Been working on a Matrix LED retrofit. I'm at a pretty decent point, the hardest part was getting the modules flashed but VCP was finally able to do that eventually.
I think I'm pretty much to the point of getting the Matrix LED's calibrated so that the high beams will begin to work. Here's my auto scan of the vehicle.
Anyone know the possibility of how to put in calibration parameters? I was trying the basic headlamp settings in the in Central Electronics but that just says "not running" and I never receive any form of prompts. Looking at Elsa, it seems like that should be kind of the direction you need to go.
There was also these in A5, but any thing i clicked here related to Matrix says "Error: Service not supported in active session"
Then I also clicked start calibration mode and now my lane assist and stuff is all faulting. I saw another thread on here where someone had to go to the dealership to get that reset. Wasn't sure if it was the full calibration or not.
I'm also not sure on the error about the Image processing control module. I read a thread about that and someone said that it eventually just went away, but I'm not seeing that.
Anyways this is where I stand. The low beams, DRLS, and sweeping turns all work correctly. The coding that I have currently is a mix between what my factory coding is and from an actual B9 with Matrix lights.
Thursday,07,June,2018,16:35:27:30225
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64(Parallels)
VCDS Version 18.2.1.2 (x64) HEX-NET CB: 0.4411.4
VIN: WA19NAF4XHA148620 License Plate:
Mileage: 33786km-20993mi Repair Order:
Chassis Type: F4-AU49 (8W8)
Scan: 01 02 03 08 09 13 15 16 17 19 22 29 36 39 3C 42 44 46 47 52
5F 6C 6D 74 81 82 8B A5 BB BC CA CF D6 D7
VIN: WA19NAF4XHA148620 Mileage: 33786km-20993miles
CA-Sunroof -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: Malfunction 0010
D7-Light Ctrl Right 2 -- Status: Malfunction 0010
Address 01: Engine (J623-CYMC) Labels: None
Part No SW: 8W0 906 259 J HW: 06L 907 425 C
Component: 2.0l R4 TFSI H15 0002
Revision: --H15---
Coding: 326500322366010E34280000000000000000000000000000
Shop #: WSC 06314 790 00001
ASAM Dataset: EV_ECM20TFS0208W0906259J 001003
ROD: EV_ECM20TFS020_AU49.rod
VCID: 48DCAACFF3C5EA04AF-801D
Readiness: 1010 0101
Address 02: Auto Trans (J217) Labels:* None
Part No SW: 80A 927 155 J HW: 0CJ 927 156
Component: 0CJ 20TFSINAR H03 0002
Revision: --H03--- Serial number: 0000001745
Coding: 000001
ASAM Dataset: EV_TCMDL382021 002024
ROD: EV_TCMDL382021_AU48.rod
VCID: 302CE22F6B5542C497-8065
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 K
Component: V553 MTFP 002 0572
Serial number: 75117071170049002168
Address 03: ABS Brakes (J104) Labels:. 8W0-907-379-PRE-V1.clb
Part No SW: 8W0 907 379 H HW: 8W0 907 379 D
Component: ESP9 Premium H09 0719
Coding: 18AA409928A62A9E91A44893207D52A2E6259A180214548912044A4567A459
Shop #: WSC 06334 790 00001
ASAM Dataset: EV_ESP9BOSCHCMP 001001
ROD: EV_ESP9BOSCHCMP_001.rod
VCID: 4AD890C7EDC91814B9-801F
200960 - Databus
U1123 00 [047] - Received Error Message
[Signal_LWR_Hoehenwert_VL_error_(255)]
Mileage: 33754 km
Date: 2018.06.07
Time: 11:53:50
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 8W0 820 043 H HW: 8W0 820 043 H
Component: Klima Zone 3 H32 0090
Coding: 240809085548010D10020100880000000000000000000000000000000000
Shop #: WSC 06335 790 00001
ROD: EV_AirCondiBHTCAU491.rod
VCID: 383CDA0F83259A84DF-806D
Subsystem 1 - Part No SW: 4M1 820 021 A HW: 4M1 820 021 A
Component: J216 FLuftV H08 0003
Serial number: 00000000000001381981
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H01 0006
Serial number: 9379C59880PAG0MUFU02
Subsystem 3 - Part No SW: 8W0 919 158 A HW: 8W0 919 158 A
Component: E265 Kli Fond H40 0080
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0267
Coding: 07500B63C13900CD051751195CAF98B9110B3D080000000000000000200016810A45022B025709
Shop #: WSC 12345 123 61029
