- May 21, 2018
- 13
- 17
- New Mexico, USA
- C?ID=337264
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 08 09 15 16 17 19 22 42 44 52 5F
VIN: 3VWH17AU9JMxxxxxx Mileage: 1400km-869miles
Address 01: Engine (J623-CXBB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 264 M HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0001
Revision: --H13---
Coding: 311D00122426002F0000
Shop #: WSC 00066 790 00072
ASAM Dataset: EV_ECM18TFS0208V0906264M 001003
ROD: EV_ECM18TFS0208V0906264M.rod
VCID: 46D5AA68A824A6470BB-8013
Part No SW: 0D9 300 018 HW: 02E 927 770 AS
Component: DQ250-6A MQB H54 5201
Revision: 06454104 Serial number: TFK01707192294
ROD: EV_TCMDQ250021.rod
VCID: 59EF7114099A39BF569-800D
P1734 00 [002] - -
Address 03: ABS Brakes (J104) Labels:| 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 614 517 AQ HW: 5Q0 614 517 AF
Component: ESC H62 0400
Revision: 00000000 Serial number: 52347000000619
Coding: 43FA6AA1342509748078030980C929C2562C9001C001943C00435050E009430000010312121212B435351919323200
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
ROD: EV_Brake1UDSContiMK100ESP_036_VW37.rod
VCID: 00597C70CA804877717-8055
Part No SW: 5GM 907 426 G HW: 5GM 907 426 G
Component: AC Manuell H03 2001
Revision: 00001K05
Coding: 02020004200110000000000000000002
ROD: EV_ACManueBHBVW37X_004_VW37.rod
VCID: 4CC19840B6485C17DDF-8019
Part No SW: 5Q0 937 087 AR HW: 5Q0 937 087 AN
Component: BCM PQ37BOSCH 034 0243
Revision: -------- Serial number: C864150917006L
Shop #: WSC 00066 790 00249
ROD: EV_BCMCONTI.rod
VCID: 0B435B5CF3C61B2F145-805F
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 170721 043 0551
Serial number: 97022066170811181346
Subsystem 2 - Part No SW: 5Q0 955 559 B HW: 5Q0 955 559 B Labels: 5Q0-955-547.CLB
Component: RLS 042 0105
Serial number: S7Y17M07D23H23M54S04
Coding: 00A8DD
Serial number: 003GCR08LR2U
VCID: 47CBA76CAF2EBF4FF0D-8013
Occupant Detection:
Component: BF-Gewichtss. H13 0022
Serial number: IBH000000000007SUIBB
Coding: 303135
Subsystem 2 - Part No SW: ----------- HW: 480 000 308 17
Serial number: 357000000001B968172H
Subsystem 3 - Part No SW: ----------- HW: 480 000 308 17
Serial number: 358000000008B968172P
Subsystem 4 - Part No SW: ----------- HW: 480 402 308 17
Serial number: 3510001C72625E15316V
Subsystem 5 - Part No SW: ----------- HW: 480 402 308 17
Serial number: 35200019D25E61368473
Subsystem 6 - Part No SW: ----------- HW: 480 401 107 17
Serial number: 3550002B324F3854832/
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 401 107 17
Serial number: 3560002BD24F38540353
Part No SW: 5Q0 953 507 GH HW: 5Q0 953 549 E
Revision: -------- Serial number: 24091708491412
Coding: 0410
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 025D7678C48C5A67673-8057
Part No SW: 5G1 920 840 C HW: 5G1 920 840 C
Component: KOMBI 242 0310
Coding: 0BB4100DA180CF0502082B001000000000000000
VCID: 270B07EC0F6E5F4F10D-8073
Part No SW: 3Q0 907 530 F HW: 3Q0 907 530 B
Component: GW MQB Mid 517 5304
Serial number: 30091700842482
Coding: 0101000830085900FB0020081E0F00000001070000000000000000000000
Shop #: WSC 00066 790 00204
ROD: EV_GatewNF_VW27.rod
VCID: 323DE6B834AC2AE7B73-8067
Subsystem 2 - Part No SW: 5G0 959 442 P HW: 5G0 959 442 P Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0103
Serial number: 26170001775030011439
Coding: 31FFFF
Serial number: HA1-00026.06.17
Coding: 0001
VCID: 4ACD9E58BC3C4227EF3-801F
Component: TSG FS 011 0032
Serial number: 5037727000047
Coding: 003A03200000020000000000
Serial number: 00000000000006831168
Coding: 011000
Part No SW: 5QM 909 144 A HW: 5QM 909 144 A
Component: EPS_MQB_ZFLS 171 1072
Coding: 8102
ROD: EV_SteerAssisMQB_013.rod
VCID: 4FFB8F4C475E670FB8D-801B
Component: TSG BFS 011 0032
Serial number: 6038725400027
Serial number: 00000000000007034238
Coding: 091000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 5G6 035 868 HW: 5G6 035 868
Component: MU-E--ER 671 8395
Serial number: 10081700020997
Coding: 02731200FF00000041220001001000009F0008D40000010000
ASAM Dataset: EV_MUEnt4CGen2LGE 001041
VCID: 70B92CB0FA2058F7817-8025
End----------(Elapsed Time: 01:13, VBatt start/end: 12.3V/12.3V)-----------
