2010 A4 quattro 2.0T differences
Zingrox
C?ID=336968
Hey guys, I'm wondering how I find all the code-able differences between manual and automatic transmissions for the b8 A4 (not 8.5). Long story short, I'm doing a transmission swap - among other things - on it and would like to prep for this aspect. If there is a list, or a way to easily find out by doing it myself, that'd be grand. But searching each module for anything remotely relevant to the matter isn't too efficient. Thanks for any help you might have
-Chris
Well, a good start would be to post an Auto-Scan so people can see exactly how this vehicle is currently equipped. Equipment does vary based on trim level and other such things.
Zingrox
C?ID=336968
Solid point. Ill have to wait until my unit comes in, unfortunately
Zingrox
C?ID=336968
To preface this absolute LIST I have here: The car is currently in full project mode. A lot of things taken apart. Among other things, a manual conversion and full engine swap is under way. The ecu is manual, the car used to be automatic. Besides some wiring things I must alter, I know there are many issues here. Anyone who takes the time to help me is phenomenal, and I plan to post a final write-up of all the findings on this subject. The car currently does not have a transmission in it, though I just received one today. So there is currently an engine that doesn't fully belong, an ecu that is altered to ignore the immobilizer (hopefully) and the cars body wiring is completely unchanged right now. I wanted a clean slate before I started changing things, so as to keep track of it all. It does not attempt to turn over, but I didnt expect it to. Thanks for the read
Tuesday,15,May,2018,17:07:03:09178
VCDS Version: 18.2.0.3 (x64)
VIN: WAURV68T28A031733   License Plate:
Chassis Type: 8T-AU48 (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 42 46 47 52 53 56 62 72
VIN: WAURV68T28A031733   Mileage: 220310km-136894miles
02-Auto Trans -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: Malfunction 1010
Address 01: Engine (J623-CAUB)       Labels:. 079-907-560-CAU.clb
   Part No SW: 8T0 907 560 G    HW: 8T0 907 560
   Component: 4.2l V8/4V    H10 0008
   Revision: 76H10---
   Coding: 01140009180F0120
   Shop #: WSC 93204 999 83903
   VCID: 3E25C295B0758857404-806A
006418 - Pressure Sensor for Brake Boost (G294)
               P1912 - 001 - Short to Plus
000400 - Fuel Pressure Sensor (G247)
               P0190 - 001 - Circuit Malfunction
001796 - Clutch Switch (F36)
               P0704 - 004 - Implausible Signal
000112 - Sensor for Ambient Air Temperature (G17)
               P0070 - 001 - Malfunction
Readiness: 0110 1101
Address 02: Auto Trans
   Part No SW: 8K0 907 379 CA    HW: 8K0 907 379 AN
   Component: ESP8 quattro  H04 0010
   Coding: 150D10
   Shop #: WSC 02391 823 56573
   VCID: 7AAD0E85ECDD64773CC-802E
12 Faults Found:
02214 - Tire Pressure Warning
            000 -  -  - Intermittent
            013 - Check DTC Memory
01794 - Control Module - Incorrect Chassis (VIN) Number
            000 -  -  - Intermittent - MIL ON
   Part No SW: 8K0 907 064 DF    HW: 8K0 907 064 DF
   Component: BCM2 1.1      H02 0321
   Coding: 090100
   Shop #: WSC 02399 823 56573
   VCID: 77AB17B1DFCF791F432-8022
   Subsystem 1 - Part No SW: 8T0 959 754 A    HW: 8T0 959 754 A
   Serial number: 0509000034446013
   Component: J764 ELV MLB  H36 0042
   Serial number: 0209000046095011
02241 - Engine Control Module; Immobilizer Data not Adapted
02811 - Control Module for Electronic Steering Column Lock (J764)
02823 - Requirements for Locking the Steering Column Lock not met
   Part No SW: 8T1 820 043 AN    HW: 8T1 820 043 AN
   Component: KLIMA 1 ZONE  H08 0160
   Revision: A1000000    Serial number: 01010720090991
   Coding: 64002000
   VCID: 7DA70599FDF3534F19E-8028
8 Faults Found:
03220 - Stop Valve for Coolant for Climatronic (N422)
            006 - Short to Plus
   Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
   Component: BCM1 1.0      H25 0380
   Revision: 10025001    Serial number: 00000000297025
   Coding: 690000B1063C00010000080300007F5F0F14520802000001000000
   Shop #: WSC 08180 444 68462
   VCID: 3C21C89DA6699A476E0-8068
