I have a 2010 vw crafter witha dpf fault, the filter has been checked and cleaned and is in perfect working order, however i need to reset channels 15/16 to switch off the engine light, however the standard adaption logins do not work.
Please can somebody assist with finding the correct login code please.
Auto scan log attached.
Many thanks
Spencer
Many thanks
Spencer
Friday,18,May,2018,09:52:50:26203
VCDS Version: 18.2.0.3
VIN: WV1ZZZ2EZA6019462 License Plate: CRAFTER
Chassis Type: 2E (2E - VW Crafter Panel Van (LT3 / 2006 > 2016))
B0 B1 B2 B3 B4 B5 B6 C1
Address 01: Engine (CEB) Labels: Redir Fail!
Part No SW: 076 906 022 N HW: 076 906 022 G
Component: R5 2,5L EDC A020SG 7731
Revision: 24H32--- Serial number: VWXDZ0J1000050
Coding: 0003032
Shop #: WSC 00072 210 89962
VCID: 1E33339FCAD18EB40A-5106
009315 - Diesel Particle Filter
P2463 - 000 - Excessive Soot Accumulation - MIL ON
Fault Status: 11100000
RPM: 777 /min
Pressure: 15 mbar
Hex Value: 0xFF00
Temperature: 180.0°C
(no units): 71.4
Mileage: 330 km
Address 91: LT3 Engine Labels: Redir Fail!
Coding: 0003032
VCID: 1E33339FC9D18EB40A-804A
RPM: 777 /min
Pressure: 15 mbar
Hex Value: 0xFF00
(no units): 71.4
Mileage: 330 km
Address 93: LT3 Immo Labels: 2E0-905-865-93.clb
Part No SW: 2E0 905 865 AD HW: 906 545 580 8
Component: IMMO 0805 0815
Revision: 00805000 Serial number: VWXDZ0J1000050
VCID: 6DD1245374F7A52CC3-8038
01176 - Key
Address 94: LT3 Airbag
Part No HW: 9064461442
Shop #: WSC 00117 555 00000
ASAM Dataset: 3 3332
ROD: CRFT_AB_3_3331.rod (*)
VCID: 55A16CB334670DEC1B-8000
Address 96: LT3 Instruments
Part No SW: 9069024700 HW: 9069012000
ASAM Dataset: 32 786
ROD: CRFT_KOMBI_32_786.rod
VCID: 05017CF384477D6C2B-8050
Address 99: LT3 Ign. Switch
Part No HW: 9065455808
ASAM Dataset: 67 257
ROD: CRFT_EZS_67_257.rod (*)
9001 - Voltage: Lower limit not reached
Test Complete - Stored
Address 9A: LT3 Central Locks Labels: 2E0-905-865-9A.clb
Component: HF-FFB 0805 0815
Revision: 00805000 Serial number: 12345678901234
00172 - Key 2 not learned
002 - Lower Limit Exceeded
Address 9B: LT3 Driver Door
Part No HW: 9068204126
ASAM Dataset: 33 773
ROD: CRFT_FTUHR_33_773.rod (*)
Address B0: LT3 Roof Display
Part No SW: 9069021000 HW: 9069010900
ASAM Dataset: 21 3
ROD: CRFT_DBE_21_3.rod (*)
VCID: 7BF51A0BF2833B9C4D-802E
909B - Alarm Horn (H12): No communication
9001 - Terminal 30: Lower limit not reached
Address B1: LT3 Upper Console
Part No HW: 9065454107
ASAM Dataset: 67 3
ROD: CRFT1_OBF_67_3.rod (*)
Address B4: LT3 Central Elec.
Part No SW: 9064420700 HW: 9065453801
ASAM Dataset: 33 772
ROD: CRFT_EZE_33_772.rod (*)
90C2 - Emergency light activated; for rotary light switch evaluation: voltage not correct
90A6 - Fuel level sensor: Short to Plus
Address B6: LT3 Steering Wheel
Part No SW: 9065402345 HW: 9065402345
ASAM Dataset: 72 257
ROD: CRFT_SML_72_257.rod (*)
VCID: 06037BFFB941767422-8052
End-------------------------(Elapsed Time: 02:47)--------------------------
Address 01: Engine
Control Module Part Number: 076 906 022 N
Component and/or Version: R5 2,5L EDC A020SG 7731
Software Coding: 0003032
Work Shop Code: WSC 00072
VCID: 1E33339FCAD18EB40A-5124
Advanced Identification
Identification: BPG-810
Revision: 24H32---
Date: 08.01.10
Test stand number: 1335
Manufacturer number: 0417
Flash Status
Programming Attempts: 1
Successful Attempts: 1
Programming Status: 00000000
Required Conditions: 00000001
Flash Tool Code: 147306 210 00072
Flash Date: 00.00.00
Software
R4KG
Misc.
Hardware number: 076 906 022 G
Lot Number: 78
Type Lock:
Car Info
Chassis Number: WV1ZZZ2EZA6019462
Engine code: CEB
VCDS Info:
Labels: Redir Fail!
Readiness: No script available
Long Adaptation Channel 016:
Stored value 0
150 ml milliliters
55.2
14.4
340 km Mileage
Long Adaptation Channel 015:
Stored value
ERROR:
Security
access
required
Address 01: Engine
Revision: 24H32---
Date: 08.01.10
Flash Status
Software
R4KG
Misc.
Lot Number: 78
Type Lock:
Car Info
Engine code: CEB
VCDS Info:
Labels: REDIR FAIL!
Address 01: Engine
Revision: 24H32---
Date: 08.01.10
Flash Status
Software
R4KG
Misc.
Lot Number: 78
Type Lock:
Car Info
Engine code: CEB
VCDS Info:
Labels: REDIR FAIL!
Address 01: Engine (076 906 022 N)
09:56:13 Group 070
00000001 Bin. Bits
00000010 Bin. Bits
1.00 (no units)
09:56:13 Group 073
11.20 (no units)
6.08 (no units)
0.00 (no units)
09:56:13 Group 075
-1.28 (no units)
0.32 (no units)
-8.00 (no units)
