Monday,11,June,2018,19:23:38:42907
VCDS Version: 18.2.1.2 (x64) HEX-NET CB: 0.4411.4
VIN: XXX License Plate:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 4F 52 56 75
VIN: XXX Mileage: 20km-12miles
75-Telematics -- Status: Not registered 0011
Address 01: Engine (J623-CPRA) Labels:. 06K-907-425-V2.clb
Part No SW: 06K 906 071 K HW: 06K 907 425 C
Component: Simos18.2 H13 8104
Revision: --H13---
Coding: 001A0012242400170000
Shop #: WSC 09003 957 00200
ASAM Dataset: EV_ECM18TFS02006K906071K 001006
ROD: EV_ECM18TFS02006K906071AC.rod
VCID: B3265BC81A9273DC6A-80E6
19795 - EVAP System Leak Detection Pump Heater Control Circuit
P240A 00 [039] - Open Circuit
Mileage: 29 km
Date: 2018.06.07
Time: 00:35:46
Coolant temperature: 20 °C
Intake air temperature: 24 °C
Voltage terminal 30: 11.933 V
Engine: operating status: ES
STATE_LS_SAE[1]: INI
T_AST_SAE: 0 s
MAP_MES_SAE: 100 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
FAC_TPS_1_SAE: 18.359375 %
FUP_H_SAE: 640.0 kPa
19798 - Control Circuit for EVAP Vent Control
P0447 00 [039] - Open Circuit
Mileage: 29 km
Date: 2018.06.07
Time: 00:35:45
T_AST_SAE: 0 s
19791 - EVAP Leak Detection Pump Control Circuit
P2400 00 [039] - Malfunction
Mileage: 29 km
Date: 2018.06.07
Time: 00:35:45
T_AST_SAE: 0 s
17178 - Databus
U1123 00 [039] - Received Error Message
Fault Frequency: 13
Mileage: 29 km
Date: 2018.06.07
Time: 00:35:43
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Readiness: 1110 0101
Address 02: Auto Trans (J217) Labels:| 09G-927-749-V1.clb
Part No SW: 09G 927 749 B HW: 09G 927 749 B
Component: AISIN AG6 G3 109 2784
Coding: 000348
ASAM Dataset: EV_TCMAQ250031 001004
ROD: EV_TCMAQ250031_001_VW41.rod
VCID: B83C6CE403F490845F-80EC
22920 - Implausible Data Received from Parking Brake Control Module
U0417 00 [171] - -
Reset counter: 36
Mileage: 29 km
Engine speed: 0.0 /min
Transmission input speed: 0 /min
Transmission output speed: 0 /min
Engine torque: 0 Nm
Transmission fluid temperature: 23 °C
Accelerator position: 0.0 %
Clutch_C1: Open
Clutch_C2: Open
Clutch_C3: Open
Clutch_C4: Open
Clutch_B1: Open
Clutch_B2: Open
Lock Up Clutch: Open
Electrical Oil Pump target revolution: 65534 /min
Electrical Oil Pump actual revolution: 65279 /min
Engine Speed signal Current: 65279 /min
Electrical Oil Pump failure status with Electrical Oil Pump without HV 1: Motor normal stop
Electrical Oil Pump target current: 65278 mA
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: C54BC0F5492500FBA31103E892210041A1100012
VCID: 8444C81407BC046483-80D0
Reset counter: 36
Mileage: 29 km
Date: 2018.06.10
Time: 04:32:17
Count: 7
Count: 13
Count: 12288
Count: 128
Count: 28928
Count: 512
Reset counter: 36
Mileage: 29 km
Date: 2018.06.07
Time: 02:15:19
Count: 2
Count: 12
Count: 4096
Count: 16390
Count: 42496
Count: 512
Fault Status: 01100101
Reset counter: 36
Mileage: 29 km
Date: 2018.06.07
Time: 02:15:15
Count: 2
Count: 12
Count: 4096
Count: 291
Count: 42496
Count: 512
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
ROD: EV_ClimaBasis_VW36.rod
VCID: F5A2A5D054662DEC84-80A0
9471253 - Temperature Sensor for Footwell Vent
B1085 15 [009] - Open or Short to Plus
Reset counter: 36
Mileage: 29 km
Date: 2018.06.07
Time: 01:37:57
9471509 - Temperature Sensor for Driver Side Vent in Dashboard
B1086 15 [009] - Open or Short to Plus
Reset counter: 36
Mileage: 29 km
Date: 2018.06.07
Time: 01:37:57
13701936 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[Steuergerät für Bordnetz - bitte Fehlerspeicher auslesen]
Reset counter: 76
Mileage: 29 km
Date: 2018.06.07
Time: 02:19:06
13701536 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Türsteuergerät hinten rechts - kein Signal/Kommunikation]
Reset counter: 36
Mileage: 29 km
Date: 2018.06.07
Time: 01:37:57
B10AB F0 [009] - Too Low
Reset counter: 36
Mileage: 29 km
Date: 2018.06.07
Time: 01:37:57
Address 09: Cent. Elect.