   Component: WWS 260609  H06 0070
   Serial number: SWF09060260410
   Coding: 00FD11
   Subsystem 2 - Part No SW: 8K0 941 531 AK    HW: 8K0 941 531 AK
   Component: E1 - LDS  H08 0090
   Serial number: 00000000002506090800
9 Faults Found:
03351 - Bulb for DRL and Marker Light; Left
03354 - Bulb for DRL and Marker Light; Right
00910 - Indicator Lamp for Emergency Flashers (K6)
   Part No SW: 8K0 959 655 H    HW: 8K0 959 655 H
   Component: AirbagVW-AU10 H37 0520
   Serial number: 003EGD0264ET
   Coding: 303836354230303030304A55304C384B3053
   Shop #: WSC 02145 785 00200
   VCID: 42DDB665C40DECB724C-8016
   Subsystem 1 - Part No SW: 8K0 959 339 B    HW: 8K0 959 339 B
   Component: BF-Gewichtss.  H01 0030
   Serial number: 5810000R0900004FL4
   Serial number: 6334MSME4903092CC
   Serial number: 6344MSME49636B47O
   Serial number: 6352QSME20313434/
   Serial number: 6362QSME7E311C20I
9443859 - Driver's Front Airbag Crash Sensor
          B101A 15 [137] - Open or Short to Plus
9444115 - Front Passenger's Front Airbag Crash Sensor
          B101B 15 [137] - Open or Short to Plus
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
          B1016 14 [137] - Open or Short to Ground
12583424 - Powertrain Databus
          U0002 00 [008] - No Communications
          [High Speed CAN Communication Bus no signal/communication]
9482752 - Seat Occupied Recognition
          B10B2 00 [008] - Function Restriction due to Missing Message(s)
          [Bladder Mat: functional restriction because of missing message]
   Revision: --------    Serial number: 90315IFT0004U
   Coding: 000014
   VCID: 3D27C599BD73934F59E-8068
   Part No SW: 8K0 920 950 E    HW: 8K0 920 950 E
   Component: KOMBIINSTR.   H19 0253
   Revision: 00100000    Serial number: BWX33GR69
   Coding: 8B1209000300D705020000
   VCID: 313FE9A9712B672FCD6-8064
00771 - Fuel Level Sensor (G)
00438 - Fuel Supply Sensor 2 (G169)
   Part No SW: 8T0 907 468 R    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0101
   Revision: GB500049    Serial number: 4900G096208416
   Coding: 00C303
   VCID: 50F98C2D1AE10E27A28-8004
   Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
   Component: J367-BDM  H06 0160
   Serial number: 19082A05110609
6 Faults Found:
01312 - Powertrain Data Bus
01304 - Radio
   Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000008999560
   Coding: 011C03204000410001
   VCID: 45D7AD79D5A3DB8F01E-8010
   Revision: 00002001    Serial number: 0119131169
   Coding: 0106023A007A000400B0010000000000
   Subsystem 2 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
   Component: J245 PS039  H06 0041
10 Faults Found:
02616 - Fuel Tank Cap; Unlock
02615 - Fuel Tank Cap; Lock
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
   Part No SW: 8T0 035 223 AH    HW: 8T0 035 223
   Component: DSP STD       H07 0230
   Revision: S2200000
   Coding: 0203010101
   VCID: 74B120BDCEB91207660-8020
   Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
   Component: TSG BF        H11 0306
   Revision:             Serial number: 0000009013006
   VCID: 44D1B07DDE99E287160-8010
   Component: EPB Audi B8   H09 0090
   Revision: 00000003    Serial number: 00000000402919
   VCID: 3431E0BD8E395207A60-8060
7 Faults Found:
03200 - Switch for Electric Parking Brake (E538)
03182 - Clutch Position Sensor (G476)
   Part No SW: 8T1 035 186 R    HW: 8T1 035 186 R
   Component: Con3 Sirius   H03 0351
   Revision: 00000005    Serial number: AUZ5Z6I1240320
   Coding: 05020000010105004119070000
   VCID: 46D5AA75E8A5D097084-8012
   Subsystem 1 - Part No SW: 8T0 919 603 E    HW: 8T0 919 603 E
   Component: Display
03138 - Input AUX IN
02259 - Information Display and Control Head (Front) (J685)
   Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
   Component: TSG HL        H10 0306
   Revision:             Serial number: 0000101439676
   Coding: 010C03204000210001
   VCID: 42DDB665C48DECB724C-8016
   Component: TSG HR        H10 0306
   Revision:             Serial number: 0000101439673
End----------(Elapsed Time: 01:27, VBatt start/end: 12.6V/12.6V)-----------
Wow! That is indeed a project!
The first thing I'd do is remove 02-Auto Trans from the Gateway's Installation List.
