Not quite sure how this fault came about but I am unable to get rid of it. It shows up at multiple Addresses: 03: ABS Brakes (J104) and 44: Steering Assist (J500).
Only Address 44 allows initialization of the sensor. Address 03 in my car has no steering angle sensor settings.
In Address 44 I enter the security code that's provided by VCDS and it's accepted.
I go to Basic Settings, select IDE05744-Steering Angle Sensor: initialization, GO, and the response is: "ERROR: Security access required"
Anybody out there have a different security code?
There's a few posts of people out there who had the same problem, but none of them offered a solution.
Hans
Hans
Tuesday,24,April,2018,11:19:46:40467
VCDS Version: 18.2.0.3 (x64) HEX-V2 CB: 0.4411.4
VIN: 3VWFA7AU8FM519186 License Plate:
Mileage: 14322km-8900mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 05 08 09 15 16 17 19 2B 42 44 47 52 55 5F 69 75
VIN: 3VWFA7AU8FM519186 Mileage: 14322km-8899miles
47-Sound System -- Status: Cannot be reached 0100
Address 01: Engine (J623-CRUA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 C HW: 04L 907 309
Component: R4 2.0l TDI H23 9282
Revision: 85H23---
Coding: 01190012032410081000
Shop #: WSC 30840 002 1048576
ASAM Dataset: EV_ECM20TDI01104L906021C 004014
ROD: EV_ECM20TDI01104L906021C_004.rod
VCID: 25170C6B2568E71F21E-8070
17158 - Databus
U1123 00 [047] - Received Error Message
Mileage: 14294 km
Date: 2018.04.22
Time: 00:03:33
Coolant temperature: 46 °C
Intake air temperature: 41 °C
Ambient air pressure: 830 mbar
Voltage terminal 30: 12.360 V
Drivetrain coordinator: brake fault status-Bits 0-7: 4
Drivetrain coordinator: brake function status-Bits 0-7: 0
Acceleration: 0.000 m/s²
17149 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [175] - -
[Checking coding/versions ofcontrol modules in drivetrain]
Fault Frequency: 119
Mileage: 13738 km
Date: 2018.03.27
Time: 16:57:16
Coolant temperature: 22 °C
Intake air temperature: 22 °C
Voltage terminal 30: 11.660 V
ACC variants-Bits 0-7: 0
CCS Switch-Bits 0-7: 1
Cruise control switch actuation-Bits 0-7: 0
Cruise control switch actuation-Bits 0-7: 32
ACC variants (coding)-Bits 0-7: 1
U0428 00 [047] - -
Mileage: 14294 km
Date: 2018.04.22
Time: 00:03:32
Voltage terminal 30: 12.380 V
Cruise Control System (CCS): status-Bits 0-7: 0
17921 - Databus
U1122 00 [032] - Implausible Message
Mileage: 14152 km
Date: 2018.04.15
Time: 17:27:39
Coolant temperature: 12 °C
Intake air temperature: 13 °C
Voltage terminal 30: 12.040 V
Unlearning counter according OBD: 32
Drivetrain coordinator: brake fault status-Bits 0-7: 1
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-ESP-V1.clb
Part No SW: 3Q0 907 379 P HW: 3Q0 907 379 C
Component: ESC H32 0385
Revision: 00000000 Serial number: 51385000000080
Coding: 04FA6AA1242109750078020881C92520562490004081A4B200630050C002
VCID: 47CBA6E3FF24150FF32-8012
0295 - Steering angle sensor
Reset counter: 61
Mileage: 14322 km
Date: 2018.04.23
Time: 21:15:40
16412 - Display for Tire Pressure Monitoring
C1146 02 [009] - Signal Failure
Reset counter: 61
Mileage: 14322 km
Date: 2018.04.23
Time: 21:15:49
16413 - Display for Tire Pressure Monitoring
Reset counter: 61
Mileage: 14322 km
Date: 2018.04.23
Time: 21:15:49
Revision: 00021000 Serial number: 0365852065
Coding: 030C1C
Shop #: WSC 01383 790 50316
VCID: 3A2DCF17BCD678E77CC-806E
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5GM 907 426 A HW: 5GM 907 426 A
Component: AC Manuell H02 1001
Revision: 00001K01
Coding: 02020104202100000000000000000000
ROD: EV_ACManueBHBVW37X_003_VW37.rod
VCID: 46D5ABE7F82E0C07084-8012
B10CD 00 [008] - -
Reset counter: 99
Mileage: 14294 km
Date: 2018.04.23
Time: 16:49:03
Voltage terminal 30: 11.3 V
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 087 R HW: 5Q0 937 087 R
Component: BCM PQ37BOSCH 028 0145
Revision: -------- Serial number: 86582404150684
Coding: 005308464041026969E44000001407001800000000000000000000000000
ROD: EV_BCMBOSCH_014.rod
VCID: 4ACD9FD7EC36E867ECC-801E
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150411 043 0581
Serial number: 150609124147
Coding: 1F4DFD
Subsystem 2 - Part No SW: 5Q0 955 559 A HW: 5Q0 955 559 A Labels: 5Q0-955-547.CLB
Component: RLS 037 0059
Serial number: S2Y15M04D16H23M14S06
Coding: 14A8DD
Sun Roof:
