N290 mystery on golf mk5
Fredrick Awuor
Kenya
C?ID=309834
Hello,can anyone shed more light on where the N290 is fitted on this Golf5,it is nowhere in the workshop manual,SSP334 about fuel on FSi engines,what im getting in the FINE BOOKS are N276 mounted HPFP,G410 on low pressure fuel rail,G247 on high pressure fuel rail and even SSP322 on AXW which is the ancestor of BLX,BLR,BVY etc does not have it!,problem started after car was taken for the rear quarter paint job,the guys there have changed three different J538 but still no luck, i connected fuel pressure tester on low pressure side and after cycling ignition on/off 3 times the pressure builds to around 5 bar,then engine is able to start and idle but after a few minutes the fuel pressure recedes until engine stalls,i have checked the fuel holding pressure and after 10 minutes it is within specs,now Iam left wondering if ECU is giving VCDS incorrect info or if N290 FUEL METERING VALVE means something else on this car
Thursday,17,May,2018,10:21:44:48669
Dealer/Shop Name: FREDRICK'S VWAUDI
VIN: WVWZZZ1KZ5U009724   License Plate: LR1
Mileage: 143070km-88899mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ5U009724   Mileage: 143070km-88899miles
Address 01: Engine        Labels: None
   Part No SW: 06F 906 056 DH    HW: Hardware No
   Component: MED9.5.10       G00 7000
   Revision: 00000000    Serial number: VWZ7Z0D0580697
   Coding: 0000075
   Shop #: WSC 00046 412 00000
   VCID: 72BED32588A4C04774C-8026
   Subsystem 1 - Part No: 06F 907 807 F
   Component: NOX  0409150432 002 0409
   06F907807F  NOX  0409150432 002 0409
16474 - Valve for Fuel Metering (N290)
            P0090 - 004 - Open Circuit - MIL ON
Readiness: 1110 0101
   Part No: 09G 927 750 EF
   Component: AQ 250 6F           0618
   Coding: 0000008
   VCID: 79ACE409D5D2B31F356-802C
01045 - Tiptronic Switch (F189)
   Part No: 1K0 907 379 M
   Component: ESP FRONT MK60      0105
   Coding: 0021122
   VCID: 3C223D1D9A6046376E0-8068
   Part No: 1K0 907 044 AC
   Component: ClimatronicPQ35 066 0404
   VCID: 688AB14DBE783A97DA8-803C
   Part No SW: 1K0 937 049 T    HW: 1K0 937 049 T*
   Component: Bordnetz-SG 1.0 H30 0704
   Revision: 00030000    Serial number: 00000000988223
   Coding: E58D8F0600041800001400001400000000
   VCID: 40DA49EDF68822D7328-8014
   Subsystem 1 - Part No: 1K2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00049109
   Subsystem 2 - Part No: 1K0 955 559 M  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 005  0605
   Coding: 00217125
01259 - Fuel Pump Relay (J17)
            009 - Open or Short to Ground
   Part No SW: 1K0 909 605 F    HW: 1K0 909 605 F
   Component: 02 AIRBAG VW8R  023 5600
   Revision: 07023000    Serial number: 0037RD04ER5E
   Coding: 0012338
   VCID: 2F381A515B16ADAFDB2-807A
   Subsystem 1 - Serial number: 6332MSME044C1D4DM
   Subsystem 2 - Serial number: 6342MSME056B5C3CQ
   Subsystem 3 - Serial number: 6351HSME040D4405/
   Subsystem 4 - Serial number: 6361HSME036D4100
   Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
   Component: Lenksäulenmodul 012 0030
   Coding: 0010042
   VCID: 303A192D4628B257C28-8064
   Part No: 1K0 920 861 A
   Component: KOMBIINSTRUMENT VDD 0814
   Coding: 0003503
   Shop #: WSC 00999 444 64523
   VCID: 2708F27173E6F5EF132-8072
00771 - Fuel Level Sensor (G)
            010 - Open or Short to Plus
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H09 0110
   Revision: 09          Serial number: 27001048290346
   Coding: 3F3F0340070003
   VCID: 290CF44965F2C39F056-807C
                    Reset counter: 223
                    Mileage: 143073 km
                    Time: 19:34:54
                    Reset counter: 223
                    Mileage: 143073 km
                    Time: 19:34:54
01304 - Radio
                    Reset counter: 223
                    Mileage: 143073 km
                    Time: 19:34:58
   Component: IMMO            VDD 0814
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX1.lbl
   Part No: 1K0 959 701 G
   Component: Tuersteuergeraet 09 0148
   Coding: 0000054
   Shop #: WSC 00046 000 00000
   VCID: 323E132548248047B4C-8066
   Part No: 1K2 909 144 G
   Component: EPS_ZFLS Kl.0       1301
Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 BN
   Component: 01 KSG              0301
   Coding: 80C802087F2D8404085F01E010
   VCID: 7DA4F019C1FA8F3F19E-8028
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX1.lbl
   Part No: 1K0 959 702 G
   Coding: 0000054
   VCID: 33301621B73E894FBFA-8066
Address 56: Radio
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 C
   Component: Tuersteuergeraet 06 0213
   Coding: 0000016
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 C
   Coding: 0000016
   VCID: 313C1C294D22BB5FCD6-8064
End----------(Elapsed Time: 00:58, VBatt start/end: 13.8V/13.7V)-----------
It is entirely possible that there is no "N290" in this car. VAG started re-using fault code texts that had DIN identifiers in them for components with different DIN identifiers. A few years ago, they removed all the DIN identifiers from their fault code texts, but we have not done that, because most of the time, they are still correct.