VCID: 024878E79579005431-8057
Subsystem 1 - Part No SW: 8W1 955 119 HW: 8V1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS491 170201 043 0813
Serial number: 89435300301703200408
Coding: 5BC7F7
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Serial number: 20296446X81A955555A0
Coding: 02005D
Light switch:
Subsystem 3 - Part No SW: 4M0 941 531 AB HW: 4M0 941 531 AB
Component: E1 - LDS H06 0008
Serial number: 04 07 2016 00695960
Subsystem 4 - Part No SW: 4M0 907 410 A HW: 4M0 907 410 A
Component: USHL5 H04 0050
Serial number: 0000009600335Z32Z002
Coding: 350000
Subsystem 5 - Part No SW: 4M0 959 719 A HW: 4M0 959 719 A
Component: GTO BF H01 0010
Serial number: 20170221114259 00510
Subsystem 6 - Part No SW: 8W0 857 511 B HW: 8W0 857 511 B
Component: Y7_Innenspieg H01 0002
Serial number: GX1CE103011711520689
Coding: 030000
Interior Light Module:
Subsystem 7 - Part No SW: 8W0 947 135 CS HW: 8W0 947 135
Component: J528-Dachele H14 0130
Serial number: B00288587
Subsystem 8 - Part No SW: 8W0 925 301 BD HW: 8W0 925 301 BD
Component: SL-B9/Q5NF H17 0010
Serial number: 2616000199313006
Subsystem 9 - Part No SW: 4M0 963 575 HW: 4M0 963 575
Component: V512 LLR1SLvL H03 0012
Serial number: L14DG36200481
Subsystem 10 - Part No SW: 4M0 963 575 HW: 4M0 963 575
Component: V514 LLR1SKvL H03 0012
Serial number: L14DG36200261
Subsystem 11 - Part No SW: 4M0 963 575 HW: 4M0 963 575
Component: V516 LLR1SLvR H03 0012
Serial number: L14DG36201118
Subsystem 12 - Part No SW: 4M0 963 575 HW: 4M0 963 575
Component: V518 LLR1SKvR H03 0012
Serial number: L14DG36200312
6 Faults Found:
66707 - Image processing control module
U1079 00 [009] - No communication
Reset counter: 145
Mileage: 33754 km
Date: 2018.06.07
Time: 11:53:54
average_Voltage_terminals: 14.30 V
Outside air temperature sensor-Resistance: 0.00 kOhm
Outside air temperature sensor-Outside air temperature on CAN: 28.00 °C
interior_temperature: 33.50 °C
Vehicle speed: 0.00 km/h
66881 - Databus
[Left LED headlamp power output module: incorrect data record]
Reset counter: 184
Mileage: 33754 km
Date: 2018.06.07
Time: 11:53:51
66882 - Databus
[Right LED headlamp power output module: incorrect data record]
Reset counter: 184
Mileage: 33754 km
Date: 2018.06.07
Time: 11:53:51
67735 - Databus
[MxB not available]
Reset counter: 144
Mileage: 33754 km
Date: 2018.06.07
Time: 11:53:51
131955 - Unknown Error Code
U134F 00 [009] - -
[EFP control module: implausible message in signal FA_height-value_FL_00]
Reset counter: 144
Mileage: 33754 km
Date: 2018.06.07
Time: 11:53:51
131956 - Unknown Error Code
U134F 00 [009] - -
[EFP control module: implausible message in signal FA_height-value_RL_00]
Reset counter: 144
Mileage: 33754 km
Date: 2018.06.07
Time: 11:53:51
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 8W0 907 561 B HW: 8W0 907 561
Component: LRR4 H10 0220
Coding: B4779FF258FFEC09949880A1
ASAM Dataset: EV_ACCBOSCHAU49X 002018
ROD: EV_ACCBOSCHAU49X_002.rod
VCID: 3D32CB1BAC07BFAC0C-8069
2153 - Databus
[FAULT_HC_STA_FAIL]
Reset counter: 144
Mileage: 33757 km
Date: 2018.06.07
Time: 12:15:17
Control Module temperature: 59 °C
Voltage terminal 15: 13.0 V
Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
Part No SW: 8W0 959 655 G HW: 8W0 959 655 G
Component: Airbag10.44 H05 0104
Serial number: 003UQ000JGX+
Coding: BFCCF0C000800000A0000033D24C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 005015
ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
VCID: 4DD29BDB1CA70F2C9C-8019
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 B HW: 4M0 980 945 B
Component: BeltPretRevFL 306 2033
Serial number: 8W0857705C0062R01681
Coding: 80000D
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 B HW: 4M0 980 946 B
Component: BeltPretRevFR 306 2033
Serial number: 8W0857706D0067R00315
Coding: 80000D
Occupant Detection:
Subsystem 3 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H11 0022
Serial number: IBH0000J170006UDPJ0.
