Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 1B 22 28 36 3B 3C 42 44 46
47 52 53 55 56 5F 62 65 6C 6D 72 8F 90 BA
VIN: WUAW2AFC4EN904345 Mileage: 85119km-52890miles
BA-Motor Mounts -- Status: Malfunction 0010
Address 01: Engine (------CRDB) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 906 560 B HW: 4H0 906 014
Component: 4.0l V8TFSI / H62 0008
Revision: NCH62---
Coding: 1A2A003265260A0E1000
Shop #: WSC 11686 002 1048576
ASAM Dataset: EV_ECM40TFS0114G0906560B 001008
ROD: EV_ECM40TFS0114G0906560B.rod
VCID: 275D91025E520A7C46-8072
U1113 00 [032] - -
U1113 00 [032] - -
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 4G0 927 158 BE HW: 0BK 927 156 AM
Component: 0BK 40TFSIUSA H16 1006
Revision: --H16---
Coding: 000001
VCID: 72EBB056A5103FD421-8026
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 P HW: 4G0 907 379 P
Component: ESP PREMIUM H09 0100
Coding: 63BF1103C6FD88C04B00
ASAM Dataset: EV_ESPPremiAU57X 004036
VCID: 3E735466A1C8ABB415-806A
1792 - No Communcation with Control Module for Electronic Suspension Damping
U0139 00 [009] - -
Reset counter: 115
Mileage: 85111 km
Date: 2018.06.05
Time: 12:48:21
VzRef: 00
Bit Info 1: 80
Bit Info 2: 4F
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 00
F-Type: B3
Uz: 9B
Part No SW: 4H0 907 064 ER HW: 4H0 907 064 ER
Component: BCM2 2.0 H36 0521
Coding: 0D8A2046000000000000
VCID: 7DF1936AE44E70AC4C-8028
Serial number: 0214000033696003
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 AM HW: 4G0 820 043 AM
Component: KLIMA 4 ZONEN H14 0093
Serial number: 14031400040374
Coding: 6803207849
ASAM Dataset: EV_AirCondiComfoUDS 004003
ROD: EV_AirCondiComfoUDS_004.rod
VCID: 6ADBA8368DC0F71499-803E
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001716271
Coding: 0D072015073E9FF0B10008C7A0003820CF9CD308A2090221800308457B00
VCID: 6FEDB922BE22123CCE-803A
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 140228 H37 0080
Serial number: 140308190628
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 22371434
Coding: 02006E
Subsystem 3 - Part No SW: 4G0 941 531 E HW: 4G0 941 531 E
Component: E1 - LDS H07 0044
Serial number: 17 03 2014 00001278
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 0000002274555RAQK803
Subsystem 5 - Part No SW: 4G0 907 472 HW: 4G0 907 472
Component: A31 LED Mod1L H02 0002
Serial number: 00000000001402114097
Subsystem 6 - Part No SW: 4G0 907 472 HW: 4G0 907 472
Component: A27 LED Mod1R H02 0002
Serial number: 00000000001401251355
Subsystem 7 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA107529000006290952
Coding: 020300
Subsystem 8 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 7D288C17000000000001
Subsystem 9 - Part No SW: 4G0 907 472 A HW: 4G0 907 472 A
Component: A32 LED Mod2L H02 0002
Serial number: 00000000001403101782
Subsystem 10 - Part No SW: 4G0 907 472 A HW: 4G0 907 472 A
Component: A28 LED Mod2R H02 0002
Serial number: 00000000001402203379
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AC HW: 4H0 919 475 AG
Component: PARKHILFE ACC H01 0091
Revision: 11001001 Serial number: 61061407200240
Coding: A8C119
VCID: 73E5B552DA0A36DC2A-8026
Address 15: Airbags (J234) Labels:| 4H0-959-655.clb
Part No SW: 4G0 959 655 A HW: 4G0 959 655 A
Component: Airbag10.43 H33 0033
Revision: -------- Serial number: 003D8003YUW.
