hello,can anyone help with this abs coding,the new owner does not have a previous repair history apart from the engine ECU being taken out of car and swapped with another one to see if some unexplained faults could go away,I have tried some codes in another thread on mk60 here but not successful so far,I can see that VIN in ECU and IMMO advanced ID match,however theres a fault of immo not being adapted,[i do not know whether immo was bench flashed] i cleared it,it has not come back,but will check if it resurfaces tomorrow,any insights will be greatly appreciated,below are
the autoscans
the autoscans
Friday,25,May,2018,07:13:09:48669
VCDS Version: 18.2.1.2 (x64) HEX-V2 CB: 0.4411.4
Dealer/Shop Name: FREDRICK'S VWAUDI
VIN: WVWZZZ1KZ9U009952 License Plate: CF933Y
Mileage: 114580km-71196mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72
VIN: WVWZZZ1KZ9U009952 Mileage: 114580km-71196miles
03-ABS Brakes -- Status: Not registered 0011
Address 01: Engine Labels: 03C-906-032-BLG.lbl
Part No SW: 03C 906 032 AK HW: 03C 906 032 C
Component: MED17.5.1 G 6457
Revision: 96H07--- Serial number: VWX7Z0H63N881O
Coding: 0000075
Shop #: WSC 43127 000 1048576
VCID: 6696BF75B46C2CE7EBB-8032
049441 - No Communication with ABS Brake Control Module
U0121 - 000 - - Intermittent
Mileage: 114571 km
Time: 01:15:21
RPM: 1766 /min
Load: 29.4 %
Temperature: 87.0°C
Temperature: 33.0°C
Absolute Pres.: 830.0 mbar
Voltage: 13.589 V
Part No SW: 02E 300 051 F HW: 02E 927 770 AJ
Component: GSG DSG AG6 431 1803
Revision: 04843012 Serial number: 00000807060297
Shop #: WSC 44551 111 44551
VCID: 1676CFB5C48C7C67BBB-8042
18259 - Powertrain Data Bus
P1851 - 000 - Missing Message from ABS Controller - Intermittent
Fault Frequency: 255
Reset counter: 40
Mileage: 114466 km
18261 - Powertrain Data Bus
P1853 - 000 - Implausible Message from ABS Controller - Intermittent
Reset counter: 40
Mileage: 114466 km
Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Shop #: WSC 00046 412 00000
VCID: 75B4E839F5CAD77F521-8020
6 Faults Found:
Reset counter: 30
Mileage: 114467 km
Count: 7
Count: 512
Count: 294
Count: 48390
Reset counter: 245
Mileage: 114466 km
Count: 7
Count: 14
Count: 12800
Count: 195
Count: 48640
Count: 57344
01130 - ABS Operation
Reset counter: 245
Mileage: 114466 km
Count: 7
Count: 14
Count: 12800
Count: 100
Count: 48640
Count: 57344
00150 - Plausibility Brake Booster System
Reset counter: 245
Mileage: 114466 km
Count: 7
Count: 14
Count: 12800
Count: 398
Count: 48640
Count: 57344
014 - Defective
Fault Status: 01101110
Reset counter: 245
Mileage: 114466 km
Count: 7
Count: 4608
Count: 104
Count: 48152
Count: 65280
01312 - Powertrain Data Bus
014 - Defective
Fault Frequency: 7
Reset counter: 248
Mileage: 114466 km
Count: 7
Count: 14
Count: 8704
Count: 161
Count: 48384
Count: 57600
Part No SW: 1K0 907 044 DD HW: 1K0 907 044 DD
Component: ClimatronicPQ35 130 1213
Revision: 00130023 Serial number: 00000000000000
VCID: 6C82CD5DAA8016B7BDF-8038
Revision: 00H54000 Serial number: 00000008680100
Coding: 038F0F2700041500471400001400000000097F075C000100000000000000
VCID: 33301621B73E894FBC5-8066
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 030908 020 0501
