Results 1 to 9 of 9
Thread: Audi TT 8N - 2001 BAM
    Feb 2018
    GR
    Hi
    This is a complete Auto-Scan from my Audi TT 2001. Can you please help with errors? The only "strange" i see in the car is the DIS display that started not to work (after me playing around with VCDS a few months ago because i couldn't get the Telephone cradle to work)
    Chassis Type: 8N (8N - Audi TT (1999 > 2007))
    Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
    VIN: TRUZZZ8NZ11045966   Mileage: 171250km-106409miles
    Address 01: Engine        Labels: 06A-906-032-BAM.lbl
       Part No: 8N0 906 018 H
       Component: 1.8L R4/5VT     G   0004
       Coding: 10710
       VCID: 3635DB65F159CC47984-513D
       TRUZZZ8NZ11045966     AUZ5Z0A4212029
    Address 03: ABS Brakes        Labels: 8N0-907-379-MK20-E.clb
       Part No: 8N0 907 379 E
       Component: ESP     20    CAN  V005
       Coding: 18446
       Shop #: WSC 01236
       VCID: 3E25C345D9690407404-4B01
    Address 08: Auto HVAC        Labels: 8N0-820-043.lbl
       Part No: 8N0 820 043 A
       Component: TT-KLIMAVOLLAUTOMAT D03
       Coding: 00040
       Shop #: WSC 01236
       VCID: 2809051D2BEDAAB71A8-2581
    00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
    Address 15: Airbags        Labels: 8N8-909-601.lbl
       Part No: 8N8 909 601
       Component: Airbag Front+Seite 2008
       Coding: 10102
       Shop #: WSC 01236
       VCID: 77AB1661B6D3F54F432-513D
    Address 17: Instruments        Labels: 8Nx-920-xxx-17.lbl
       Part No: 8N1 920 880 H
       Component: KOMBI+WEGFAHRS. M73 D56
       Coding: 05044
       Shop #: WSC 01020
       VCID: 3A2DCF55C54128277CC-4B01
                49-00 - No Communications
    01304 - Radio
                37-10 - Faulty - Intermittent
    Address 22: AWD        Labels: 02D-900-554.lbl
       Part No: 02D 900 554 B
       Component: HALDEX LSC  ECC     0006
       VCID: 1F1B1EC17EA36D0F6B2-4B01
    Address 35: Centr. Locks        Labels:. 8Nx-962-267.lbl
       Part No: 8N8 962 267
       Component: Zentralverrieg.,DWA D05
       Coding: 06730
       Shop #: WSC 01236
       VCID: 7EA5034599E9C407004-4F0D
       Part No: 8N8 951 177 A
       Component: Innenraumueberw.    D09
       Coding: 00001
       VCID: 3D27C449D46F1F1F59E-5119
    Address 55: Headlight Range        Labels: 4B0-907-357-AUT.lbl
       Part No: 4B0 907 357
       Component: LEUCHTWEITEREGLER  D004
       Coding: 00010
       Shop #: WSC 01236
       VCID: 65974C291C7F77DFE1E-5161
    Address 56: Radio        Labels: 8D0-035-1xx-56.lbl
       Part No: 4B0 035 186 D
       Component:  Radio             0001
       Coding: 00207
       Shop #: WSC 00040
       VCID: 211F183948D75BFF5D6-4AE1
    00852 - Loudspeaker(s); Front
                36-10 - Open Circuit - Intermittent
    00854 - Radio Display Output in dash Panel insert
                00-00 -  -
    End----------(Elapsed Time: 02:25, VBatt start/end: 12.2V/12.2V)-----------
    Thank you
    Nikolas
    Quote Originally Posted by napostolidis View Post
    It looks like you have edited out the header information that VCDS provides including VCDS version, etc.
    Please can you post a full unedited Auto-Scan.
