Results 1 to 7 of 7
Thread: The underboosting Audi A3 8p
    New User
    May 2018
    Canada
    Went from apr stage one at 15psi to 3-5 psi max
    Overnight!
    Have replaced dv,n75, and boost leak tested
    And de catted
    Vcds scan revealed
    000665- boost pressure regulation
    P0299-002- control range not reached
    005634-power supply terminal 30
    P1602-002-voltage too low- intermittent
    Have all values please help
    Please post a complete Auto-Scan for context.
  3. Likes Trade Member liked this post
    New User
    May 2018
    Canada
    Friday,11,May,2018,13:45:35:24746
    VCDS Version: 18.2.0.3 (x64)
    VIN: WAUHF68PX6A000724   License Plate:
    Mileage: 89090km-55357mi   Repair Order:
    Chassis Type: 8P (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72
    VIN: WAUHF68PX6A000724   Mileage: 89090km-55357miles
    42-Door Elect, Driver -- Status: Sporadic communication error 1000
       Part No SW: 8P0 907 115 B    HW: 8P0 907 115 B
       Component: 2.0l R4/4V TFSI     0080
       Revision: --H10---    Serial number: AUX7Z0E1FN70NJ
       Coding: 0103010A18070160
       Shop #: WSC 95982 999 84216
       VCID: 316937C4A849F0CCA7-8064
    000665 - Boost Pressure Regulation
                   P0299 - 002 - Control Range Not Reached - Intermittent
                        Fault Status: 00110010
                        Mileage: 89035 km
                        Date: 2018.04.24
                        Time: 00:23:27
                        RPM: 5264 /min
                        Load: 58.0 %
                        Speed: 106.0 km/h
                        Temperature: 77.0°C
                        Temperature: 18.0°C
                        Absolute Pres.: 980.0 mbar
                        Voltage: 14.224 V
                        Load: 0.0 %
                        Temperature: -40.0°C
                        Absolute Pres.: 0.0 mbar
                        Voltage: 0.000 V
    Readiness: 0010 0101
       Part No: 1K0 907 379 K
       Component: ESP FRONT MK60      0104
       Coding: 0021126
       Shop #: WSC 95982 999 54568
       VCID: 3A7B10E8753F339416-806E
       Part No SW: 8P0 820 043 H    HW: 8P0 820 043 H
       Component: KlimavollautomatH14 0180
       Revision: 153488      Serial number: 8P0820043H
       Shop #: WSC 06314 000 00000
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Fault Frequency: 35
                        Reset counter: 211
                        Mileage: 88113 km
                        Date: 2018.04.02
                        Time: 13:17:35
                        Temperature: 13.0°C
                        Voltage: 11.90 V
                        Load: 0.0 %
                        Load: 9.0 %
                        Fault Frequency: 13
                        Reset counter: 250
                        Mileage: 88142 km
                        Date: 2018.04.03
                        Time: 10:46:56
    Address 09: Cent. Elect.        Labels:. 8P0-907-279-23-H.lbl
       Part No SW: 8P0 907 279 F    HW: 8P0 907 279 F
       Component: Bordnetz-SG     H35 1102
       Revision: 00H35000    Serial number: 00000001353857
       Coding: 098C4F828014100000181800180000000038FE075C1100
       Shop #: WSC 98765 666 36447
       VCID: 408F620013E3694458-8014
       Subsystem 1 - Part No: 8P1 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer AU350   H01 0130
       Coding: 00062736
       Shop #: WSC 98765
    7 Faults Found:
    01501 - Bulb for Blinkers; Rear Left (M6)
                        Fault Status: 00101100
                        Reset counter: 240
                        Mileage: 88832 km
                        Date: 2018.04.19
                        Time: 04:47:00
                        Voltage: 13.50 V
                        Reset counter: 240
                        Mileage: 88467 km
                        Date: 2018.04.13
                        Time: 17:41:00
                        Voltage: 14.45 V
    00984 - Left Tail Light (M4)
                        Fault Frequency: 45
                        Reset counter: 240
                        Mileage: 88144 km
                        Date: 2018.04.03
                        Time: 15:51:00
                        Voltage: 13.85 V
    00985 - Right Tail Light (M2)
                        Reset counter: 240
                        Mileage: 88113 km
                        Date: 2018.04.02
                        Time: 13:15:00
                        Voltage: 11.55 V
                        Fault Frequency: 121
                        Reset counter: 251
                        Mileage: 88126 km
                        Date: 2018.04.02
                        Time: 17:05:00
                        Voltage: 12.30 V
