Here is what VCDS-Mobile says:
And VCDS "regular":
Trying to run VCDS-Mobile was a vortex of ASAM related alerts and updates that never worked until I switched it to the beta update channel. Electric Drive (51) and Hybrid Battery (8C) don't show up in the VCDS-Mobile autoscan, but come up if I type in the address. The measuring fields available in 8C don't match VCDS, and looking at, logging, or putting them in a HUD configuration generally either yields non-sensical values, or the HEX-NET grinding to a halt and rebooting. Since doing some logging of battery data sans-laptop is primary goal, I'm keen to help in any way I can in getting config data lined up.
Here is the 8C adpmap from VCDS:
And the blockmap
#hndoc:?docid=00003DAF&xt=hnh:A8FCFA36DE7DE71993C8A5248F1E91EB503D7DFFF957F82052BB22D9A413BA3F
VCDS Mobile 0.4422.0.4
Scan: 01 03 05 08 09 10 13 15 16 17 19 23 29 2B 39 3C 42 44 4B 52
5F 75 A5 BD C0 C5 C6 D6 D7
29-Left Light -- Status: Malfunction 0010
39-Right Light -- Status: Malfunction 0010
4B-Multifunc. Module -- Status: Malfunction 0010
BD-Hi Volt. Batt. Charge -- Status: OK 0000
C0-Act. For Ext. Noise -- Status: OK 0000
C5-Therm. mgt. -- Status: OK 0000
C6-Batt. Chrg. -- Status: Malfunction 0010
Address 01: Engine (EAZA J623) Labels: 0E-01.lbl
Part No SW: 0EA 906 016 F HW: 0EA 907 309 A
Component: E-Vehicle H24 4238
Revision: WMH24---
Coding: 000D0016006400003000
ASAM Dataset: EV_VCU00XXX0110EA906016F 004005
ROD: EV_VCU00XXX0110EA906016F_004.rod
VCID: 322789CBCF49E95EC5F7384FB-8067
17156 - Databus
Address 03: ABS Brakes (J104) Labels: 5Q-03.clb
Part No SW: 5Q0 614 517 BL HW: 5Q0 614 517 AH
Component: ESC H62 0855
Revision: 00000000
Coding: 01FA40A12C252170857A020581C62980023484A14081943238915058C2E203
ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019
ROD: EV_Brake1UDSContiMK100OMG_003_VW37.rod
VCID: 7CBB67F35D8DEF2E5FDB46C79-8029
No fault codes found.
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Part No SW: 5Q0 959 435 C HW: 5Q0 959 435
Component: VWKESSYMQB 021 0803
Revision: 00021000
Coding: 032C0C
ASAM Dataset: EV_KessyHellaMQBAB 002020
ROD: EV_KessyHellaMQBAB.rod
VCID: 3C3BA7F31D0D2F2E1F5B86C79-8069
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5GE 907 044 AN HW: 5GE 907 044 AN
Component: Climatronic H04 1702
Revision: 00001K01
Coding: 0002220020011001050500021211102B
VCID: 88538B239955338ECB53CA77D-80DD
Subsystem 1 -
Subsystem 2 -
Address 09: Cent. Elect. (J519) Labels: 5Q-09.clb
Part No SW: 5Q0 937 085 BN HW: 5Q0 937 085 BF
Component: BCM MQBAB MNA H36 0253
ROD: EV_BCMMQB_018.rod
VCID: 864F851B934125FEB93FD45F7-80D3
Subsystem 1 - Part No SW: 5G1-955-119-A Labels: 5Qx-955-119-V1.clb
Component: MÝ
Subsystem 2 -
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-298.clb
Part No SW: 5QA 919 298 E HW: 5QA 919 298 A
Component: PLA 3.0 12K
Coding: 2271167811
ASAM Dataset: EV_EPHVA2CAU3700000 009038
ROD: EV_EPHVA2CAU3700000_009_VW37.rod
VCID: 52E7E94BAF89C95EE53798CFB-8007
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
Part No SW: 5Q0 907 572 H HW: 5Q0 907 572 H
Component: ACC BOSCH MQB H10 0620
Coding: 7D0000C159FFC728949C810580401600000000000000000000
ASAM Dataset: EV_ACCBOSCHVW416 002005
ROD: EV_ACCBOSCHVW416.rod
1236 - Databus
1127 - Databus
1218 - Databus
1219 - Databus
Component: AirbagVW20 010 0830
Coding: 8CCCFC00002000005000001AC20800000065
VCID: 47D1C81F54CB7CF682C901438-8012
Subsystem 1 - Part No SW: 4M0-959-339-B
Component: 019
Subsystem 2 - Component: ---
Subsystem 3 - Component: ---
Subsystem 4 - Component: ---
Subsystem 5 - Component: ---
Subsystem 6 - Component: ---
Address 16: Steering wheel (J527) Labels: 5Q-16.lbl
Part No SW: 5Q0 953 507 HN HW: 5Q0 953 549 E
Revision: --------
Coding: 0C10
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 89558E27825F4A86D45DF77BE-80DC
Part No SW: 5G1 920 895 A HW: 5G1 920 895 A
Component: KOMBI 407 3194
Coding: 0BB4701A6F88CF050288690B5701032080000000
VCID: 2F2180BFDC7BC4B6AAD919230-807A