[Select]
[19-CAN Gateway]
[Installation List]
Uncheck 02-Auto Trans
[Save Coding]
Zingrox
C?ID=336968
Thank you so much. Ive used this product before but only recently did I buy one for myself! Ive done some reading but cant quite get fluent enough just from that to do it all myself. Ill do that shortly and see how it acts after. Should probably place the master cylinder in, but the sensor is on the slave, on the transmission.
Edit: Everything happily accepted that. Despite doing above, It still locks the key without the auto shifter connected in park. But I'm sure that deals with different aspects of this
Zingrox
C?ID=336968
Update on that change, and I still do not have my transmission in or at least hooked up yet. Maybe soon if things check out!
Wednesday,16,May,2018,18:03:59:09178
Mileage: 220310km-136894mi   Repair Order: Test 02
Scan: 01 03 05 08 09 15 16 17 19 42 46 47 52 53 56 62 72
   Revision: 76H10---
                    Fault Status: 01100001
                    Mileage: 220314 km
                    Date: 2009.05.08
                    Time: 20:50:09
                    Temperature: 21.0°C
                    Temperature: 27.0°C
                    Absolute Pres.: 940.0 mbar
                    Voltage: 12.827 V
                    Mileage: 220314 km
                    Date: 2009.05.08
                    Time: 20:50:09
                    Temperature: 21.0°C
                    Temperature: 27.0°C
                    Voltage: 12.827 V
                    Mileage: 220314 km
                    Date: 2009.05.08
                    Time: 20:50:09
                    Temperature: 21.0°C
                    Temperature: 27.0°C
                    Voltage: 12.827 V
                    Mileage: 220314 km
                    Date: 2009.05.08
                    Time: 20:50:09
                    Temperature: 21.0°C
                    Temperature: 27.0°C
                    Voltage: 12.827 V
   Coding: 150D10
12 Faults Found:
                    Reset counter: 99
                    Mileage: 219357 km
                    Date: 2017.08.20
                    Time: 11:43:35
                    Hex Value: 0x4400
                    Hex Value: 0x4006
                    Hex Value: 0x1237
                    Hex Value: 0x1CA8
                    Hex Value: 0x00FF
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2017.09.05
                    Time: 12:11:53
                    Hex Value: 0x00C0
                    Hex Value: 0x0806
                    Hex Value: 0x1203
                    Hex Value: 0x0373
                    Hex Value: 0x00FF
                    Fault Status: 01101101
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.30
                    Time: 20:32:02
                    Hex Value: 0x0000
                    Hex Value: 0x0082
                    Hex Value: 0x0032
                    Hex Value: 0x0296
                    Hex Value: 0x00FF
                    Fault Frequency: 7
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:06:21
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x002B
                    Hex Value: 0xB99D
                    Hex Value: 0x00FF
                    Fault Frequency: 23
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:06:21
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x0027
                    Hex Value: 0x859D
                    Hex Value: 0x00FF
                    Fault Frequency: 24
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:06:23
                    Hex Value: 0x0000
                    Hex Value: 0x2282
                    Hex Value: 0x0038
                    Hex Value: 0x339C
                    Hex Value: 0x00FF
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.30
                    Time: 20:32:02
                    Hex Value: 0x0000
                    Hex Value: 0x0082
                    Hex Value: 0x0032
                    Hex Value: 0x0296
                    Hex Value: 0x00FF
                    Reset counter: 131
                    Hex Value: 0x0000
                    Hex Value: 0x2280
                    Hex Value: 0x0038
                    Hex Value: 0x66A4
                    Hex Value: 0x00FF
                    Fault Status: 00101101
                    Reset counter: 131
                    Hex Value: 0x0000
                    Hex Value: 0x2280
                    Hex Value: 0x001C
                    Hex Value: 0x23A3
                    Hex Value: 0x00FF
                    Fault Status: 00100101
                    Reset counter: 131
                    Hex Value: 0x0000
                    Hex Value: 0x2280
                    Hex Value: 0x001C
                    Hex Value: 0x2AA4
                    Hex Value: 0x00FF
                    Reset counter: 131
                    Hex Value: 0x0000
                    Hex Value: 0x2280
                    Hex Value: 0x0038
                    Hex Value: 0x1BA3
                    Hex Value: 0x00FF
                    Fault Status: 10100000
                    Reset counter: 131
                    Hex Value: 0x0000
                    Hex Value: 0x2280
                    Hex Value: 0x0014
                    Hex Value: 0x13A3
                    Hex Value: 0x00FF
   Coding: 090100
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:06:21
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.05.01
                    Time: 23:19:45
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.05.05
                    Time: 19:34:14
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.05.05
                    Time: 22:20:11
   Coding: 64002000
8 Faults Found:
                    Reset counter: 91
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.30
                    Time: 20:31:59
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.30
                    Time: 20:31:59
                    Temperature: 15.0°C
                    Fault Status: 00101001
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:06:19
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:06:19
            006 - Short to Plus
                    Fault Status: 01100110
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.05.01
                    Time: 23:19:45
                    Voltage: 12.70 V
                    Voltage: 12.90 V
                    Voltage: 13.00 V
                    Voltage: 13.00 V
                    Bin. Bits: 00000000
                    Time: 0.00 s
                    Count: 1
                    Reset counter: 131
                    Reset counter: 131
   Coding: 00FD11
9 Faults Found:
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.30
                    Time: 20:31:00
                    Reset counter: 91
                    Mileage: 219028 km
                    Date: 2017.08.15
                    Time: 21:15:00
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2017.10.07
                    Time: 15:19:00
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:11:00
