Hi all, I have retrofitted the front and rear parking sensors with screen display in an Audi Q2 of 2017 the system works but I can not activate the visualization in the MMI,
I have already made the adjustments on the 5F but without result.
Can someone help me?
I attach log
I attach log
Friday,27,April,2018,15:57:13:49000
VCDS Version: 18.2.0.3
VIN: WAUZZZGA2HA024125 License Plate:
Chassis Type: GA-AU37 (3Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 55 5F
VIN: WAUZZZGA2HA024125 Mileage: 34608km-21504miles
Address 01: Engine (2D2D2-DDYA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 056 LF HW: 04L 907 445 E
Component: R4 1.6l TDI H01 3906
Revision: 22005001
Coding: 0219401243241D092000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM16TDI03004L906056LF 004008
ROD: EV_ECM16TDI03004L906056QT.rod
VCID: 7CF06D9EF7540FA444-8028
Readiness: N/A
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 CE HW: 5Q0 614 517 AC
Component: ESC H25 0413
Revision: 00000000 Serial number: 60077000000381
Coding: 34006A8D34220C7049780E0260C8242C562C3092700624F21241F078801B4200002B64121213122835351919323200
ROD: EV_Brake1UDSContiMK100IPB_036_AU37.rod
VCID: 76E47FB6C97855F432-8022
Part No SW: 8V0 820 043 K HW: 8V0 820 043 K
Component: AC Automat H03 0130
Revision: 20003000 Serial number: 00000001123893
Coding: 06000104002000001000000000001000
ASAM Dataset: EV_AirCondiFrontVaAU37X 008022
VCID: 3A7CAB86BDE0F19416-806E
Subsystem 1 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0006
Serial number: 57E8856800PAG0MUFU03
Part No SW: 5Q0 937 084 CF HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H34 0236
Serial number: 02001700201734
ROD: EV_BCMBOSCH_017.rod
VCID: 7EF46796E1481DB46A-802A
Subsystem 1 - Part No SW: 81A 955 555 A HW: 81A 955 555
Serial number: 20169227X81A955555A0
Coding: 80005E
Light switch:
Subsystem 2 - Part No SW: 8V0 941 531 AQ HW: 8V0 941 531 AQ
Component: E1 - LDS MQB H06 0032
Serial number: 19 10 2016 00000679
Part No SW: 5QA 919 294 A HW: 5QA 919 294
Component: PDC 8 KanalH07 0038
Serial number: 000308418617125
Coding: 0430051001
ASAM Dataset: EV_EPHVA18AU3700000 009031
ROD: EV_EPHVA18AU3700000_009_AU37.rod
VCID: 4A9CFB46ED00611486-801E
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 J HW: 2Q0 907 572 B
Component: ACCCONTIMQB H01 0156
Coding: 2A00000110F78728747C60450040A7
ASAM Dataset: EV_ACCMRRCONTIVW376 001011
ROD: EV_ACCMRRCONTIVW376_001.rod
VCID: 3B72AE82B2DAC89C0D-806E
1389 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Reset counter: 46
Mileage: 34608 km
Date: 2018.04.26
Time: 21:31:13
Voltage terminal 15: 9.3 V
Control Module temperature: 65 °C
Longitudinal_acceleration_vehicle_reference: -0.03 m/s²
Part No SW: 5Q0 959 655 AQ HW: 5Q0 959 655 AQ
Component: AirbagVW21 003 0317
Serial number: 003T8R2H0DR/
Coding: 88CCF0C000000000585400DFC04800000065
VCID: 0F2A2A52D6E2043C91-805A
Subsystem 1 - Part No SW: ----------- HW: 480 000 701 17
Serial number: 357000000004735DBF1V
Subsystem 2 - Part No SW: ----------- HW: 480 000 701 17
Serial number: 35800000000DF16DBF15
Subsystem 3 - Part No SW: ----------- HW: 480 400 901 17
Serial number: 3510001B922B4E815292
Subsystem 4 - Part No SW: ----------- HW: 480 400 901 17
Serial number: 3520001B922B4E82034
Subsystem 5 - Part No SW: ----------- HW: 480 402 212 16
Component: FrontSensor_D 000 6149
Serial number: 3550001BF23B3B312493
Front Sensor Passenger:
Subsystem 6 - Part No SW: ----------- HW: 480 402 212 16
Component: FrontSensor_P 000 6149
Serial number: 3560001C7237EE3472AE
Part No SW: 8V0 953 521 HD HW: 5Q0 953 549 E
Revision: -------- Serial number: 18121608490717
Coding: A44C
VCID: 030216628AAA705C05-8056
Part No SW: 81A 920 741 HW: 81A 920 741
Component: KOMBI H02 8317
Coding: 07A422042B800008048008001000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009054
VCID: 61CE3CEA70F6C24C77-8034
U1014 00 [009] - -
Reset counter: 6
Mileage: 34608 km
Date: 2018.04.26
Time: 21:19:56
Part No SW: 3Q0 907 530 C HW: 3Q0 907 530 C
Component: GW MQB High 418 4286
Revision: -------- Serial number: 0005798949
Coding: 030000041F0873005B000248080000000001010000000000000000000000
ROD: EV_GatewNF_VW27.rod
VCID: 2F6A8AD276A2243CB1-807A
Subsystem 2 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Component: J367-BDMConti H03 1050
Serial number: 75410803921611100530
Part No SW: 5Q0 959 393 E HW: 5Q0 959 393 B
Component: TSG FS 020 0041
Serial number: 031216EL235245
Coding: 00100B204000040000001002
VCID: 418EDC6AD036A24C57-8014
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000012709751
Coding: 110000
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 0107
ROD: EV_SteerAssisMQB_013.rod
Part No SW: 5Q0 959 392 E HW: 5Q0 959 392 B
Component: TSG BFS 020 0041
Serial number: 031216EL306602
Coding: 001003204000040000001002
VCID: 4088D96EDB3CAB4458-8014
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000012747153
Coding: 090000
Part No SW: 7P6 907 357 E HW: 7P6 907 357 A
Component: AFS-ECU H07 0070
Coding: 0B8A00102B200201
ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
ROD: EV_HeadlRegulAFSMQBMAX_VW37.rod
Part No SW: 81A 035 812 HW: 81A 035 812
Component: MU-S--ER 710 0741
Coding: 017206003C00000010110001000A000000002B040170010000
ROD: EV_MUStd4CDELP_AU37.rod
VCID: 5DB6001A4C8EE6AC53-8008
Subsystem 1 - Part No SW: 81A 919 603 HW: 81A 919 603
Component: DU Bas AU216 H41 0080
Serial number: INX00122051600030189
Multimedia Operating Unit:
Subsystem 2 - Part No SW: 81B 919 614 HW: 81B 919 614
Component: ControlUnit_B H20 0200
Serial number: APVAK118101600060054
End-------------------------(Elapsed Time: 04:57)--------------------------
