2002 A4 B6Speedometer
Larhal
South Yorkshire, UK
C?ID=295910
I have searched the forum and could not find any distance impulse corrections for a 2002 A4 B6. When in 17, instruments it doesn't give the option, or maybe I not doing something correct. Can anybody help me here?
If it's the cluster I think it is, there are only three choices:
C01,??xxx: Options
C02,+00 = 1st Distance Impulse Number (Standard - Europe/USA/Rest of World)
C03,+01 = All-Wheel-Drive/Quattro (smaller Fuel Tank Volume)
C04,+02 = Seatbelt Warning (North American Region OLD - < CW 44/2004)
C05,+04 = 3rd Distance Impulse Number (Rental Cars)
C06,+08 = 2nd Distance Impulse Number (Australia)
PetrolDave
Westbury, UK
C?ID=1423
What are you hoping to achieve by changing the distance impulse correction value?
Larhal
South Yorkshire, UK
C?ID=295910
C01,??xxx: Options
Thanks Uwe,
That is what I found, My speedo is off by 5 mph, it states 75 and actual is 70, and I was looking to correct this. So as I see it there is no correction to be had, correct?
Larhal
Saturday,28,April,2018,13:58:52:49418
VIN: WAUZZZ8E32A200477   License Plate:
Mileage: 207040km-128648mi   Repair Order:
          67 69 75 76 77
VIN: WAUZZZ8E32A200477   Mileage: 207040km-128648miles
Address 01: Engine        Labels: 06B-906-018-AVJ.lbl
   Part No SW: 8E0 909 518 M    HW: 8E0 909 018
   Component: 1.8L R4/5VT         0001
   Coding: 0011501
   Shop #: WSC 00000 000 08192
   VCID: 3A2DCF2C604389777CC-5160
Readiness: 0110 1101
   Part No: 8E0 614 517
   Component: ABS/ESP front       1726
   Coding: 04275
   Shop #: WSC 06435
   VCID: 65974C50BC7DD68FE1E-51F2
   Part No: 8E0 820 043
   Component:   A4 Klimaautomat   0712
   Coding: 00000
   Shop #: WSC 63351
   VCID: 5EE563BC992B8557204-5160
   Part No: 8E0 907 279 C
   Component: int. Lastmodul  RDW 0203
   Coding: 00001
   Shop #: WSC 63351
   VCID: 323DE70CBD337137B4C-4B00
Address 15: Airbags        Labels: 8E0-959-655-84.lbl
   Part No: 8E0 959 655
   Component: Airbag 8.4E         4001
   Coding: 0010602
   Shop #: WSC 63351 000 00000
   VCID: 74B1211402A73F07660-5160
   Part No: 8E0 953 549 F
   Component: Lenksáulenmodul     0308
   Coding: 00001
   Shop #: WSC 63351
   VCID: 3635DB1C515B6D17984-4B00
   Part No: 8E0 920 950 G
   Component: KOMBI+WEGFAHRS. RB4 D26
   Coding: 00400
   Shop #: WSC 00260
   VCID: 2D07F470A40D2ECFE9E-5160
   WAUZZZ8E32A200477     AUZ6Z0A0309521
Address 46: Central Conv.        Labels:. 8E0-959-433-MIN.clb
   Part No: 8E0 959 433 AD
   Component: Komfortgerát T85    0315
   Coding: 06848
   Shop #: WSC 63351
   VCID: 73B3220802A9383F7FA-4B00
   Subsystem 1 - Part No: 8E2959802B
   Component: Tõrsteuer.FS BRM 0002
   Subsystem 2 - Part No: 8E2959801B
   Component: Tõrsteuer.BF BRM 0002
01561 - Rear left door
            61-00 - Won't De-Safe
01562 - Rear right door
01559 - Drivers Door
            59-00 - Can't Unlock
   Part No: 8E0 035 186
   Component: concert II  GRO    0007
   Coding: 00001
   Shop #: WSC 63351
   VCID: 64915154B777AF87F60-4B1E
00852 - Loudspeaker(s); Front
End----------(Elapsed Time: 05:34, VBatt start/end: 12.2V/12.2V)-----------
PetrolDave
Westbury, UK
C?ID=1423
5mph in 70mph is just over 7% - as all speedos are required to never under-read but must not over-read by more than 10% this is within the expected "normal" range.
Larhal
South Yorkshire, UK
C?ID=295910
I understand that is correct, I just find it annoying as my wife is always watching the speedo and telling me to slow down. Just thought I could adjust the impulse number to correct. Was worth a try. Thanks all for your assistance, much appreciated.
Well, you could try coding it your cluster to 04400 or 08400 to see what effect that has and report back, because I really don't know why taxis or cars sold in 'straya would be different.
PS: FWIW, we had a 2002 A4 for a while and the speedo on that car was dead on (within 1 mph). It was a 3.0L petrol V6 with MT6 transmission and 17" sport wheels. What size are your tires?
Larhal
South Yorkshire, UK
C?ID=295910
My Audi is a 1.8T with a 5 speed, running 17 also with 235 45 17 tires. The door placard for tire pressure has these listed.
I will have to try the different settings next weekend and report back the results.
Larhal
PetrolDave
Westbury, UK
C?ID=1423
I've owned 3 B6s (2 x 4.2 V8 S4 + 1 x 1.9TDi 130 Sport) and 1 B7 (4.2 V8 RS4) and they all over-read (according to my GPS) by between 5% and 7% - all were MT6 and fitted with OE wheels & tyres.
Larhal
South Yorkshire, UK
C?ID=295910
He Uwe,
I was able to try the 04400 and the 08400. Funny thing the instrument cluster would not take the codes. Maybe it is because I do not have the pin for the IMMO.
Larhal
South Yorkshire, UK
C?ID=295910
I had 205 55 16 on the car before and the speedo was off over 11 MPH. When I changed to the 235 45 17 it dropped to the 5 mph over. As the tire rolling circumference is different it helped but not totally resolved. Guess I will have to live with it, or should I say my wife complaining I am going too fast.
I do not think the Immo PIN would have any influence whether it will accept a coding.
Get an app for your phone that shows the true speed via GPS and mount it on the dash where she can see it? :D
Larhal
South Yorkshire, UK
C?ID=295910
Oh OK, So this would be like the fake break peddle and steering wheel I have on her side of the car, It would add a instrument cluster so she thinks she is in control. LOL
NZDubNurd
New Zealand
C?ID=230482
Make sure it's an app that you can program to "correct" the speed... you could make it read 20% low, and she might start telling you to go faster!
Larhal
South Yorkshire, UK
C?ID=295910
Where can I find that app, it would save my ears and keep both of us happy. Good suggestion but probably not feasible. Or maybe I could put a set of blinders on her so she cannot see the speedometer?
Larhal
South Yorkshire, UK
C?ID=295910
Solved.
I was refreshing my instrument cluster LED Lights and dials. I found that the previous oner had removed the check engin LED. When I put the cluster back togeather again and did a needle sweep the speedometer dial was not in the correct position. I adjusted the speedometer needle to be the correct position (60 MPH on the sweep) and low and behold the speedometer is now bang on. I did not realize that the instrument cluster had been removed before.
Lesson learned. Needle sweep was the game changer.:)