Part No SW: 5C0 959 655 AA HW: 5C0 959 655 AA
Component: AirbagVW10 500 0975
Serial number: 003LYD017DHN
Coding: 00004832
ROD: EV_AirbaVW10SMEVW360.rod
VCID: F1AA91C0200E01CC58-80A4
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Serial number: 3572MSME4E2F2D48ZZZC
Serial number: 3582MSME4A312D48ZZZ$
Subsystem 3 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3516KSME796E0A30ZZZ
Subsystem 4 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME1567702FZZZ
20 Faults Found:
9440027 - Driver's side; side-airbag igniter
B100B 1B [137] - Resistance Too High
Mileage: 29 km
Date: 2018.06.07
Time: 02:15:41
9439771 - Front Passenger's Side Airbag Igniter
B100A 1B [137] - Resistance Too High
Mileage: 29 km
Date: 2018.06.07
Time: 02:15:41
9438491 - Igniter for Driver head airbag
B1005 1B [137] - Resistance Too High
Mileage: 29 km
Date: 2018.06.07
Time: 02:15:41
9438235 - Igniter for Front passenger's Head Curtain Airbag
B1004 1B [137] - Resistance Too High
Mileage: 29 km
Date: 2018.06.07
Time: 02:15:41
9437723 - Igniter for Passenger's Airbag
B1002 1B [137] - Resistance Too High
Mileage: 29 km
Date: 2018.06.07
Time: 02:15:41
Mileage: 29 km
Date: 2018.06.07
Time: 02:15:41
B1007 1B [137] - Resistance Too High
Mileage: 29 km
Date: 2018.06.07
Time: 02:15:41
9442075 - Driver's Belt Force Limiter Igniter
B1013 1B [137] - Resistance Too High
Mileage: 29 km
Date: 2018.06.07
Time: 02:15:41
9442331 - Passenger's Belt Force Limiter Igniter
B1014 1B [137] - Resistance Too High
Mileage: 29 km
Date: 2018.06.07
Time: 02:15:41
9437979 - Igniter 2 for Passenger's Airbag
B1003 1B [137] - Resistance Too High
Mileage: 29 km
Date: 2018.06.07
Time: 02:15:41
9440539 - Driver's Safety Belt Tensioner Igniter 2
B100D 1B [137] - Resistance Too High
Mileage: 29 km
Date: 2018.06.07
Time: 02:15:41
9441051 - Front passenger's safety belt tensioner igniter 2
B100F 1B [137] - Resistance Too High
Mileage: 29 km
Date: 2018.06.07
Time: 02:15:41
9443605 - Rear Side Airbag Crash Sensor (on front passenger's side)
B1019 15 [137] - Open or Short to Plus
Mileage: 29 km
Date: 2018.06.07
Time: 02:15:41
9443861 - Driver's Front Airbag Crash Sensor
B101A 15 [137] - Open or Short to Plus
Mileage: 29 km
Date: 2018.06.07
Time: 02:15:41
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
B1016 14 [137] - Open or Short to Ground
Mileage: 29 km
Date: 2018.06.07
Time: 02:15:41
9445937 - Seat occupied recognition control module
B1022 31 [137] - No Signal
Reset counter: 36
Mileage: 29 km
Date: 2018.06.07
Time: 02:15:43
9445141 - Passenger's seat position sensor
B101F 15 [137] - Open or Short to Plus
Mileage: 29 km
Date: 2018.06.07
Time: 02:15:41
13635840 - Supply voltage
[Powersupply lower threshold fall short of]
Reset counter: 76
Mileage: 29 km
Date: 2018.06.10
Time: 04:12:41
9483264 - Seat Occupied Recognition