Subsystem 4 - Part No SW: ----------- HW: 442 060 303 17
Serial number: 3577Y00C1209FF449389
Subsystem 5 - Part No SW: ----------- HW: 442 060 303 17
Serial number: 3587Y00B31FD7524C39D
Subsystem 6 - Part No SW: ----------- HW: 442 0B1 502 17
Component: SideSensor_Dr 1C7 0148
Serial number: 3517700222A53DB9A82E
Subsystem 7 - Part No SW: ----------- HW: 442 0B1 502 17
Serial number: 3527700142A53DB8F8CU
Subsystem 8 - Part No SW: ----------- HW: 442 0C0 903 17
Component: FrontSensor_D 1C5 014A
Serial number: 3557500C121E5F93515C
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 442 0C0 903 17
Component: FrontSensor_P 1C5 014A
Serial number: 3567500C921E5F95142J
Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
Part No SW: 4M0 907 129 GS HW: 4M0 907 129 GS
Component: Lenks.Modul H11 0009
ROD: EV_SMLSKLOAU736_006.rod
VCID: 075E69F3BE5B257C66-8053
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8W5 920 890 C HW: 8W5 920 890 C
Component: FBenUSA H17 0309
Coding: 08CF99C3FC89CF0502A769601804400008000000
ASAM Dataset: EV_DashBoardAU736 001022
VCID: 43C6BDE3CAE3C95C7A-8017
16777046 - Charger for HV Battery
U1139 00 [009] - No Communications
[BAP_BatteryControl_0x25 communication error bap_error_timeout heartbeat]
Fault Frequency: 47
Reset counter: 145
Mileage: 33754 km
Date: 2018.06.07
Time: 11:53:49
Part No SW: 8W8 907 468 D HW: 8W8 907 468 D
Component: Gateway H30 0308
Revision: 5D010003 Serial number: 0385D281717309
Coding: 03010001000006402907000000590030DCB20007000000000175078E10000000
ASAM Dataset: EV_CGateCONTIAU491 002040
ROD: EV_CGateCONTIAU491_002_AU49.rod
Subsystem 1 - Part No SW: 4M0 951 523 A HW: 4M0 951 523 A
Component: J453 MFL H06 0002
Serial number: 20170302233716 02696
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 6936703304
Address 22: AWD (J492) Labels:* None
Part No SW: 8W9 927 755 HW: 0CJ 927 749
Component: B9_DL3_H_SD5 H01 0004
Serial number: 1625815576
Coding: 11040000
ASAM Dataset: EV_AWDCQUOD31 001048
ROD: EV_AWDCQUOD31.rod
VCID: 0B5655C3A233411C42-805F
Address 29: Left Light (J1018) Labels: 4M0-907-397.clb
Part No SW: 4M0 907 397 AD HW: 4M0 907 397 D
Component: LCM_MLBevoH05 0022
ASAM Dataset: EV_LCMLeftHELLAAU736 001011
VCID: 79BA1F0BF8AF438C60-802D
Address 36: Seat Mem. Drvr (J136) Labels:* None
Part No SW: 4M1 959 760 HW: 4M1 959 760
Component: MEM-FS 008 0031
Serial number: 00000246014727
Coding: 005C1B000000B0010000010101010000000000000000000000000000000000
ROD: EV_SCMDriveSideCONTIAU736.rod
VCID: 76A01437C9B12CF40D-8023
Address 39: Right Light (J1023) Labels: 4M0-907-397.clb
ASAM Dataset: EV_LCMRightHELLAAU736 001011
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4M0 907 566 D HW: 4M0 907 566
Component: MRR1Rear H18 0410
Revision: --------
Coding: 0EC002
ASAM Dataset: EV_RearRadarS1BoschAU736 001022
ROD: EV_RearRadarS1BoschAU736.rod
VCID: 3620D43789316CF4CD-8063
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 4M0 959 793 E HW: 4M0 959 793 C
Component: TSG FS 009 0057
Serial number: 0000245151150
Coding: 005D1B215E001080000100B2
ROD: EV_DCU2DriveSideMAXHCONT.rod
