Hi guys.. So I'm so tired of my MIB2 is saying there "Parkpilot not active" that I'm actually thinking about retrofitting it.. However since my mk5 is a MY05 I have some doubts about how much I need to change before it'll work?
I've already changed my ABS to the MK60EC1 unit but i'm not sure with my steering? Anyone in here who could clarify if I need to change anything before this will work ?
Here's my autoscan :
Saturday,10,February,2018,12:06:19:31035
VCDS Version: 18.1.0.2 (x64)
VIN: WVWZZZ1KZ5W036030 License Plate:
Chassis Type: 1K-VW35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 55 5F 62 72 7D
VIN: WVWZZZ1KZ5W036030 Mileage: 355100km-220648miles
Address 01: Engine Labels: 03G-906-016-BKD.clb
Part No SW: 03G 906 016 KC HW: 028 101 190 3
Component: R4 2,0L EDC G000SG 8457
Revision: 12345678 Serial number: VWZ7Z0D0121566
Coding: 0000072
Shop #: WSC 00774 204 87198
VCID: 6ED39C4A79EE3E3557-803A
Readiness: 0 0 1 1 1
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 113B400D09250000880B02E790190062310800
Shop #: WSC 12345 678 12345
VCID: 76E3B42AC1BE06F59F-8022
Part No SW: 3AD 907 044 AE HW: 3AD 907 044 AE
Component: Climatronic H03 0808
Revision: 00001K02
Coding: 0000000002
Shop #: WSC 01234 567 56789
ROD: EV_ACClimaBHBVW411_VW36.rod
VCID: 76E3B42AC9BE06F59F-8022
9472881 - Motor for Fresh Air / Recirculated Air Flap
B108B 71 [009] - Actuator stuck
Reset counter: 26
Mileage: 354999 km
Date: 2018.02.05
Time: 18:04:27
9472882 - Motor for Fresh Air / Recirculated Air Flap
B108B 54 [009] - Missing Calibration / Basic Setting
Reset counter: 22
Mileage: 354999 km
Date: 2018.02.05
Time: 18:04:27
13701424 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Fault Frequency: 20
Reset counter: 27
Mileage: 354999 km
Date: 2018.02.05
Time: 18:04:26
9480469 - Control Circuit for A/C Compressor
B10A9 15 [009] - Open or Short to Plus
Reset counter: 22
Mileage: 354999 km
Date: 2018.02.05
Time: 18:04:31
Revision: 00H54000 Serial number: 00000003324221
Coding: EFEB0F0601041800001400001400000000017F035C00002C17C000000000
VCID: 33654D3E524C53DD78-8066
Subsystem 1 - Part No: 1K1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0401
Coding: 00065493
Shop #: WSC 01234
Component: RLS 140712 054 0403
Coding: 00479405
Shop #: WSC 01234
Reset counter: 27
Mileage: 355106 km
Voltage: 11.60 V
00984 - Left Tail Light (M4)
Reset counter: 27
Mileage: 355106 km
Voltage: 11.60 V
00985 - Right Tail Light (M2)
Reset counter: 27
Mileage: 355106 km
Voltage: 11.60 V
Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
Part No SW: 5K0 919 475 E HW: 5K0 919 475 E
Component: PARKHILFE 8K H01 0012
Revision: -------- Serial number: 12561208004496
Coding: 100001
Shop #: WSC 31136 677 00001
VCID: 387F7A128B2AB0854D-806C
Part No SW: 1K0 909 605 D HW: 1K0 909 605 D
Component: 01 AIRBAG VW8 022 0600
Revision: 05022000 Serial number: 0033JD0F8V28
Coding: 0012337
Shop #: WSC 01371 785 00200
VCID: 2D515B46B468052D2E-8078
Subsystem 1 - Serial number: 6332MSME4C4A5203
Subsystem 2 - Serial number: 6342MSME74384E02
Subsystem 3 - Serial number: 6351HSME32087E02