Coding: 00049109
Shop #: WSC 00046
Reset counter: 248
Mileage: 114466 km
Voltage: 13.55 V
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 15 AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D0BFBUE
Coding: 0012597
Subsystem 1 - Serial number: 6332MSME3D51026DE
Subsystem 2 - Serial number: 6342MSME3B3571248
Subsystem 3 - Serial number: 6352QSME69623159I
Subsystem 4 - Serial number: 6362QSME73472C71L
Part No SW: 1K0 953 549 BS HW: 1K0 953 549 BS
Component: J0527 752 0101
Coding: 0012142
VCID: 045285FDA210FEF755F-8050
Component: E0221 002 0010
Part No SW: 1K0 920 864 G HW: 1K0 920 864 G
Component: KOMBIINSTRUMENT VDD 1212
Revision: V0002000 Serial number: VWX7Z0H63N881O
Coding: 0007503
Shop #: WSC 50942 000 942208
VCID: 303A192D4628B257C17-8064
Reset counter: 31
Mileage: 114549 km
Time: 00:00:05
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 080608F2001714
Coding: E5817F060002020003
Shop #: WSC 00046 412 12345
VCID: 35342839B94A977F921-8060
Fault Frequency: 46
Reset counter: 247
Mileage: 114466 km
Time: 11:18:22
Mileage: 114466 km
Time: 11:18:22
Component: IMMO VDD 1212
02241 - Engine Control Module; Immobilizer Data not Adapted
Mileage: 114466 km
Time: 11:18:20
Part No SW: 1K0 959 701 N HW: 1K0 959 701 N
Component: Tuer-SG 006 1210
Coding: 0000694
VCID: 392C24099552731F769-806C
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 69 2301
Revision: 00H15000
VCID: 2A0E0B4560F4C8870F3-807E
Fault Frequency: 140
Reset counter: 43
Mileage: 114580 km
Time: 10:45:18
Voltage: 14.00 V
DU
Temperature: 38.0°C
RPM: 1235 /min
Speed: 47.0 km/h
Speed: 47.0 km/h
Part No SW: 1K0 959 433 CA HW: 1K0 959 433 CA
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 809002005103087F2D0484056008DF03E0FCA0
VCID: 71BCDC298DA2FB5F8E9-8024
Part No SW: 1K0 959 702 N HW: 1K0 959 702 N
Coding: 0000950
VCID: 3A2E3B05905478077F3-806E
00097 - Front Passengers Central Locking (Safe) Motor (V162)
00942 - Exterior Mirror Retract Motor; Passenger Side (V122)
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74B2D53DF2B0CE7765F-8020
Address 56: Radio
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 006 1301
Coding: 0000144
Shop #: WSC 00046 412 1012544
VCID: 382A210DAE586A17897-806C
00098 - Rear Left Central Locking (Safe) Motor (V163)
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Coding: 0000144
01814 - Supply Voltage for Door Controller; Rear Right (J389)
End----------(Elapsed Time: 01:14, VBatt start/end: 13.8V/13.8V)-----------
Friday,25,May,2018,15:06:28:48669
VIN: WVWZZZ1KZ9U009952 License Plate: CF935Y
Control Module Part Number: 1K0 920 864 G
Component and/or Version: IMMO VDD 1212
Software Coding:
Work Shop Code: WSC 00000
Advanced Identification
Identification: VDD-024
Revision: V0002000
Date: 08.07.08
Test stand number: 7702
Manufacturer number: 0428
Flash Status
Programming Attempts: 0
Successful Attempts: 0
Programming Status: 00000000
Required Conditions: 00000000
Flash Tool Code: 00000 000 00000
Flash Date: --.--.--
Software
DKBI339
Y012
Z0012
Misc.
Hardware number: 1K0 920 864 G
Lot Number: 000
Type Lock: 0000
Car Info
Chassis Number: WVWZZZ1KZ9U009952
VCDS Info:
