Code out electronic dampning control 2014 Audi RS7
gillmotorsports
C?ID=210708
We removed DRC we are trying to code out the electronic dampning control
We removed it from gateway module
We coded instrument cluster
We unplugged drc module
We are still getting warning on dashboard "suspension electronic failure"
We identified there is a fault is in ABS that we can not make go away that we believe is causing the warning light.
When we go into coding ABS it directs us to contact Rosstech to code
I can provide full auto scan.
gillmotorsports
C?ID=210708
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 1B 22 28 36 3B 3C 42 44 46
          47 52 53 55 56 5F 62 65 6C 6D 72 8F 90 BA
VIN: WUAW2AFC4EN904345   Mileage: 85119km-52890miles
BA-Motor Mounts -- Status: Malfunction 0010
Address 01: Engine (------CRDB)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 906 560 B    HW: 4H0 906 014
   Component: 4.0l V8TFSI / H62 0008
   Revision: NCH62---
   Coding: 1A2A003265260A0E1000
   Shop #: WSC 11686 002 1048576
   ASAM Dataset: EV_ECM40TFS0114G0906560B 001008
   ROD: EV_ECM40TFS0114G0906560B.rod
   VCID: 275D91025E520A7C46-8072
          U1113 00 [032] - -
          U1113 00 [032] - -
   Part No SW: 4G0 927 158 BE    HW: 0BK 927 156 AM
   Component: 0BK 40TFSIUSA H16 1006
   Revision: --H16---
   Coding: 000001
   VCID: 72EBB056A5103FD421-8026
   Part No SW: 4G0 907 379 P    HW: 4G0 907 379 P
   Component: ESP PREMIUM   H09 0100
   Coding: 63BF1103C6FD88C04B00
   ASAM Dataset: EV_ESPPremiAU57X 004036
   VCID: 3E735466A1C8ABB415-806A
1792 - No Communcation  with Control Module for Electronic Suspension Damping
          U0139 00 [009] - -
                    Reset counter: 115
                    Mileage: 85111 km
                    Date: 2018.06.05
                    Time: 12:48:21
                    VzRef: 00
                    Bit Info 1: 80
                    Bit Info 2: 4F
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: B3
                    Uz: 9B
   Part No SW: 4H0 907 064 ER    HW: 4H0 907 064 ER
   Component: BCM2 2.0      H36 0521
   Coding: 0D8A2046000000000000
   VCID: 7DF1936AE44E70AC4C-8028
   Serial number: 0214000033696003
   Part No SW: 4G0 820 043 AM    HW: 4G0 820 043 AM
   Component: KLIMA 4 ZONEN H14 0093
   Serial number: 14031400040374
   Coding: 6803207849
   ASAM Dataset: EV_AirCondiComfoUDS 004003
   ROD: EV_AirCondiComfoUDS_004.rod
   VCID: 6ADBA8368DC0F71499-803E
   Revision: 11012002    Serial number: 00000001716271
   Coding: 0D072015073E9FF0B10008C7A0003820CF9CD308A2090221800308457B00
   VCID: 6FEDB922BE22123CCE-803A
   Component: WWS57X 140228  H37 0080
   Serial number:         140308190628
   Coding: 0045F7
   Serial number: 22371434
   Coding: 02006E
   Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
   Component: E1 - LDS  H07 0044
   Serial number: 17 03 2014  00001278
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555RAQK803
   Subsystem 5 - Part No SW: 4G0 907 472     HW: 4G0 907 472
   Component: A31 LED Mod1L  H02 0002
   Serial number: 00000000001402114097
   Subsystem 6 - Part No SW: 4G0 907 472     HW: 4G0 907 472
   Component: A27 LED Mod1R  H02 0002
   Serial number: 00000000001401251355
   Subsystem 7 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA107529000006290952
   Coding: 020300
   Serial number: 7D288C17000000000001
   Subsystem 9 - Part No SW: 4G0 907 472 A    HW: 4G0 907 472 A
   Component: A32 LED Mod2L  H02 0002
   Serial number: 00000000001403101782
   Subsystem 10 - Part No SW: 4G0 907 472 A    HW: 4G0 907 472 A
   Component: A28 LED Mod2R  H02 0002
   Serial number: 00000000001402203379
   Part No SW: 4H0 919 475 AC    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0091
   Revision: 11001001    Serial number: 61061407200240
   Coding: A8C119
   VCID: 73E5B552DA0A36DC2A-8026
Address 15: Airbags (J234)       Labels:| 4H0-959-655.clb
   Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
   Component: Airbag10.43   H33 0033
   Revision: --------    Serial number: 003D8003YUW.
