwheel, but new airbag.
Errors of stalks are fixed because of wrong coding. Module16 is error free now.
myounus
Northwest UK
C?ID=321059
Can you delete all DTC's, turn steering wheel all the way left and then right. Then please post a new autoscan.
Rainesh
C?ID=315283
Already did that. DTC's comes back from crash shut-down
myounus
Northwest UK
C?ID=321059
Did you replace the airbag with the correct one with MFSW wires?
I'd advise you to double check the part numbers and connections from the airbag and slip ring.
Shuhel
Birmingham, UK
C?ID=368132
Did you find a solution to deactivate crash shut down?
downtime
C?ID=280813
I have a solution that has been tested as working one for this particular steering rack with crash shut down activated.
You need to flash the steering rack to 144M first and then downgrade it back to 144J. Flash is to be done in following order:
1. 2Q1909144ZT BOOT
2. 2Q1909144M frf file
3. 2Q1909144ZU BOOT
4. 2Q1909144J frf file
5. Online parameterization and coding using ODIS. Mandatory step.
This is 100% verified and working solution.
Shuhel
Birmingham, UK
C?ID=368132
thanks for the info downtime, i also hear that it can be done with vcp although unverified
downtime
C?ID=280813
Can be done if you have the steering rack dataset. Which unfortunately is not available.
So at the moment only ODIS online.
milkatrek
Poland
C?ID=147536
Hi
could you help me and send me this flash files
my ecu 2q1909144j
skype milkatrek
haruto0
Unauthorized Advertiser
C?ID=345518
Guys i had the same problem as above on a Seat Arona which has the same MQB 2 generation steering system.You cannot reset these module until you are connected to the Geko system and remove the firmware reset-lock.Tthese is very unique to these modules on Polo 2018 Ibiza 2018 and Arona and some Q2s.
I tried every trick available and i was not successful until i found these guys on ebay who does the job.All you need to do is copy the original coding by VCDS and send the module to them and you will get it back Virgin.Simply put back the coding and it work as new.
https://www.ebay.co.uk/itm/[redacted]
Not even the dealerships are aware and the technicians have not been updated on these modules as i came to realise.I spoke to several dealerships and they only know of the earlier procedure for the earlier modules only and not these new ones.They are only instructed to replace them and replacing cost £300 new module and £40 coding it is terrible !!!
downtime
C?ID=280813
I did this for Arona with that J ending gen2 steering rack and I can say for sure that the procedure I described earlier works.
