Hi All
Hope to get some clarification on this one and would like to sort out this error. Some time ago I retrofitted LED Rear Lights of which was popular at the time and lots of different codes were knocking around on the websites for this retrofit.
Anyway retrofit done and cables/plugs changed to accommodate all working accept the fast in cabin indicator flash and 03389 - Data Set Implausible on Address 46 due to incorrect coding on channels 199, 200, 201,202
After talking with different people I was told that the BCM2 is locked and the only way to fix this problem is to replace the BCM2.
I know rlarsen has made many posts about the retrofit of which I have gone though, but as stated when trying to input the correct coding on channels 199.200,201,202 all I get is Error and the new code is not accepted even with security entered.
I have listed full scan details and adpmap, blockmap.
Is there anyway of fixing the problem without changing the BCM2 or is it now toast.
Many Thanks for your help.
Tuesday,12,June,2018,12:41:45:47835
VCDS Version: 18.2.1.2 (x64)
Mileage: 136280km-84680mi Repair Order:
Mode 9 : Calibration Identification
Type 02 - VIN : WAUZZZ8K68A048757 (Address E8)
Type 04 - Calibration ID : 03L906022B 3210 (Address E8)
Type 06 - Calibration Verification Number : FAD1D735 (Address E8)
Type 0A - Controller Name : ECM-Engine Control (Address E8)
Tuesday,12,June,2018,12:28:07:47835
VIN: WAUZZZ8K68A048757 License Plate:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 03 05 07 08 09 0E 10 15 16 17 19 1E 37 42 46 47 52 53 55
56 62 72 77
VIN: WAUZZZ8K68A048757 Mileage: 136280km-84680miles
Address 01: Engine (J623-CAGA) Labels:| 03L-906-022-CAG.clb
Part No SW: 03L 906 022 B HW: 03L 906 022 B
Component: R4 2,0L EDC H01 3210
Revision: --H01---
Coding: 0104002C18072118
Shop #: WSC 99999 123 12345
ASAM Dataset: EV_ECM20TDI03L906022B A01014
ROD: EV_ECM20TDI03L906022.rod
VCID: 244CFA4D2F61246463-8070
Part No SW: 8K0 907 379 P HW: 8K0 907 379 P
Component: ESP8 front H04 0180
Coding: 160500
Shop #: WSC 06325 123 12345
VCID: 468840C5F11D36745D-8012
Part No SW: 8K0 907 064 BC HW: 8K0 907 064 C
Component: BCM2 1.1 H70 0252
Coding: 031100
Shop #: WSC 06325 000 00000
VCID: 72E0CC15AD15FAD421-8026
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0508000018062009
Component: ELVAUDIB8 H35 0039
Serial number: 0208000005823009
Address 07: Control Head Labels: 8T0-035-7xx-07-H.clb
Part No SW: 8T0 035 729 T HW: 4E0 035 729
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 329DM087564020
Shop #: WSC 00046 000 00000
VCID: 4A9074F52505D214B9-801E
Subsystem 1 - Part No: 8T0 919 609
Component: E0380 BedienteilH08 0100
Subsystem 2 - Serial number: 00000000077250
Subsystem 3 - Serial number: 0124.04.080000000100010114ÿ
Subsystem 4 - Serial number: 010114ÿ
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T2 820 043 S HW: 8T2 820 043 S