                    Reset counter: 87
                    Mileage: 220204 km
                    Date: 2017.09.01
                    Time: 20:39:00
                    Reset counter: 87
                    Mileage: 220204 km
                    Date: 2017.09.01
                    Time: 20:39:00
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.30
                    Time: 20:31:00
                    Reset counter: 91
                    Mileage: 219028 km
                    Date: 2017.08.15
                    Time: 21:15:00
                    Reset counter: 91
                    Mileage: 1048574 km
                    Mileage: 220314 km
                    Date: 2009.04.30
                    Time: 20:31:56
                    Mileage: 220314 km
                    Date: 2009.04.30
                    Time: 20:31:56
                    Mileage: 220314 km
                    Date: 2009.05.05
                    Time: 22:26:32
                    Reset counter: 131
                    Reset counter: 131
   Coding: 000014
                    Reset counter: 131
                    Reset counter: 40
                    Reset counter: 131
                    (no units): 44.0
                    Text: 2C8BFFFFFFFF00C0FF
                    RPM: 0
                    Raw, Index/Key Err.: 255 255 000
                    Fault Frequency: 71
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:06:13
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:06:21
                    Fault Status: 00101010
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:13:51
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:13:51
   Coding: 00C303
6 Faults Found:
                    Fault Frequency: 37
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2017.09.29
                    Time: 16:20:18
                    Bin. Bits:    10011
                    Voltage: 11.60 V
                    Count: 6
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:00:00
                    Bin. Bits:    00000
                    Voltage: 13.00 V
                    Count: 7
                    Bin. Bits:    10000
                    Time: 0.40 s
                    Fault Frequency: 20
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:00:00
                    Bin. Bits:    00000
                    Voltage: 13.00 V
                    Count: 7
                    Bin. Bits:    10000
                    Time: 0.40 s
                    Fault Frequency: 54
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:00:00
                    Bin. Bits:    00000
                    Voltage: 13.00 V
                    Count: 7
                    Bin. Bits:    10000
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.05.02
                    Time: 00:08:26
                    Bin. Bits:    00000
                    Voltage: 13.30 V
                    Count: 7
                    Bin. Bits:    10000
                    Time: 0.90 s
01304 - Radio
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.05.05
                    Time: 22:12:08
                    Bin. Bits:    10000
                    Voltage: 13.10 V
                    Count: 12
                    Bin. Bits:    10000
                    Reset counter: 131
                    Reset counter: 131
                    Reset counter: 131
                    Reset counter: 131
                    Reset counter: 131
10 Faults Found:
                    Fault Status: 01101001
                    Reset counter: 22
                    Mileage: 218339 km
                    Date: 2017.08.07
                    Time: 12:37:14
                    Reset counter: 23
                    Mileage: 218369 km
                    Date: 2017.08.07
                    Time: 13:04:11
                    Reset counter: 131
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:06:21
                    Fault Frequency: 130
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:06:39
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.05.02
                    Time: 00:08:30
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.05.05
                    Time: 22:27:22
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:14:14
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:14:14
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:14:14
   Revision: S2200000
   Coding: 0203010101
                    Reset counter: 131
                    Reset counter: 131
                    Reset counter: 131
                    Reset counter: 131
                    Reset counter: 131
7 Faults Found:
                    Reset counter: 131
                    Voltage: 13.10 V
                    Count: 68
                    Hex Value: 0x0273
                    Hex Value: 0x0001
                    Hex Value: 0x1010
                    Reset counter: 131
                    Voltage: 13.10 V
                    Count: 67
                    Hex Value: 0x0273
                    Hex Value: 0x0001
                    Hex Value: 0x1010
                    Fault Status: 00101011
                    Fault Frequency: 23
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.05.01
                    Time: 23:50:33
                    Voltage: 14.20 V
                    Count: 38
                    Hex Value: 0x0173
                    Hex Value: 0x0008
                    Hex Value: 0x1010
                    Fault Status: 01101010
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.05.01
                    Time: 23:19:46
                    Voltage: 13.00 V
                    Count: 51
                    Hex Value: 0x02F3
                    Hex Value: 0x0001
                    Hex Value: 0x1010
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:06:21
                    Voltage: 12.60 V
                    Count: 66
                    Hex Value: 0x0270
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:06:21
                    Voltage: 12.60 V
                    Count: 64
                    Hex Value: 0x0270
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Fault Status: 11101101
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.30
                    Time: 20:32:02
                    Voltage: 12.00 V
                    Count: 80
                    Hex Value: 0x0260
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   Component: Display
                    Reset counter: 22
                    Mileage: 218339 km
                    Date: 2017.08.07
                    Time: 11:58:26
                    Reset counter: 22
                    Mileage: 218339 km
                    Date: 2017.08.07
                    Time: 11:58:35
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:06:24
                    Reset counter: 40
End----------(Elapsed Time: 01:27, VBatt start/end: 13.0V/12.6V)-----------
I think my list elongated, but there are things in there I am pleased to see that make sense with where the car is.