   Coding: 303145313131303030314A55304C34473853
   VCID: 336575529A8A76DCEA-8066
   Serial number: 6940000Y1400011ET90Q
   Serial number: 3575HRB40552DJEQ5PJ/
   Serial number: 3585HRB40512BDFS98UU
   Serial number: 3515JRB401050U80EP7-
   Serial number: 3525JRB400O50U80O1QM
   Serial number: 3554VRB400U50UJELGHR
   Serial number: 3564VRB404P2EBL4K0BV
   Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
   Revision: --------    Serial number: 90372NCC000RU
   Coding: 000034
   VCID: 377D414286F29AFCD6-8062
   Serial number: 31 01 2014  C0424096
   Part No SW: 4G8 920 984 E    HW: 4G8 920 984 E
   Component: TBenUsa   Nv  H58 0621
   Revision: 29460235    Serial number: 658040314596054
   Coding: 03EF010CABC3D705020500
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K.rod
   VCID: 387F427E83EC9584DF-806C
16776966 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 116
                    Mileage: 85119 km
                    Date: 2018.06.05
                    Time: 13:18:26
   Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
   Revision: --------    Serial number: 00000001315823
   Coding: 00E1034800
   Serial number: 3239232803
   Part No SW: 8K0 907 144 M    HW: 8K0 907 144 M
   Component: DYNAMIKLENK.  H06 0730
   VCID: 3979477AB0E68C8C20-806C
Address 22: AWD (J492)       Labels: 4H0-907-163.clb
   Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H16 0200
   Serial number: 001003140001107
   ASAM Dataset: EV_AllWheelDiffeQSPFR 003026
   VCID: 285F923E534C05044F-807C
0333 - Oil Pressure and Temperature Sensor
          C1004 F0 [008] - Oil Pressure Implausible
                    Reset counter: 47
                    Mileage: 79721 km
                    Date: 2017.12.28
                    Time: 17:01:44
0377 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 48
                    Mileage: 82741 km
                    Date: 2018.04.14
                    Time: 12:20:09
Address 28: HVAC, Rear (E265)       Labels:| 4G0-919-158.clb
   Part No SW: 4G0 919 158 M    HW: 4G0 919 158 M
   Component: KLIMA FOND    H08 0093
   Serial number: 15031400040050
   Coding: 20
   ASAM Dataset: EV_ClimaContrUnitRearUDS 004002
   VCID: 3979477AB8E68C8C20-806C
   Revision: AA000000    Serial number: 00000092681957
   Coding: 00581B0000002001000001010101102030303232203232
   VCID: 77FD8142C6725AFC16-8022
   Component: SARA 6D red   H03 0056
   Revision: --------    Serial number: EJ1BPA7E00WPSE
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 377D41428EF29AFCD6-8062
   Part No SW: 4G0 907 566 L    HW: 4G0 907 566
   Component: J769  SWA MasterH04 0010
   Revision: 00H04000    Serial number: 6PZ 010 287-10
   Coding: 0000006
   VCID: 387F427E4BEC9584DF-806C
   Subsystem 1 - Part No: 4G0 907 568 L
   Component: J770  SWA Slave H04 0010
   Subsystem 2 - Serial number: 6PZ 010 287-30
   Subsystem 3 - Serial number: 5F18.02.1400H04000AMS14564ÿ
   Subsystem 4 - Serial number: S14564ÿ
   Coding: 011F57025E00628002000412
   VCID: 479D3182F612EA7CA6-8012
   Component: RCEPS         H40 0010
   Revision: 00001000    Serial number: 0001352075
   Coding: 011000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 326B705665907FD4E1-8066
   Revision: 00002001    Serial number: 0329601111
   Coding: 0126023A20FAF08580B00A80020114000000000000000000000000000000