Component: KLIMA 3 ZONEN H06 0140
Revision: D0000000 Serial number: 0130.04.080590
Coding: 34040000
VCID: 42805CD5DD350A5471-8016
Part No SW: 8K0 907 063 C HW: 8K0 907 063 C
Component: BCM1 1.0 H21 0253
Revision: 04021001 Serial number: 00000000133453
Coding: 2600509140148F000001000000001D0D4F1D030800010141000000
Shop #: WSC 84725 210 00546
VCID: 2F6605617EA7973C8E-807A
Subsystem 1 - Part No SW: 8K2 955 119 HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 250408 H05 0060
Serial number: SWFBIE 0001159
Coding: 00FD11
Component: RLS H04 0003
Serial number: 10116665
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
Serial number: 00000000000405080593
Part No SW: 8T2 035 110 C HW: 8T2 035 110 C
Component: MP3-Changer H42 0390
Revision: 00042001 Serial number: AUZ5ZBH8379535
VCID: 2B5E11718ABFEB1CA2-807E
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 AA HW: 8P0 919 475 N
Component: PARKHILFE 8K H01 0080
Revision: 11001001 Serial number: 12501104002886
Coding: 100003
Shop #: WSC 06335 123 12345
VCID: 78F4FE3DCB6990841F-802C
Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H26 0410
Serial number: 0038JD155YDF
Coding: 30363434363030303030554A3052384B3053
VCID: 3C7C222DB7D17CA43B-8068
Serial number: 6334MSME3A234031%
Serial number: 6344MSME336034362
Serial number: 6352QSME6713277BL
Serial number: 6362QSME630C4857N
Serial number: 63732SME62491607Y
Serial number: 63832SME67171039Y
Component: Lenks.Modul H12 0013
Revision: -------- Serial number: 90315HE6000JN
Coding: 000016
VCID: 3D7A2F29A4CB75AC0C-8068
Component: E221 - MFL H02 0003
Part No SW: 8K0 920 980 B HW: 8K0 920 980 B
Component: KOMBIINSTR. H15 0221
Revision: 00100000 Serial number: 7BY72R258
Coding: 2F04080002002600010000
VCID: 31620319689381CC98-8064
Part No SW: 8T0 907 468 K HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0092
Revision: EB302042 Serial number: 4200E08425835D
Coding: 000303
VCID: 49924BF9E003D90CB0-801C
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H03 0150
Serial number: 1800264B140108
Address 1E: Media Player 2 (R199) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 F HW: 4E0 035 785 C
Component: SG ext.Player H15 0850
Revision: 00000000
VCID: 2B5E11714ABFEB1CA2-807E
Part No SW: 4E0 910 888 P HW: 4E0 919 887 M
Component: MNS ECE H51 1060
Revision: 00000000 Serial number: 333EZ087564847
Shop #: WSC 00976 210 89512
VCID: 3B7E21317ADF7B9C32-806E
Part No SW: 8K0 959 793 B HW: 8K0 959 793
Component: TSG FA H10 0170
Revision: Serial number: 0000007127739
Coding: 011C02205001410001
VCID: 3F865521AEC767BC1E-806A
Revision: 00002001 Serial number: 0111326377
Coding: 011F0622003904C00220010000000000
Component: LIN BACKUP HO H03 1301
Reset counter: 236
Mileage: 136254 km
Date: 2018.06.11
Time: 12:12:21
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 8T0 035 223 T HW: 8T0 035 223 F