Coding: 303145313131303030314A55304C34473853
VCID: 336575529A8A76DCEA-8066
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Serial number: 6940000Y1400011ET90Q
Serial number: 3575HRB40552DJEQ5PJ/
Serial number: 3585HRB40512BDFS98UU
Serial number: 3515JRB401050U80EP7-
Serial number: 3525JRB400O50U80O1QM
Serial number: 3554VRB400U50UJELGHR
Serial number: 3564VRB404P2EBL4K0BV
Part No SW: 4H0 953 568 G HW: 4H0 953 568 G
Component: Lenks.Modul H04 0005
Revision: -------- Serial number: 90372NCC000RU
Coding: 000034
VCID: 377D414286F29AFCD6-8062
Serial number: 31 01 2014 C0424096
Address 17: Instruments (J285) Labels:. 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 984 E HW: 4G8 920 984 E
Component: TBenUsa Nv H58 0621
Revision: 29460235 Serial number: 658040314596054
Coding: 03EF010CABC3D705020500
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K.rod
VCID: 387F427E83EC9584DF-806C
16776966 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 116
Mileage: 85119 km
Date: 2018.06.05
Time: 13:18:26
Part No SW: 4G0 907 468 AD HW: 4G0 907 468 AC
Revision: -------- Serial number: 00000001315823
Coding: 00E1034800
Serial number: 3239232803
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 M HW: 8K0 907 144 M
Component: DYNAMIKLENK. H06 0730
Revision: 52001005 Serial number: --------------
VCID: 3979477AB0E68C8C20-806C
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 B HW: 4H0 907 163 A
Component: 4 Wheel Drive H16 0200
Serial number: 001003140001107
ASAM Dataset: EV_AllWheelDiffeQSPFR 003026
VCID: 285F923E534C05044F-807C
0333 - Oil Pressure and Temperature Sensor
C1004 F0 [008] - Oil Pressure Implausible
Reset counter: 47
Mileage: 79721 km
Date: 2017.12.28
Time: 17:01:44
0377 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Reset counter: 48
Mileage: 82741 km
Date: 2018.04.14
Time: 12:20:09
Address 28: HVAC, Rear (E265) Labels:| 4G0-919-158.clb
Part No SW: 4G0 919 158 M HW: 4G0 919 158 M
Component: KLIMA FOND H08 0093
Serial number: 15031400040050
Coding: 20
ASAM Dataset: EV_ClimaContrUnitRearUDS 004002
VCID: 3979477AB8E68C8C20-806C
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000092681957
Coding: 00581B0000002001000001010101102030303232203232
VCID: 77FD8142C6725AFC16-8022
Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
Component: SARA 6D red H03 0056
Revision: -------- Serial number: EJ1BPA7E00WPSE
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 377D41428EF29AFCD6-8062
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4G0 907 566 L HW: 4G0 907 566
Component: J769 SWA MasterH04 0010
Revision: 00H04000 Serial number: 6PZ 010 287-10
Coding: 0000006
VCID: 387F427E4BEC9584DF-806C
Subsystem 1 - Part No: 4G0 907 568 L
Component: J770 SWA Slave H04 0010
Subsystem 2 - Serial number: 6PZ 010 287-30
Subsystem 3 - Serial number: 5F18.02.1400H04000AMS14564ÿ
Subsystem 4 - Serial number: S14564ÿ
Component: TSG FA H03 0507
Coding: 011F57025E00628002000412
VCID: 479D3182F612EA7CA6-8012
Component: RCEPS H40 0010
Revision: 00001000 Serial number: 0001352075
Coding: 011000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 326B705665907FD4E1-8066
Revision: 00002001 Serial number: 0329601111
Coding: 0126023A20FAF08580B00A80020114000000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0081
Serial number: 00000000000000209300
Subsystem 3 - Part No SW: 4G8 959 591 HW: 7P0 959 591 C
Component: J245 PS40.039 H01 0008
Serial number: WOO27821251
Coding: 101F00
Subsystem 4 - Part No SW: 4G0 947 135 G HW: 4G0 947 135
Serial number: 0000000AP00006376839