   Component: GTO BF  H01 0081
   Serial number: 00000000000000209300
   Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
   Component: J245 PS40.039  H01 0008
   Serial number:     WOO27821251
   Coding: 101F00
   Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
   Serial number: 0000000AP00006376839
   Subsystem 5 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H11 0029
   Serial number: WA107669000006534821
02616 - Fuel Tank Cap; Unlock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 114
                    Mileage: 85103 km
                    Date: 2018.06.03
                    Time: 10:11:31
   Part No SW: 4G0 035 465 C    HW: 4G0 035 465 B
   Component: BO G3 C7      H09 0160
   Revision: 11000000    Serial number: 0019317
   VCID: 25419B0A2C5E186C74-8070
   Subsystem 1 - Part No SW: 4G0 035 466     HW: 4G0 035 466
   Component: BO C7 SLAVE  H51 0100
   Serial number: 02201140026679
   Coding: 011F57025E00628002000402
   VCID: 46833C86F118F3745D-8012
   Component: EPB-4         H03 0015
   Revision: --------    Serial number: 00000000998089
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D51632A7CAE202CBC-8078
   Serial number: 140317-0002-106
   Coding: 1223A6601002B400
   ROD: EV_HeadlRegulBasic.rod
   Component: Radio U SIRIU H60 0133
   Revision: AB001007    Serial number: 156C00E7982219
   Coding: 020007010000000001
   VCID: 2447860E2764E16463-8070
   Part No SW: 4G0 035 746 F    HW: 4G0 035 746 E
   Component: H-BNT-NA      H41 0757
   Revision: --------    Serial number: 194C+0E7604890
   Coding: 0B0200040303E1EF55128F3E00000003100001000000000000
   VCID: 2A5B68364540371459-807E
   Subsystem 1 - Part No: 8R0 060 884 BL
   Component: NAR 2014  0902
   Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
   Component: DU8 C7 SV  H43 0021
   Serial number: AUZ8ZDDD003SDK6
   Subsystem 3 - Part No SW: 4G1 919 612 Q    HW: 4G1 919 612 Q
   Serial number: 90349NCD000WK
   Component: CD-Database  5571
02067 - Optical Databus; Unpermitted Wake-Up Request
            000 -  -  - Intermittent
                    Reset counter: 136
                    Mileage: 84722 km
                    Date: 2018.05.14
                    Time: 19:17:25
                    Voltage: 12.40 V
   Coding: 010F17024000628002000002
   VCID: 499937BAE0061C0CB0-801C
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 4H0 907 273     HW: 4H0 907 273
   Component: RDKBERU25     H09 0700
   Serial number: 10000000007638
   ROD: EV_RDKBERU25_AU57.rod
   VCID: 68DFD23E93CCC5048F-803C
8392961 - TPMS Transceiver in Front Left Wheel Well
          C104C 01 [008] - Electrical Failure
                    Reset counter: 124
                    Mileage: 84494 km
                    Date: 2018.05.04
                    Time: 21:18:32
   Revision: --H08---    Serial number: 525 PA8J42G9BP
   Coding: 1081013
   VCID: 26439C06915813747D-8072
   Part No SW: 4G8 959 107 R    HW: 4G8 959 107 G
   Component: HDSG-Modul    H13 0043
   Revision: 12013001    Serial number: 038400185
   Coding: 0A3305C102
   ASAM Dataset: EV_HDSGAu573 001022
   ROD: EV_HDSGAu571.rod
   VCID: 4487268ECF24C16443-8010
Address 8F: Pretens. Frt Left (J854)       Labels:. 4H0-980-94x-RGS.clb
   Coding: 0006E008031F0300070308014244C8010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 31697F5A609644CC98-8064
