01794 - Control Module Incorrect Chassis (VIN) Number
rayjones
New Member
i have an a4 3.2 quartro the air bag went off so i sent it away to be cleared but now it is show incorrect vin number
i have done a VAG_COM auto scan
Monday,06,October,2014,17:16:42:55497
VCDS Version: 12.12.3.0 (x64)
Data version: 20140905
VIN: WAUZZZ8H77K005106   License Plate:
Mileage: 69490km-43179mi   Repair Order:
Chassis Type: 8H (8H - Audi Cabrio B6/B7 (2003 > 2009))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 26 36 37 45 46 55 56 57
          63 65 67 73 75 76 77
VIN: WAUZZZ8H77K005106   Mileage: 69490km/43179miles
Address 01: Engine (AUK)       Labels: 06E-910-559-BKH.lbl
   Part No SW: 8E0 910 559 Q    HW: 8E0 907 559
   Component: 3.2l V6 FSI         0020
   Revision: --H16---    Serial number:
   Coding: 01040003190F0120
   Shop #: WSC 00672 785 00200
   VCID: 3B7170697ABD69C68EF-806E
Readiness: 0110 0001
   Part No SW: 8E1 910 156 E    HW: 09L 927 156 B
   Component: AG6 09L 3,2 FSI RdW 0040
   Revision: --H01---    Serial number:        4140560
   VCID: 295DBA218021EB56EC3-807C
002309 - Gate Select Position Circuit for Tiptronic (F189)
               P0905 - 000 - Implausible Signal
                    Fault Status: 01110000
                    Reset counter: 40
                    Mileage: 68991 km
                    Date: 2064.00.00
                    Time: 00:00:00
                    RPM: 704 /min
                    (no units): 23.0
                    (no units): 41.0
                    Temperature: 65.0∞C
                    T.B. Angle: 0.0∞
Address 03: ABS Brakes        Labels: 8E0-910-517.clb
   Part No SW: 8E0 910 517 E    HW: 8E0 614 517 AL
   Component: ESP8 quattro    H06 0120
   Coding: 0004532
                    Reset counter: 40
                    Hex Value: 0x0000
                    Hex Value: 0x4000
                    Hex Value: 0x0013
                    Hex Value: 0x16A4
                    Hex Value: 0x0001
   Part No: 8E0 820 043 BM
   Component:   A4 Klimaautomat   2832
   Coding: 00100
   Shop #: WSC 00672
   VCID: 6DD58E312749377640B-515A
Address 09: Cent. Elect.        Labels: 8E0-907-279-8EC.lbl
   Part No: 8E0 907 279 N
   Component: int. Lastmodul  ECE 0907
   Coding: 21021
   VCID: 3D757E7137A967F6B0B-4B18
02071 - Local Databus
            57-00 - Electric Circuit Failure
Address 15: Airbags        Labels: 8H0-959-655-94.lbl
   Part No SW: 8H0 959 655 E    HW: 8H0 959 655 E
   Component:    Airbag 9.42  H09 1840
   Revision: 92H09184    Serial number: 0037Y000509F
   Coding: 0071114
   Shop #: WSC 00763 551 00000
   VCID: 3C7373757FB36EFE875-8069
   Subsystem 1 - Serial number: 6332BRB400EC709AX
   Subsystem 2 - Serial number: 6342BRB400EC7132L
   Subsystem 3 - Serial number: 63729RB4021F49FE0
   Subsystem 4 - Serial number: 63829RB4021F4967S
24 Faults Found:
01794 - Control Module - Incorrect Chassis (VIN) Number
            000 - - - MIL ON
                    Fault Status: 11100000
                    Date: 2064.00.00
                    Time: 00:00:00
                    Date: 2064.00.00
                    Time: 00:00:00
01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
            011 - Open Circuit - Intermittent - MIL ON
                    Fault Status: 10101011
                    Date: 2064.00.00
                    Time: 00:00:00
01221 - Crash Sensor Side Airbag; Driver Side (G179)
                    Date: 2064.00.00
                    Time: 00:00:00
01222 - Crash Sensor Side Airbag; Passenger Side (G180)
                    Date: 2064.00.00
                    Time: 00:00:00
01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
                    Date: 2064.00.00
                    Time: 00:00:00
                    Date: 2064.00.00
                    Time: 00:00:00
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