Subsystem 4 - Serial number: 6361HSME4D0B5C02
Part No SW: 1K0 953 549 CH HW: 1K0 953 549 CH
Component: J0527 056 0111
Coding: 0000532
VCID: 7AFBA01A35A66295FB-802E
Subsystem 1 - Part No: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0037
Coding: 00000130
Part No SW: 1K8 920 885 G HW: 1K8 920 885 G
Component: KOMBI H03 1008
Coding: 170F080000
VCID: 3B75651EB21C9B9DA0-806E
Part No SW: 7N0 907 530 AS HW: 7N0 907 530 AN
Component: J533 Gateway H56 1653
Revision: H56 Serial number: 050515F1001937
Coding: 350002
VCID: 0109D7F69870314DBA-8054
Component: IMMO H03 1008
Shop #: WSC 00020 999 00000
VCID: 6ADB905A8D06D2150B-803E
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
Part No: 1K0 959 701 L
Component: Tuer-SG 024 2455
Coding: 0000252
VCID: 377D792E4634BFFD44-8062
Part No: 1K1 909 144 G
Component: EPS_ZFLS Kl.8 1401
VCID: 2F6D414EBE64773D1C-807A
Part No SW: 1K0 959 433 AR HW: 1K0 959 433 AR
Component: 01 KSG PQ35 G2 010 0101
Revision: 00010000 Serial number: 00000000000000
Coding: 989008085103087F00028505E00A0F0660E400
VCID: 000FD2F2537A3845B5-8054
Reset counter: 62
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX2.lbl
Part No: 1K0 959 702 L
Component: Tuer-SG 024 2461
Coding: 0000252
VCID: 387F7A124B2AB0854D-806C
00121 - Outside Warning Light/Door exit Light Passenger Side
00942 - Exterior Mirror Retract Motor; Passenger Side (V122)
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0002
Coding: 0000003
Shop #: WSC 01392 785 00200
VCID: 74E78E2217C214E5A1-8020
Part No SW: 5C0 035 680 C HW: 5C0 035 680 C
Component: MU-S-ND-ER H20 0241
Serial number: VWZAZ2R8769189
Coding: 02731201FF0000000111120100880A001F0106C400200100CF
ROD: EV_MUStd4CTSAT_VW27.rod
VCID: 2149B77630B0D14D9A-8074
Subsystem 1 - Part No SW: 3G0 919 866 AQ HW: -----------
Component: ECE1 2017 --- 0730
6714 - Databus
Reset counter: 22
Mileage: 354999 km
Date: 2018.02.06
Time: 15:35:50
Voltage terminal 30: 13.7 V
7179 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 22
Mileage: 354999 km
Date: 2018.02.06
Time: 15:35:47
Voltage terminal 30: 14.1 V
BAP-BAP_Function_ID: 02
0001 - Antenna 1 for Radio
B1119 13 [009] - Open Circuit
Reset counter: 22
Mileage: 354999 km
Date: 2018.02.06
Time: 15:35:45
Voltage terminal 30: 13.6 V
Status of antenna 1 for radio-Antenna current: 0 mA
Status of antenna 1 for radio-Connection between radio and antenna amplifier: Electrical OK
Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Electrical OK
Status of antenna 1 for radio-Reception level antenna 1: 0 dBµV
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN1.lbl
Part No: 1K0 959 703 C
Component: Tuersteuergeraet 06 0202
Coding: 0000016
VCID: 306F4232A35A68C505-8064
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
Part No: 1K0 959 704 C
Component: Tuersteuergeraet 06 0213
Coding: 0000016
VCID: 31694736A85061CD0A-8064
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 D HW: 1K0 963 235 D
Component: PTC-Element 0404
Revision: 00700000 Serial number:
VCID: 2C5756428F720C2539-8078
End-------------------------(Elapsed Time: 02:13)--------------------------
