- Feb 24, 2018
- 141
- 47
- Czech Republic
- C?ID=204559
I was triyng to activate cornering (BCM with long coding) but haven´t found it in coding - is it possible with this BCM?
2nd thing is language of instrument cluster - Is it possible to change it to czech language (btw. it is with PR-code "X1F = National sales program Czech Republic") or the czech language isn´t even present in the unit?
And is it possible to solve hot starts by the adaptation? (77kW BKP) I know that in case of older EDC(or MSA15) is it possible only by desoldering eeprom and reprogramming (if I want to lower the revs when ECU let the fuel to inject, not mentionig the start fuel amount in channel 5 with 12233 login) , btw. this EDC16 also accepts login 12233 (not in popup) and there are more channels with default value 8192, but not sure what exactly affects, so I´ve made also an adpmap and would appreciate some help.
Here is the autoscan (sorry for cs language but hopefully the main things understandable):
And I don´t see an option to attach the adpmaps, so I´ve uploaded it to ulozto.cz (can also elsewhere if needed), here is the link:
Thanks for any help
Sobota,19,Kviten,2018,11:34:53:12188
VCDS -- Windows VAG/VAS Emulator Biží na Windows 7 x64
VCDS verze: SVO 18.2.1.0 HEX-NET CB: 0.4411.4
Verze dat: 20170224 DS287.0
www.vag-com.cz
Jméno servisu: FH
Eíslo dílny: 444 12345 000001
VIN: WAUZZZ8P25A145848 Výrobní štítek:
Model: 8P (1K0)
Sken: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 55 56 7D
VIN: WAUZZZ8P25A145848 Kilometry: 128110km
00-Snímae úhlu rízení -- stav: OK 0000
01-Motor -- stav: OK 0000
03-ABS brzdy -- stav: OK 0000
08-Klima/topení -- stav: OK 0000
09-Centrální elektrika -- stav: OK 0000
15-Airbagy -- stav: OK 0000
16-Elektronika volantu -- stav: Nefunkení 0010
17-Poístrojová deska -- stav: OK 0000
19-CAN Gateway -- stav: OK 0000
25-Imobilizér -- stav: OK 0000
42-El. dveoí oidiee -- stav: OK 0000
44-Posilovae oízení -- stav: OK 0000
46-Komfort systém -- stav: OK 0000
47-Audio soustava -- stav: OK 0000
52-El. PP dveoí -- stav: OK 0000
55-Reg.sklonu svitel -- stav: OK 0000
56-Rádio -- stav: Nefunkení 0010
7D-Poídavné topení -- stav: OK 0000
Adresa 01: Motor Labely: User\03G-906-016-BKC.clb
Oídící jednotka SW: 03G 906 016 CC HW: 028 101 183 2
Díl: R4 1,9L EDC 0000SG 6231
Revize: 12345678 Seriové eíslo: AUX7Z0E2FNE00P
Kódování: 0000071
Dílna #: WSC 06314 000 00000
VCID: 66805A9751485174BB-8032
Nenalezena žádná chyba.
Adresa 03: ABS brzdy Labely: User\1K0-907-379-MK70.clb
Oídící jednotka: 1K0 907 379 P
Díl: ASR FRONT MK70 0105
Kódování: 0017025
VCID: 3FCEAFF36E5220BC18-806A
Adresa 08: Klima/topení Labely: User\8P0-820-043.clb
Oídící jednotka SW: 8P0 820 043 H HW: 8P0 820 043 H
Díl: KlimavollautomatH14 0180
Revize: 166113 Seriové eíslo: 8P0820043H
VCID: 312AF9CBA806C6CC9E-8064
Adresa 09: Centrální elektrika Labely:. 8P0-907-279-23-H.lbl
Oídící jednotka SW: 8P0 907 279 C HW: 8P0 907 279 C
Díl: Bordnetz-SG H37 0301
Revize: 00H37000 Seriové eíslo: 00000001636792
Kódování: 018A4F168214100000000000000000000000FE0F5C
Dílna #: WSC 29238 401 83621
VCID: 3D32D5FB645E32AC0A-8068
Subsystém 1 - Oídící jednotka: 8P1 955 119 B Labely: SVO\1KX-955-119.CLB
Díl: Wischer AU350 H01 0130
Kódování: 00062736