Address 19: CAN Gateway (J533) Labels: 3Q-19.clb
Part No SW: 3Q0 907 530 M HW: 3Q0 907 530 D
Component: GW MQB EV 618 6322
Coding: 0201001704F81000FB001212081D00000001070100070000000300000000
ROD: EV_GatewNF_VW37.rod
VCID: 3935BEE7123F1A06043D67BBE-806C
Subsystem 1 - Part No SW: 5G0-959-442-R Labels: 3C8-959-537.clb
Component: 4ÿÿ
Subsystem 2 -
Address 23: Brake Booster (J539) Labels: None
Part No SW: 5QE 909 059 G HW: 5QE 909 059 B
Component: EBKV H14 0211
Coding: 06720100321A00010002000500
ASAM Dataset: EV_BrakeBoostBoschMQBOMG 004003
ROD: EV_BrakeBoostBoschMQBOMG_004.rod
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 D HW: 8V0 907 399 D
Component: LCM_MLBevo
Shop #: WSC 00000 000
0033 - Supply voltage
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000
Coding: 7900000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 342B8FD3355DE76ED70B2E671-8061
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
ROD: EV_LCMRightHELLAAU736_VW37.rod
Address 3C: Lane Change (J1086) Labels: 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0080
Coding: 02011103
ROD: EV_HREntryHella.rod
VCID: 3D3DAAF7061726262865B3CBA-8068
Address 42: Door Elect, Driver (J386) Labels: 5Q-42.clb
Component: TSG FS 020 0041
Coding: 003E13208000040000000000
ROD: EV_DCUDriveSideEWMAXKLO.rod
VCID: 43C9DC0F60F350D65EA1F533C-8016
Part No SW: 5Q0 909 144 T HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 128 1072
Coding: D302
ROD: EV_SteerAssisMQB_013.rod
VCID: 45CDC2176EC76EE670B5EB2B2-8010
Address 4B: Multifunc. Module (J745) Labels: None
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Coding: 000000050100054A00310F01040000000000000000000000000000000000
VCID: F2A7C9CB8FC9295E8577784FB-80A7
13705489 - Databus
Address 52: Door Elect, Pass. (J387) Labels: 5Q-52.clb
Component: TSG BFS 020 0041
ROD: EV_DCUPasseSideEWMAXKLO.rod
VCID: 42C7D90B7FE959DE5597C80FB-8017
Address 5F: Information Electr. (J794) Labels: 3Q-5f.clb
Part No SW: 3Q0 035 876 B HW: 3Q0 035 876 B
Component: MU-S-NS-US 851 0842
Coding: 02738002FF00000051220001001808009F0505F401200405C6
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 33298CCF3053E056CE012573C-8066
Subsystem 1 - Part No SW: 5G6-919-605-D
Component: ABT_Std-2_Nav
Subsystem 2 -
Address 75: Telematics (J949) Labels: 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 009 0570
Coding: 02737002C2829A017FFE06000000
ROD: EV_OCULowMQB.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels: 3Q-a5.clb
Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
Component: MQB_B_MFK H07 0272
Coding: 000307000000020100221354C150490084000E200120
ROD: EV_MFKBoschMQBB_VW37.rod
1122664 - Databus
Address BD: Hi Volt. Batt. Charge (J966) Labels: 5QE-915-022.clb
Part No SW: 5QE 915 022 AJ HW: 12E 915 022 H
Component: LMSG H20 1097
Coding: 4A4914040400
ASAM Dataset: EV_HVChargManagVWMQB 003004
ROD: EV_HVChargManagVWMQB.rod
Address C0: Act. For Ext. Noise (----) Labels: 5QE-035-335.clb
Part No SW: 5QE 035 335 M HW: 5QE 035 335 B
Component: E_SOUND_SG H10 0223
Coding: 04
ASAM Dataset: EV_ENoiseS1NNVW3707 007015
ROD: EV_ENoiseS1NNVW3707_007.rod
VCID: 4BD9F42F48A39896A6F12D934-801E
Address C5: Therm. mgt. (J1024) Labels: None
Part No SW: 5GE 907 458 C HW: 5GE 907 458
Component: TME-Min H06 0203
Coding: 02
ASAM Dataset: EV_ThermContrVISAU49X 001021
ROD: EV_ThermContrVISAU49X_VW37.rod
Subsystem 1 -
Subsystem 2 -
Subsystem 3 -
Subsystem 4 -
Subsystem 5 -
Subsystem 6 -
Subsystem 7 -
Subsystem 8 -
Subsystem 9 -
Subsystem 10 -
Subsystem 11 -
Subsystem 12 -
37096 - Automatic addressing Sub Bus 1
B1484 21 [032] - Signal Amplitude Too Low
Address C6: Batt. Chrg. (J1050) Labels: 5QE-915-681.clb
Part No SW: 5QE 915 681 B HW: 5QE 915 681 B
Component: OBC Delta-ES H59 1560
ASAM Dataset: EV_OBCTwoPhaseDT2VW3707 003009
ROD: EV_OBCTwoPhaseDT2VW3707.rod
14746197 - Battery Charger; Charging Module 2
P31EA 00 [008] - Faulty
Address D6: Light Ctrl Left 2 (A31) Labels: None