    Feb 2018
    GR
    Thank you. Thought this info is not important
    I post it again unedited
    Monday,14,May,2018,09:28:25:60191
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels)
    VCDS Version 18.2.0.3 (x64)  HEX-V2 CB: 0.4411.4
    VIN: TRUZZZ8NZ11045966   License Plate: EYA9900
    Mileage: 171250km-106409mi   Repair Order:
       Coding: 10710
       Coding: 18446
       Shop #: WSC 01236
       Coding: 00040
       Shop #: WSC 01236
       Coding: 10102
       Shop #: WSC 01236
       Coding: 05044
       Shop #: WSC 01020
    01304 - Radio
       Coding: 06730
       Shop #: WSC 01236
       Coding: 00001
       Coding: 00010
       Shop #: WSC 01236
       Coding: 00207
       Shop #: WSC 00040
                00-00 -  -
    May 2016
    PHP Code:
    VCDS Version 18.2.0.3 (x64)  HEX-V2 CB0.4411.4
    Data version
    20180212 DS287.0
    [url]www.Ross-Tech.com[/url]
    3 Faults Found
    01303 Telephone Transceiver (R36)
    49-00 No Communications
    01304
    Radio
                49
    01305
                37
    -10 Faulty Intermittent
    VIN
    TRUZZZ8NZ11045966   License PlateEYA9900
    Mileage
    Chassis Type8N (8N Audi TT (1999 2007))
    Scan01 02 03 08 15 17 22 35 37 45 55 56 76 77
    VIN
    TRUZZZ8NZ11045966   Mileage171250km-106409miles
    Address 01Engine        Labels06A-906-032-BAM.lbl
       Part No
    8N0 906 018 H
       Component
    1.8L R4/5VT     G   0004
       Coding
    10710
       Shop
    #: WSC 00000
    VCID3635DB65F159CC47984-513D
    No fault code found
    Readiness0000 0000
    Address 03ABS Brakes        Labels8N0-907-379-MK20-E.clb
       Part No
    8N0 907 379 E
       Component
    ESP     20    CAN  V005
       Coding
    18446
       Shop
    #: WSC 01236
    VCID3E25C345D9690407404-4B01
    No fault code found
    Address 08Auto HVAC        Labels8N0-820-043.lbl
       Part No
    8N0 820 043 A
       Component
       Coding
    00040
       Shop
    #: WSC 01236
    VCID2809051D2BEDAAB71A8-2581
    1 Fault Found
    00604 Potentiometer Positioning Motor for Air Flow Flap (G113
    30-10 Open or Short to Plus Intermittent
    Address 15Airbags        Labels8N8-909-601.lbl
       Part No
    8N8 909 601
       Component
       Coding
    10102
       Shop
    #: WSC 01236
    VCID77AB1661B6D3F54F432-513D
    No fault code found
    Address 17Instruments        Labels8Nx-920-xxx-17.lbl
       Part No
    8N1 920 880 H
       Component
    KOMBI+WEGFAHRSM73 D56
       Coding
    05044
       Shop
    #: WSC 01020
    VCID3A2DCF55C54128277CC-4B01
    3 Faults Found
    01304
    Radio
                49
    01305
                37
    Address 22AWD        Labels02D-900-554.lbl
       Part No
    02D 900 554 B
       Component
    HALDEX LSC  ECC     0006
       VCID
    1 Fault Found
    00526 Brake Light Switch (F
    27-10 Implausible Signal Intermittent
    Address 35CentrLocks        Labels:. 8Nx-962-267.lbl
       Part No
    8N8 962 267
       Component
       Coding
    06730
       Shop
    #: WSC 01236
    VCID7EA5034599E9C407004-4F0D
    No fault code found
    Address 45InterMonitor        Labels8E0-951-177.lbl
       Part No
    8N8 951 177 A
       Component
       Coding
    00001
       Shop
    #: WSC 00000
    VCID3D27C449D46F1F1F59E-5119
    No fault code found
    Address 55Headlight Range        Labels4B0-907-357-AUT.lbl
       Part No
    4B0 907 357
       Component
       Coding
    00010
       Shop
    #: WSC 01236
    VCID65974C291C7F77DFE1E-5161
    No fault code found
    Address 56Radio        Labels8D0-035-1xx-56.lbl
       Part No
    4B0 035 186 D
       Component
    :  Radio             0001
       Coding
    00207
       Shop
    #: WSC 00040
    VCID211F183948D75BFF5D6-4AE1
    3 Faults Found
    00852 Loudspeaker(s); Front
                36
    -10 Open Circuit Intermittent
    00854
                49
    65535
                00
    -00 -  -
    End----------(Elapsed Time02:25VBatt start/end12.2V/12.2V)-----------
    Morning, I not being a communications guru, but you would be well served to get a good wire diag and see how these and other codes interact, as I am not sure if they are Can Bus or powered otherwise, but appear databus for infotainment related, would appear Can, but not going to lead you wrong is my point.
