After retrofitting a trailer hitch(electrically operated) on passat B8 (trailer hitch set is form second hand(from another car))
I have problem with open trailer with button( in Adv. Meas. Values not coded), when i try it with output test the same result, when controlling whatever channel in otuput test I have the same error in all chanel, I am currently not going to say what is the error code, i dont remember now.I also tried to make basic settings, but like in output test i have fault in any options.
What I have done so far is:
- Added 69-trailer in 01,09,13,19.
The log is listed below (before test drive, some fault from G85, after clear dtc and test drive, no fault code) . Hope someone can help.
Thank you!
PS. Sorry for my very basic english...
Thank you!
Saturday,02,June,2018,16:40:31:48233
VCDS Version: 18.2.1.2
VIN: WVWZZZ3CZGE006942 License Plate:
Mileage: 122732km-76262mi Repair Order:
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 18 19 2B 42 44 52 55 5F 69 6D
BB BC
VIN: WVWZZZ3CZGE006942 Mileage: 122732km-76262miles
Address 01: Engine (J623-CRLB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 ES HW: 04L 907 309 R
Component: R4 2.0l TDI H21 1989
Revision: B5H21---
Coding: 0119001A03541D083000
Shop #: WSC 37367 002 104857
ASAM Dataset: EV_ECM20TDI01104L906026ES 002002
ROD: EV_ECM20TDI01104L906026FK.rod
VCID: 7F072AAFE64115BC5E-802A
17158 - Databus
U1123 00 [039] - Received Error Message
Mileage: 122732 km
Date: 2018.06.02
Time: 00:00:07
Coolant temperature: 36 °C
Intake air temperature: 38 °C
Voltage terminal 30: 12.240 V
Drivetrain coordinator: brake fault status-Bits 0-7: 4
Drivetrain coordinator: brake function status-Bits 0-7: 0
Drivetrain coordinator: brake function status-Bits 0-7: 4
Acceleration: 0.000 m/s˛
4865 - No Communication with Towing System Control Module (J345)
U1003 00 [038] - -
Mileage: 122732 km
Date: 2018.06.02
Time: 00:01:25
Coolant temperature: 37 °C
Voltage terminal 30: 12.140 V
Cruise Control System (CCS): status-Bits 0-7: 7
selected gear-Bits 0-7: 0
U0428 00 [039] - -
Mileage: 122732 km
Date: 2018.06.02
Time: 16:15:01
Intake air temperature: 39 °C
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 3Q0 907 379 AF HW: 3Q0 907 379 F
Component: ESC H42 0625
Revision: 00000000 Serial number: 61385000002712
Coding: 0FEC6A8F34200B720780060441C549F0562CD0E0608292F11460F078C002
ROD: EV_Brake1UDSContiMK100IPB_034.rod
VCID: 7EF9D7ABE14B1CB455-802A
0297 - Steering angle sensor
B1168 16 [137] - Voltage Too Low
Reset counter: 147
Date: 2018.06.02
Time: 16:15:01
16412 - Display for Tire Pressure Monitoring
Reset counter: 147
Mileage: 122732 km
Date: 2018.06.02
Time: 16:15:13
16413 - Display for Tire Pressure Monitoring
Reset counter: 147
Mileage: 122732 km
Date: 2018.06.02
Time: 16:15:13
Part No SW: 3Q0 959 435 B HW: 3Q0 959 435 B
Component: VWKESSYMQB 026 0709
Revision: 00026000 Serial number: 0369525340
Coding: 000F0F0603
Shop #: WSC 05311 115 00300
ASAM Dataset: EV_KessyHellaMQBAB 004032
VCID: 397304B7B8E5FB8C20-806C
Part No SW: 5G0 907 044 BH HW: 5G0 907 044 BH
Component: Climatronic H04 1202
Revision: 00001K10
Coding: 12020104204401011015500200101802
Shop #: WSC 00015 115 00001
ASAM Dataset: EV_ACClimaBHBVW37X 005137
ROD: EV_ACClimaBHBVW37X_005_VW37.rod
VCID: 6ED9E7EBB12B6C34C5-803A
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 086 AK HW: 5Q0 937 086 AK