            009 - Open or Short to Ground - Intermittent - MIL ON
                    Fault Status: 10101001
                    Date: 2064.00.00
                    Time: 00:00:00
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
            010 - Open or Short to Plus - Intermittent - MIL ON
                    Fault Status: 10101010
                    Date: 2064.00.00
                    Time: 00:00:00
01217 - Side Airbag Igniter; Driver Side (N199)
            001 - Upper Limit Exceeded - Intermittent - MIL ON
                    Fault Status: 10100001
                    Date: 2064.00.00
                    Time: 00:00:00
01211 - Belt Tensioner Igniter; Rear Driver Side (N196)
                    Date: 2064.00.00
                    Time: 00:00:00
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
                    Date: 2064.00.00
                    Time: 00:00:00
01212 - Belt Tensioner Igniter; Rear Passenger Side (N197)
                    Date: 2064.00.00
                    Time: 00:00:00
                    Date: 2064.00.00
                    Time: 00:00:00
01587 - Igniter 2 for Airbag; Drivers Side (N250)
                    Date: 2064.00.00
                    Time: 00:00:00
01762 - Solenoid for Roll-Over Protection; Pass. Side (N310)
                    Date: 2064.00.00
                    Time: 00:00:00
01761 - Solenoid for Roll-Over Protection; Drivers Side (N309)
                    Date: 2064.00.00
                    Time: 00:00:00
00589 - Airbag Igniter 1; Passenger Side (N131)
                    Date: 2064.00.00
                    Time: 00:00:00
                    Date: 2064.00.00
                    Time: 00:00:00
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
                    Fault Status: 11100001
                    Date: 2064.00.00
                    Time: 00:00:00
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
                    Date: 2064.00.00
                    Time: 00:00:00
01312 - Powertrain Data Bus
                    Fault Status: 00110100
                    Date: 2064.00.00
                    Time: 00:00:00
00595 - Crash Data Stored
            000 - - - Intermittent - MIL ON
                    Fault Status: 10100000
                    Date: 2064.00.00
                    Time: 00:00:00
00003 - Control Module
            014 - Defective - MIL ON
                    Fault Status: 11101110
                    Date: 2064.00.00
                    Time: 00:00:00
   Part No: 8E0 953 549 Q
   Component: Lenks·ulenmodul     0601
   Coding: 03141
   Shop #: WSC 00672
   VCID: 418D02814B510316D43-4B18
            49-00 - No Communications
Address 17: Instruments        Labels: 8E0-920-9xx-8EC.lbl
   Part No SW: 8H0 920 981 E    HW: 8H0 920 981 E
   Component: KOMBI+WFS 4     H14 0110
   Revision: 0110        Serial number: 00000000000000
   Coding: 0007411
   Shop #: WSC 01066 210 64753
   VCID: 326F5D4DAEF7A88E5D9-515A
01771 - Control Module for Headlight Range (J431)
Address 25: Immobilizer        Labels: 8E0-920-9xx-8EC.lbl
   Coding: 0007411
Address 26: Auto Roof        Labels: 8H0-959-255.lbl
   Part No: 8H0 959 255 A
   Component:  VSG  B6 CABRIO     6792
   VCID: 34635B5554E3A6BE4F5-513C
00470 - Combination comfort Databus in Single Wire
00532 - Supply Voltage B+
Address 37: Navigation        Labels: 8E0-035-192-RNSE.lbl
   Part No SW: 8H0 035 192 A    HW: 8H0 035 192 A
   Component: RNS-E HIGH EU   H72 0460
   Revision:      03S    Serial number: AUZBZ7F1226564
   Coding: 0419717
   VCID: 2545B611EF39CF36C8B-5196
                    Fault Frequency: 147
                    Reset counter: 46
                    Date: 2005.02.10
                    Time: 00:05:17
                    Voltage: 10.50 V
                    Mileage: 655350 km
                    Count: 610
                    Clock: 17:04