    Noted potentiometer AC flap coded, but that did not seem to be your issue.
    best of luck, Larimore.
    01304 - Radio
    Feb 2018
    GR
    The story goes as follows. My Audi has preparation phone for handsfree. Wanted to keep the old-school design i bought a cradle for an old device i had. However every time i was connecting the phone, i was having the following issues
    i) radio stuck, buttons were not functioning showing TELEFON on radio display
    ii) dashboard display stuck, showing TELEFON
    When i was disconnecting it, everything was working properly. (the dashboard display as well)
    So i went to an Audi garage and the guy told me that he couldn't see Canbus being activated and that's why the Telephone seemed not to be read by CanBus, so he tried to activate CanBus manually via VCDS, then he tried to reset some things, can't recall what exactly he did as i had no idea what he was doing. If i am not wrong, my car does NOT have Canbus!
    From then on, the dashboard display stopped functioning. i can see the "OK" etc when car engine starts, but then...black screen, i don't get any radio info.
    So, i bought a VCDS Hex v2 so as to solve it by myself.
    Trying to give you some more info to help me solve this:
    Coding: 00040
    Shop #: WSC 01236
    think this is not a problem. it has to do with a gauge that has been installed in the position of an air-vent for the aircondition
    Coding: 05044
    Shop #: WSC 01020
    01304 - Radio
    Coding: 00207
    Shop #: WSC 00040
    00-00 - -
    I believe the error is here but don't know what exactly.
    Regarding open circuits, i have installed a bluetooth device for music/audio streaming, think this is a reason for showing "fault" but this is not important. Even with bluetooth device installed, the dashboard display was working until i went to this garage.
  6. #6
    Feb 2018
    GR
    http://wiki.ross-tech.com/wiki/index.php/Audi_TT_(8N)
    can someone post the coding/adaptation et all from "[17] - Instrument Cluster" ?
  7. #7
    Administrator Andy's Avatar
    All of the information that we have is likely in the label file 8Nx-920-xxx-17.lbl
    It's plain text so you can open it with Notepad on your PC:
    C:\Ross-Tech\VCDS\8Nx-920-xxx-17.lbl
  8. #8
    Feb 2018
    GR
    thanks.
    on Coding mine is 05044.
    On label file i see the following:
    C00,Instrument Cluster (J285) Coding
    C01,??xxx: Options
    C02,+01 = All-Wheel-Drive (AWD) / Quattro (Extended Fuel Tank)
    C03,+02 = Seatbelt Warning active
    C04,+04 = Manual Transmission (02M)
    C05,+16 = Secondary Display (Radio/Navigation - w/o CAN-Databus Display)
    I am trying to change from 05044 to 21044 but it doesn't go through.
    (21 = 01 + 04 + 16)
  9. #9
    Feb 2018
    GR
    The solution is:
    [17 Instrument Cluster] / Adaptation / channel 62 / correct code is 4 for models up to 2001.
    Mine was at code 3. As soon as i changed it to 4, it worked like a charm!
    For model from 2002, it's either the correct is either 1 or 5 (for navigation system NS-Low)
    The radio coding didn't have any effect since i had 00207 (7 = 1 antenna + 2 cd changer + 4 secondary display) but i think the correct one is 00007 (so i changed that as well)
  10. Likes Uwe, Dana liked this post