Part No SW: 7P5 941 572 A HW: 7P5 941 572 A
Component: LED1L H06 0002
ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
ROD: EV_LEDMinMaxL_KEBODAVW481.rod
Address D7: Light Ctrl Right 2 (A27) Labels: None
Component: LED1R H06 0002
ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
ROD: EV_LEDMinMaxR_KEBODAVW481.rod
And VCDS "regular":
Friday,27,April,2018,19:11:40:41186
VCDS Version: 18.2.0.3 (x64) HEX-NET CB: 0.4422.4
VIN: <redacted> License Plate:
Mileage: 3867km-2402mi Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 23 29 2B 39 3C 42 44 4B 51
52 5F 75 8C A5 BD C0 C5 C6 D6 D7
VIN: <redacted> Mileage: 3867km-2402miles
BD-Hi Volt. Batt. Charg. -- Status: OK 0000
Address 01: Engine (J623-EAZA) Labels:. 0EA-907-309-V1.clb
Revision: WMH24---
VCID: B2286D6DE58F03D45E-80E6
17156 - Databus
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-OMG-V1.clb
Revision: 00000000 Serial number: 62867000001487
VCID: FCB48355774B05A4C4-80A8
Revision: 00021000 Serial number: 0459455521
Coding: 032C0C
VCID: BC34435537CBC5A484-80E8
Revision: 00001K01
VCID: 885CEF8533935904D0-80DC
Serial number: 01001730300128
ROD: EV_BCMCONTI.rod
VCID: 8640E1BD39874F74A2-80D2
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 170926 043 0551
Serial number: 171002145018
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 047 0105
Serial number: S8Y17M10D30H21M10S55
Coding: 00A8DD
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Component: PLA 3.0 12KH07 0452
Serial number: 000308417617199
Coding: 2271167811
VCID: D2E80DED854F23D47E-8086
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
1236 - Databus
[FAULT_TIMEOUT_BV1_POSITION]
Reset counter: 139
Mileage: 396 km
Date: 2018.02.07
Time: 15:19:26
Control Module temperature: 23 �C
Voltage terminal 15: 14.8 V
Velocity_vehicle_reference: 12.67 m/s
Longitudinal_acceleration_vehicle_reference: 0.11 m/s�
1127 - Databus
[FAULT_TIMEOUT_PSD_04]
Reset counter: 135
Mileage: 1194 km
Date: 2018.03.03
Time: 19:47:32
Control Module temperature: 31 �C
Voltage terminal 15: 14.7 V
Longitudinal_acceleration_vehicle_reference: 0.00 m/s�
1218 - Databus
[FAULT_TIMEOUT_PSD_05]
Reset counter: 135
Mileage: 1194 km
Date: 2018.03.03
Time: 19:47:33
Voltage terminal 15: 14.9 V
1219 - Databus
[FAULT_TIMEOUT_PSD_06]
Fault Frequency: 7
Reset counter: 151
Mileage: 1194 km
Date: 2018.03.03
Time: 19:47:33
Serial number: 003GCR08SKB$
VCID: C7DE2CB97E0D967C19-8092
Occupant Detection:
Component: BF-Gewichtss. H13 0022
Serial number: IBH000000000007WR1B
Coding: 303139
Subsystem 2 - Part No SW: ----------- HW: 480 003 010 17
Serial number: 35700000000A08D0492I
Subsystem 3 - Part No SW: ----------- HW: 480 003 010 17
Serial number: 35800000000A593CF62Z
Subsystem 4 - Part No SW: ----------- HW: 480 400 311 17
Serial number: 3510001B927CABF241EM
Subsystem 5 - Part No SW: ----------- HW: 480 403 010 17
Serial number: 3520001C527FACA382EP
Subsystem 6 - Part No SW: ----------- HW: 480 400 211 17
Component: FrontSensor_D 000 6149
Serial number: 3550001C927CABF4018J
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 400 211 17
Component: FrontSensor_P 000 6149
Serial number: 3560001AF27E043693EG
Revision: -------- Serial number: 31101704221574
Coding: 0C10
VCID: 895AEA812899200CCF-80DC
VCID: AF2E6419F6BD2E3C31-80FA
Serial number: 23101710800231
ROD: EV_GatewNF_VW27.rod
VCID: B93A5A4138F9F08C9F-80EC
Subsystem 1 - Part No SW: 5G0 959 442 R HW: 5G0 959 442 R Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0040
Serial number: 39170002461460087405
Coding: 34FFFF
Subsystem 2 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 5014795704
Address 23: Brake Booster (J539) Labels:* None
Serial number: 085460013747
Brake Assistance Sub:
Subsystem 1 - Part No SW: 5QE 909 057 D HW: 5QE 909 057 A
Component: VX70BrakeAssi H04 0155
Serial number: 05802861211017043437
Component: LCM_MLBevoH08 0014
[Supply voltage - lower limit exceeded]
Reset counter: 122
Mileage: 2195 km
Date: 2018.03.26
Time: 21:43:09