This car is getting a proper, 3-pedal transmission, right?
Zingrox
C?ID=336968
Yes, of course. Manual transmission, three pedals, linkages and all. I know it's an ordeal, but I figured if I'm changing the engine and would need a different tranny for it, why not attempt a manual conversion. The transmission is currently on a pallet in front of the car, taunting me
Zingrox
C?ID=336968
So, while I looked over my options of getting the transmission in, I noticed something. The people who pulled my engine before me broke THREE mounting bolts for the bell housing to the engine. Lovely, now I'm chiseling and drilling those out. Because of this setback, though, it gave me an excuse to pull the engine (again) and I can mount the transmission easier and faster, then just toss it all in as one unit. Silver lining, sorta. Once it's all in there, I'll have an update for any of you reading this. Aluminum stretch bolts are the bane of my existence right now
Zingrox
C?ID=336968
Transmission and engine are now friends, and both in the car. Will have an update shortly, just getting things hooked up and the laptop charged
Zingrox
C?ID=336968
Here she is. Apparently the unit does not like what is going on very much. Many things are equated to not being hooked up or having lost power previously. The car also has had the trip status as SAFE this whole time, which means it also doesn't like my key I guess. I am not sure if I can adapt this myself, but I haven't checked, I just recall some forum posts now and again about it. It'll all be taken care of in due time of course. Anyway, I'm approaching the road to getting it to fire up, which of course means I need that sorted out and a few other things. Unfortunately, random things I do not know about will restrict starting, sometimes crazy stuff. Like on the BMW m5, if your hood latch sensor goes awry it just wont start. Anywho, here she is, all 1500 lines :I
If you have an suggestions, please tell me, trying to figure it all out alone is a bit of a grind and the number of tabs I have open on google is astounding. And for those of you interested, here is a thread I started on Audizine showing what I'm doing with a bit more color: https://www.audizine.com/forum/showthread.php/814342-Zingrox-s-B8-A4-Build
Friday,01,June,2018,17:01:51:09178
Mileage: 220310km-136894mi   Repair Order: 03 w/ trans
Chassis Type: 8T0
   Revision: 76H10---
10 Faults Found:
                    Temperature: -40.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
                    Temperature: 21.0°C
                    Temperature: 26.0°C
                    Voltage: 12.954 V
                    Temperature: 21.0°C
                    Temperature: 26.0°C
                    Voltage: 12.827 V
                    Temperature: 21.0°C
                    Temperature: 26.0°C
                    Voltage: 12.954 V
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 16:56:09
                    Temperature: 21.0°C
                    Temperature: 27.0°C
                    Voltage: 13.081 V
004200 - Intake Air Switch-Over Valve (N335)
               P1068 - 004 - Open Circuit
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 17:15:50
                    RPM: 119 /min
                    Load: 100.0 %
                    Temperature: 21.0°C
                    Temperature: 27.0°C
                    Voltage: 12.192 V
005495 - Right Engine Mount Solenoid Valve (N145)
               P1577 - 004 - Open Circuit
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 17:15:50
                    RPM: 119 /min
                    Load: 100.0 %
                    Temperature: 21.0°C
                    Temperature: 27.0°C
                    Voltage: 12.192 V
005491 - Left Engine Mount Solenoid Valve (N144)
               P1573 - 004 - Open Circuit
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 17:15:50
                    RPM: 119 /min
                    Load: 100.0 %
                    Temperature: 21.0°C
                    Temperature: 27.0°C
                    Voltage: 12.192 V
001152 - Coolant Fan Control Circuit 1
               P0480 - 004 - Electrical Malfunction
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 17:15:50
                    RPM: 119 /min
                    Load: 100.0 %
                    Temperature: 21.0°C
                    Temperature: 27.0°C
                    Voltage: 12.192 V
001153 - Coolant Fan Control Circuit 2
               P0481 - 004 - Electrical Malfunction
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 17:15:50
                    RPM: 119 /min
                    Load: 100.0 %
                    Temperature: 21.0°C
                    Temperature: 27.0°C
                    Voltage: 12.192 V
   Coding: 150D10
12 Faults Found:
                    Reset counter: 99
                    Mileage: 219357 km
                    Date: 2017.08.20
                    Time: 11:43:35
                    Hex Value: 0x4400
                    Hex Value: 0x4006
                    Hex Value: 0x1237
                    Hex Value: 0x1CA8
                    Hex Value: 0x00FF
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2017.09.05
                    Time: 12:11:53
                    Hex Value: 0x00C0
                    Hex Value: 0x0806
                    Hex Value: 0x1203
                    Hex Value: 0x0373
                    Hex Value: 0x00FF
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.30
                    Time: 20:32:02
                    Hex Value: 0x0000