Address 90: Pretens. Frt Right (J855)       Labels:. 4H0-980-94x-RGS.clb
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
Address BA: Motor Mounts (J931)       Labels: 4H0-907-145.clb
   Part No SW: 4H0 907 145 B    HW: 4H0 907 145
   Component: AEM - LEAR    H07 0008
   Revision: 00001001    Serial number: 97812003363701
   ASAM Dataset: EV_AEMLearAU64X 002016
   ROD: EV_AEMLearAU64X.rod
1294 - Actuator 1 for Drivetrain Mounts
          C1131 07 [009] - Mechanical Failure
                    Reset counter: 131
                    Mileage: 77282 km
                    Date: 2017.11.06
                    Time: 12:26:41
iichel
Netherlands, eastern part
C?ID=284912
00 01 02 03 04 05 06 07 08 09 byte
61 B7 53 03 86 ED CA C0 4B 00 No DCC source 1
62 B7 DB 01 46 ED DB 80 DB 00 No DCC source 2
61 B7 53 03 86 ED CA C0 4B 00 No DCC source 4
63 BF 11 03 C6 FD 88 C0 4B 00 Yours with DCC
63 B7 13 03 C6 ED C8 C0 4B 00 With DCC source 3
So what's not interesting.. and what is...
Byte 0 is either 61 62 or 63, with 63 only in DCC cars.
Byte 1 is BF but only in your case. Not sure why.
Byte 2 is low in DCC cars (11/13 = 00010001 or 00010011) and high in non-DCC cars (53 01010011 DB = 11011011 = 53+bit 7)
Byte 3 is not intersting for DCC.
byte 4 is the inverted value of byte 0. see byte 7 since I saw that one earlier.
byte 5 is the inverted value of byte 1. see byte 7 since I saw that one earlier.
byte 6 is the inverted value of byte 2. see byte 7 since I saw that one earlier.
byte 7 is the inverted value of byte 3. C0 HEX is BIN 11000000 and BIN 00000011 is HEX 03. Same goes for 80 and 01. Hey byte 3!
byte 8 is DB on car 2 but 4B on all aother cars.
byte 9 is all zeros
source 1 http://forums.ross-tech.com/showthr...edure-for-resetting-the-ZF-8HP90-transmission
source 2 http://forums.ross-tech.com/showthread.php?432-Audi-RS7-Data-Collection
source 3 http://forums.ross-tech.com/showthread.php?13399-Onboard-cam-missing-calibration-no-basic-setting
source 4 http://forums.ross-tech.com/showthread.php?3009-2014-Audi-RS7-4-0-TFSI-CRDB
maybe you can have a look at the adaptation channels of the ABS module, see if there's anything interesting regarding DCC.
or feel free to try some of the systematics discovered above.
gillmotorsports
C?ID=210708
we went through all adaptations channels in DRC and it was not mentioned anywhere. Wondering if we could find coding from an A7 with no air or DRC but is same chasis vehicle and pick through the coding to see if this can be used?
iichel
C?ID=284912
looks like this ABS controller is unique to RS7 so I'd stick to that.
gillmotorsports
C?ID=210708
Thank you very much for helping on this. Any other suggestions you may have for us to see if we can code this RS7 module?
iichel
C?ID=284912
you could try a few of the bytes above, like byte 0 to 63 and simultaneously byte 4 to c6. see what happens, monitor all dtcs...
gillmotorsports
C?ID=210708
Thank you again. We have been able code out the ABS with your suggestion. We are still finding now a malfunction in the Instrument Cluster related back to the DRC "Dynamic Ride Control" . It shows the warning on the instrument cluster. I have attached the auto scan from after coding the ABS. Would you kindly take a look at the auto scan and let us know what your suggestion would be?
