Wednesday,02,May,2018,12:06:22:43192
VCDS Version: 18.2.0.3 HEX-V2 CB: 0.4411.4
VIN: WAUFNAF44HN043277 License Plate:
Mileage: 31600km-19635mi Repair Order:
Chassis Type: F4-AU49 (8W8)
Scan: 01 02 03 08 09 13 15 16 17 19 29 36 39 3C 42 44 46 47 52 5F
6C 74 81 82 8B A5 BB BC CA CF D6 D7
VIN: WAUFNAF44HN043277 Mileage: 31600km-19635miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CYMC) Labels: None
Part No SW: 8W0 906 259 C HW: 06L 907 425
Component: 2.0l R4 TFSI H13 0005
Revision: --H13---
Coding: 0A2500322366010E34280000000000000000000000000000
ASAM Dataset: EV_ECM20TFS0208W0906259C 001006
ROD: EV_ECM20TFS0208W0906259C.rod
VCID: 41DC4D4D8103418F3D6-8014
Readiness: 1010 0101
Address 02: Auto Trans (J217) Labels:* Redir Fail!
Part No SW: 8W1 927 155 B HW: 0CJ 927 156
Component: 0CL 20TFSINAR H03 0003
Revision: --H03--- Serial number: 0000000712
Coding: 000001
ASAM Dataset: EV_TCMDL382021 002023
ROD: EV_TCMDL382021_AU48.rod
VCID: 3FD84BB5F7F7377F4B2-806A
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 K
Component: V553 MTFP 002 0572
Serial number: 75117071160267001102
Address 03: ABS Brakes (J104) Labels:. 8W0-907-379-PRE-V1.clb
Part No SW: 8W0 907 379 H HW: 8W0 907 379 D
Component: ESP9 Premium H09 0719
Coding: 18AA409928A60A9911A04898008452A2E625DA180214508812004A4567A45B
ASAM Dataset: EV_ESP9BOSCHCMP 001001
ROD: EV_ESP9BOSCHCMP_001.rod
VCID: 4ACE6A61BC3582D7ECC-801E
419584 - TPMS Warning; Rear Left Tire
C1059 00 [047] - Flat
Mileage: 31600 km
Date: 2018.05.01
Time: 19:51:31
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 8W0 820 043 H HW: 8W0 820 043 H
Component: Klima Zone 3 H32 0071
Coding: 140805085548010D10020100880000000000000000000000000000000000
ROD: EV_AirCondiBHTCAU491.rod
VCID: 382A20A9D2D900478A8-806C
Subsystem 1 - Part No SW: 4M1 820 021 HW: 4M1 820 021
Component: J216 FLuftV H05 0001
Serial number: 00000000000001074820
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H01 0005
Serial number: BF38015800PAG0MUFU02
Subsystem 3 - Part No SW: 8W0 919 158 A HW: 8W0 919 158 A
Component: Klima Heck H40 0073
524289 - Rear Left Seat Heater
B1117 01 [009] - Electrical Failure
Reset counter: 143
Mileage: 31600 km
Date: 2018.05.01
Time: 19:54:04
Voltage terminal 30: 14.33 V
Outside air temperature: 16.50 °C
524288 - Rear Right Seat Heater
B1118 01 [009] - Electrical Failure
Reset counter: 143
Mileage: 31600 km
Date: 2018.05.01
Time: 19:54:04
459031 - Databus
Reset counter: 143
Mileage: 31600 km
Date: 2018.05.01
Time: 19:54:04
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W0 907 063 BG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0248
Coding: 07500363E07900CD0117511918AC98FB11033D080000000000000000600016010A6901AB02B50A
Shop #: WSC 09518 003 104857
ASAM Dataset: EV_BCM1BOSCHAU736 016006
ROD: EV_BCM1BOSCHAU736_016.rod
VCID: 015C8D4DC183818F7D6-8054
Subsystem 1 - Part No SW: 8W1 955 119 HW: 8V1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS491 160815 043 0813
Serial number: 89435300301622802781
Coding: 5BCFF7
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Serial number: 20068805X81A955555A0
Coding: 02005D
Light switch:
Subsystem 3 - Part No SW: 4M0 941 531 AB HW: 4M0 941 531 AB
Component: E1 - LDS H06 0008
Serial number: 13 06 2016 00414671
Subsystem 4 - Part No SW: 4M0 907 410 A HW: 4M0 907 410 A
Component: USHL5 H04 0050
Serial number: 0000009600335Z1YIM02
Coding: 350000
Subsystem 5 - Part No SW: 4M0 959 719 A HW: 4M0 959 719 A
Component: GTO BF H01 0010
Serial number: 20160906112214 00442
Subsystem 6 - Part No SW: 8W0 857 511 B HW: 8W0 857 511 B
Component: Y7_Innenspieg H01 0002
Serial number: GX1CE114071612011312
Interior Light Module:
Subsystem 7 - Part No SW: 8W0 947 135 CJ HW: 8W0 947 135
Component: J528-Dachele H14 0130
Serial number: B10263133
Subsystem 8 - Part No SW: 8W0 925 301 BF HW: 8W0 925 301 BF
Component: SL-B9/Q5NF H15 0010
Serial number: 2615000097118002
Subsystem 9 - Part No SW: 4M0 963 575 HW: 4M0 963 575
Component: V512 LLR1SLvL H03 0012
Serial number: L14DG20201706
Subsystem 10 - Part No SW: 4M0 963 575 HW: 4M0 963 575
Component: V514 LLR1SKvL H03 0012
Serial number: L14DG18200286
Subsystem 11 - Part No SW: 4M0 963 575 HW: 4M0 963 575
Component: V516 LLR1SLvR H03 0012
Serial number: L14DG20201711
Subsystem 12 - Part No SW: 4M0 963 575 HW: 4M0 963 575
Component: V518 LLR1SKvR H03 0012
Serial number: L14DG18200280
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 8W0 907 561 B HW: 8W0 907 561
Component: LRR4 H10 0220
Coding: B4779FF35CFFEF09949880A1
ASAM Dataset: EV_ACCBOSCHAU49X 002018
ROD: EV_ACCBOSCHAU49X_002.rod
VCID: 3D2431BDFDFB256F59E-8068
Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
Part No SW: 8W0 959 655 A HW: 8W0 959 655 A
Component: Airbag10.44 H74 0086
Serial number: 003N800172BC
Coding: BFCCF0C000800000A0000033C24C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 005012
ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
VCID: 47C85355AF277FBFF32-8012
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 B HW: 4M0 980 945 B
Component: BeltPretRevFL 306 2033
Serial number: 8W0857705C0264Q00275
Coding: 80000D
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 B HW: 4M0 980 946 B
Component: BeltPretRevFR 306 2033
Serial number: 8W0857706D0265Q01807
Coding: 80000D
Occupant Detection:
Subsystem 3 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H11 0022
Serial number: IBH0000J160005V58P0H
Subsystem 4 - Part No SW: ----------- HW: 442 061 509 16
Serial number: 3577Y009D1FB75D0942G
Subsystem 5 - Part No SW: ----------- HW: 442 061 609 16
Serial number: 3587Y00A31FFD131E06A
Subsystem 6 - Part No SW: ----------- HW: 442 0B2 006 16
Component: SideSensor_Dr 1C7 0148
Serial number: 3517700BF211FA13937F
Subsystem 7 - Part No SW: ----------- HW: 442 0B2 006 16
Serial number: 3527700C320DD1F1926F
Subsystem 8 - Part No SW: ----------- HW: 442 0C1 208 16
Component: FrontSensor_D 1C5 014A
Serial number: 3557500A32135013E1B-
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 442 0C1 208 16
Component: FrontSensor_P 1C5 014A
Serial number: 3567500A32135010B31N
Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
Part No SW: 4M0 907 129 GQ HW: 4M0 907 129 GQ
Component: Lenks.Modul H11 0009
ROD: EV_SMLSKLOAU736_006.rod
VCID: 0554995DD5ABADAF41E-8050