                    Hex Value: 0x0082
                    Hex Value: 0x0032
                    Hex Value: 0x0296
                    Hex Value: 0x00FF
                    Fault Frequency: 7
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:06:21
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x002B
                    Hex Value: 0xB99D
                    Hex Value: 0x00FF
                    Fault Frequency: 29
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:06:21
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x0027
                    Hex Value: 0x859D
                    Hex Value: 0x00FF
                    Fault Frequency: 31
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:06:23
                    Hex Value: 0x0000
                    Hex Value: 0x2282
                    Hex Value: 0x0038
                    Hex Value: 0x339C
                    Hex Value: 0x00FF
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.30
                    Time: 20:32:02
                    Hex Value: 0x0000
                    Hex Value: 0x0082
                    Hex Value: 0x0032
                    Hex Value: 0x0296
                    Hex Value: 0x00FF
                    Reset counter: 131
                    Hex Value: 0x0000
                    Hex Value: 0x2280
                    Hex Value: 0x0038
                    Hex Value: 0x66A4
                    Hex Value: 0x00FF
                    Reset counter: 131
                    Hex Value: 0x0000
                    Hex Value: 0x2280
                    Hex Value: 0x001C
                    Hex Value: 0x23A3
                    Hex Value: 0x00FF
                    Reset counter: 131
                    Hex Value: 0x0000
                    Hex Value: 0x2280
                    Hex Value: 0x001C
                    Hex Value: 0x2AA4
                    Hex Value: 0x00FF
                    Reset counter: 131
                    Hex Value: 0x0000
                    Hex Value: 0x2280
                    Hex Value: 0x0038
                    Hex Value: 0x1BA3
                    Hex Value: 0x00FF
                    Reset counter: 131
                    Hex Value: 0x0000
                    Hex Value: 0x2280
                    Hex Value: 0x0014
                    Hex Value: 0x13A3
                    Hex Value: 0x00FF
   Coding: 090100
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:06:21
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.05.01
                    Time: 23:19:45
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.05.05
                    Time: 19:34:14
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.05.05
                    Time: 22:20:11
   Coding: 64002000
8 Faults Found:
                    Reset counter: 91
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.30
                    Time: 20:31:59
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.30
                    Time: 20:31:59
                    Temperature: 15.0°C
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:06:19
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:06:19
            006 - Short to Plus
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.05.01
                    Time: 23:19:45
                    Voltage: 12.70 V
                    Voltage: 12.90 V
                    Voltage: 13.00 V
                    Voltage: 13.00 V
                    Bin. Bits: 00000000
                    Time: 0.00 s
                    Count: 1
                    Reset counter: 131
                    Reset counter: 131
   Coding: 00FD11
9 Faults Found:
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.30
                    Time: 20:31:00
                    Reset counter: 91
                    Mileage: 219028 km
                    Date: 2017.08.15
                    Time: 21:15:00
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2017.10.07
                    Time: 15:19:00
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:11:00
                    Reset counter: 87
                    Mileage: 220204 km
                    Date: 2017.09.01
                    Time: 20:39:00
                    Reset counter: 87
                    Mileage: 220204 km
                    Date: 2017.09.01
                    Time: 20:39:00
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.30
                    Time: 20:31:00
                    Reset counter: 91
                    Mileage: 219028 km
                    Date: 2017.08.15
                    Time: 21:15:00
                    Reset counter: 91
                    Mileage: 1048574 km
                    Mileage: 220314 km
                    Date: 2009.04.30
                    Time: 20:31:56
                    Mileage: 220314 km
                    Date: 2009.04.30
                    Time: 20:31:56
                    Mileage: 220314 km
                    Date: 2009.05.05
                    Time: 22:26:32
                    Reset counter: 131
                    Reset counter: 131
   Coding: 000014
                    Reset counter: 131
                    Reset counter: 40
                    Reset counter: 131
                    (no units): 44.0
                    RPM: 0
                    Fault Frequency: 82
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:06:13
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:06:21
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:13:51
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:13:51
   Coding: 00C303
6 Faults Found:
                    Fault Frequency: 37
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2017.09.29
                    Time: 16:20:18
                    Bin. Bits:    10011
                    Voltage: 11.60 V
                    Count: 6
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:00:00
                    Bin. Bits:    00000
                    Voltage: 13.00 V
                    Count: 7
                    Bin. Bits:    10000
                    Time: 0.40 s
                    Fault Frequency: 25
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:00:00
                    Bin. Bits:    00000
                    Voltage: 13.00 V
                    Count: 7
                    Bin. Bits:    10000
                    Time: 0.40 s
                    Fault Frequency: 61
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:00:00
                    Bin. Bits:    00000
                    Voltage: 13.00 V
                    Count: 7
                    Bin. Bits:    10000
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.05.02
                    Time: 00:08:26
                    Bin. Bits:    00000
                    Voltage: 13.30 V
                    Count: 7
                    Bin. Bits:    10000
                    Time: 0.90 s
01304 - Radio
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.05.05
                    Time: 22:12:08
                    Bin. Bits:    10000
                    Voltage: 13.10 V
                    Count: 12
                    Bin. Bits:    10000
                    Reset counter: 131
                    Reset counter: 131
                    Reset counter: 131
                    Reset counter: 131
                    Reset counter: 131
10 Faults Found:
                    Reset counter: 22
                    Mileage: 218339 km
                    Date: 2017.08.07
                    Time: 12:37:14
                    Reset counter: 23
                    Mileage: 218369 km
                    Date: 2017.08.07
                    Time: 13:04:11
03305 - Wire for Engine Start Request
                    Fault Status: 00100110
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:00:00
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:06:21
                    Fault Frequency: 147
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:06:39
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.05.02
                    Time: 00:08:30
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.05.05
                    Time: 22:27:22
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:14:14
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:14:14
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:14:14
   Revision: S2200000
   Coding: 0203010101
                    Reset counter: 131
                    Reset counter: 131
                    Reset counter: 131
                    Reset counter: 131
                    Reset counter: 131
7 Faults Found:
                    Reset counter: 131
                    Voltage: 13.10 V
                    Count: 68
                    Hex Value: 0x0273
                    Hex Value: 0x0001
                    Hex Value: 0x1010
                    Reset counter: 131
                    Voltage: 13.10 V
                    Count: 67
                    Hex Value: 0x0273
                    Hex Value: 0x0001
                    Hex Value: 0x1010
                    Fault Frequency: 23
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.05.01
                    Time: 23:50:33
                    Voltage: 14.20 V
                    Count: 38
                    Hex Value: 0x0173
                    Hex Value: 0x0008
                    Hex Value: 0x1010
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.05.01
                    Time: 23:19:46
                    Voltage: 13.00 V
                    Count: 51
                    Hex Value: 0x02F3
                    Hex Value: 0x0001
                    Hex Value: 0x1010
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:06:21
                    Voltage: 12.60 V
                    Count: 66
                    Hex Value: 0x0270
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:06:21
                    Voltage: 12.60 V
                    Count: 64
                    Hex Value: 0x0270
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.30
                    Time: 20:32:02
                    Voltage: 12.00 V
                    Count: 80
                    Hex Value: 0x0260
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   Component: Display
                    Reset counter: 22
                    Mileage: 218339 km
                    Date: 2017.08.07
                    Time: 11:58:26
                    Reset counter: 22
                    Mileage: 218339 km
                    Date: 2017.08.07
                    Time: 11:58:35
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:06:24
                    Reset counter: 40
End----------(Elapsed Time: 01:28, VBatt start/end: 13.2V/12.8V)-----------
You've got an awful lot of DTCs that are flagged "Intermittent". I would go through each and every control module and clear faults in 'em, one at a time. Then cycle ignition and scan again to see what comes back.
No, you're not going to be able to do the immobilizer adaptation with VCDS. The path of least resistance on that might be to send the ECU out for to have the Immo disabled in it. That won't fix the error message in the dash, but it will at least allow the engine to run.