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Revision: 00000000 Serial number: 17000317743008
VCID: B4246B751F9B0DE44C-80E0
Fault Frequency: 9
Reset counter: 120
Mileage: 447 km
Date: 2018.02.08
Time: 18:37:24
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Serial number: 0458074663
Coding: 02011103
ROD: EV_HREntryHella_VW37.rod
VCID: BD324E512CD1CCACB3-80E8
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0080
Serial number: 0458079978
Coding: 020111
Serial number: 140917EIE1974A
VCID: C3C638A94A35BA5CC5-8096
Subsystem 1 - Part No SW: 5Q0 959 811 D HW: 5Q0 959 811 D
Component: FOND_FHSG_DRV 006 0007
Serial number: 00000000000017114673
Coding: 111000
Coding: D302
VCID: C5C226B14401846CEB-8090
Address 4B: Multifunc. Module (J745) Labels:* None
Serial number: 19101710521471
VCID: F2A8AD6D250F43D49E-80A6
13705489 - Databus
[PSD_04 data bus missing message]
Reset counter: 135
Mileage: 1194 km
Date: 2018.03.03
Time: 19:47:33
Address 51: Electric Drive (J841) Labels: None
Part No SW: 5QE 907 080 K HW: 5QE 907 080 K
Component: LE Gen 3.3H16 2052
Revision: 00H16000
Coding: 40020000000000000000
ASAM Dataset: EV_DMCM10030115QE907080K 001008
ROD: EV_DMCM10030115QE907080K.rod
VCID: CED0199D917747345A-809A
Serial number: 231017EJN04018
VCID: C2C83DAD552FB354CE-8096
Subsystem 1 - Part No SW: 5Q0 959 812 D HW: 5Q0 959 812 D
Component: FOND_FHSG_PSG 006 0007
Serial number: 00000000000017283291
Coding: 091000
ROD: EV_MUStd4CDELP_VW27.rod
VCID: B32668691A950ADC55-80E6
Subsystem 1 - Part No SW: 5G6 919 605 D HW: 5G6 919 605 D
Component: ABT_Std-2_Nav H50 8130
Serial number: VWZ6ZJT2650681
Subsystem 2 - Part No SW: 3G0 919 866 BH HW: -----------
Component: NAR 2017/18 --- 0620
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Address 8C: Hybrid Battery (J840) Labels: None
Part No SW: 5GE 915 225 A HW: 5GE 915 225 A
Component: K8C 005 0350
Serial number: 03101707010180
ASAM Dataset: EV_BECM08820215GE915225A 001003
ROD: EV_BECM08820215GE915225A.rod
VCID: BA38454D3DFFFB9496-80EE
Battery Junction Box:
Subsystem 1 - Part No SW: 5GE 915 316 A HW: 5GE 915 316 A
Component: A2 HVSMBJBECU 011 0300
Serial number: 00000001101705010020
Cell module: control module 1:
Subsystem 2 - Part No SW: 5QE 915 599 AH HW: 5QE 915 599 AH
Component: J991Battmod1 H08 0322
Serial number: 17828Y18AH0803226006
Cell module: control module 2:
Subsystem 3 - Part No SW: 5QE 915 599 AH HW: 5QE 915 599 AH
Component: J992Battmod2 H08 0322
Serial number: 17901Y18AH0803227251
Cell module: control module 3:
Subsystem 4 - Part No SW: 5QE 915 599 AH HW: 5QE 915 599 AH
Component: J993Battmod3 H08 0322
Serial number: 17829Y18AH0803225606
Cell module: control module 4:
Subsystem 5 - Part No SW: 5QE 915 599 AH HW: 5QE 915 599 AH
Component: J994Battmod4 H08 0322
Serial number: 17901Y18AH0803225979
Cell module: control module 5:
Subsystem 6 - Part No SW: 5QE 915 599 AH HW: 5QE 915 599 AH
Component: J995Battmod5 H08 0322
Serial number: 17828Y18AH0803226320
Cell module: control module 6:
Subsystem 7 - Part No SW: 5QE 915 599 AH HW: 5QE 915 599 AH
Component: J996Battmod6 H08 0322
Serial number: 17901Y18AH0803227066
Cell module: control module 7:
Subsystem 8 - Part No SW: 5QE 915 599 AH HW: 5QE 915 599 AH
Component: J997Battmod7 H08 0322
Serial number: 17828Y18AH0803225655
Cell module: control module 8:
Subsystem 9 - Part No SW: 5QE 915 599 AH HW: 5QE 915 599 AH
Component: J998Battmod8 H08 0322
Serial number: 17901Y18AH0803227529
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Serial number: 25101711K14558
ROD: EV_MFKBoschMQBB_VW27.rod
1122664 - Databus
[TIMEOUT_PSD_04]
Reset counter: 135
Mileage: 1194 km
Date: 2018.03.03
Time: 19:47:32
Outside air temperature: 2.5 �C
Vehicle speed: 0.00 km/h
System run time: 489.6 s
mid: 01 F0
Status of camera: operational
Engine_Running_Info: 1
Software_Info_4: 2
Software_Info_3: 7
Software_Info_2: 2
Software_Info_1: 0
Address BD: Hi Volt. Batt. Charg. (J966) Labels:* Redir Fail!