NZDubNurd
New Zealand
C?ID=230482
I think it's actually N276... but there is no label file for your ecu.
N276 is on the HPFP, black 2 terminal connector.
It may have a damaged wire.
Change HPP if wiring from ECU consumer feeds + grounds or to pump N276 (n290) valve or ecu could also be damaged maybe water ingress.
Check fuses and for corrosion.
Fredrick Awuor
Kenya
C?ID=309834
I read an earlier SSP that explained the n290 to be mounted at the shock absorber tower on fuel rail,maybe on an earlier model Golf
Fredrick Awuor
Kenya
C?ID=309834
Thanks,I was of the same opinion but was unsure,will have a look on it when it comes back on Wednesday and post results,I've been wondering why the ecu doesn't have the label file,I thought it was changed but saw that immobilizer is working so my mind is a bit off it
Fredrick Awuor
Kenya
C?ID=309834
Thanks Jack for the insight,ECU's location makes it a candidate for water entry,what ties my hands is that the workshop manual for this particular model (Row) lacks WD,voltage parameters,n276 resistance,been trying how to convert the HTML only version offered by erWin to PDFs,but no luck still
AA7QQ
C?ID=337402
You might want to pay the $35 for a day's subscription & download everything pertinent to your VIN. Sure helped me much better than the Bentley's & Chiltons, at 1/4 the price. I need paper & books when wrenching. I just use the laptop for diagnostics & the forum.
I am actually picking all of the files for my Jetta out & going to print them & punch for 3 ring binders.
Ed
NZDubNurd
New Zealand
C?ID=230482
The N276 on the HPFP in my garage came off a running 2006 BVY 2.0 FSI.
It measures 1.8 Ohms. It's an aftermarket pump, but it has had number machined off, so was quite possibly made by and OEM.
It worked perfectly, other than some dumbass fitted it without putting a cam follower in (at all!), so the pin is worn.
Fredrick Awuor
Kenya
C?ID=309834
Thanks, I hope this is at room temperature, ie 20°C there about
Fredrick Awuor
Kenya
C?ID=309834
Ed
for some reason that I don't understand, PDFs by VIN are easily downloadable on erWin Nar site,but on Row no guided search,only HTML versions,I haven't yet figured a way to go round this problem so am hesitant because I lost a one hours subscription sometimes back while trying to hit the right buttons
NZDubNurd
New Zealand
C?ID=230482
Yes it was 20C -ish.
Although I think it's a solenoid coil, so shouldn't change much.
Fredrick Awuor
Kenya
C?ID=309834
hello, i got 1.5 ohms at room temperature today,and roughly 8 volts across the component connector with ignition on,engine off,next step is to check wiring to ecu and signal to j538
Fredrick Awuor
Kenya
C?ID=309834
Finally got the problem....car showed up today and while scanning, I got even more codes( will post tomorrow) some not even related to hpfp, that got me puzzled While chasing the n276 wiring to ecu and wiring from onboard power supply I was surprised to find a mouse had made the top of can gateway its new abode and was chewing wires indiscriminately ,so I traced all the wires that had been damaged and VOILA...the pesky check light went off and motor ran like new....but I made sure I evicted the new immigrant by turning ac blower full speed and temp to max hot,closed all the windows and let engine run for a full 2hrs by which time the rodent &descendants lay unconscious under the seats!.....thanks to all especially to Jack@european parts,FOD is real only the form may be different!
FOD wins again! :p
4 Pyramids is superior to hand with 3 Pyramids.
