Audi A6 2018 - modify output audio channel gains - enable development mode
tihi
Slovenia
C?ID=336726
I would like to decrease the level of the front center audio channel as it is too loud comparing to front left/right channels.
Any information in this regard is welcome.
I also tried to enable development mode on MMI unit but got error "out of range".
Any hint?
This is auto scan (MMI):
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 20 36 3B 42 44 46 52 53 55 5F
          62 6D 72 8F 90 AC
   Part No SW: 4G1 035 043 J    HW: 4G1 035 043 D
   Component: MU-H-N-EU     054 0910
   Serial number: A736C0JS031856
   Coding: 01750101FF0A000013110001000A00002F0006E5F1700100DF
   ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
   VCID: 2516067E456C899F21E-8070
   Subsystem 1 - Part No SW: V03 959 801 FD    HW: -----------
   Component: ECE 2017/2018  --- 0161
   Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
   Serial number: AUZ8Z9JY80AADB
   Multimedia Operating Unit:
   Serial number: 90349RD500081
   Component: Gracenote2  --- 1016
          U11B8 00 [008] - No Communications
          [USB - communication error]
                    Reset counter: 50
                    Mileage: 41 km
                    Date: 2018.05.08
                    Time: 16:02:34
                    Voltage terminal 30: 13.0 V
                    Interface for external media: status-Status: Measured value not available
Thank you.
MasterTommy
Amsterdam
C?ID=295586
Please post a complete auto-scan.
Enabling developement mode usually requires a different diagnostic mode which VCDS only supports on a few modules. Someone from RT can probably verify this.
tihi
Slovenia
C?ID=336726
This is complete scan
Wednesday,16,May,2018,20:39:28:55547
VIN: WAUZZZ4G5JN109158
          62 6D 72 8F 90 AC
Address 01: Engine (J623-DDDA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 HA    HW: 04L 907 309 AA
   Component: R4 2.0l TDI   H20 4166
   Revision: 8DH20---
   Coding: 0A254012232401080000
   ASAM Dataset: EV_ECM20TDI01104L906021HA 004005
   ROD: EV_ECM20TDI01104L906021HA_004.rod
   VCID: 6B823046E3087FEFB7A-803E
Address 02: Auto Trans (J217)       Labels:* None
   Part No SW: 4G1 927 153 G    HW: 0CJ 927 156
   Component: 0CK 20TDI RdW H05 0001
   Revision: --H05---    Serial number: 0000001026
   Coding: 100001
   ASAM Dataset: EV_TCMDL382021 002028
   ROD: EV_TCMDL382021_AU48.rod
   VCID: 2E04F952109ACAC7D04-807A
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 L
   Component: V553 MTFP  003 0576
   Serial number: 75145041180085000604
   Coding: 06A29E41604579829B00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 41DEB2EEB10445BF3D6-8014
   Part No SW: 4H0 907 064 HN    HW: 4H0 907 064 HN
   Component: BCM2 2.0      H61 0825
   Coding: 01A8700E000000000000
   VCID: 7CA0031A96E6E8572E0-8028
   Part No SW: 4G0 820 043 CB    HW: 4G0 820 043 CB
   Component: KLIMA 2 ZONEN H14 0113
   Serial number: 11041800110852
   Coding: 34010908210000
   ASAM Dataset: EV_AirCondiBasisUDS 003009
   ROD: EV_AirCondiBasisUDS_003.rod
   VCID: 619E526E11C425BF1D6-8034
Address 09: Cent. Elect. (J519)       Labels: Redir Fail!