Serial number: 01148074120161
Address C0: Act. for Ext. Noise (----) Labels:| 5QE-035-335.clb
Serial number: EN174304470000
Coding: 04
VCID: CBD610896265721C3D-809E
Address C5: Therm. mgt. (J1024) Labels:* None
Serial number: 0051948
Coding: 02
Subsystem 1 - Part No SW: 4M0 959 603 C HW: 4M0 959 603 C
Component: G395 pT-Sens1 H11 0009
Subsystem 2 - Part No SW: 12E 963 231 G HW: 12E 963 231 G
Component: J848 HV-PTC H09 0208
Serial number: LR173023003810000000
Subsystem 3 - Part No SW: 5QE 816 803 A HW: 5QE 816 803 A
Component: J842 eKK H03 0009
Refrigerant Pressure And Temperature Sender 2:
Subsystem 4 - Part No SW: 4M0 959 603 C HW: 4M0 959 603 C
Component: G826 pT-Sens2 H11 0009
Refrigerant Pressure And Temperature Sender 3:
Subsystem 5 - Part No SW: 4M0 959 603 C HW: 4M0 959 603 C
Component: G827 pT-Sens3 H11 0009
Refrigerant Pressure And Temperature Sender 4:
Subsystem 6 - Part No SW: 4M0 959 603 C HW: 4M0 959 603 C
Component: G828 pT-Sens4 H11 0009
Refrigerant Pressure And Temperature Sender 5:
Subsystem 7 - Part No SW: 4M0 959 603 C HW: 4M0 959 603 C
Component: G829 pT-Sens5 H11 0009
Refrigerant Expansion Valve 1:
Subsystem 8 - Part No SW: 4M0 816 682 D HW: 4M0 816 682 D
Component: N636 EV1_KaMi H12 0102
Serial number: 00000000000120249844
Refrigerant Expansion Valve 2:
Subsystem 9 - Part No SW: 4M0 816 682 D HW: 4M0 816 682 D
Component: N637 EV2_KaMi H12 0102
Serial number: 00000000000120249933
Refrigerant Expansion Valve 3:
Subsystem 10 - Part No SW: 4M0 816 682 D HW: 4M0 816 682 D
Component: N638 EV3_KaMi H12 0102
Serial number: 00000000000120249931
Refrigerant Shut Off Valve 1:
Subsystem 11 - Part No SW: 4M0 816 703 B HW: 4M0 816 703 B
Component: V424 AV1_KaMi H12 0102
Serial number: 00000000000140249949
Refrigerant Shut Off Valve 4:
Subsystem 12 - Part No SW: 4M0 816 703 B HW: 4M0 816 703 B
Component: N642 AV4_KaMi H12 0102
Serial number: 00000000000140249551
Refrigerant Shut Off Valve 5:
Subsystem 13 - Part No SW: 4M0 816 703 B HW: 4M0 816 703 B
Component: N643 AV5_KaMi H12 0102
Serial number: 00000000000140233343
[AC_current_sensor_R2_PA_RAT]
Mileage: 313 km
Date: 2018.02.05
Time: 09:21:02
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
End----------(Elapsed Time: 02:20, VBatt start/end: 13.1V/13.1V)-----------
;SW:5GE-915-225-A HW:5GE-915-225-A --- Hybrid Battery
;Component:K8C 005 0350, Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BECM08820215GE915225A,001003,EV_BECM08820215GE915225A.rod
;Friday,27,April,2018,19:38:49:41186
;VCDS Version: Release 18.2.0 (x64) Data version: 20180212 DS287.0
;VCID: BA38454D3DFFFB9496-80EE
IDE00001-Production mode,not active ,3
IDE00011-Vehicle Identification Number (VIN),----------------- ,17
IDE05417-Serial number of H-V / hybrid battery,288 VWADHL200JT ,15
IDE05963-ASSY part number,5QE915597N ,12
IDE09090-Deactivation mode: insulation measurement,not active ,1
IDE80001-Analysis 1,not active ,1
Elapsed Time: 00:02
And the blockmap
;Friday,27,April,2018,19:38:24:41186
Group,Description,Actual
IDE00010,Serial number,03101707010180,
IDE00019,Voltage terminal 30,12.900, V
IDE00020,Terminal 15 status,On,
IDE00030,Status of actuator test,not active,
IDE00056,History data 1,8,
IDE00056,History data 1,6,
IDE00056,History data 1,48,
IDE00056-ENG28733,History data 1-HVBHDM01_4,00 00 00 00,
IDE00057,History data 2,8,
IDE00057,History data 2,64,
IDE00057-ENG28734,History data 2-HVBHDM02_4,00 00 00 00,
IDE00058,History data 3,64,
IDE00058,History data 3,8,