Revision: -------- Serial number: 86581305151985
Coding: 00030A66C2C102FF53C44004001457081C80000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 030FA65F8AA9715C3A-8056
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150423 042 0607
Serial number: 150429045527
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S4Y15M05D22H09M35S22
Coding: 90A8EE
Light switch:
Subsystem 3 - Part No SW: 3G0 941 633 H HW: 3G0 941 633 H
Component: E1 - LDS MQB H01 0032
Serial number: 27 02 2015 00000888
529173 - Databus
Reset counter: 187
Mileage: 122732 km
Date: 2018.06.02
Time: 00:01:25
Part No SW: 5Q0 919 294 L HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0056
Revision: -------- Serial number: 39391512506047
Coding: 0071051A01
Shop #: WSC 05311 115 00063
ROD: EV_EPHVA18AU3700000_002_VW27.rod
VCID: 448D6543CF27B66443-8010
13637426 - Databus
Reset counter: 147
Mileage: 122732 km
Date: 2018.06.02
Time: 16:15:00
13632273 - Databus
Reset counter: 187
Mileage: 122732 km
Date: 2018.06.02
Time: 00:01:25
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 3Q0 907 572 B HW: 3Q0 907 572 B
Component: ACC BOSCH MQB H04 0192
Coding: 2A00600A51FFC428949C804D
ASAM Dataset: EV_ACCBOSCHVW48X 001008
ROD: EV_ACCBOSCHVW48X.rod
VCID: 346D35839F8706E4F3-8060
2055 - Databus
U1122 00 [009] - Implausible Message
Reset counter: 147
Mileage: 122732 km
Date: 2018.06.02
Time: 00:01:54
Control Module temperature: 43 °C
Voltage terminal 15: 12.0 V
Longitudinal_acceleration_vehicle_reference: 0.00 m/s˛
Status_ACC_System: ACC_irreversible error
0795 - Databus
Reset counter: 147
Mileage: 122732 km
Date: 2018.06.02
Time: 00:01:54
2101 - Databus
Reset counter: 147
Mileage: 122732 km
Date: 2018.06.02
Time: 00:01:54
0937 - Databus
Reset counter: 187
Mileage: 122732 km
Date: 2018.06.02
Time: 00:01:54
2068 - Databus
Reset counter: 147
Mileage: 122732 km
Date: 2018.06.02
Time: 00:01:54
Part No SW: 3Q0 959 655 AF HW: 3Q0 959 655 AF
Component: Airbag VW20 012 0195
Revision: -------- Serial number: 003R2P9AS3EZ
Coding: 88CCC000008000005C5400CC000800000065
Shop #: WSC 05314 000 00001
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 0201A35B95B3785431-8056
Subsystem 1 - Part No SW: ----------- HW: 454 001 005 15
Serial number: 3576U000000392AC941F
Subsystem 2 - Part No SW: ----------- HW: 454 001 105 15
Serial number: 3586U00000032449541+
Subsystem 3 - Part No SW: ----------- HW: 454 801 905 15
Component: SideSensor_Dr 111 0148
Serial number: 3516RE584EA06000000H
Subsystem 4 - Part No SW: ----------- HW: 454 801 005 15
Component: SideSensor_Pr 111 0148
Serial number: 3526R14868B060000001
Subsystem 5 - Part No SW: ----------- HW: 454 801 005 15
Component: FrontSensor_D 114 0149
Serial number: 3556V3FC13F06000000J
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 3Q0 953 521 P HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20150512500210
Coding: 0400
ROD: EV_SMLSVALEOMQB.rod
VCID: 3D7B10A7ACCDC7AC0C-8068
Part No SW: 3G0 920 751 A HW: 3G0 920 751 A
Component: KOMBI 307 7640
Coding: 07A409102F80000800886B011000000000000000
ASAM Dataset: EV_DashBoardJCIMQBAB 009005
ROD: EV_DashBoardJCIMQBAB_009.rod
VCID: 234FC6DF2A69915C1A-8076
16777024 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
Reset counter: 187
Mileage: 122732 km
Date: 2018.06.02
Time: 00:00:10
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
Part No SW: 5Q0 963 272 E HW: 5Q0 963 272 E