B10B4 00 [008] - Function Restriction due to Undervoltage
Reset counter: 76
Mileage: 29 km
Date: 2018.06.10
Time: 04:11:57
9483008 - Seat Occupied Recognition
B10B3 00 [008] - Function Restriction due to Implausible Message(s)
Reset counter: 76
Mileage: 29 km
Date: 2018.06.10
Time: 03:49:54
Part No SW: 1K5 953 521 BM HW: 5K0 953 569 AE
Component: LENKS.MODUL 016 0140
Revision: FF010042 Serial number: 20140603200150
Coding: 089A140000
ROD: EV_SMLSNGVOLWS.rod
VCID: F9BAA9E0787E498CE0-80AC
Component: E221__MFL-YVJ H07 0023
Coding: E30000
114178 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Reset counter: 76
Time: 00:00:00
136194 - Supply voltage
Reset counter: 76
Mileage: 29 km
Date: 2018.06.10
Time: 04:31:20
617742 - Selector Lever Park Position Lock Switch
B1162 07 [009] - Mechanical Failure
Reset counter: 36
Mileage: 29 km
Date: 2018.06.11
Time: 00:00:43
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 970 F HW: 561 920 970 F
Component: KOMBI H04 0811
Coding: 230800
Shop #: WSC 27461 001 104857
VCID: 9D729D708C16D5ACAC-80C8
[Supply voltage too low]
Reset counter: 76
Mileage: 29 km
Date: 2018.06.10
Time: 04:30:25
Part No SW: 7N0 907 530 AR HW: 7N0 907 530 AM
Component: J533 Gateway H55 1653
Revision: H55 Serial number: 07091403000360
Coding: 358400
VCID: 804CC40413A41844A7-80D4
Mileage: 29 km
Date: 2018.06.11
Time: 00:00:01
Address 1C: Position Sensing
Component: IMMO H04 0811
VCID: EA9886AC0DD8F21419-80BE
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0525
Revision: 13110009 Serial number: 0008855618
Coding: 0404B5
ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: DBF6D368D2829B9C92-808E
65538 - Local Data Bus
U10BA 00 [009] - No Communication
[Front Timeout LIN Sub bus]
Reset counter: 36
Mileage: 29 km
Date: 2018.06.07
Time: 02:19:44
B11EC 54 [009] - Missing Calibration / Basic Setting
Reset counter: 36
Mileage: 29 km
Date: 2018.06.07
Time: 02:19:44
67074 - Motors for Central Locking
B122B 01 [009] - Electrical Failure
Reset counter: 36
Mileage: 29 km
Date: 2018.06.07
Time: 01:00:36
67589 - Turn Signal in Exterior Mirror
B11FD 01 [009] - Electrical Failure
Reset counter: 36
Mileage: 29 km
Date: 2018.06.07
Time: 03:12:14
65793 - Supply voltage
[Front DCU undervoltage]
Reset counter: 76
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 211 3501
Revision: 00H22000
VCID: B93A69E0F0FE898CA0-80EC
Fault Status: 11100101
Date: 2018.03.10
Time: 00:11:47
Battery Volts: 12.1 V
DD
Temperature: 24.0°C
Count: 3
Steering Angle: 0.00°
SteerAng n.Init
Reset counter: 67
Voltage: 12.63 V
DD
Temperature: 23.0°C
Fault Status: 00101101
Fault Frequency: 14
Reset counter: 76
Mileage: 27 km
Date: 2018.05.10
Time: 09:54:49
Voltage: 14.38 V
DU
Temperature: 12.0°C
RPM: 1741 /min
Speed: 17.0 km/h
Speed: 17.0 km/h
Address 46: Central Conv.
Part No SW: 7N0 907 532 HW: 7N0 907 530 AM
Component: EZE_2 H55 1653
Coding: 00000000
VCID: EFAE97B83E3A173C4E-80BA
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0525
Revision: 15110009 Serial number: 0008877502
Coding: 0404B4
ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: DCF4D074D78C9CA49B-8088
Reset counter: 36
Mileage: 29 km
Date: 2018.06.07
Time: 02:21:14
Reset counter: 36
Mileage: 29 km
Date: 2018.06.07
Time: 02:21:14
Reset counter: 36
Mileage: 29 km
Date: 2018.06.07
Time: 01:00:36
Part No SW: 1K0 035 180 AE HW: 1K0 035 180 AE
Component: Radio Prem-8 H02 0016
Revision: -----16S Serial number: VWZ4Z7L3191183
Coding: 01000200000007
Shop #: WSC 00066 123 12345
VCID: E386EB88E2F2A35CDA-80B6
00856 - Radio Antenna
Reset counter: 36
Mileage: 29 km
Date: 2018.06.07
Time: 02:10:08
Reset counter: 36
Mileage: 29 km
Date: 2018.06.07
Time: 02:10:08
02633 - Antenna for Satellite Tuner
Reset counter: 36
Mileage: 29 km
Date: 2018.06.07
Time: 02:10:08
Reset counter: 36
Mileage: 29 km
Date: 2018.06.07
Time: 02:10:08
00532 - Supply Voltage B+
Reset counter: 76
Mileage: 29 km
Date: 2018.06.10
Time: 04:30:32
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Part No SW: 561 035 285 A HW: 561 035 285 A
Component: OCULowUSA 020 0156
Serial number: 000003554140528
Coding: 02140102C21612107F1606C00000
ASAM Dataset: EV_OCULow 002009
ROD: EV_OCULow_002.rod
VCID: 9464F8547FDC94E413-80C0
10 Faults Found:
12670208 - Databus
[CAN TO instrument cluster]
Reset counter: 67
Time: 00:00:00
0022 - Databus
[CAN TO radio]
Reset counter: 67
Date: 2018.04.08
Time: 01:17:55
0037 - Databus
[CAN TO Telephone ECU]
Fault Frequency: 104
Reset counter: 36
Time: 00:00:00
[supply voltage lower limit exceeded]
Reset counter: 76
Date: 2018.03.10
Time: 05:00:25
U1400 00 [008] - -
[restriction due to undervoltage]
Fault Frequency: 19
Reset counter: 76
Date: 2018.03.10
Time: 04:55:57
9455635 - Microphone 1
B129B 13 [009] - Open Circuit
Reset counter: 27
Date: 2018.03.10
Time: 00:11:47
9457171 - Audio signal output 1
B14F1 13 [009] - Open Circuit
Reset counter: 27
Time: 00:00:00
9458195 - Control Module for Cellular Telephone
B1052 13 [009] - Open Circuit
[roofline module open load]
Reset counter: 27
Date: 2018.03.10
Time: 00:11:47
9458451 - Cellular Antenna
B1053 13 [009] - Open Circuit
[GSM antenna open load]
Reset counter: 0
2566 - GPS Antenna
B1054 13 [009] - Open Circuit
[GPS antenna open load]
Reset counter: 0
End----(Elapsed Time: 00:59, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