IDE00058-ENG28735,History data 3-HVBHDM03_4,00 00 00 00,
IDE00059,History data 4,8,
IDE00059,History data 4,64,
IDE00059-ENG28736,History data 4-HVBHDM04_4,00 00 00 00,
IDE00060,History data 5,6,
IDE00060-ENG28737,History data 5-HVBHDM05_4,00 00 00 00,
IDE00061,History data 6,20,
IDE00061,History data 6,2,
IDE00061,History data 6,10,
IDE00061-ENG28738,History data 6-HVBHDM06_4,00 00 1A 7B,
IDE00062,History data 7,21,
IDE00062,History data 7,6,
IDE00062-ENG28739,History data 7-HVBHDM07_4,00 00,
IDE00063,History data 8,6,
IDE00063,History data 8,21,
IDE00063-ENG28740,History data 8-HVBHDM08_4,00 00,
IDE00064,History data 9,88,
IDE00064-ENG28787,History data 9-HVBHDM09_2,00 06 7D 12,
IDE00065,History data 10,10,
IDE00065-ENG28788,History data 10-HVBHDM10_2,00 45 7E 6B,
IDE00066,History data 11,8,
IDE00066,History data 11,2,
IDE00066,History data 11,16,
IDE00066-ENG28741,History data 11-HVBHDM11_4,00 00,
IDE00067,History data 12,16,
IDE00067,History data 12,8,
IDE00067,History data 12,2,
IDE00067-ENG28742,History data 12-HVBHDM12_4,00 00,
IDE00068,History data 13,8,
IDE00068-ENG28789,History data 13-HVBHDM13_2,00 00 00 F7,
IDE00069,History data 14,2A EE,
IDE00069,History data 14,88,
IDE00069-ENG28743,History data 14-HVBHDM14_3,BB,
IDE00070,History data 15,27,
IDE00070,History data 15,40,
IDE00070,History data 15,1080,
IDE00070-ENG28744,History data 15-HVBHDM15_4,B8,
IDE00071,History data 16,73,
IDE00071,History data 16,00 00,
IDE00071,History data 16,00 C2,
IDE00071,History data 16,00 F6,
IDE00071,History data 16,FF,
IDE00071,History data 16,1,
IDE00322,Status of basic setting,not active,
IDE00323,Security Access: Number of invalid keys,0,
IDE00445,Unlearning counter according OBD,255,
IDE00773,Terminal 15 status via CAN,On,
IDE00961-MAS05695,Malfunction Indicator Lamp-Start request,not active,
IDE01021,Current of H-V / hybrid battery,-0.500, A
IDE01036-MAS01375,High voltage / Hybrid Battery history data 1-Counter for amp hour charge,1520.359, Ah
IDE01036-MAS01376,High voltage / Hybrid Battery history data 1-Counter for amp hour discharge,-1248.424, Ah
IDE01036-MAS01377,High voltage / Hybrid Battery history data 1-Counter for kilowatt hour charge,518.953, kWh
IDE01036-MAS01378,High voltage / Hybrid Battery history data 1-Counter for kilowatt hour discharge,-415.633, kWh
IDE01718,Crash signal,not active,
IDE01803,History data 17,6,
IDE01803-ENG28745,History data 17-HVBHDM17_2,02 56,
IDE01804,History data 18,8,
IDE01804-ENG28746,History data 18-HVBHDM18_2,00 08 2C A0,
IDE01805,History data 19,7,
IDE01805-ENG28747,History data 19-HVBHDM19_2,00 07 3E 98,
IDE01806,History data 20,7,
IDE01806-ENG28748,History data 20-HVBHDM20_2,00 4C E5 FF,
IDE01838,Battery temperature,17.500, �C
IDE01839,Battery charge condition,66.800, %
IDE03410-MAS05695,Yellow warning lamp-Start request,not active,
IDE03411-MAS05695,Red warning lamp-Start request,not active,
IDE05416,H-V battery insulation measurement test voltage,500, V
IDE05417,Serial number of H-V / hybrid battery,288 VWADHL200JT,
IDE05963,ASSY part number,5QE915597N ,
IDE06346,H-V battery voltage,336.250, V
IDE06404,Pilot line,not active,
IDE06673,Initialization status,not active,
IDE06805,Status of voltage freedom,High voltage power off not recognized,
IDE06948,High-volt. battery mode: spec. value,Driving mode,
IDE06973,Power reduction status,not active,
IDE07044-MAS01420,Predictive limit for charge current-Limit for charge current,141, A
IDE07045-MAS01420,Dynamic limit for charge current-Limit for charge current,141, A