Dílna #: WSC 29238
Adresa 15: Airbagy Labely: 8P0-959-655-84.lbl
Oídící jednotka SW: 8P0 959 655 E HW: 8P0 959 655 E
Díl: Airbag 8.4EDmin H00 0140
Kódování: 0010103
VCID: 44C4A01F07B4436445-8010
Adresa 16: Elektronika volantu Labely: 1K0-953-549-MY8.lbl
Oídící jednotka SW: 1K0 953 549 F HW: 1K0 953 549 F
Díl: Lenksäulenmodul 021 0050
Kódování: 0000012
VCID: 3522CDDB5C6EEAECC2-8060
1 nalezena chyba:
00888 - spinac stiracu pro intervalovy provoz (E22)
014 - defekt - Sporadická
Adresa 17: Poístrojová deska Labely: 8P0-920-xxx-17-MY7.lbl
Oídící jednotka SW: 8P0 920 930 Q HW: 8P0 920 930 Q
Díl: KOMBIINSTR. VDO H73 0300
Revize: D06 Seriové eíslo: 2242ED06039853
Kódování: 0004113
Dílna #: WSC 00100 401 08723
VCID: 40CCAC0F13AC5F4461-8014
Adresa 19: CAN Gateway Labely:. SVO\1K0-907-530-V1.clb
Oídící jednotka SW: 1K0 907 530 D HW: 1K0 907 951
Díl: Gateway H08 0100
Revize: 08 Seriové eíslo: 25001052280861
Kódování: 7D0F0B42070100
VCID: 281C14AF9BDC870449-807C
Adresa 25: Imobilizér Labely: SVO\1K0-920-xxx-25.clb
Revize: D06 Seriové eíslo: AUX7Z0E2FNE00P
Dílna #: WSC 00000 000 00000
Adresa 42: El. dveoí oidiee Labely: 8P0-959-801-MIN1.lbl
Oídící jednotka: 8P0 959 801 E
Díl: Tuersteuerger. H10 0040
Kódování: 0000048
Adresa 44: Posilovae oízení Labely: SVO\1Kx-909-144-G2V2.clb
Oídící jednotka: 1K1 909 144 H
Díl: EPS_ZFLS Kl.7 1502
VCID: 302CFCCFA30CCFC491-8064
Adresa 46: Komfort systém Labely: 8P0-959-433.lbl
Oídící jednotka: 8P0 959 433 B
Díl: KSG H03 0040
Kódování: 008000186D288505488A016000
VCID: 3B36DBE37A4A3C9C34-806E
Subsystém 1 - Díl: Sounder n.mounted
Subsystém 2 - Díl: NGS n.mounted
Subsystém 3 - Díl: IRUE n.mounted
Adresa 47: Audio soustava Labely: 8Px-035-382.lbl
Oídící jednotka SW: 8P3 035 382 HW: 8P3 035 382
Díl: AB2 SUBWOOFERBOXH25 0160
Revize: 00003 Seriové eíslo: 10000001180205
VCID: 70AC3CCF638C8FC4D1-8024
Adresa 52: El. PP dveoí Labely: 8P0-959-802-MIN1.lbl
Oídící jednotka: 8P0 959 802 E
Kódování: 0000048
VCID: 3E30D2F7695829B413-806A
Adresa 55: Reg.sklonu svitel Labely: User\8P0-907-357.clb
Oídící jednotka: 8P0 907 357 C
Díl: Dynamische LWR H01 0010
Revize: 00000000 Seriové eíslo:
Kódování: 0000001
VCID: 3A38DEE7757005942F-806E
Adresa 56: Rádio Labely: 8P0-035-1xx-56.lbl
Oídící jednotka SW: 8P0 035 186 C HW: 8P0 035 186 C
Díl: concert II EU H51 0100
Revize: 01S Seriové eíslo: AUZ2Z3E2161474
Kódování: 0001001
Dílna #: WSC 06435 000 00000
VCID: 3228F6C7AD00FDD4E7-8066
2 závad nalezeno.
00856 - antena radioprijimace
011 - Preruseni
info o závadi:
Stav závad: 01101011
Priorita závad: 5
Frekvence závad: 2
Poeítadlo resetu: 91
Kilometry: 118881 km
Indikace easu: 0
Datum: 2017.08.19
Eas: 11:34:43
00858 - spojeni: ZF vystupu radioprijimace k antennimu zesilovaci
007 - Zkrat na kostru - Sporadická
info o závadi:
Stav závad: 00100111
Priorita závad: 5
Frekvence závad: 1
Poeítadlo resetu: 252
Kilometry: 127238 km
Indikace easu: 0
Datum: 2018.04.28
Eas: 13:38:35
Adresa 7D: Poídavné topení Labely: 1K0-963-235.lbl
Oídící jednotka SW: 1K0 963 235 E HW: 1K0 963 235 E
Díl: PTC-Element 0404
Revize: 00800000 Seriové eíslo:
VCID: 2D12E5BBB43EA22CBA-8078
Konec-------(Uplynulý eas: 01:01, VBat zaeátek/konec: 12.2V/12.2V)---------
https://uloz.to/!eKew2pN1Yur7/adpmap-ecu-a3-8p1bj4-rar
Thanks for any help
