rizzy7786
New Member
Hi I am new on here
I have lost my coding for my ABS module and require help please Thanks
VIN: WVWZZZAUZFP043179 License Plate:
Chassis Type: AU (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZFP043179 Mileage: 29544km-18357miles
Address 01: Engine (J623-CXSA) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 016 DE HW: 04E 907 309 A
Component: 1,4l R4 TSI H10 7774
Revision: WAH10---
Coding: 01190032234405082000
Shop #: WSC 00028 028 00314
ASAM Dataset: EV_ECM14TFS01104E906016DE 002006
ROD: EV_ECM14TFS01104E906016DE_VW37.rod
VCID: 68D45946934C360141-803C
17158 - Databus
U1123 00 [047] - Received Error Message
Fault Frequency: 9
Mileage: 29543 km
Date: 2018.06.07
Time: 19:45:23
Coolant temperature: 56 °C
Intake air temperature: 36 °C
Voltage terminal 30: 10.531 V
Mass flow through throttle valve: 0.0 kg/h
4716 - No Communications with Parking Brake Control Module
U0128 00 [047] - -
Mileage: 29543 km
Date: 2018.06.07
Time: 19:45:23
Voltage terminal 30: 10.554 V
CAN status - engine control module-Bit 0: 0
selected gear-Bit 0: 0
Readiness: 0010 0001
Part No SW: 3Q0 907 379 F HW: 3Q0 907 379 F
Component: ESC H42 0609
Revision: 00000000 Serial number: 62984000002943
Shop #: WSC 00028 028 00067
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034027
VCID: 3D7AD812AC4E43A9C2-8068
12 Faults Found:
0195 - Control module not coded
U1013 00 [137] - -
Reset counter: 36
Mileage: 29543 km
Date: 2018.06.07
Time: 20:39:35
0212 - Longitudinal Acceleration Sensor
C1017 54 [137] - Missing Calibration / Basic Setting
Reset counter: 36
Mileage: 29543 km
Date: 2018.06.07
Time: 20:39:35
0270 - Lateral Acceleration Sensor
C1079 54 [137] - Missing Calibration / Basic Setting
Reset counter: 36
Mileage: 29543 km
Date: 2018.06.07
Time: 20:39:35
0279 - Brake Pressure Sensor 1
C107A 54 [137] - Missing Calibration / Basic Setting
Reset counter: 36
Mileage: 29543 km
Date: 2018.06.07
Time: 20:39:35
0295 - Steering angle sensor
Reset counter: 36
Mileage: 29543 km
Date: 2018.06.07
Time: 20:39:35
0398 - Control Module Incorrectly Coded
U1014 00 [009] - -
Reset counter: 36
Mileage: 29543 km
Date: 2018.06.07
Time: 20:39:56
4161 - Coding invalid
U10DA 00 [008] - -
Reset counter: 77
Mileage: 29544 km
Date: 2018.06.08
Time: 01:38:22
8278 - Control Module Incorrectly Coded
U1014 00 [137] - -
Reset counter: 37
Mileage: 29543 km
Date: 2018.06.07
Time: 20:39:35
8306 - Databus
U1122 00 [137] - Implausible Message
Reset counter: 36
Mileage: 29543 km
Date: 2018.06.07
Time: 20:39:37
8308 - Control Module Incorrectly Coded
U1014 00 [008] - -
Reset counter: 77
Mileage: 29543 km
Date: 2018.06.07
Time: 20:58:48
8314 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [009] - -
Reset counter: 37
Mileage: 29543 km
Date: 2018.06.07
Time: 20:39:35
32848 - Control Module for Electric Parking Brake
C10E2 F1 [137] - Switches/Motors Detected
Reset counter: 36
Mileage: 29543 km
Date: 2018.06.07
Time: 20:39:35
Address 08: Auto HVAC (J301) Labels: 5G0-907-426.clb
Part No SW: 5G0 907 426 T HW: 5G0 907 426 T
Component: AC Manuell H02 1001
Revision: 00001K06
Coding: 00120004200100001000000000000000
ROD: EV_ACManueBHBVW37X_SK48.rod
VCID: 3C7CD516B7544AA1F5-8068
7 Faults Found:
459525 - Databus
Reset counter: 62
Mileage: 29486 km
Date: 2017.09.22
Time: 09:20:05
459023 - Databus
Reset counter: 62
Mileage: 29486 km
Date: 2017.09.22
Time: 09:20:04
590082 - Control Circuit for A/C Compressor
B10A9 15 [008] - Open or Short to Plus
Reset counter: 62
Mileage: 29486 km
Date: 2017.09.22
Time: 09:20:10
Outside air temperature: -27.0 °C
Engine speed: 0 /min
Compressor shut-off requirement: Outside air temperature too low
Compressor current: actual value: 0.125 A
Compressor current: specified value: 0.000 A
262658 - High Pressure Sensor
B10AE 31 [009] - No Signal
Reset counter: 22
Mileage: 29486 km
Date: 2017.09.22
Time: 09:20:05
Outside air temperature: -23.5 °C
Compressor current: actual value: 0.130 A
Temperature after evaporator: 6.0 °C
System run time-Terminal 15 on: 241 s
459527 - Databus
Reset counter: 70
Mileage: 29486 km
Date: 2017.09.22
Time: 09:20:12
B10CD 00 [008] - -
Fault Frequency: 21
Reset counter: 75
Mileage: 29486 km
Date: 2017.09.22
Time: 10:41:14
Voltage terminal 30: 10.7 V
CAN input signal(s) status-Windshield wiper: On
1048839 - Function limitation due to crash signal
B1397 00 [008] - -
Reset counter: 62
Mileage: 29486 km
Date: 2017.09.22
Time: 09:20:24
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 AG HW: 5Q0 937 084 AG
Component: BCM MQBAB M H18 0137
Serial number: 01011428601722
Coding: 03000842C241027B0BA44080B10403281000000000000000000000000000
ROD: EV_BCMBOSCH_013.rod
VCID: 7DFA1812ECCE83A982-8028
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 141013 042 0551
Serial number: 141015134240
Subsystem 2 - Part No SW: 5Q0 955 559 A HW: 5Q0 955 559 A Labels: 5Q0-955-547.CLB
Component: RLS 037 0059
Serial number: S2Y14M10D16H18M37S38
Coding: 00A8DD
Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY14258395E
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000060847593
12307 - License Plate Light
B12CA 01 [008] - Electrical Failure
Reset counter: 77
Mileage: 29534 km
Date: 2018.06.06
Time: 19:55:29
131330 - Supply voltage
Reset counter: 75
Mileage: 29543 km
Date: 2018.06.07
Time: 20:15:18
204290 - Remote key 1
B1479 18 [009] - Current Too Low
Reset counter: 34
Mileage: 29537 km
Date: 2018.06.06
Time: 20:18:32