IDE07227-IDE01024,Voltage in H-V system-Voltage of hybrid battery after protection,336.000, V
IDE07227-MAS05684,Voltage in H-V system-Voltage at power electronics,336.500, V
IDE07227-MAS05685,Voltage in H-V system-Voltage at high-voltage charging device,330, V
IDE07336,Voltage terminal 30C battery circuit breaker,12.750, V
IDE08217-MAS01234,maximum voltage for battery cells-Index 1,1,
IDE08217-MAS02985,maximum voltage for battery cells-Value,3.828, V
IDE08218-MAS01234,minimum voltage for battery cells-Index 1,32,
IDE08218-MAS02985,minimum voltage for battery cells-Value,3.817, V
IDE08228,Positive voltage of high volt battery after load protection,0.000, V
IDE08229,Negative voltage of high volt battery after load protection,0.000, V
IDE08230-MAS01421,Dynamic limit for discharge current-Limit for discharge current,371, A
IDE08231-MAS01421,Predictive limit for discharge current-Limit for discharge current,371, A
IDE80253,Voltage terminal 30C,12.800, V
MAS00464-MAS00106,Standard - ambient data 1-Year,2018,
MAS00464-MAS00107,Standard - ambient data 1-Month,1,
MAS00464-MAS00108,Standard - ambient data 1-Day,27,
MAS00464-MAS00109,Standard - ambient data 1-Hours,3,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,0,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,35,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,114,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,3867, km
MAS00474,Counter over-run,Not available,
MAS01302,Protection of posit. terminal of high voltage / hybrid battery,closed,
MAS01303,Protection of neg. terminal of high voltage / hybrid battery,closed,
MAS02199-MAS01966,Lowest measured temperature-Temperature sensor,23,
MAS02199-MAS02985,Lowest measured temperature-Value,16.000, �C
MAS02200-MAS01966,Highest measured temperature-Temperature sensor,3,
MAS02200-MAS02985,Highest measured temperature-Value,20.000, �C
MAS04266,Temperature sensor 1,18.000, �C
MAS04267,Temperature sensor 2,18.500, �C
MAS04268,Temperature sensor 3,20.000, �C
MAS04269,Temperature sensor 4,19.500, �C
MAS04270,Temperature sensor 5,19.000, �C
MAS04271,Temperature sensor 6,17.500, �C
MAS04272,Temperature sensor 7,17.500, �C
MAS04273,Temperature sensor 8,18.000, �C
MAS04291,Positive voltage of high volt battery after protection,175.875, V
MAS04292,Negative Voltage of high volt battery after protection,-160.594, V
MAS04293-MAS01632,Entire HV system positive terminal insulation resistance-Status,Initializing,
MAS04293,Entire HV system positive terminal insulation resistance,5110, kOhm
MAS04294-MAS01632,HV battery positive terminal insulation resistance-Status,Initializing,
MAS04294,HV battery positive terminal insulation resistance,10210, kOhm
MAS04295-MAS01632,Entire HV system minus terminal insulation resistance-Status,Initializing,
MAS04295,Entire HV system minus terminal insulation resistance,5000, kOhm
MAS04296-MAS01632,HV battery minus terminal insulation resistance-Status,Initializing,
MAS04296,HV battery minus terminal insulation resistance,10210, kOhm
MAS04649,Cell 1,3.828, V
MAS04650,Cell 2,3.828, V
MAS04651,Cell 3,3.827, V
MAS04652,Cell 4,3.826, V
MAS04653,Cell 5,3.827, V
MAS04654,Cell 6,3.826, V
MAS04655,Cell 7,3.825, V
MAS04656,Cell 8,3.825, V
MAS04657,Cell 9,3.826, V
MAS04658,Cell 10,3.826, V
MAS04659,Cell 11,3.825, V
MAS04660,Cell 12,3.825, V
MAS04661,Cell 13,3.826, V
MAS04662,Cell 14,3.828, V
MAS04663,Cell 15,3.827, V
MAS04664,Cell 16,3.827, V
MAS04665,Cell 17,3.827, V
MAS04666,Cell 18,3.828, V
MAS04667,Cell 19,3.828, V