                        Fault Status: 01101100
                        Reset counter: 211
                        Mileage: 88113 km
                        Date: 2018.04.02
                        Time: 13:15:00
                        Voltage: 11.55 V
                        Reset counter: 211
                        Mileage: 88113 km
                        Date: 2018.04.02
                        Time: 13:15:00
                        Voltage: 11.55 V
    Address 15: Airbags        Labels: 8P0-959-655-94.lbl
       Part No SW: 8P0 959 655 A    HW: 8P0 959 655 A
       Component:    Airbag 9.41  H10 3250
       Revision: 91H10325    Serial number: 0035W0000MYA
       Coding: 0030605
       Subsystem 1 - Serial number: 6332DRB40169CE90Y
       Subsystem 2 - Serial number: 6342DRB4016B4F24R
       Subsystem 3 - Serial number: 63528RB4003E3D84P
       Subsystem 4 - Serial number: 63628RB4003E1EA2P
       Subsystem 5 - Serial number: 63729RB4004C6D2BV
       Subsystem 6 - Serial number: 63829RB4044D29B7Y
       Part No SW: 8P0 953 549 C    HW: 8P0 953 549 C
       Component: Lenksäulenmodul H21 0050
       Coding: 0000022
       VCID: 3E731CF869171FB42A-806A
    Address 17: Instruments        Labels: 8P0-920-xxx-17-MY7.lbl
       Part No SW: 8P0 920 900 J    HW: 8P0 920 900 J
       Component: KOMBIINSTR. VDO H73 0300
       Revision: D04         Serial number: 1241ED04007798
       Coding: 0004333
       VCID: 366304D84127D7F4F2-8062
       Part No SW: 1K0 907 530 D    HW: 1K0 907 951
       Component: Gateway         H08 0100
       Revision: 08          Serial number: 25001051290652
       Coding: 3D3F0342072102
       VCID: 285FDAA09B93B10470-807C
                        Fault Frequency: 230
                        Reset counter: 251
                        Mileage: 88126 km
                        Date: 2018.04.02
                        Time: 17:05:23
       Revision: D04         Serial number: AUX7Z0E1FN70NJ
       Shop #: WSC 65157 001 1048576
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN1.lbl
       Part No: 8P0 959 801 E
       Component: Tuersteuerger.  H10 0030
       Coding: 0000017
       VCID: 3D711BF4641104AC33-8068
       Part No: 1K1 909 144 H
       Component: EPS_ZFLS Kl.7       1502
       VCID: 306F32C0A343F9C4A8-8064
                000 -  -
    Address 46: Central Conv.        Labels: 8P0-959-433.lbl
       Part No: 8P0 959 433 D
       Component: 02 KSG          H04 0050
       Coding: 9AC003382D08850FC88F447300
       Component: LIN BACKUP HORN H02 1301
       Subsystem 2 - Part No: 1K0 907 719 B
       Component: Neigungssensor  004 0003
    01134 - Alarm Horn (H12)
       Part No SW: 8P4 035 382     HW: 8P4 035 382
       Component: AB2 SUBWOOFERBOXH03 0180
       Revision: 00002       Serial number: 10000001218640
       VCID: 71E9F7C468C9B0CCE7-8024
    Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MIN1.lbl
       Part No: 8P0 959 802 E
       Coding: 0000017
    Address 56: Radio        Labels: 8P0-035-1xx-56.lbl
       Part No SW: 8P0 035 186 A    HW: 8P0 035 186 A
       Component: concert II US   H56 0410
       Revision:      09S    Serial number: AUZ5Z6E6012087
       Coding: 0001001
       Shop #: WSC 06435 000 00000
                        Fault Status: 01101011
                        Reset counter: 152
                        Mileage: 88113 km
                        Date: 2018.04.02
                        Time: 13:16:11
       Part No: 8P4 959 801 B
       Component: Tuer-SG         H10 0020
       Coding: 0001168
       Part No: 8P4 959 802 B
       Coding: 0001168
       VCID: 3F8D61FC6E1D16BC21-806A
    End-------------------------(Elapsed Time: 01:45)--------------------------
    Hmm, the boost code shows good voltage in the freeze-frame, so I'm going to speculate that it's not related to the "voltage too low" code.
    How exactly was it tested for boost leaks?
    New User
    May 2018
    Canada
    3 inch rubber end cap with a tire valve over the maf
    Norristown, PA
    Have you double checked the hose that runs from the N75 to the wastegate? Check that it's fully seated and tight at both ends.
    Have you double & triple checked that the wastegate was put back in correctly...they're harder to get wrong on your car but I've seen it.
  8. Likes Uwe liked this post
    Aug 2016
    Switzerland
    Intermittent mistakes are always the most annoying. By the looks of it, didn't occur simultaneously either.
    Have a look at the vacuum lines, like suggested by dafrazi. Maybe you'll need to do a basic setting/calibration of the new N75?
    Is the actuator arm of the turbo moving? In some engines there is an output test for this.
  10. Likes Uwe liked this post