   Part No SW: 4H0 907 063 GH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 0368
   Revision: 1502003S    Serial number: 00001960321702
   Coding: 0105C01440349FE0C1014083A0001800CF9CC3082E08020100000494E101140200400024030000
   VCID: 74B02B3ABEB6A017660-8020
   Component: WWS57X 180226  H38 0080
   Serial number:         180305063526
   Coding: 0045F7
   Serial number: 21305132X81A955547A0
   Coding: 02006D
   Component: E1 - LDS  H07 0044
   Serial number: 12 03 2018  00001374
   Subsystem 4 - Part No SW: 4G0 907 658 B    HW: 4G0 907 658 B
   Component: Humidity_Sens  H02 0007
   Serial number: 8F419B1900PAG0FSA002
Address 15: Airbags (J234)       Labels:| 4H0-959-655.clb
   Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H
   Component: Airbag10.43   H83 0098
   Revision: --------    Serial number: 003P100G64W1
   Coding: 30333130313630323637554A304C34473053
   VCID: 3B22C006D3E82F6F67A-806E
   Serial number: 3575HRB400A5DKL2A8MI
   Serial number: 3585HRB40165DNAKA9OT
   Serial number: 3515JRB40025DPR4EGV/
   Serial number: 3525JRB405D5EP2CDPN+
   Serial number: 3554VRB405V5G08E41GI
   Serial number: 3564VRB40635FQRSNGI0
   Revision: C0068538    Serial number: 91560RCJ0001U
   Coding: 000014
   VCID: 3B22C006D3682F6F67A-806E
   Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
   Serial number: 03 03 2018  C0005465
   Part No SW: 4G8 920 934 R    HW: 4G8 920 934 R
   Component: TDieRdw       H17 0225
   Revision: 18001312    Serial number: 658050418592003
   Coding: 13A60D000B410008010000
   ASAM Dataset: EV_RBD4K 004060
   ROD: EV_RBD4K.rod
   VCID: 40D8B7EABA0E4CB7328-8014
   Part No SW: 4G8 907 468 K    HW: 4G8 907 468
   Component: J533--Gateway H15 0110
   Revision: --------    Serial number: 00000002932798
   Coding: C0CD074418
   ASAM Dataset: EV_GatewPkoUDS 002011
   ROD: EV_GatewPkoUDS_002.rod
   Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
   Serial number: 1877437304
   Voltage stabilizer:
   Serial number: 18012400000000000061
   Part No SW: 4H0 857 511     HW: 4H0 857 511
   Component: FLA           H04 0021
   Revision: AA001002
   VCID: 678A4C76FF605B8FD32-8032
   Revision: AA000000    Serial number: 00000311376229
   Coding: 0058130000006001000001010101102030303232203232
   VCID: 77AA1C36AFC0CB0F432-8022
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA820FGF3A
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 3634D132E8CAF207984-8062
   Coding: 011F16015E00628002080002
   VCID: 47CAACF69FA07B8FF32-8012
   Component: RCevo         H55 0202
   Revision: 00000001    Serial number: 0000583390
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A2CC502DCD216677CC-806E
   Revision: 00002001    Serial number: 0476962835
   Coding: 011A062080B93080C320088408010E470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177 B
   Component: Sensor, DWA  005 0002
   Subsystem 2 - Part No: 1K0 951 605 F
   Component: LIN BACKUP HO  H01 0008
   Subsystem 3 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
   Serial number: 0000000AP00046752767
   VCID: 46D4A1F298AA6287084-8012
   Part No SW: 4H0 907 801 N    HW: 4H0 907 801 M
   Component: EPB-4         H01 0020
   Revision: --------    Serial number: 00000002482501
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 3332E826FBB8E72FBFA-8066
   Coding: 04FA02102A630200
   VCID: 3430EB3AFEB6E017A60-8060
   Coding: E01E00
   Coding: E01E00
                    Reset counter: 50
                    Mileage: 41 km
                    Date: 2018.05.08
                    Time: 16:02:34
   Coding: 010F14004000628002080002
   VCID: 49CEAACE89B48DFFE56-801C
   Part No SW: 4G5 959 107 C    HW: 4G5 959 107 A
   Component: HDSG-Modul    H02 0049
   Revision: 13002003    Serial number: 080802130
   Coding: 111104C000
   ASAM Dataset: EV_HDSGAu571 001022
   ROD: EV_HDSGAu571.rod
   VCID: 323CED2204A2EE27B4C-8066
Address 8F: Pretens. Frt Left (J854)       Labels:. 4H0-980-94x-RGS.clb
   Component: RGS-VL        H16 0080
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313EE22E01A4D53FCD6-8064
Address 90: Pretens. Frt Right (J855)       Labels:. 4H0-980-94x-RGS.clb
   Component: RGS-VR        H16 0080
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 180800336
   ROD: EV_RDCMA00100_008.rod
   VCID: 2F3AE4561790C3CFDB2-807A
End----------(Elapsed Time: 01:54, VBatt start/end: 12.1V/12.1V)-----------
tihi
Slovenia
C?ID=336726
Anybody knows how to change the level of the audio channels?
I need to decrease the level of front center audio channel.
tihi
Slovenia
C?ID=336726
I simply disconnected the center loudspeaker and now the sound is much better.
