I'm still totally stuck on this one still.
I'm using a PQ35 H+ BCM, from a 2015 Passat Sport, 5K0937087AE, on which the car used the double relay 'dumb' wiper motor. As part of my Caddy 2K project (http://forums.ross-tech.com/showthr...My-latest-scan-from-the-biggest-Retrofit-ever) I need to run a J400 wiper setup.
I have added a wire to the N33 connector pin on the BCM, which is connected to the wiper setup, but cannot get the J400 to populate under the 09 CE module on the drop down section.
I have tested the motor and wiring on a 2009 GTI with the older style BCM (3C8937049E) and it worked immediately upon being installed.
At this point I'm totally guessing.. I have seen people retrofit the Rain Sensor using the N-33 pin on the NMS, which lets me know that it can receive a LINBus signal input, but I don't know if the BCM can handle the output for the wupers. I don't have an oscilloscope to verify if there is any LINBus activity currently.
Auto scan:
Auto scan:
Saturday,02,June,2018,23:09:55:42907
VCDS Version: 18.2.1.2 (x64) HEX-NET CB: 0.4411.4
VIN: XXX License Plate:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 4F 52 56 72 75
VIN: XXX Mileage: 20km-12miles
72-Door, Rear Right -- Status: Cannot be reached 1100
75-Telematics -- Status: Not registered 0011
Address 01: Engine (J623-CPRA) Labels:. 06K-907-425-V2.clb
Part No SW: 06K 906 071 K HW: 06K 907 425 C
Component: Simos18.2 H13 8104
Revision: --H13---
Coding: 001A0012242400170000
Shop #: WSC 09003 957 00200
ASAM Dataset: EV_ECM18TFS02006K906071K 001006
ROD: EV_ECM18TFS02006K906071AC.rod
VCID: B3265BC81A9273DC6A-80E6
19795 - EVAP System Leak Detection Pump Heater Control Circuit
P240A 00 [039] - Open Circuit
Mileage: 29 km
Date: 2018.06.02
Time: 02:14:58
Coolant temperature: 34 °C
Intake air temperature: 29 °C
Voltage terminal 30: 11.972 V
Engine: operating status: ES
STATE_LS_SAE[1]: INI
T_AST_SAE: 0 s
MAP_MES_SAE: 100 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
FAC_TPS_1_SAE: 18.359375 %
FUP_H_SAE: 15010.0 kPa
19798 - Control Circuit for EVAP Vent Control
P0447 00 [039] - Open Circuit
Mileage: 29 km
Date: 2018.06.02
Time: 02:14:58
T_AST_SAE: 0 s
MAP_MES_SAE: 99 kPa
19791 - EVAP Leak Detection Pump Control Circuit
P2400 00 [039] - Malfunction
Mileage: 29 km
Date: 2018.06.02
Time: 02:14:58
T_AST_SAE: 0 s
MAP_MES_SAE: 99 kPa
17178 - Databus
U1123 00 [039] - Received Error Message
Mileage: 29 km
Date: 2018.06.02
Time: 02:14:55
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Readiness: 1110 1101
Address 02: Auto Trans (J217) Labels:| 09G-927-749-V1.clb
Part No SW: 09G 927 749 B HW: 09G 927 749 B
Component: AISIN AG6 G3 109 2784
Coding: 000348
ASAM Dataset: EV_TCMAQ250031 001004
ROD: EV_TCMAQ250031_001_VW41.rod
VCID: B83C6CE403F490845F-80EC
22920 - Implausible Data Received from Parking Brake Control Module
U0417 00 [171] - -
Reset counter: 36
Mileage: 29 km
Engine speed: 0.0 /min
Transmission input speed: 0 /min
Transmission output speed: 0 /min
Engine torque: 0 Nm
Transmission fluid temperature: 25 °C
Accelerator position: 0.0 %
Clutch_C1: Open
Clutch_C2: Open
Clutch_C3: Open
Clutch_C4: Open
Clutch_B1: Open
Clutch_B2: Open
Lock Up Clutch: Open
Electrical Oil Pump target revolution: 65534 /min
Electrical Oil Pump actual revolution: 65279 /min
Engine Speed signal Current: 65279 /min
Electrical Oil Pump failure status with Electrical Oil Pump without HV 1: Motor normal stop
Electrical Oil Pump target current: 65278 mA
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: C54BC0F5492500FBA31103E892210041A1100012
VCID: 8444C81407BC046483-80D0
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:19
Count: 2
Count: 12
Count: 4096
Count: 16390
Count: 42496
Count: 512
Fault Status: 01100101
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:15
Count: 2
Count: 12
Count: 4096
Count: 291
Count: 42496
Count: 512
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
ROD: EV_ClimaBasis_VW36.rod
VCID: F5A2A5D054662DEC84-80A0
6 Faults Found:
9471253 - Temperature Sensor for Footwell Vent
B1085 15 [009] - Open or Short to Plus
Reset counter: 27
Date: 2018.03.09
Time: 03:18:43
9471509 - Temperature Sensor for Driver Side Vent in Dashboard
B1086 15 [009] - Open or Short to Plus
Reset counter: 27
Date: 2018.03.09
Time: 03:18:43
U1111 00 [008] - -
[Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
Reset counter: 67
Time: 00:00:00
13701536 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Türsteuergerät hinten rechts - kein Signal/Kommunikation]
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 02:57:58
9472533 - Temperature Sensor for Evaporator Vent
B108A 15 [008] - Open or Short to Plus
Reset counter: 67