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 8W5 920 890 C HW: 8W5 920 890 C
Component: FBenUSA H15 0307
Coding: 08CF51C17498CF0512AB6D605800500008000000
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_DashBoardAU736 001022
VCID: 43D047459B1F539F2FA-8016
16777097 - ROD - Unknown Error Code
- 00 [009]
[Allrad_06 communication error can_error_timeout]
Reset counter: 143
Mileage: 31600 km
Date: 2018.05.01
Time: 20:02:28
Part No SW: 8W8 907 468 C HW: 8W8 907 468 C
Component: Gateway H27 1298
Revision: 4Q080005 Serial number: 0584Q008116A05
Coding: 0301000100000E402907000000590012DC900007100000000175078E00000000
ASAM Dataset: EV_CGateCONTIAU491 002060
ROD: EV_CGateCONTIAU491_002_AU49.rod
VCID: 4CC26C79B6419CE7DE0-8018
Subsystem 1 - Part No SW: 8W0 951 523 H HW: 8W0 951 523 H
Component: J453 MFL H04 0002
Serial number: 20160825001452 00034
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 0379521504
Address 29: Left Light (J1018) Labels: 4M0-907-397.clb
Part No SW: 4M0 907 397 AC HW: 4M0 907 397 C
Component: LCM_MLBevoH05 0024
VCID: 78AAE0A99259C0474A8-802C
Address 36: Seat Mem. Drvr (J136) Labels:* None
Part No SW: 4M1 959 760 HW: 4M1 959 760
Component: MEM-FS 008 0031
Serial number: 00000217882265
Coding: 005C1B400000B0010000010101010000000000000000000000000000000000
ROD: EV_SCMDriveSideCONTIAU736.rod
VCID: 76B6EE91984DB637584-8022
Address 39: Right Light (J1023) Labels: 4M0-907-397.clb
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4M0 907 566 B HW: 4M0 907 566
Component: MRR1Rear H13 0230
Revision: --------
Coding: 0EC002
ASAM Dataset: EV_RearRadarS1BoschAU736 001015
ROD: EV_RearRadarS1BoschAU736.rod
VCID: 34321499CEB1E427A60-8060
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 4M0 959 793 E HW: 4M0 959 793 C
Component: TSG FS 009 0058
Serial number: 0000219242521
Coding: 005D1B205E001080000100B2
ROD: EV_DCU2DriveSideMAXHCONT.rod
VCID: 40DA48498A094887328-8014
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 8W0 909 144 F HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0407
Coding: 0D888380008080
ASAM Dataset: EV_EPSZFAU49X 002015
ROD: EV_EPSZFAU49X_002.rod
Address 46: Central Conv. (J393) Labels:* None
Part No SW: 8W0 907 064 BC HW: 8W0 907 064 C
Component: BCM2 MLBevo 018 0328
Coding: 013400004F900080657FA0002E0000423300400001BD27502F0400000104803F001E0001000000
ASAM Dataset: EV_BCM2HellaAU736 011012
ROD: EV_BCM2HellaAU736_011_AU49.rod
VCID: 7EA6F6B1B07DFE77004-802A
Ignition key:
Subsystem 1 - Part No SW: 36A 959 754 A HW: 36A 959 754 A
Component: ID-Geber H40 0105
Serial number: 3616000213266011
Subsystem 2 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY162220EHG
Subsystem 3 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0313
Serial number: 00000000000067249776
Subsystem 4 - Part No SW: 3AA 962 243 G HW: 3AA 962 243 G
Component: GEB.F.Heckoef H16 0903
Serial number: 84461287
Address 47: Sound System (J525) Labels:* None
Part No SW: 8W0 035 465 HW: 8W0 035 465
Component: MIB2_amp_P_B9 H11 0420
Revision: 00000001 Serial number: AUZ8ZAGJA00MHTQ
Coding: 0194010800AFAAAFAA0000010000
ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
ROD: EV_AMPMst16C2Gen2ALPI.rod