VCID: 40CCB2EFDBF5D24467-8015
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 8W0 909 144 G HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0409
Coding: 0D008380008080
ASAM Dataset: EV_EPSZFAU49X 003018
ROD: EV_EPSZFAU49X_003.rod
VCID: 41CAB7EBD0FFDB4C68-8015
Address 46: Central Conv. (J393) Labels:* None
Part No SW: 8W0 907 064 CC HW: 8W0 907 064 C
Component: BCM2 MLBevo 018 0344
Coding: 013400004F9100C0630BA0006E01080233004000014727502F0400000F04803F001F0001000000
ASAM Dataset: EV_BCM2HellaAU736 012013
ROD: EV_BCM2HellaAU736_012_AU49.rod
VCID: 7F4EF113E68B6DBC5E-802B
Subsystem 1 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY170381JFK
Subsystem 2 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000068897909
Subsystem 3 - Part No SW: 3AA 962 243 H HW: 3AA 962 243 H
Component: GEB.F.Heckoef H16 0904
Serial number: >1056806
Address 47: Sound System (J525) Labels:* None
Part No SW: 8W0 035 465 HW: 8W0 035 465
Component: MIB2_amp_P_B9 H11 0420
Revision: 00000001 Serial number: AUZ8ZAGJA01C0U1
Coding: 0194420800AFAAAFAA0000010000
ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
ROD: EV_AMPMst16C2Gen2ALPI.rod
Part No SW: 4M0 959 792 E HW: 4M0 959 792 C
Component: TSG BFS 009 0057
Serial number: 0000245521922
Coding: 005D1B215E001080000100B0
ROD: EV_DCU2PasseSideMAXHCONT.rod
VCID: 3FCEB113A60BADBC1E-806B
Address 5F: Information Electr. (J794) Labels:* 8W0-035-MIB-HGH2.clb
Part No SW: 8W5 035 880 HW: 8W5 035 880
Component: MU-P-LNS-US 033 0918
Serial number: A798C0HB017395
Coding: 019442020000000053220002041A00102F000CE501700904BE
ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
VCID: 7CB4061FF79D76A47B-8029
Subsystem 1 - Part No SW: V03 959 801 PS HW: -----------
Component: NAR 2018 --- 0063
Subsystem 2 - Part No SW: 8W1 919 605 HW: 8W1 919 605
Component: DU High AU49x H32 0160
Serial number: TPO00109011700820240
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8W0 919 614 T HW: 8W0 919 614 T
Component: ControlUnit_H H30 0206
Serial number: APVAK113021700040027
Component: Gracenote2 --- 3011
B11CF 53 [009] - Deactivated
Reset counter: 144
Mileage: 33757 km
Date: 2018.06.07
Time: 15:36:00
Voltage terminal 30: 12.4 V
Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4M0 907 428 E HW: 4M0 907 428
Component: Areaview 2 H13 0315
Serial number: C854607JG013564
Coding: 02940202BA0FA10008404000
ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
VCID: 3424EE3F9F4D7EE4F3-8061
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 4M0 959 107 B HW: 4M0 959 107 A
Component: HDSG-Modul H13 0161
Revision: -------- Serial number: 31242474100000
Coding: 0570
ROD: EV_DeckLidCONTIAU736_AU49.rod
VCID: 3228E827655970D4E1-8067
Address 74: Chassis Control (J775) Labels:* None
Part No SW: 8W0 907 777 H HW: 8W0 907 777 C
Component: Fahrwerk-SG H35 1214
Serial number: 1003170095
Coding: 1051506118
ASAM Dataset: EV_ChassContrContiAU426 001003
ROD: EV_ChassContrContiAU426.rod
VCID: 4CD496DFE7BD06248B-8019
Address 81: Gear Shift (J587) Labels: None
Part No SW: 8W1 713 041 L HW: 8W1 713 041 J
