Hello Everyone.
My name is Kenny and I have a 2000 Eurovan. I am new and here is an autoscan for all to see.
My question for now is, on measuring block 160, what is the third block (lambda) for? It is supposed to show 25% but it shows 0% for me. the second box shows 8%.
I have tried the auto start / output tests and when I get to the Secondary Air, it starts and stops and starts and stops, cycling through till I go to the next test.
When I start the bus the SAI does not run at all and I get a fault code P0411. The IAT and ECT seem to be working (same temp to start, then both increase at different rates), so what does the ECM need to get to make the SAI run?
Any help would be appreciated.
Kenny
Chassis Type: 7D - VW Transporter/Multivan (1996 > 2004)
Scan: 01 02 03 08 15 17 18 19 22 25 35 37 56
Mileage: 362820km-225445miles
Address 01: Engine Labels: 021-906-259-AES.lbl
Part No: 021 906 259 P
Component: MOTRONIC M5.9 AT V03
Coding: 00001
VCID: 2245125BAEB41156A7-4B18
16826 - EVAP Emission Control Sys
P0442 - 35-00 - Small Leak
16806 - Main Catalyst; Bank 1
P0422 - 35-10 - Efficiency Below Threshold - Intermittent
16795 - Secondary Air Injection System
P0411 - 35-00 - Incorrect Flow Detected
17816 - EGR Temp Sensor (G98)
P1408 - 35-10 - Signal too Large - Intermittent
Readiness: 0000 1000
Address 02: Auto Trans Labels: 01P-927-733.lbl
Part No: 01P 927 733 BC
Component: AG4 Getriebe 01P 4478
Coding: 00000
VCID: 75EF19074FBAD6EEB2-0960
Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl
Part No: 7D0 614 111 B
Component: ABS/EDS 5.3 D00
Shop #: BB 24258
VCID: 1B3B2FBF89DE209E64-513C
Part No: 7D0 907 040
Component: CLIMATRONIC T4 E3.4
Coding: 00032
Shop #: WSC 02743
VCID: 5FC35BAFDD467CBEC8-259E
01086 - Speedometer Sensor (G22)
35-00 - -
00658 - Control Head
35-10 - - - Intermittent
Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl
Part No: 1J0 909 603 AJ
Component: AIRBAG VW3 - V04
Coding: 16714
Shop #: WSC 02743
VCID: 71E72D173BD2FACE6E-4B18
Address 17: Instruments Labels: 7D0-920-xxx-17.lbl
Part No: 7D0 920 901 E
Component: T4-KOMBIINSTR. VDO V01
Coding: 03261
VCID: 254F0947BF9AE66EC2-513C
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1J0 035 180 D
Component: RADIO 3CP 0001
Coding: 09400
Shop #: WSC 85469
VCID: 20411853A0B80346B1-4B00
Kenny