   Revision: NCH62---
Readiness: 1110 1101
   Revision: --H16---
   Coding: 000001
   Coding: 61BF110386FD88C04B00
   Coding: 6803207849
   Coding: 0045F7
   Coding: 02006E
   Coding: 020300
   Coding: A8C119
   Coding: 000034
   ROD: EV_RBD4K.rod
          U1111 00 [009] - -
                    Reset counter: 116
                    Mileage: 85119 km
                    Date: 2018.06.08
                    Time: 09:48:17
   Coding: 00E1034800
   Coding: 20
   ROD: EV_SARA2.rod
   Coding: 0000006
   Coding: 101F00
   Coding: 1081013
   Coding: 0A3305C102
   ROD: EV_RGS_L.rod
   ROD: EV_RGS_R.rod
                    Reset counter: 116
                    Mileage: 85119 km
                    Date: 2018.06.08
                    Time: 09:42:29
End-------------------------(Elapsed Time: 07:03)-
iichel
C?ID=284912
Thank you for reporting back
63BF1103C6FD88C04B00 DCC error
61BF110386FD88C04B00 No DCC error
could you maybe tell me the identified bytes of the IC module? otherwise i'm doing more than possibly necessary in terms of stare-and-compare
00 01 02 03 04 05 06 07 08 09 10
03 EF 01 0C AB C3 D7 05 02 05 00 current cluster error
0B 8F 01 0C 8F D3 00 08 02 05 00 DCC
33 AF 11 0B 9B 41 26 00 01 04 00 no dcc
0B CF 01 0C 9F 53 D7 05 02 05 00 no dcc
03 CF 01 0C 9F 53 D7 05 02 05 00 no DCC
currently interested in byte 5
gillmotorsports
C?ID=210708
He is on it right now. Will be back to you in 2
gillmotorsports
C?ID=210708
Byte 5 Binary 11000011
Bit 0 check mark - Electronic Power Steering EPS installed
Bit 1 check mark - Rear Spoiler installed
Bit 2 no check mark - Traffic sign recognition (VZE) installed . active [PR-QR9]
Bit 3 no check mark - Dynamic Ride Control Installed /active [PR-2MC]
Bit 4 no check mark - Audi Active Lane Assist installed / active [PR-7Y4/7Y5]
gillmotorsports
C?ID=210708
Here is byte 4 as well as it looks to have some info that is related
Byte 4 Binary 10101011
Bit0 check mark - Tire pressure monitoring [TPMS] installed
Bit1 check mark - Electro Mechanical Parking brake [EPB] installed
Bit2 no check mark - Adaptive Cruise Control (ACC) installed
Bit3 check mark - Adaptive light ( swiveling headlights) installed
Bit4 no check mark - Dynamic Ride Control (DRC) installed
Bit5 check mark - Dynamic Steering installed
Bit6 no check mark - Lane Assist installed
Bit7 check mark - Quattro Sport installed
iichel
C?ID=284912
could you set byte 5 to HEX values 43, 41 and 53 tell us what happens?
gillmotorsports
C?ID=210708
Where can we input / set byte 5 to HEX values ? - We are a unsure where this change is made?
iichel
C?ID=284912
instrument cluster, coding, long coding, type 53/43/41 in the box.
Or paste this code:
03EF010CAB43D705020500
03EF010CAB53D705020500
03EF010CAB41D705020500
gillmotorsports
C?ID=210708
#43 worked right away !! Thank you so much!! Can we send you anything via PayPal for your efforts - would you care to be able to elaborate to us on how you figure this out?
iichel
C?ID=284912
How to do this is really simple. Just look up a bunch of scans of other cars by google.
Just put in the part number you're interested in with quotes and see what pops up.
Then it's a matter of putting your data in a structured way in excel or whatever
With these short and (relatively) not-complex codes, I just wrote it down on the forum like in these posts.
Then do a stare-and-compare and see what's what... sometimes things jump out immediately and sometimes it's a bit more complex.
Having a hexadecimal-to-binary converter close is a big plus. Just a website or a HEX2BIN function in Excel will do... and then just make the 'victim' try several ideas.
I guess Ross Tech could consider a little addition to the label file for this cluster.
Byte 5 bit 7 = dynamic chassis control/dynamic ride control (PR xxx) installed :)
gillmotorsports
C?ID=210708
Thank you again, please let us know if we can do anything from our side.
