AUDI TSB 00, 06-07
rstjohn003
C?ID=34952
I have a 07 cabrio with many of these open circuit faults. I little research led me to this TSB. As you can read its not much help. Has anyone run into this before?
Thanks
Rick
MIL ON - SEVERAL DTCS STORED IN THE ECM DATA MEMORY
TECHNICAL SERVICE BULLETIN
Reference Number(s): GROUP 00, NO. 06-07 (2013275/1), Date of Issue: October 30, 2006
AUDI: A3 2006-2007; A4 2006-2007; A4 Cabriolet 2007
GROUP: 00 - General
00 06 07 Oct 30, 2006, 2013275/1
APPLICABLE MODELS AND YEARS
Model(s) Year VIN Range Vehicle-Specific Equipment
A3 2006-2007 all 2.0 TFSI engine
A4 2006-2007 all 2.0 TFSI engine
3.2 V6 FSI engine
A4 Cabriolet 2007 all 2.0 TFSI engine
3.2 V6 FSI engine
CONDITION
MIL on and a combination of several of the following DTCs are stored in the ECM data memory.
DTC DTC Description
P0030 O2 sensor heater circuit, Bank 1 Sensor 1, Open Circuit
P0031 O2 sensor heater circuit, Bank 1 Sensor 1, Short to ground
P0033 Turbocharger bypass valve electrical malfunction
P0034 Turbocharger bypass valve, Short to Ground
P0036 O2 sensor heater circuit, Bank 1 Sensor 2, Open Circuit
P0243 Boost Pressure control valve, Open/Short to Ground
P0245 Boost Pressure control valve, Short to Ground
P0444 Evaporative emission system purge control valve circuit, open
P0458 Tank ventilation valve circuit, short to ground
P0685 ECM/PCM power relay circuit, open
P0686 ECM/PCM power relay control circuit, low
P0687 ECM/PCM power relay control circuit, high
P0688 ECM/PCM power relay control circuit, open
P1572 Left electro-hydraulic engine mount solenoid valve, short to ground
P1573 Left electro-hydraulic engine mount solenoid valve, open
P2294 Fuel pressure regulator control circuit, open
P2295 Fuel pressure regulator 2 control circuit, low
TECHNICAL BACKGROUND
Not applicable.
PRODUCTION SOLUTION
Not applicable.
SERVICE
Do not attempt to repair and do not replace the Engine Control Module power supply relay J271 or the Engine Component power supply relay J757.
Please create a Technical Assistance Contact Ticket under the Concern Type "Engine and Engine Electronics" in ElsaWeb and call the Audi Technical Assistance Center (Audi Helpline) for assistance.
WARRANTY
This TSB is informational only and not applicable to any Audi warranty.
Is it just me or does that TSB sounds like they're trying to hide something?
Given that the cars in that list are quite different (transverse 2.0T, longitudinal 2.0T and longitudinal 3.2 V6) makes me wonder what they miiight have in common?
Please post an Auto-Scan for context.
rstjohn003
C?ID=34952
Sorry, customer was a waiter oil change. So I cleared the ECU faults and let him go to see what comes back. I can post an auto scan if he drops car back off. Basically had open circuit faults for both engine mounts, N80, Turbocharger bypass valve,N276, LDP, and B1 S1 heater circuit. The relays or a common ground were my first thought, but Audi says no to the relays?
If you did an Auto-Scan at all, it got auto-saved to your Scans sub-folder...
Yeah, looking in the wiring diagrams for something all that stuff has in common would be the logical approach.
Yup........!
XXXXXXXXXXXXXXXXXXXXXXXX
Post an auto-scan I will share.
Hide what and where?
That's an awful lot of DTC's isn't it?
Did you observe what is shared by the ECU or supply relays in WD?
It should become apparent real fast......let's look at them together, post screen shots!
rstjohn003
C?ID=34952
I saw that they all share J757 but the TSB says don't replace it. So my question is, is there a known harness or panel problem? The problem is intermittent. My first thought was to put the relay in and let him go, but them I found the TSB.
Show your work.......step by step.
The relays can indeed be bad too & the TSB isn't totally accurate and relays do fail as a result of XXXXXX?