Date: 2018.04.04
Time: 00:31:26
B10AB F0 [009] - Too Low
Reset counter: 27
Date: 2018.03.09
Time: 03:18:44
Part No SW: 5K0 937 087 AE HW: 5K0 937 087 AE
Component: BCM PQ35 H+ 122 0174
Revision: BL122001
Coding: 81200418802B080101080001060009004104A000408018207F8400000C70
VCID: F8BCACE44B7450849F-80AC
9 Faults Found:
00897 - Windshield Washer Pump (V5)
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:27
Voltage: 12.00 V
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:27
Voltage: 12.00 V
Reset counter: 76
Mileage: 29 km
Date: 2018.06.02
Time: 03:12:17
Voltage: 11.70 V
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 02:57:59
Voltage: 11.90 V
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 03:12:02
Voltage: 11.80 V
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 03:15:00
Voltage: 12.05 V
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 03:14:56
Voltage: 12.05 V
03188 - Bulb for Side Marker Light; Front Left
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 02:44:41
Voltage: 11.90 V
03189 - Bulb for Side Marker Light; Front Right
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 02:44:41
Voltage: 11.90 V
Part No SW: 5C0 959 655 AA HW: 5C0 959 655 AA
Component: AirbagVW10 500 0975
Serial number: 003LYD017DHN
Coding: 00004832
ROD: EV_AirbaVW10SMEVW360.rod
VCID: F1AA91C0200E01CC58-80A4
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Serial number: 3572MSME4E2F2D48ZZZC
Serial number: 3582MSME4A312D48ZZZ$
Subsystem 3 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3516KSME796E0A30ZZZ
Subsystem 4 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME1567702FZZZ
17 Faults Found:
9440027 - Driver's side; side-airbag igniter
B100B 1B [137] - Resistance Too High
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:41
9439771 - Front Passenger's Side Airbag Igniter
B100A 1B [137] - Resistance Too High
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:41
9438491 - Igniter for Driver head airbag
B1005 1B [137] - Resistance Too High
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:41
9438235 - Igniter for Front passenger's Head Curtain Airbag
B1004 1B [137] - Resistance Too High
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:41
9437723 - Igniter for Passenger's Airbag
B1002 1B [137] - Resistance Too High
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:41
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:41
B1007 1B [137] - Resistance Too High
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:41
9442075 - Driver's Belt Force Limiter Igniter
B1013 1B [137] - Resistance Too High
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:41
9442331 - Passenger's Belt Force Limiter Igniter
B1014 1B [137] - Resistance Too High
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:41
9437979 - Igniter 2 for Passenger's Airbag
B1003 1B [137] - Resistance Too High
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:41
9440539 - Driver's Safety Belt Tensioner Igniter 2
B100D 1B [137] - Resistance Too High
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:41
9441051 - Front passenger's safety belt tensioner igniter 2
B100F 1B [137] - Resistance Too High
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:41
9443605 - Rear Side Airbag Crash Sensor (on front passenger's side)
B1019 15 [137] - Open or Short to Plus
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:41
9443861 - Driver's Front Airbag Crash Sensor
B101A 15 [137] - Open or Short to Plus
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:41
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
B1016 14 [137] - Open or Short to Ground
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:41
9445937 - Seat occupied recognition control module
B1022 31 [137] - No Signal
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:43
9445141 - Passenger's seat position sensor
B101F 15 [137] - Open or Short to Plus
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:41
Part No SW: 1K5 953 521 BM HW: 5K0 953 569 AE
Component: LENKS.MODUL 016 0140
Revision: FF010042 Serial number: 20140603200150
Coding: 089A140000
ROD: EV_SMLSNGVOLWS.rod
VCID: F9BAA9E0787E498CE0-80AC
Component: E221__MFL-YVJ H07 0023
Coding: E30000
617742 - Selector Lever Park Position Lock Switch
B1162 07 [009] - Mechanical Failure
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 02:15:48
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 970 F HW: 561 920 970 F
Component: KOMBI H04 0811
Coding: 230A00
Shop #: WSC 27461 001 104857
VCID: 9D729D708C16D5ACAC-80C8
Part No SW: 7N0 907 530 AR HW: 7N0 907 530 AM
Component: J533 Gateway H55 1653
Revision: H55 Serial number: 07091403000360
