Hi guy's
I'm new here and whant to share my problem I met yesterday.
had costumer with Passat 2008 with EPB module failure so got second hand off junkyard. Unfortunately I didnt know that you must save full log for other modules because newer models might lost their coding. After Installing other EPB module and coding from old module, parking brake started to work but all other lights like abs, esp, tire pressure, airbag, glow light etc lit on dash. ABS coding was lost and got no coding calculator for 7 digit code. Made account here so maybe someone here could help me out but meanwhile my account verification I got help from another forum and my problem was solved. This coding list might help other's in future or Ross-Tech should add this list to ABS module!
options:
32768 - start-stop (7L6)
16384 - start-stop or coasting?
4096 - indirect tire pressure monitoring
2048 - right wheel
512 - Off Road
256 - rear ABS sensors gray for PLA2
engine and transmission combination:
1029 - 1.4tsi 75 - 100kW front-wheel drive manual transmission
1032 - 1.4tsi 75 - 100kW front-wheel drive manual transmission (China)
1035 - 1.4tsi 101 - 130kW front-wheel drive manual transmission
1038 - 1.4tsi 101 - 130kW manual transmission 4Motion
1041 - 1.8tsi 105 - 130kW front-wheel drive manual transmission (China)
1044 - 1.8tsi 105 - 130kW front-wheel drive automatic (China)
1047 - 1.8tsi 105 - 130kW automatic transmission 4Motion (China)
1050 - 2.0tsi 125 - 160kW automatic transmission 4Motion (China)
1053 - 1.4tsi 101 - 130kW DSG front-wheel drive (NAR)
1056 - 2.0tsi 125 - 160kW DSG 4Motion (CCZD motor 132kW)
1059 - 2.0tsi 125 - 160kW front-wheel drive manual transmission (NAR)
1062 - 2.0tsi 125 - 160kW front-wheel drive automatic (NAR)
1065 - 2.0tsi 125 - 160kW automatic transmission 4Motion (NAR)
1068 - 2.0tsi 125 - 160kW manual transmission 4Motion
1071 - 2.0tsi 125 - 160kW DSG 4Motion
1074 - 2.0tsi 125 - 160kW automatic transmission 4Motion
1077 - 2.0tsi 125 - 160kW front-wheel drive manual transmission (NAR)
1080 - 2.0tdi 70 - 90kW front-wheel drive manual transmission
1083 - 2.0tdi 91 - 110kW front-wheel drive manual transmission
1086 - 2.0tdi 91 - 110kW manual transmission 4Motion
1089 - 2.0tdi 91 - 110kW DSG 4Motion
1092 - 2.0tdi 91 - 110kW automatic transmission 4Motion
1095 - 2.0tdi 111 - 130kW DSG 4Motion
1098 - 2.0tdi 111 - 130kW manual transmission 4Motion
1101 - 1.4tsi 101 - 130kW DSG front-wheel drive
For example I had a 2.0 diesel with automatic transmission with 4x4 off road, indirect tire pressure monitoring and PLA2:
4096 + 512 + 256 + 1092 = 5956, coding is 0005956.
after that you need to do basic settings/adaptation but as VCDS failed to adapt electrical steering rack I had to use ODIS to finish the job
BR
options:
2048 - right wheel
512 - Off Road
BR