                    Reset counter: 229
                    Date: 2005.02.10
                    Time: 00:00:22
02446 - Disk Drive Mechanical Malfunction
                    Reset counter: 186
                    Date: 2010.12.07
                    Time: 12:23:53
Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
   Part No: 8H0 951 178
   Component: Innenraumueberw.   0411
   Coding: 00001
   VCID: EFE91439AD454566F27-513C
01350 - Alarm via Theft Warning System; Rear
            43-00 - Closed
            81-00 - OPEN
01349 - Alarm via Theft Warning System; Front
            43-00 - Closed
Address 46: Central Conv.        Labels: 8E0-959-433-MAX.lbl
   Part No: 8H0 959 433 K
   Component: Komfortger·t T3B    5040
   Coding: 06799
   Shop #: WSC 00672
   VCID: 3C7373752CB36EFE875-4B00
   Subsystem 1 - Part No: 8H2959802D
   Component: Tırsteuer.FS BRM 0205
   Subsystem 2 - Part No: 8H2959801D
   Component: Tırsteuer.BF BRM 0205
   Subsystem 3 - Part No: 8H0959801A
   Component: Tırsteuer.HL BRM 0002
   Subsystem 4 - Part No: 8H0959802A
   Component: Tırsteuer.HR BRM 0002
9 Faults Found:
01134 - Alarm Horn (H12)
            29-00 - Short to Ground
01616 - Signal Wire to Interior Monitor
01370 - Alarm triggered by Interior Monitoring
            35-00 - -
            35-00 - -
            35-00 - -
            35-00 - -
01373 - Alarm triggered by Radio Ground Contact
            35-00 - -
01366 - Opened Due to Crash Signal
            35-00 - -
Address 56: Radio        Labels: 8E0-035-192-RNSE.lbl
   Coding: 0419717
   VCID: 2545B611EF39CF36C8B-5178
                    Reset counter: 46
                    Date: 2005.02.10
                    Time: 00:05:17
                    Voltage: 10.50 V
                    Mileage: 655350 km
                    Count: 610
                    Clock: 17:04
                    Reset counter: 229
                    Date: 2005.02.10
                    Time: 00:00:22
                    Reset counter: 186
                    Date: 2010.12.07
                    Time: 12:23:53
Address 63: Entry Assist,D        Labels: None
   Part No: 8H0 959 760 A
   Component: EasyEntry F   H13   0010
   Coding: 00005
   Shop #: WSC 00065
   VCID: 356566510F99BFB678B-4B18
            35-00 - -
Address 73: Entry Assist, P        Labels: None
   Component: EasyEntry BF  H13   0010
   Coding: 00005
   Shop #: WSC 00065
   VCID: 356566510F99BFB678B-4B00
            35-00 - -
Address 76: Park Assist        Labels: 8E0-919-283-8EC.lbl
   Part No SW: 8E0 919 283 D    HW: 8E0 919 283 D
   Component: Parkhilfe 4-Kan H06 0010
   Revision: 00H06000    Serial number: 00067802020603
   Coding: 0001024
   VCID: 316D5241ABF19396243-515A
01336 - Data Bus for Comfort System
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 48
is there any help i don't know what to do
rayjones
New Member
-17940 error code incorrect chassis number
can anyone help me
mair bag went off in my A4 3.2 quartro
i sent the airbag module off to clear the crash data
using a VAG-COM i did a auto scan
and it returned this below
                    Reset counter: 40
                    Mileage: 68991 km
                    Date: 2064.00.00
                    Time: 00:00:00
                    RPM: 704 /min
                    (no units): 23.0
                    (no units): 41.0
                    Temperature: 65.0∞C
                    T.B. Angle: 0.0∞
   Coding: 0004532
                    Reset counter: 40
                    Hex Value: 0x0000
                    Hex Value: 0x4000
                    Hex Value: 0x0013
                    Hex Value: 0x16A4
                    Hex Value: 0x0001
   Coding: 00100
   Shop #: WSC 00672
   Coding: 21021
   Coding: 0071114
24 Faults Found:
            000 - - - MIL ON
                    Date: 2064.00.00
                    Time: 00:00:00