Component: DSP Prem H14 0400
Revision: 00H14003 Serial number: 34814000992200
Coding: 020101
Shop #: WSC 12336 024 394758
Part No SW: 8K0 959 792 B HW: 8K0 959 792
Component: TSG BF H10 0170
Revision: Serial number: 0000007118379
Coding: 011C02204001410001
VCID: 3E782825A9CD6EB415-806A
Part No SW: 8K0 907 801 D HW: 8K0 907 801 D
Component: EPB Audi B8 H04 0050
Revision: 00000003 Serial number: 00000000115881
VCID: 3064061D639988C497-8064
Part No: 8K0 907 357 B
Coding: 0000004
Shop #: WSC 06324 000 00000
VCID: 346C0A0D5781B4E4F3-8060
Part No SW: 4E0 910 541 T HW: 4F0 035 541 L
Revision: 00000000 Serial number: 336EY087557256
VCID: 31620319A89381CC98-8064
Part No SW: 8K0 959 795 HW: 8K0 959 795
Component: TSG HL H06 0170
Revision: Serial number: 0000007131093
Coding: 010C02200001210001
VCID: 7F061521EE47A7BC5E-802A
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb
Part No SW: 8K0 959 794 HW: 8K0 959 795
Component: TSG HR H06 0170
Revision: Serial number: 0000007125393
Coding: 010C02204001210001
VCID: 7EF8E825E94DAEB455-802A
Part No SW: 4E0 910 336 M HW: 4E0 862 335
Component: Handyvorb2 H18 1130
Revision: 00000000 Serial number: 00000005146826
Coding: 0010920
VCID: 2C5C126D8FB1EC24AB-8078
End-------------------------(Elapsed Time: 03:53)-------------------------
;SW:8K0-907-064-BC HW:8K0-907-064-C --- Central Conv. --- SA: 16017
;Component:BCM2 1.1 H70 0252 Coding:011F0622003904C00220010000000000
;Tuesday 12 June 2018 12:36:48:47835
;VCDS Version: Release 18.2.1 (x64) Data version: 20180518 DS287.1
;VCID: 72E0CC15AD15FAD421-8026
Channel Field 1 Field 2 Field 3 Field 4
1 38880 N/A N/A N/A N/A
2 38880 N/A N/A N/A N/A
3 40929 N/A N/A N/A N/A
4 40929 N/A N/A N/A N/A
5 0 N/A N/A N/A N/A
6 0 N/A N/A N/A N/A
7 0 N/A N/A N/A N/A
8 0 N/A N/A N/A N/A
9 40929 N/A N/A N/A N/A
10 0 N/A N/A N/A N/A
11 ERROR: Channel 11 Not Available
12 ERROR: Channel 12 Not Available
13 87 N/A N/A N/A N/A
14 200 N/A N/A N/A N/A
15 200 N/A N/A N/A N/A
16 5 N/A N/A N/A N/A
17 ERROR: Channel 17 Not Available
18 ERROR: Channel 18 Not Available
19 ERROR: Channel 19 Not Available
20 ERROR: Channel 20 Not Available
21 21 N/A N/A N/A N/A
22 ERROR: Channel 22 Not Available
23 ERROR: Channel 23 Not Available
24 ERROR: Channel 24 Not Available
25 ERROR: Channel 25 Not Available
26 ERROR: Channel 26 Not Available
27 ERROR: Channel 27 Not Available
28 ERROR: Channel 28 Not Available
29 ERROR: Channel 29 Not Available
30 ERROR: Channel 30 Not Available
31 ERROR: Channel 31 Not Available
32 ERROR: Channel 32 Not Available
33 ERROR: Channel 33 Not Available
34 ERROR: Channel 34 Not Available
35 ERROR: Channel 35 Not Available
36 ERROR: Channel 36 Not Available
37 ERROR: Channel 37 Not Available
38 ERROR: Channel 38 Not Available
39 ERROR: Channel 39 Not Available
40 ERROR: Channel 40 Not Available
41 ERROR: Channel 41 Not Available
42 ERROR: Channel 42 Not Available
43 ERROR: Channel 43 Not Available
44 ERROR: Channel 44 Not Available
45 ERROR: Channel 45 Not Available
46 ERROR: Channel 46 Not Available
47 ERROR: Channel 47 Not Available
48 ERROR: Channel 48 Not Available
49 ERROR: Channel 49 Not Available
