Im having a issue with this 2012 T5.1 Transporter, I cant reset the service light because no ASAM data or rod file found in 17- Instruments
Can anyone help?
Cheers Toby
Can anyone help?
Cheers Toby
Wednesday,16,May,2018,14:33:49:06091
VCDS Version: 18.2.0.3 (x64) HEX-NET CB: 0.4411.4
Dealer/Shop Name: DG Motor Services
VIN: WV1ZZZ7HZCH087089 License Plate:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 09 15 17 19 25 56 0B
Address 01: Engine (J623-CAAC) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 022 CH HW: 03L 907 309 K
Component: R4 2,0L EDC H43 9970
Revision: 26H43--- Serial number: 00000000000000
Coding: 01194010230400080000
Shop #: WSC 81903 210 00000
ASAM Dataset: EV_ECM20TDI01103L906022CH 002013
ROD: EV_ECM20TDI01103L906022CH_002.rod
VCID: ED929FB53C86B52C43-80B8
5196 - Relay for Fuel Pump 2 (J49)
P2632 00 [032] - Open Circuit
5200 - Fuel Pump Relay Control Circuit
P0627 00 [032] - Open Circuit
9531 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0105 00 [032] - Malfunction
Mileage: 142104 km
Time: 00:00:00
Coolant temperature: 20 °C
Intake air temperature: 18 °C
Voltage terminal 30: 12.240 V
Charge air pressure: actual value: 1011.8 hPa
Intake air pressure sensor after air cleaner: raw value: 1150 hPa
Engine status: COENG_STANDBY
Outside air temperature: 16.5 °C
Particle filter: difference pressure: -2 hPa
Sensor for particle filter differential press: raw value: 0 hPa
Address 03: ABS Brakes (-----) Labels:. 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 J HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0109
Revision: 00H43001
Coding: 508724AD89AC0A9C24A29179A96710
Shop #: WSC 02748 790 49152
VCID: B93A7BE5304ED98C9F-80EC
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 086 H HW: 7H0 937 086
Component: BCM T5GP M++4 H47 0254
Revision: BM047001 Serial number: 0428 003121077
Coding: A0A0393A0E212011002008102C2B8CD00000430F60060000300000000000
Shop #: WSC 02736 790 00000
VCID: B83C7EE10B44C08460-80EC
Subsystem 1 - Part No SW: 7E0 959 801 C HW: 7E0 959 801 C Labels: 7E0-959-80X-V1.CLB
Component: J386__TSG_FT 003 3311
Coding: 050000
Subsystem 2 - Part No SW: 7E0 959 802 C HW: 7E0 959 802 C Labels: 7E0-959-80X-V1.CLB
Component: J387__TSG_BT 003 3311
Coding: 040000
03303 - Response Closing Status of Rear Left Door
Reset counter: 64
Mileage: 134805 km
Date: 2000.14.27
Time: 10:55:57
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag009 H06 0013
Revision: -------- Serial number: 003HL009HJXX
Shop #: WSC 02734 790 50316
VCID: B52277D514563DEC7B-80E0
Address 17: Instruments (J285) Labels:. 5K0-920-xxx-17.clb
Part No SW: 7E0 920 960 E HW: 7E0 920 960 E
Component: KOMBI H04 0305
Coding: 460200
Shop #: WSC 02736 790 50316
ASAM Dataset: EV_Kombi_cÿ_VDD_RM09 A04113
ROD: N/A
VCID: AB1651ADC2127B1C1D-80FE
No ASAM data for: "EV_Kombi_cÿ_VDD_RM09" (VW36 *)
Part No SW: 6N0 909 901 HW: 7H0 937 086
Component: GW-K-CAN TP20 H47 0254
Revision: BM047001
Coding: 042300
VCID: F0AC86C123B458C468-80A4
Component: IMMO H04 0305
VCID: EA9894A90D68A21426-80BE
Part No SW: 7E0 035 156 B HW: 7E0 035 156 B
Component: Radio H42 0105
Revision: R0000000 Serial number: VWZAZ1L2284017
Coding: 0000020001
Shop #: WSC 02734 790 00000
VCID: A208BC89BDD8BA54AE-80F6
End----------(Elapsed Time: 01:08, VBatt start/end: 14.4V/14.5V)-----------