Coding: 358400
VCID: 804CC40413A41844A7-80D4
6 Faults Found:
01771 - Control Module for Headlight Range (J431)
Fault Status: 01110100
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 02:18:02
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 02:57:59
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 02:18:06
Mileage: 29 km
Date: 2018.06.02
Time: 02:57:58
03272 - Control Module for Audio Interface
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 02:18:06
03605 - Control Module Auomatic Sliding Door, Rear Right
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 02:18:02
Address 1C: Position Sensing
Component: IMMO H04 0811
VCID: EA9886AC0DD8F21419-80BE
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0525
Revision: 13110009 Serial number: 0008855618
Coding: 0404B5
ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: DBF6D368D2829B9C92-808E
65538 - Local Data Bus
U10BA 00 [009] - No Communication
[Front Timeout LIN Sub bus]
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 02:19:44
B11EC 54 [009] - Missing Calibration / Basic Setting
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 02:19:44
67589 - Turn Signal in Exterior Mirror
B11FD 01 [009] - Electrical Failure
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 03:12:14
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 211 3501
Revision: 00H22000
VCID: B93A69E0F0FE898CA0-80EC
Fault Status: 11100101
Date: 2018.03.05
Time: 00:11:47
Battery Volts: 12.1 V
DD
Temperature: 24.0°C
Count: 3
Steering Angle: 0.00°
SteerAng n.Init
Reset counter: 67
Voltage: 12.63 V
DD
Temperature: 23.0°C
Fault Status: 00101101
Fault Frequency: 14
Reset counter: 76
Mileage: 27 km
Date: 2018.05.05
Time: 09:54:49
Voltage: 14.38 V
DU
Temperature: 12.0°C
RPM: 1741 /min
Speed: 17.0 km/h
Speed: 17.0 km/h
Part No SW: 7N0 907 532 HW: 7N0 907 530 AM
Component: EZE_2 H55 1653
Coding: 00000000
VCID: EFAE97B83E3A173C4E-80BA
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0525
Revision: 15110009 Serial number: 0008877502
Coding: 0404B4
ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: DCF4D074D78C9CA49B-8088
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 02:21:14
Reset counter: 36
Mileage: 29 km
Date: 2018.06.02
Time: 02:21:14
Part No SW: 1K0 035 180 AE HW: 1K0 035 180 AE
Component: Radio Prem-8 H02 0016
Revision: -----16S Serial number: VWZ4Z7L3191183
Coding: 01000400040007
VCID: E386EB88E2F2A35CDA-80B6
15 Faults Found:
01704 - Terminal 58 (Dimming)
Reset counter: 67
Date: 2018.03.05
Time: 00:11:47
00856 - Radio Antenna
Reset counter: 27
Date: 2018.03.05
Time: 00:11:47
Reset counter: 27
Date: 2018.03.05
Time: 00:11:47
Reset counter: 27
Date: 2018.03.05
Time: 00:11:47
Fault Status: 00101011
Reset counter: 67
Date: 2018.03.05
Time: 00:17:58
Reset counter: 36
Date: 2018.03.05
Time: 00:17:58
Reset counter: 36
Date: 2018.03.05
Time: 00:17:58
Reset counter: 67
Date: 2018.03.05
Time: 00:18:00
Fault Frequency: 10
Reset counter: 36
Date: 2018.03.05
Time: 00:18:00
Fault Frequency: 10
Reset counter: 36
Date: 2018.03.05
Time: 00:18:00
00532 - Supply Voltage B+
Reset counter: 69
Date: 2018.03.09
Time: 04:03:04
02633 - Antenna for Satellite Tuner
Reset counter: 27
Date: 2018.04.03
Time: 01:17:31
Reset counter: 67
Reset counter: 27
Reset counter: 27
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Part No SW: 561 035 285 A HW: 561 035 285 A
Component: OCULowUSA 020 0156
Serial number: 000003554140528
Coding: 02140102C21612107F1606C00000
ASAM Dataset: EV_OCULow 002009
ROD: EV_OCULow_002.rod
VCID: 9464F8547FDC94E413-80C0
10 Faults Found:
12670208 - Databus
[CAN TO instrument cluster]
Reset counter: 67
Time: 00:00:00
0022 - Databus
[CAN TO radio]
Reset counter: 67
Date: 2018.04.03
Time: 01:17:55
0037 - Databus
[CAN TO Telephone ECU]
Fault Frequency: 104
Reset counter: 36
Time: 00:00:00
13635840 - Supply voltage
[supply voltage lower limit exceeded]
Reset counter: 69
Date: 2018.03.05
Time: 05:00:25
U1400 00 [008] - -
[restriction due to undervoltage]
Fault Frequency: 9
Reset counter: 76
Date: 2018.03.05
Time: 04:55:57
9455635 - Microphone 1
B129B 13 [009] - Open Circuit
Reset counter: 27
Date: 2018.03.05
Time: 00:11:47
9457171 - Audio signal output 1
B14F1 13 [009] - Open Circuit
Reset counter: 27
Time: 00:00:00
9458195 - Control Module for Cellular Telephone
B1052 13 [009] - Open Circuit
[roofline module open load]
Reset counter: 27
Date: 2018.03.05
Time: 00:11:47
9458451 - Cellular Antenna
B1053 13 [009] - Open Circuit
[GSM antenna open load]
Reset counter: 0
2566 - GPS Antenna
B1054 13 [009] - Open Circuit
[GPS antenna open load]
Reset counter: 0
End----------(Elapsed Time: 01:12, VBatt start/end: 12.1V/12.1V)-----------