                    Date: 2064.00.00
                    Time: 00:00:00
                    Date: 2064.00.00
                    Time: 00:00:00
                    Date: 2064.00.00
                    Time: 00:00:00
                    Date: 2064.00.00
                    Time: 00:00:00
                    Date: 2064.00.00
                    Time: 00:00:00
                    Date: 2064.00.00
                    Time: 00:00:00
                    Date: 2064.00.00
                    Time: 00:00:00
                    Date: 2064.00.00
                    Time: 00:00:00
                    Date: 2064.00.00
                    Time: 00:00:00
                    Date: 2064.00.00
                    Time: 00:00:00
                    Date: 2064.00.00
                    Time: 00:00:00
                    Date: 2064.00.00
                    Time: 00:00:00
                    Date: 2064.00.00
                    Time: 00:00:00
                    Date: 2064.00.00
                    Time: 00:00:00
                    Date: 2064.00.00
                    Time: 00:00:00
                    Date: 2064.00.00
                    Time: 00:00:00
                    Date: 2064.00.00
                    Time: 00:00:00
                    Date: 2064.00.00
                    Time: 00:00:00
                    Date: 2064.00.00
                    Time: 00:00:00
                    Date: 2064.00.00
                    Time: 00:00:00
                    Date: 2064.00.00
                    Time: 00:00:00
                    Date: 2064.00.00
                    Time: 00:00:00
                    Date: 2064.00.00
                    Time: 00:00:00
   Coding: 03141
   Shop #: WSC 00672
   Coding: 0007411
   Coding: 0007411
   Coding: 0419717
                    Reset counter: 46
                    Date: 2005.02.10
                    Time: 00:05:17
                    Voltage: 10.50 V
                    Mileage: 655350 km
                    Count: 610
                    Clock: 17:04
                    Reset counter: 229
                    Date: 2005.02.10
                    Time: 00:00:22
                    Reset counter: 186
                    Date: 2010.12.07
                    Time: 12:23:53
   Coding: 00001
            43-00 - Closed
            81-00 - OPEN
            43-00 - Closed
   Coding: 06799
   Shop #: WSC 00672
9 Faults Found:
            35-00 - -
            35-00 - -
            35-00 - -
            35-00 - -
            35-00 - -
            35-00 - -
   Coding: 0419717
                    Reset counter: 46
                    Date: 2005.02.10
                    Time: 00:05:17
                    Voltage: 10.50 V
                    Mileage: 655350 km
                    Count: 610
                    Clock: 17:04
                    Reset counter: 229
                    Date: 2005.02.10
                    Time: 00:00:22
                    Reset counter: 186
                    Date: 2010.12.07
                    Time: 12:23:53
   Coding: 00005
   Shop #: WSC 00065
            35-00 - -
   Coding: 00005
   Shop #: WSC 00065
            35-00 - -
   Coding: 0001024
            014 - Defective
                    Reset counter: 48
any help would be appreciated.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
According to these fault codes in your Airbag module:
Your next steps are:
1) Get a refund from whomever "cleared" this airbag module for you
2) Throw this airbag module in the trash
3) Order and install a new genuine airbag module from an Audi dealer, ordered specifically for your car by VIN
The entry assist modules 63 and 73 are also showing incorrect chassis VIN codes. Were those components, or any Immobilizer components (instrument cluster, ECUs) swapped out during your repairs? Is the VIN shown at the top of your Auto-Scan correct for this car?
