HI EVERYONE,
TODAY I DID CODING IN THE NEW POLO TSI 2018.
BUT I DIDN´T WORK ACCESS IN THE ADAPTATION 17 INTRUMENTS.
I HAD THE ALMOST PROBLEM WITH TIGUAN 2017 TSI CENTRAL 42.
I USED THE VERSION 18.2 HEX NET AND VERSION 18.4 ALPHA, BUT DIDN´T WORK.
BELOW THE COMPLETE SCAN OF THE CAR.
BEST REGARDS AND THANKS FOR THE SUPPORT.
Saturday,19,May,2018,18:15:17:17240
VCDS Version: 18.2.0.3 (x64) HEX-NET CB: 0.4422.4
VIN: 9BWAH5BZ6JP082403 License Plate:
Mileage: 1272km-790mi Repair Order:
Chassis Type: BZ-VW27 (2Q0)
Scan: 01 02 03 05 08 09 10 15 17 19 44 5F
VIN: 9BWAH5BZ6JP082403 Mileage: 1272km-790miles
Address 01: Engine (J623-DHSB) Labels: None
Part No SW: 04C 906 026 BT HW: 04C 907 309 AH
Component: R3 1.0l TFS H21 5244
Revision: WVH21---
Coding: 011A0012232400001000
Shop #: WSC 01530 935 00200
ASAM Dataset: EV_ECM10TFS01104C906026BT 001002
ROD: EV_ECM10TFS01104C906026BT.rod
VCID: 74A437E1DFF877E40C-8020
CAN Converter 01:
Address 02: Auto Trans (J217) Labels: None
Part No SW: 09G 927 158 CL HW: 09G 927 158
Component: AISIN AG6 G3 202 3409
Coding: 0000000000000000010000000000000000000000
ROD: EV_TCMAQ250031_002_VW25.rod
VCID: 7F4EE8CDE6BE24BC61-802A
Part No SW: 2Q0 614 517 S HW: 2Q0 614 517 L
Component: ESC_base H13 0222
Serial number: 86404930180306
Coding: 33044C673749CCAF3200EC1614DD126A49444D26226A242444541254452848569222B26444562424222A482AA229344004942C0220
ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004032
ROD: EV_Brake1BOSCHESPMQBA0.rod
VCID: 3E30D5C9A134EDB42A-806A
Part No SW: 3Q0 959 435 G HW: 3Q0 959 435 G
Component: VWKESSYMQB 037 0907
Revision: 00037000 Serial number: 0464637692
Coding: 132C0C0723
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 6EA 820 045 A HW: 6EA 820 045 A
Component: SG_AC_Manuell H50 0301
Coding: 012000000800000000000400000000000000000000000000000000000000
ASAM Dataset: EV_ACManuePrehMQBA0 001011
ROD: EV_ACManuePrehMQBA0.rod
VCID: 302CFBF16B600BC4A8-8064
Part No SW: 2Q0 937 089 HW: 2Q0 937 089
Component: BCM A0 Std H97 0916
Serial number: 20117344010302
ASAM Dataset: EV_BCMA0 204001
ROD: EV_BCMA0_104_VW27.rod
VCID: 77BE00EDCE8E1CFC29-8022
Subsystem 1 - Part No SW: 5Q0 955 559 B HW: 5Q0 955 559 B Labels: 5Q0-955-547.CLB
Component: RLS 047 0105
Serial number: S2Y18M03D07H08M45S06
Coding: 0038DD
Drivers Door Control Module:
Subsystem 2 - Part No SW: 2Q1 959 881 B HW: 2Q1 959 881 B
Component: FHSG_DRV 001 0001
Serial number: 00000000000018924795
Coding: 138000
Subsystem 3 - Part No SW: 2Q1 959 882 D HW: 2Q1 959 882 D
Component: FHSG_PSG 001 0002
Serial number: 00000000000018991182
Coding: 098000
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY173330HF9
Subsystem 5 - Part No SW: 5Q0 959 811 D HW: 5Q0 959 811 D
Component: FOND_FHSG_DRV 006 0007
Serial number: 00000000000018837169
Coding: 030000
Subsystem 6 - Part No SW: 5Q0 959 812 D HW: 5Q0 959 812 D
Component: FOND_FHSG_PSG 006 0007
Serial number: 00000000000019135148
Coding: 1B0000
Part No SW: 5Q0 919 294 L HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0056
Revision: -------- Serial number: 55401807725128
Coding: 0011051011
ROD: EV_EPHVA18AU3700000_002_VW27.rod
VCID: 44C4A721CFD887647C-8010
Address 15: Airbags (J234) Labels:* None
Part No SW: 2QB 959 655 HW: 2QB 959 655
Component: VW22Airbag 010 0246
Revision: --------
Coding: 88C0C00000000000540000CF000000000065
ASAM Dataset: EV_AirbaVW22BPAVW27X 001010
ROD: EV_AirbaVW22BPAVW27X.rod
VCID: 0C544F01A7080F2474-8058
Subsystem 1 - Part No SW: ----------- HW: 442 1A2 001 18
Component: SideSensor_Df 2C4 0148
Serial number: 349B4D2C5292F3F4D2BA
Subsystem 2 - Part No SW: ----------- HW: 442 1A2 001 18
Component: SideSensor_Pf 2C4 0148
Serial number: 350B4D2C5292F3F1E0F2
Subsystem 3 - Part No SW: ----------- HW: 442 131 001 18
Component: FrontSensor_D 290 118A
Serial number: 355AG11A92824C5534AT
Address 17: Instruments (J285) Labels:* None-SRI3
Part No SW: 6EA 920 740 A HW: 6EA 920 740 A
Component: KOMBI 309 0460
Coding: 042402082000000C020822001000000000000000
ASAM Dataset: EV_DashBoardVDDMQBA0 001020
ROD: EV_DashBoardVDDMQBA0_VW27.rod
VCID: 3326F4FD9A7630DCD5-8066
Part No SW: 2Q0 909 901 HW: 2Q0 937 089
Component: GW MQB A0 H97 0916
Coding: 0101000020085600F80000081C0F00000001070000000000000000000000
ASAM Dataset: EV_GatewA0 013020
ROD: EV_GatewA0_VW27.rod
VCID: 6FAE388DB6DE543CF1-803A
Subsystem 2 - Part No SW: 56D 959 442 HW: 56D 959 442
Component: E221__MFL-834 H01 0130
Serial number: 000000000B0907190318
Coding: 200000
Address 44: Steering Assist (J792) Labels:* None
Part No SW: 2Q1 909 144 J HW: 2Q1 909 144 F
Component: TRW_G4L_MQBA0 610 6030
Serial number: 02I1J073CB4J087
Coding: 00000001000000000101020101000101000001
ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 009014
ROD: EV_SteerAssisTRWG4LMQBA0_009.rod
VCID: 393AC6D5B81ACA8C1F-806C
Part No SW: 5G0 035 280 C HW: 5G0 035 280 C
Component: MU-G--RW 557 5516
Serial number: VWZ7Z2U4677437
Coding: 02721000BE00000000220001010000002F0000040000010003
ASAM Dataset: EV_MUGlb4CGen25TPWR 001001
ROD: EV_MUGlb4CGen25TPWR.rod
VCID: 210A0EB5308AB24C37-8074
End----------(Elapsed Time: 01:10, VBatt start/end: 12.6V/12.5V)-----------