Component: GSM-LL H09 0073
Revision: 0L0D5012 Serial number: 20170303002311
ROD: EV_GSMWaehlZFAU736_AU49.rod
VCID: 3C34C61FB71DB6A43B-8069
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 8W5 919 617 B HW: 8W5 919 617 B
Component: HeadUpDisplay H17 1603
Coding: 4F01E0
ASAM Dataset: EV_HudNSEIKAU736 001015
ROD: EV_HudNSEIKAU736_AU49.rod
VCID: 47DEA9F3FEDBE57CA6-8013
Address 8B: Adaptive Cruise 2 (J850) Labels: None
Part No SW: 8W0 907 541 B HW: 8W0 907 541
ASAM Dataset: EV_ACC2BOSCHAU49X 002018
ROD: EV_ACC2BOSCHAU736_002_AU73.rod
VCID: 3B36C503B213B19C32-806F
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 8W0 907 217 B HW: 8W0 907 217
Component: BVS H15 0042
Coding: 0404090200000202022023A6AD0000FCB0F0C023E280
ROD: EV_BVSMLBevKOSTAAU736.rod
1122640 - Databus
[TIMEOUT_SARA_08]
Reset counter: 145
Mileage: 33757 km
Date: 2018.06.07
Time: 12:23:26
Control Module temperature: 69 °C
Voltage terminal 15: 13.20 V
13679104 - Databus Front Lights
U1504 00 [009] - No Communications
[AFS_CAN_no_communication]
Reset counter: 144
Mileage: 33757 km
Date: 2018.06.07
Time: 12:23:26
1123669 - Left Matrix High Beam
C1175 54 [009] - Missing Calibration / Basic Setting
Reset counter: 144
Mileage: 33757 km
Date: 2018.06.07
Time: 12:23:25
Control Module temperature: 68 °C
1123670 - Right Matrix High Beam
C1176 54 [009] - Missing Calibration / Basic Setting
Reset counter: 144
Mileage: 33757 km
Date: 2018.06.07
Time: 12:23:25
0660 - No Basic Setting
B2010 00 [009] - -
[Initial_calibration_missing]
Reset counter: 144
Mileage: 33757 km
Date: 2018.06.07
Time: 12:23:25
Voltage terminal 15: 13.10 V
Part No SW: 4M0 959 795 E HW: 4M0 959 795 C
Component: TSG HFS 009 0057
Serial number: 0000246569818
Coding: 000D1B2000001080400000A0
ROD: EV_DCU2RearDriveMAXHCONT.rod
VCID: 42C8B8E7D5F9C05471-8017
Component: TSG HBFS 009 0057
Serial number: 0000245539627
ROD: EV_DCU2RearPasseMAXHCONT.rod
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4M0 907 594 HW: 4M0 907 594
Component: SAD_STG_1 011 0003
Coding: 208000049202
ASAM Dataset: EV_SunRoofCONTIAU736 004008
ROD: EV_SunRoofCONTIAU736_004.rod
VCID: 73A62D23DAC339DC2A-8027
Address CF: Lane Chge Asst 2 (J770) Labels: None
Part No SW: 4M0 907 590 D HW: 4M0 907 590
Revision: --------
Coding: 0EC002
ASAM Dataset: EV_RearRadarS2BoschAU736 001022
ROD: EV_RearRadarS2BoschAU736.rod
VCID: 3326ED239A4379DCEA-8067
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 7PP 941 571 BB HW: 7PP 941 571 B
Component: LED1L H09 0003
VCID: 166034B7E9F18CF4ED-8043
0019 - Headlamp Type
C119F 00 [008] - Implausible
Reset counter: 184
Mileage: 33754 km
Date: 2018.06.07
Time: 11:53:49
0304 - Databus
[can message MXB_Soll_Fktx missing]
Reset counter: 144
Mileage: 33754 km
Date: 2018.06.07
Time: 11:53:49
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H09 0003
Reset counter: 184
Mileage: 33754 km
Date: 2018.06.07
Time: 11:53:49
0304 - Databus
Reset counter: 144
Mileage: 33754 km
Date: 2018.06.07
Time: 11:53:49
End----------(Elapsed Time: 02:25, VBatt start/end: 12.3V/12.3V)-----------