Jason
Was the car in a crash or did the airbag just "go off"?
You have bigger worries there than "01794 - Control Module - Incorrect Chassis (VIN) Number ", specifically "00003 - Control Module 014 - Defective".
PS: Please register your system with us for support by filling out this form.
PPS: Threads merged.
rayjones
New Member
reply to jason comment
Jason
none were swapped on the repair and the airbag module is the same one i took out of the car
rayjones
New Member
yes the car was in a crash
rayjones
New Member
yes the car was in a crash what must i do now
I think Jason's previous advice was spot-on:
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
The process of "clearing" an airbag control module is very sketchy. They are not designed to be re-used after a crash. If this vendor's clearing process succeeded, the "Crash Data Stored" DTC should have gone away, and even then "success" is unclear since it's not like they can crash it again to test. In this case, they didn't even manage to clear the "Crash Data Stored" DTC, so they didn't do their job.
You also have a "Control Module - Defective" DTC. This means the airbag control module is even more trash than it already was, very possibly due to tampering by the vendor that tried to clear crash data by unapproved means.
You need a new airbag control module, from a dealer, ordered using your VIN so it's matched to your car.
Jason
rayjones
New Member
thank u jason
Jason
ill have to go back to the firm that tried to clear the crash data
I'm i right in saying that they made the module defective
while a new airbag module clear all the faults
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
It's very possible (but not definite) that they broke the module in some way while trying to clear crash data.
Again, I do not recommend using a used airbag module. Even if the airbag warning light is off, there's no particular guarantee it will actually deploy airbags in a future crash.
A new airbag controller would not have the crash-data stored and control module defective DTCs. It would probably also clear up the airbag igniter DTCs. Those are all flagged as intermittent and would probably go away if cleared. I'm assuming you've installed new airbags.
It would still probably show the seatbelt tensioner DTCs. Those are not flagged as intermittent; they are still a problem. There are one-shot pyrotechnic devices in the seatbelt re-winder mechanisms that tighten the seatbelts during a crash. They will need to be replaced, just like the airbags.
Jason
rayjones
New Member
i have now got a new module for the audi how can i install it using a vag com
rayjones
New Member
rayjones
New Member
hi jason young thank you for your advise i have now brought a new air bag module but how can i install it with a vag com
After you register your system with us for support, like we asked almost one year ago, and we can make you a Verified User here, then we'll tell you. :D
ajea7474
C?ID=170603
I have the same problem with an audi a4 2005. I bought this car and car fax is clean don't look like was in a crash.
Address 15: Airbags        Labels: 8E0-959-655-94.lbl
   Part No SW: 8E0 959 655 H    HW: 8E0 959 655 H
   Component:    Airbag 9.41  H10 3230
   Revision: 91H10323    Serial number: 0036N0001P9O
   Coding: 0032607
   Shop #: WSC 06335 000 00000
   VCID: 3C773B317FF4FFA2B2-8068
   Subsystem 1 - Part No: 8E0 910 339 B
   Component: BF-Gewichtsens. 02  0070
   Serial number: 6332DRB4011207ADH
   Coding: 00032607
   Subsystem 2 - Serial number: 6342DRB401094B10A
   Subsystem 3 - Serial number: 6352ARB4003BC4B1O
   Subsystem 4 - Serial number: 6362ARB4003B747BQ
   Subsystem 5 - Serial number: 63729RB40033F0BAP
   Subsystem 6 - Serial number: 63829RB40033EE54R
                    Fault Status: 00110000
                    Fault Frequency: 11
                    Reset counter: 99
                    Reset counter: 99
The two fault codes that are flagged "Intermittent" should clear without further ado.
For the Side Airbag Igniter code that's not intermittent, check the connections going to that airbag -- I think it's in the seat on that car?
MartinsX
Riga, Latvia
C?ID=268515
Complete autoscan needed to see all situation and give some suggestions.
