Hi Ross-tech forum. Although I am using VCDS for a couple of years now this is my first question to you. I am having trouble with the airco of an Audi A6 avant 19tdi from 2002 (C5).
Apparently the airco has been out of order for some years now, I would like to fix it.
First I went to a car centre to remove the oil en gas and let it refill with new one.
The printout of the Waeco Aircon Service mentioned the remaining quantities: 6 ml of oil & 145 grams of coolant. The refill process added 11 ml of oil and 675 grams of coolant.
Unfortunately still no cold air…
I then hooked up my vcds and got a fault in module 08 Auto HVAC: “Fault 01592 – air quality sensor (G238) 37-00 – Faulty” (the airco fan did not run either). Since I have exactly the same sensor in my Audi A8 d3 I switched sensors. After that the error in mod 08 has disappeared and the airco fan is activated. Though, still no cold air ☹ (btw: the airco in my A8 is still doing it after the switch!)
So I saved a recent logfile and took some screenshots of the measuring blocks with the hope some of you specialised in airco can give me a clue where to look.
next thing I would have done is to clean the valves but they are not so easily reachable. So I’d prefer to wait for some input of someone who can read those measuring blocks, tia for your help, Peter
Monday,28,May,2018,20:10:33:30559
VCDS Version: 18.2.0.3
Dealer/Shop Name: PPS
Workshop Code: 202 01022 081940
VIN: WAUZZZ4B62N009964 License Plate: BRT
75 76 77
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 GF
Component: 1,9l R4 EDC G500SG 1434
Coding: 00002
Shop #: WSC 02325
VCID: 61C985E1EB3EF54C77-4AE8
WAUZZZ4B62N009964 AUZ5Z0A5070142
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 G
Component: ABS/ESP front 1328
Coding: 06255
Shop #: WSC 02325
VCID: 2541D1F1BF96596C4B-5106
Address 08: Auto HVAC Labels: 4B0-820-043-MY2.lbl
Part No: 4B0 820 043 AB
Component: A6-Klimavollautomat 0104
Coding: 00103
Shop #: WSC 02325
VCID: 5ABBB20DC668269436-257A
Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
Part No: 4B0 959 655 M
Component: Airbag 8.4E 3002
Coding: 0000106
Shop #: WSC 02325 785 00200
VCID: 3A7B128D7628C69416-5140
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 900 Q
Component: KOMBI+WEGFAHRS. M73 D09
Coding: 00140
Shop #: WSC 03141
VCID: 2B5527C9D9726F1C9D-4B00
No Faults Found
Address 35: Centr. Locks Labels:. 4B0-962-258.lbl
Part No: 4B0 962 258 K
Component: Zentralverrieg.,DWA D35
Coding: 04939
VCID: 316935A1FB5E05CCA7-4F06
6 Faults Found:
01559 - Drivers Door
58-10 - Can't Lock - Intermittent
01562 - Rear right door
59-00 - Can't Unlock
60-10 - Won't Safe - Intermittent
01560 - Passenger Door
60-00 - Won't Safe
61-00 - Won't De-Safe
01134 - Alarm Horn (H12)
76-10 - Terminal 30 missing - Intermittent
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00002
Shop #: WSC 02325
VCID: 60CF80E5E034FC4478-4B1A
Address 76: Park Assist Labels: 8Z0-919-283.lbl
Part No: 8Z0 919 283
Component: Parkingsyst. A6 RDW D08
Coding: 00116
Shop #: WSC 02325
VCID: 020BAA6D0E784E540E-5140
End-------------------------(Elapsed Time: 06:32)--------------------------
Tuesday,29,May,2018,17:52:20:30559
75 76 77
Coding: 00002
Shop #: WSC 02325
Coding: 06255
Shop #: WSC 02325
VCID: 2541D1F1BF96596C4B-5124
Coding: 00103
Shop #: WSC 02325
VCID: 5ABBB20DC668269436-2580
Coding: 0000106
Coding: 00140
Shop #: WSC 03141
No Faults Found
Coding: 04939
VCID: 316935A1FB5E05CCA7-4F20
60-00 - Won't Safe
Coding: 00002
Shop #: WSC 02325
VCID: 60CF80E5E034FC4478-4B32
Coding: 00116
Shop #: WSC 02325
End-------------------------(Elapsed Time: 06:21)--------------------------