Part No SW: 4M0 959 792 E HW: 4M0 959 792 C
Component: TSG BFS 009 0058
Serial number: 0000218326658
Coding: 005D1B205E001080000100B0
ROD: EV_DCU2PasseSideMAXHCONT.rod
Address 5F: Information Electr. (J794) Labels:* 8W0-035-MIB-HGH2.clb
Part No SW: 8W0 035 880 A HW: 8W0 035 880
Component: MU-P-LNS-US 052 0692
Serial number: A400J0G7519570
Coding: 019401020000000053220002041A00102F0002E501700904BE
ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
Subsystem 1 - Part No SW: V03 959 801 PS HW: -----------
Component: NAR 2018 --- 0063
Subsystem 2 - Part No SW: 8W1 919 605 HW: 8W1 919 605
Component: DU High AU49x H31 0160
Serial number: TPO00105081600820293
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8W0 919 614 T HW: 8W0 919 614 T
Component: ControlUnit_H H30 0206
Serial number: APVAK119091600020230
Component: Gracenote2--- --- 3009
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4M0 907 428 E HW: 4M0 907 428
Component: Areaview 2 H13 0315
Serial number: C854607JG004070
Coding: 02940102BA0FA10008404000
ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
Address 74: Chassis Control (J775) Labels:* None
Part No SW: 8W0 907 777 E HW: 8W0 907 777 C
Component: Fahrwerk-SG H34 1213
Serial number: 1609160614
Coding: 1050484158
ASAM Dataset: EV_ChassContrContiAU426 001003
ROD: EV_ChassContrContiAU426.rod
VCID: 49CC556DB93389CFE56-801C
Address 81: Gear Shift (J587) Labels: None
Part No SW: 8W1 713 041 J HW: 8W1 713 041 J
Component: GSM-LL H09 0073
Revision: 0L0D5012 Serial number: 20160916003610
ROD: EV_GSMWaehlZFAU736_AU49.rod
VCID: 3A2E3AA1ECD512577CC-806E
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 8W5 919 617 B HW: 8W5 919 617 B
Component: HeadUpDisplay H16 1603
Coding: 4F01E0
ASAM Dataset: EV_HudNSEIKAU736 001015
ROD: EV_HudNSEIKAU736_AU49.rod
Address 8B: Adaptive Cruise 2 (J850) Labels: None
Part No SW: 8W0 907 541 B HW: 8W0 907 541
ASAM Dataset: EV_ACC2BOSCHAU49X 002018
ROD: EV_ACC2BOSCHAU736_002_AU73.rod
VCID: 3B203FA5E3EF2B5F67A-806E
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 8W0 907 217 B HW: 8W0 907 217
Component: BVS H15 0042
Coding: 0404090100010202022023E6AD0000FCB0F0C020E220
ROD: EV_BVSMLBevKOSTAAU736.rod
Part No SW: 4M0 959 795 G HW: 4M0 959 795 C
Component: TSG HFS 009 0052
Serial number: 0000219282991
Coding: 000D1B2000001080400000A0
ROD: EV_DCU2RearDriveMAXHCONT.rod
VCID: 44D244599E1154A7160-8010
Component: TSG HBFS 009 0052
Serial number: 0000218687430
ROD: EV_DCU2RearPasseMAXHCONT.rod
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4M0 907 594 A HW: 4M0 907 594
Component: SAD_STG_1 011 0003
Coding: 208000049100
ASAM Dataset: EV_SunRoofCONTIAU736 004008
ROD: EV_SunRoofCONTIAU736_004.rod
Address CF: Lane Chge Asst 2 (J770) Labels: None
Part No SW: 4M0 907 590 B HW: 4M0 907 590
Revision: --------
Coding: 0EC002
ASAM Dataset: EV_RearRadarS2BoschAU736 001015
ROD: EV_RearRadarS2BoschAU736.rod
VCID: 313C1D8D31A3D10FCD6-8064
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED1L H09 0003
VCID: 1676CE11B80D1637B84-8042
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H09 0003
End----------(Elapsed Time: 02:22, VBatt start/end: 13.2V/13.2V)-----------