50 ERROR: Channel 50 Not Available
51 ERROR: Channel 51 Not Available
52 ERROR: Channel 52 Not Available
53 ERROR: Channel 53 Not Available
54 ERROR: Channel 54 Not Available
55 ERROR: Channel 55 Not Available
56 ERROR: Channel 56 Not Available
57 ERROR: Channel 57 Not Available
58 ERROR: Channel 58 Not Available
59 ERROR: Channel 59 Not Available
60 15 N/A N/A N/A N/A
61 9947 N/A N/A N/A N/A
62 48059 N/A N/A N/A N/A
63 44 N/A N/A N/A N/A
64 40 N/A N/A N/A N/A
65 63 N/A N/A N/A N/A
66 ERROR: Channel 66 Not Available
67 ERROR: Channel 67 Not Available
68 ERROR: Security access required
69 0 N/A N/A N/A N/A
70 ERROR: Channel 70 Not Available
71 ERROR: Channel 71 Not Available
72 ERROR: Channel 72 Not Available
73 ERROR: Channel 73 Not Available
74 ERROR: Channel 74 Not Available
75 ERROR: Channel 75 Not Available
76 ERROR: Channel 76 Not Available
77 ERROR: Channel 77 Not Available
78 ERROR: Channel 78 Not Available
79 ERROR: Channel 79 Not Available
80 ERROR: Channel 80 Not Available
81 ERROR: Channel 81 Not Available
82 ERROR: Channel 82 Not Available
83 ERROR: Channel 83 Not Available
84 ERROR: Channel 84 Not Available
85 ERROR: Channel 85 Not Available
86 ERROR: Channel 86 Not Available
87 ERROR: Channel 87 Not Available
88 ERROR: Channel 88 Not Available
89 ERROR: Channel 89 Not Available
90 ERROR: Channel 90 Not Available
91 ERROR: Channel 91 Not Available
92 ERROR: Channel 92 Not Available
93 ERROR: Channel 93 Not Available
94 ERROR: Channel 94 Not Available
95 ERROR: Channel 95 Not Available
96 ERROR: Channel 96 Not Available
97 ERROR: Channel 97 Not Available
98 ERROR: Channel 98 Not Available
99 ERROR: Channel 99 Not Available
100 ERROR: Channel 100 Not Available
101 ERROR: Channel 101 Not Available
102 ERROR: Security access required
103 ERROR: Channel 103 Not Available
104 ERROR: Channel 104 Not Available
105 ERROR: Channel 105 Not Available
106 ERROR: Channel 106 Not Available
107 ERROR: Channel 107 Not Available
108 ERROR: Channel 108 Not Available
109 ERROR: Channel 109 Not Available
110 ERROR: Channel 110 Not Available
111 ERROR: Channel 111 Not Available
112 ERROR: Channel 112 Not Available
113 ERROR: Channel 113 Not Available
114 ERROR: Channel 114 Not Available
115 ERROR: Channel 115 Not Available
116 ERROR: Channel 116 Not Available
117 ERROR: Channel 117 Not Available
118 ERROR: Channel 118 Not Available
119 ERROR: Channel 119 Not Available
120 ERROR: Channel 120 Not Available
121 ERROR: Channel 121 Not Available
122 ERROR: Channel 122 Not Available
123 ERROR: Channel 123 Not Available
124 ERROR: Channel 124 Not Available
125 ERROR: Channel 125 Not Available
126 ERROR: Channel 126 Not Available
127 ERROR: Channel 127 Not Available
128 ERROR: Channel 128 Not Available
129 ERROR: Channel 129 Not Available
130 ERROR: Channel 130 Not Available
131 ERROR: Channel 131 Not Available
132 ERROR: Channel 132 Not Available
133 ERROR: Channel 133 Not Available
134 ERROR: Channel 134 Not Available
135 ERROR: Channel 135 Not Available
136 ERROR: Channel 136 Not Available
137 ERROR: Channel 137 Not Available
138 ERROR: Channel 138 Not Available