Subsystem 5 - Part No SW: 4G8 959 252 HW: 4G8 959 252
Component: HSP-SG H11 0029
Serial number: WA107669000006534821
02616 - Fuel Tank Cap; Unlock
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 114
Mileage: 85103 km
Date: 2018.06.03
Time: 10:11:31
Part No SW: 4G0 035 465 C HW: 4G0 035 465 B
Component: BO G3 C7 H09 0160
Revision: 11000000 Serial number: 0019317
VCID: 25419B0A2C5E186C74-8070
Subsystem 1 - Part No SW: 4G0 035 466 HW: 4G0 035 466
Component: BO C7 SLAVE H51 0100
Serial number: 02201140026679
Component: TSG BF H03 0507
Coding: 011F57025E00628002000402
VCID: 46833C86F118F3745D-8012
Part No SW: 4H0 907 801 H HW: 4H0 907 801 A
Component: EPB-4 H03 0015
Revision: -------- Serial number: 00000000998089
ROD: EV_ParkiBrake_VW51.rod
VCID: 2D51632A7CAE202CBC-8078
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Serial number: 140317-0002-106
Coding: 1223A6601002B400
ROD: EV_HeadlRegulBasic.rod
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H60 0133
Revision: AB001007 Serial number: 156C00E7982219
Coding: 020007010000000001
VCID: 2447860E2764E16463-8070
Part No SW: 4G0 035 746 F HW: 4G0 035 746 E
Component: H-BNT-NA H41 0757
Revision: -------- Serial number: 194C+0E7604890
Coding: 0B0200040303E1EF55128F3E00000003100001000000000000
VCID: 2A5B68364540371459-807E
Subsystem 1 - Part No: 8R0 060 884 BL
Component: NAR 2014 0902
Subsystem 2 - Part No SW: 4G0 919 605 C HW: 4G0 919 605 C
Component: DU8 C7 SV H43 0021
Serial number: AUZ8ZDDD003SDK6
Subsystem 3 - Part No SW: 4G1 919 612 Q HW: 4G1 919 612 Q
Component: E380 BDT C7 H11 0204
Serial number: 90349NCD000WK
Component: CD-Database 5571
02067 - Optical Databus; Unpermitted Wake-Up Request
Reset counter: 136
Mileage: 84722 km
Date: 2018.05.14
Time: 19:17:25
Voltage: 12.40 V
Component: TSG HL H03 0507
Coding: 010F17024000628002000002
VCID: 499937BAE0061C0CB0-801C
Address 65: Tire Pressure (J502) Labels: 3Y0-907-273.clb
Part No SW: 4H0 907 273 HW: 4H0 907 273
Component: RDKBERU25 H09 0700
Serial number: 10000000007638
ROD: EV_RDKBERU25_AU57.rod
VCID: 68DFD23E93CCC5048F-803C
8392961 - TPMS Transceiver in Front Left Wheel Well
C104C 01 [008] - Electrical Failure
Reset counter: 124
Mileage: 84494 km
Date: 2018.05.04
Time: 21:18:32
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 B HW: 4H0 907 441
Component: SG Rueckfahrkamera 0061
Revision: --H08--- Serial number: 525 PA8J42G9BP
Coding: 1081013
VCID: 26439C06915813747D-8072
Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
Part No SW: 4G8 959 107 R HW: 4G8 959 107 G
Component: HDSG-Modul H13 0043
Revision: 12013001 Serial number: 038400185
Coding: 0A3305C102
ASAM Dataset: EV_HDSGAu573 001022
ROD: EV_HDSGAu571.rod
VCID: 4487268ECF24C16443-8010
Component: TSG HR H03 0507
Address 8F: Pretens. Frt Left (J854) Labels:. 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 B HW: 4H0 980 945 C
Component: RGS-VL H13 0080
Coding: 0006E008031F0300070308014244C8010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 31697F5A609644CC98-8064
Address 90: Pretens. Frt Right (J855) Labels:. 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 B HW: 4H0 980 946 C
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
Part No SW: 4H0 907 145 B HW: 4H0 907 145
Component: AEM - LEAR H07 0008
Revision: 00001001 Serial number: 97812003363701
ASAM Dataset: EV_AEMLearAU64X 002016
ROD: EV_AEMLearAU64X.rod
1294 - Actuator 1 for Drivetrain Mounts
C1131 07 [009] - Mechanical Failure
Reset counter: 131
Mileage: 77282 km
Date: 2017.11.06
Time: 12:26:41