Component: STH-MQB 007 0072
Coding: 9309
ASAM Dataset: EV_AuxilParkiHeateWOS 002018
VCID: 387501B383EFE284DF-806C
Subsystem 1 - Part No SW: 5Q0 963 513 A HW: 5Q0 963 513 A
Component: R149 T91-LIN 003 0301
Serial number: 00000000000001134315
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 M
Component: GW MQB High 212 2227
Revision: -------- Serial number: 15051510803440
Coding: 0B0300045F017300FB000258080F00010001070000000000000000000000
ROD: EV_GatewConti_013_VW37.rod
VCID: 75EBC887D47D5FEC04-8020
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H16 0040
Serial number: 29150001000760085197
Coding: 2CFFFF
Subsystem 3 - Part No SW: 3Q0 915 181 A HW: 3Q0 915 181 A
Component: J367-BDMHella H04 8050
Serial number: 1180646503
Power Converter DC AC:
Subsystem 4 - Part No SW: 5Q0 907 155 C HW: 5Q0 907 155 C
Component: WECHSELRICHTE H54 0033
Serial number: 0062017
Analog clock:
Subsystem 5 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 111 1004
Serial number: 0605201500010351
131655 - No Communication with Towing System Control Module (J345)
U1003 00 [008] - -
Reset counter: 187
Mileage: 122732 km
Date: 2018.06.02
Time: 00:01:27
Terminal 15: On
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0031
Serial number: 15000092263014
Coding: 0000000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71E3FC97A01573CCD8-8024
Component: TSG FS 020 0041
Serial number: 050515BE308169
Coding: 00350B208000020000001000
VCID: 438F665FCA29B15C7A-8016
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 K HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2033
Revision: 00000000 Serial number: 0000240754
Coding: 01000010005000
Shop #: WSC 00015 115 00300
ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
ROD: EV_SteerAssisVWBSMQBA_008_VW48.rod
VCID: 3B7F1EBFB2D9C99C32-806E
5262656 - Steering Angle Sensor
B1168 F2 [137] - Not Initialized
Reset counter: 147
Mileage: 122732 km
Date: 2018.06.02
Time: 16:15:00
valid
Component: TSG BFS 020 0041
Serial number: 070515BE607241
Coding: 003501208000020000001000
VCID: 4281635BD533B85471-8016
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Coding: 03DA000009000000
Shop #: WSC 05311 000 00001
Part No SW: 3Q0 035 846 HW: 3Q0 035 846
Component: MU-S-N-ER 820 0627
Coding: 02840201FF00000051110001000808031F0100C401200100CF
ROD: EV_MUStd4CDELP_VW27.rod
Subsystem 1 - Part No SW: 3G0 919 605 D HW: 3G0 919 605 D
Component: ABT_Std-2_Nav H44 1031
Serial number: VWZ8Z9RD8022HF
Subsystem 2 - Part No SW: 3G0 919 866 H HW: -----------
Component: ECE 2015/16 --- 0430
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 5Q0 907 383 H HW: 5Q0 907 383 C
Component: Anhaenger H21 0204
Revision: 8B001003 Serial number: 0373546501
Coding: 0100000201000000
VCID: 3C7D1DA3B7D7CEA43B-8068
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 5Q0 959 107 E HW: 5Q0 959 107 E
Component: HDSG-Modul H12 0233
Revision: -------- Serial number: 30018426200000
Coding: 0200
ASAM Dataset: EV_DeckLidCONTIAU736 001009
ROD: EV_DeckLidCONTIAU736_VW27.rod
VCID: 3A711BBBBDE3F09429-806E
Part No SW: 5Q0 959 395 E HW: 5Q0 959 395 B
Component: TSG HFS 020 0041
Serial number: 030515BE21652B
Coding: 000001200100020000001000
Shop #: WSC 24425 001 1048576
Component: TSG HBFS 020 0041
Serial number: 030515BE216538
End-------------------------(Elapsed Time: 05:45)--------------------------