Zingrox
C?ID=336968
I completely forgot about clearing the faults. Ill make sure to get on that, thank you! As for the immobilizer, it is apparently rather hard to deal with. Several people and businesses just don't deal with it because of that. I found a guy who has his own tuning business who says he can do it, hopefully. The last guy said he could do it, I sent him the eeprom files, and he responded that he wont now because it is the 9.1.1 and he hasnt before :facepalm:
Zingrox
C?ID=336968
Woo momma she narrowed down a tad. As for the immobilizer, I dont expect you guys to worry about that, I'll find that on my own time. Ive moved coding files on it twice now to see if they work, the people I discussed it with seemed to have complete confidence in them. One was even password protected and demanded not to be shared, which I will comply with. Regardless, we'll see. The SAFE message apparently relates to the key fobs adaption, rather than the immobilizer, but I'm still new to this chassis and cant be too sure I guess. I was originally talking about the key fob rather than the immobilizer
Also, I would not doubt having a sensor or positive/ground wire in the wrong place. While I don't actively see things in the wrong place, you never know. I have a second harness I use to reference and debate what should be what if I'm not entirely sure, in addition to the old engine and harness.
Friday,01,June,2018,18:17:32:09178
Mileage: 220310km-136894mi   Repair Order: 04 w/ trans
Chassis Type: 8T0
   Revision: 76H10---
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 18:57:08
                    Temperature: 22.0°C
                    Temperature: 27.0°C
                    Voltage: 13.335 V
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 18:57:08
                    Temperature: 22.0°C
                    Temperature: 27.0°C
                    Voltage: 13.335 V
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 18:57:08
                    Temperature: 22.0°C
                    Temperature: 27.0°C
                    Voltage: 13.335 V
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 18:57:08
                    Temperature: 22.0°C
                    Temperature: 27.0°C
                    Voltage: 13.335 V
   Coding: 150D10
   Coding: 090100
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 19:08:37
   Coding: 64002000
            006 - Short to Plus
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 19:08:37
                    Voltage: 12.70 V
                    Voltage: 12.70 V
                    Voltage: 11.70 V
                    Voltage: 12.70 V
                    Bin. Bits: 00000000
                    Time: 240.00 s
                    Count: 1691
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 19:08:37
                    Temperature: 1.0°C
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 19:08:37
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 19:08:38
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 19:08:38
   Coding: 00FD11
8 Faults Found:
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 19:08:00
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 19:08:00
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 19:08:00
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 19:08:00
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 19:08:00
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 19:08:00
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 19:08:00
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 19:08:00
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 19:08:39
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 19:08:40
   Coding: 000014
                    Fault Frequency: 85
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:06:13
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:06:21
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:13:51
                    Reset counter: 131
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 00:13:51
   Coding: 00C303
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 19:08:37
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 19:08:42
   Revision: S2200000
   Coding: 0203010101
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 19:08:37
                    Voltage: 12.80 V
                    Count: 80
                    Hex Value: 0x0273
                    Hex Value: 0x0001
                    Hex Value: 0x1010
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 19:08:38
                    Voltage: 12.90 V
                    Count: 51
                    Hex Value: 0x0273
                    Hex Value: 0x0001
                    Hex Value: 0x1010
   Component: Display
                    Reset counter: 91
                    Mileage: 220314 km
                    Date: 2009.04.28
                    Time: 19:08:47
End----------(Elapsed Time: 01:20, VBatt start/end: 12.8V/12.8V)-----------
Zingrox
C?ID=336968
New information has surfaced. The car, upon seeing an error with a transmission or difference in hardware, will throw an unclearable error and refuse to communicate with the unit. Because I did not adapt my ecu to the modules of the car via the long coding before I put it together, it will now forever refuse to communicate until it is virginized/entirely wiped. Now for anyone else doing so, this is still possible if you decode ALL your modules and match the cars before putting it together. This is awfully verbose to do, so the best way would be to clear the ecu so it will think its new and adapt to the car as is. Doing so is not possible for us, and requires dealer intervention if they are able to be swoon to do so. The information for the ecu and immobilizer must be imported from Germany, from Audi themselves, over a secure connection and ethernet only. This is a problem for us, because getting that to happen is very unlikely. This information was from someone who has done manual conversions more than once, he very much knows whats going on here. Your best bet is to make good friends with a dealer or someone working there.
Thats what I can tell you guys so far. As I progress with this I will continue to update
Zingrox
C?ID=336968
So I took the car to a shop that said they where capable of recoding the ECU to virginize it or at least remove the immobilizer past the key so the car would start. It has been about a year now, and they got nowhere big. The ECU was recoded, did not work, immo off also did not work. I'm suspicious of bcm 2 currently, amongst other wiring messes. I'm currently using the a4's when the s5's could very well have a different pinout, as it controls parts of the start authentication. I thought it'd be ok since the key and modules used where native to the original car. They have given up, I'm taking the car back, I'll investigate myself.