MAS04668,Cell 20,3.825, V
MAS04669,Cell 21,3.826, V
MAS04670,Cell 22,3.826, V
MAS04671,Cell 23,3.824, V
MAS04672,Cell 24,3.824, V
MAS04673,Cell 25,3.825, V
MAS04674,Cell 26,3.826, V
MAS04675,Cell 27,3.824, V
MAS04676,Cell 28,3.824, V
MAS04677,Cell 29,3.824, V
MAS04678,Cell 30,3.825, V
MAS04679,Cell 31,3.825, V
MAS04680,Cell 32,3.816, V
MAS04681,Cell 33,3.826, V
MAS04682,Cell 34,3.826, V
MAS04683,Cell 35,3.825, V
MAS04684,Cell 36,3.827, V
MAS04685,Cell 37,3.824, V
MAS04686,Cell 38,3.825, V
MAS04687,Cell 39,3.824, V
MAS04688,Cell 41,3.824, V
MAS04689,Cell 42,3.823, V
MAS04690,Cell 43,3.824, V
MAS04691,Cell 44,3.825, V
MAS04692,Cell 45,3.825, V
MAS04693,Cell 46,3.826, V
MAS04694,Cell 47,3.826, V
MAS04695,Cell 48,3.826, V
MAS04696,Cell 49,3.825, V
MAS04697,Cell 50,3.825, V
MAS04698,Cell 51,3.825, V
MAS04699,Cell 52,3.826, V
MAS04700,Cell 53,3.826, V
MAS04701,Cell 54,3.823, V
MAS04702,Cell 55,3.827, V
MAS04703,Cell 56,3.826, V
MAS04704,Cell 57,3.826, V
MAS04705,Cell 58,3.826, V
MAS04706,Cell 59,3.826, V
MAS04707,Cell 60,3.827, V
MAS04708,Cell 61,3.826, V
MAS04709,Cell 62,3.825, V
MAS04710,Cell 63,3.826, V
MAS04711,Cell 64,3.826, V
MAS04712,Cell 65,3.825, V
MAS04713,Cell 66,3.822, V
MAS04714,Cell 67,3.824, V
MAS04715,Cell 68,3.824, V
MAS04716,Cell 69,3.824, V
MAS04717,Cell 70,3.825, V
MAS04718,Cell 71,3.826, V
MAS04719,Cell 72,3.826, V
MAS04720,Cell 40,3.825, V
MAS04721-MAS01234,Minimum charge level-Index 1,32,
MAS04721-MAS02985,Minimum charge level-Value,65.920, %
MAS04722-MAS01234,Maximum charge level-Index 1,60,
MAS04722-MAS02985,Maximum charge level-Value,67.380, %
MAS06746,Temperature sensor 9,18.500, �C
MAS06747,Temperature sensor 10,18.500, �C
MAS06748,Temperature sensor 11,17.000, �C
MAS06749,Temperature sensor 12,17.000, �C
MAS06750,Temperature sensor 13,18.000, �C
MAS06751,Temperature sensor 14,16.500, �C
MAS06752,Temperature sensor 15,17.500, �C
MAS06753,Temperature sensor 16,17.500, �C
MAS06754,Positive voltage of high volt battery before protection,175.906, V
MAS06755,Negatve voltage of high volt battery before protection,-160.594, V
MAS06761,Sum of voltage of all battery cells,336.624, V
MAS07429,Status loader positive terminal,Open,
MAS07430,Status loader negative terminal,Open,
MAS07735,Cell 73,3.826, V
MAS07736,Cell 74,3.825, V
MAS07737,Cell 75,3.826, V
MAS07738,Cell 76,3.827, V
MAS07739,Cell 77,3.826, V
MAS07740,Cell 78,3.820, V
MAS07741,Cell 79,3.826, V
MAS07742,Cell 80,3.825, V
MAS07743,Cell 81,3.825, V
MAS07744,Cell 82,3.826, V
MAS07745,Cell 83,3.826, V
MAS07746,Cell 84,3.827, V
MAS07747,Cell 85,3.827, V
MAS07748,Cell 86,3.826, V
MAS07749,Cell 87,3.825, V
MAS07750,Cell 88,3.823, V
MAS07773,Temperature sensor 17,18.000, �C
MAS07774,Temperature sensor 18,17.500, �C
MAS07775,Temperature sensor 19,18.000, �C
MAS07776,Temperature sensor 20,17.000, �C
MAS07777,Temperature sensor 21,16.500, �C
MAS07778,Temperature sensor 22,18.000, �C
MAS07779,Temperature sensor 23,16.000, �C
MAS07780,Temperature sensor 24,17.000, �C
MAS07781,Temperature sensor 25,17.500, �C
MAS07782,Temperature sensor 26,17.000, �C
MAS07783,Temperature sensor 27,17.500, �C
MAS07798,Status pre-loader,Open,
MAS07826,Reqmnt. emergency discharge HV interm. circ. condenser,not active,
MAS07827,Mode HV battery actual value,Driving mode,
MAS09283,HV interlock detector voltage,0.499, V
MAS09284,HV interlock source voltage,2.144, V
MAS09285,HV interlock detector current,10.629, mA
MAS09286,HV interlock source current,10.471, mA
Elapsed Time: 00:24