139 ERROR: Channel 139 Not Available
140 ERROR: Channel 140 Not Available
141 ERROR: Channel 141 Not Available
142 ERROR: Channel 142 Not Available
143 ERROR: Channel 143 Not Available
144 ERROR: Channel 144 Not Available
145 ERROR: Channel 145 Not Available
146 ERROR: Channel 146 Not Available
147 ERROR: Channel 147 Not Available
148 ERROR: Channel 148 Not Available
149 ERROR: Channel 149 Not Available
150 ERROR: Channel 150 Not Available
151 ERROR: Channel 151 Not Available
152 ERROR: Channel 152 Not Available
153 ERROR: Channel 153 Not Available
154 ERROR: Channel 154 Not Available
155 ERROR: Channel 155 Not Available
156 ERROR: Channel 156 Not Available
157 ERROR: Channel 157 Not Available
158 ERROR: Channel 158 Not Available
159 ERROR: Channel 159 Not Available
160 ERROR: Channel 160 Not Available
161 ERROR: Channel 161 Not Available
162 ERROR: Channel 162 Not Available
163 ERROR: Channel 163 Not Available
164 ERROR: Channel 164 Not Available
165 ERROR: Channel 165 Not Available
166 ERROR: Channel 166 Not Available
167 ERROR: Channel 167 Not Available
168 ERROR: Channel 168 Not Available
169 ERROR: Channel 169 Not Available
170 ERROR: Channel 170 Not Available
171 ERROR: Channel 171 Not Available
172 ERROR: Channel 172 Not Available
173 ERROR: Channel 173 Not Available
174 ERROR: Channel 174 Not Available
175 ERROR: Channel 175 Not Available
176 ERROR: Channel 176 Not Available
177 ERROR: Channel 177 Not Available
178 ERROR: Channel 178 Not Available
179 ERROR: Channel 179 Not Available
180 ERROR: Channel 180 Not Available
181 65520 N/A N/A N/A N/A
182 255 N/A N/A N/A N/A
183 16383 N/A N/A N/A N/A
184 255 N/A N/A N/A N/A
185 65535 N/A N/A N/A N/A
186 255 N/A N/A N/A N/A
187 16368 N/A N/A N/A N/A
188 1 N/A N/A N/A N/A
189 16383 N/A N/A N/A N/A
190 1021 N/A N/A N/A N/A
191 16143 N/A N/A N/A N/A
192 3 N/A N/A N/A N/A
193 6 N/A N/A N/A N/A
194 7 N/A N/A N/A N/A
195 5251 N/A N/A N/A N/A
196 5283 N/A N/A N/A N/A
197 5124 N/A N/A N/A N/A
198 5156 N/A N/A N/A N/A
199 10248 N/A N/A N/A N/A
200 10280 N/A N/A N/A N/A
201 10248 N/A N/A N/A N/A
202 10280 N/A N/A N/A N/A
203 73 N/A N/A N/A N/A
204 105 N/A N/A N/A N/A
205 13 N/A N/A N/A N/A
206 45 N/A N/A N/A N/A
207 12 N/A N/A N/A N/A
208 44 N/A N/A N/A N/A
209 0 N/A N/A N/A N/A
210 0 N/A N/A N/A N/A
211 51214 N/A N/A N/A N/A
212 51215 N/A N/A N/A N/A
213 13618 N/A N/A N/A N/A
214 3 N/A N/A N/A N/A
215 ERROR: Channel 215 Not Available
216 ERROR: Channel 216 Not Available
217 ERROR: Channel 217 Not Available
218 ERROR: Channel 218 Not Available
219 ERROR: Channel 219 Not Available
220 ERROR: Channel 220 Not Available
221 51400 N/A N/A N/A N/A
222 51400 N/A N/A N/A N/A
223 51400 N/A N/A N/A N/A
224 51400 N/A N/A N/A N/A
225 51400 N/A N/A N/A N/A
226 51400 N/A N/A N/A N/A
227 51400 N/A N/A N/A N/A
228 51400 N/A N/A N/A N/A
229 51400 N/A N/A N/A N/A
230 2740 N/A N/A N/A N/A
231 2741 N/A N/A N/A N/A
232 2738 N/A N/A N/A N/A
233 2739 N/A N/A N/A N/A
234 0 N/A N/A N/A N/A
235 0 N/A N/A N/A N/A
236 0 N/A N/A N/A N/A
237 0 N/A N/A N/A N/A
238 1502 N/A N/A N/A N/A
239 1506 N/A N/A N/A N/A
240 1518 N/A N/A N/A N/A
241 1519 N/A N/A N/A N/A
242 1501 N/A N/A N/A N/A
243 1505 N/A N/A N/A N/A
244 0 N/A N/A N/A N/A
245 0 N/A N/A N/A N/A
246 1504 N/A N/A N/A N/A
247 1503 N/A N/A N/A N/A
248 ERROR: Channel 248 Not Available
249 ERROR: Channel 249 Not Available
250 ERROR: Channel 250 Not Available
251 ERROR: Channel 251 Not Available
252 ERROR: Channel 252 Not Available
253 ERROR: Channel 253 Not Available
254 ERROR: Channel 254 Not Available
255 ERROR: Channel 255 Not Available
;Tuesday 12 June 2018 12:36:10:47835
Group Field 1 Data type Field 2 Data type Field 3 Data type Field 4 Data type
1 12.70 V 12.60 V 12.60 V 0
2 Not Oper. Not Oper. Not Installed Closed
3 Not Installed Not Installed Not Installed Not Oper.
4 Not Installed Not Installed Not Installed Not Oper.
5 Not Installed Not Installed Not Installed Not Installed
6 Door Closed Not Oper. Unlocked Not Safe
7 Door Closed Not Oper. Unlocked Not Safe
8 Door Closed Not Oper. Unlocked Not Safe
9 Door Closed Not Oper. Unlocked Not Safe
10 1111 0 0
11 0 0 0 0
12 Not Installed Not Installed OFF Not Installed
13 Not Installed Not Installed 0 0
14 0.00 km/h 835 /min
15 Not Installed Not Installed 0.000 A 22.0°C
16 Not Installed Not Installed 0 OFF
17 -1.5° Inactive 3.5° Inactive
18 1 1 1 4
19 2 2 2 2
20 Inactive Inactive Inactive 0
21 10 2018:06:10 14:01 h
22 10 2018:06:03 16:30 h
23 10 2018:06:03 15:55 h
24 10 2018:06:03 15:54 h
25 0 0 OFF
26 Not Oper. Lid close Not Connected Not Oper.
27 No ON Not Installed 0
28 10000 0 0 0
29 Not Installed Not Installed Not Installed
30 Not Installed Not Installed Not Installed Not Installed
31 Not Installed Not Installed Not Installed Not Installed
32 Not Installed Not Installed Not Installed Not Installed
33 Not Installed Not Installed Not Installed Not Installed
34 Not Installed Not Installed Not Installed Not Installed
35 Not Installed Not Installed Not Installed Not Installed
36 30.0°C 32 11.1°C 25.5°C
37 Not Installed Not Installed Not Installed Not Installed
38 Not Installed 10000110 0 Not Installed
39 0 0 0 0
41 OFF OFF OFF ON
42 Not Installed 10 Not Installed 0
43 10100100 1010000 0 1
44 0 Not Installed OFF Not Installed
45 ON ON ON
46 Not Installed Not Installed 0 0
47 Not Installed Not Installed Not Installed
50 4 OPEN Unlock 2
51 4 Closed safe 2
52 4 OPEN Unlock 2
53 19 OPEN Unlock 0
54 18 Closed Lock 0
55 2018:06:12 12:20 h
56 2018:06:12 11:51 h
57 2018:06:12 11:43 h
58 2018:06:12 11:42 h
59 2018:06:12 11:26 h
60 0 0 0 0
61 7 0 10000110 10000110
68 Not Installed
73 0 11001 1
74 1100111 10011 0
75 1000001 0 110010 1111100
76 0 0 0 0
77 0 0 0 0
78 155 10 0 0
79 255 255 255 255
80 0 0 0 0
81 0 00000000 00000000 0 0
85 0 0 0 0
86 0x0000 0x0000 0x0000 0x0000
87 0x0000 0x0000 0x0000
88 9 0 0 0
89 00000101 01111100 10000101 10000 0
100 52
101 0 0 0 0
102 0 0 0 0
103 0 0 0 0
104 0 0 0 0
105 0 0 0 0
106 0 0 0 0
107 0 0 0 0
110 Not Installed Not Installed Not Installed Not Installed
111 Not Installed Not Installed Not Installed Not Installed
112 Not Installed Not Installed Not Installed Not Installed
113 Not Installed Not Installed Not Installed Not Installed
114 Not Installed Not Installed Not Installed Not Installed