Subsystem 3 - Part No SW: 5G0 959 591 A HW: 8V3 959 591 A
Component: J245 PS22.409 H03 0004
Serial number: 0000FST0004CZM100000
Coding: 191800
Roof Blind:
Subsystem 4 - Part No SW: 5G0 959 591 A HW: 8V3 959 591 A
Component: J394 PS22.409 H03 0004
Serial number: 0000FST0004CZKZ00000
Coding: 191800
Reset counter: 101
Mileage: 14294 km
Date: 2018.04.23
Time: 16:45:07
Component: AirbagVW20 009 0825
Serial number: 003GCR01VAAO
Occupant Detection:
Component: BF-Gewichtss. H11 0021
Serial number: IBH0000J150002P5XA0H
Coding: 303135
Subsystem 2 - Part No SW: ----------- HW: 480 002 005 15
Serial number: 3570000000090685941E
Subsystem 3 - Part No SW: ----------- HW: 480 002 005 15
Serial number: 3580000000035585941D
Subsystem 4 - Part No SW: ----------- HW: 480 401 404 15
Serial number: 3510002A91A87854010V
Subsystem 5 - Part No SW: ----------- HW: 480 402 104 15
Serial number: 3520002B519EFF53C3EX
Subsystem 6 - Part No SW: ----------- HW: 480 401 404 15
Serial number: 3550002BF19EFF50E13W
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 401 804 15
Serial number: 3560002BF1A878553216
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 521 AT HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20150422500922
Coding: 0400
ROD: EV_SMLSVALEOMQB.rod
VCID: 045171EF8E92FE17560-8050
Part No SW: 5G1 920 841 HW: 5G1 920 841
Component: KOMBI 243 4270
Coding: 0BA4121221804E0502086A001000000000000000
VCID: 65974C6B65E8271FE1E-8030
U1014 00 [009] - -
Fault Frequency: 17
Reset counter: 61
Mileage: 14322 km
Date: 2018.04.23
Time: 20:29:53
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 M
Component: GW MQB High 212 2265
Revision: -------- Serial number: 19101610522089
Coding: 000000F0000F58000E000002000B00000000000100000000000000000000
ROD: EV_GatewConti_013_VW37.rod
VCID: 7CA1090FF66286D72E0-8028
131695 - Digital sound System control module
U106A 00 [009] - No Communication
[Timeout Knoten 0x6F / 47 - Steuergerät für digitales Soundpaket]
Fault Frequency: 39
Reset counter: 61
Mileage: 14152 km
Date: 2018.04.15
Time: 17:54:07
Supply voltage: Terminal 30: 11.8 V
Terminal 15: On
67072 - Local Databus
U1125 00 [009] - Additional Installations Detected
[Subsystem Mehrverbau erkannt]
Fault Frequency: 167
Reset counter: 61
Mileage: 14152 km
Date: 2018.04.15
Time: 17:54:07
Terminal 15: On
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000105448003
Coding: 5500000000000000
Shop #: WSC 00066 790 07030
ROD: EV_ELVMarquMQB.rod
VCID: 3431E12F9EB28E97A60-8060
Part No SW: 5Q0 959 393 B HW: 5Q0 959 393 B
Component: TSG FS 020 0025
Serial number: 21051506050FWV
Coding: 003013200000040000000000
VCID: 3E25C307A0FE54C7404-806A
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000001282438
Coding: 011000
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1061
Coding: 0102
VCID: 43D3B2F3CB1C392F2FA-8016
15873 - Steering angle sensor
Reset counter: 61
Mileage: 14322 km
Date: 2018.04.23
Time: 21:04:31
Motor status: 00
Supply voltage: 12.00 V
Temperature: 39.0 °C
KFC: 3E
KFA: 00 01
Environmental conditions: 5F
uioUdNotFilt_xdu16: 12.02 V
uAdSensI_SwitchedKl30_xdu16: 12.01 V
Address 47: Sound System (J525) Labels:| 5G0-035-456.clb
Part No SW: 5G0 035 456 HW: 5G0 035 456
Component: MIB_lite_amp H40 0070
Serial number: VWZ8Z1FC402PGHI
Coding: 22000000AAAAAA0000
ASAM Dataset: EV_AMPMst12C1ALPI 001007
ROD: EV_AMPMst12C1ALPI.rod
VCID: 639352736BDC592F0FA-8036
Part No SW: 5Q0 959 392 B HW: 5Q0 959 392 B
Component: TSG BFS 020 0025
Serial number: 280515060506FW
Coding: 003013200C00040000000000
VCID: 3D27C40BADF84FDF59E-8068
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000001235066
Coding: 091000
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Coding: 0000000000000000
VCID: 75B71C2BD548D79F51E-8020
10490624 - No End-of-Line Programming
B2013 00 [137] - -
Reset counter: 34
Mileage: 13897 km
Date: 2018.04.03
Time: 17:40:21
13636352 - Control module not coded
U1013 00 [137] - -
[Steuergeraet nicht codiert]
Reset counter: 34
Mileage: 13897 km
Date: 2018.04.03
Time: 17:40:21
5275220 - Headlight
Reset counter: 34
Mileage: 13897 km
Date: 2018.04.03
Time: 17:40:21
13705992 - Databus
U1123 00 [137] - Received Error Message
[LWI_01: Fehlerwert im Signal LWI_Lenkradwinkel]
Fault Frequency: 27
Reset counter: 61
Mileage: 14294 km
Date: 2018.04.23
Time: 16:28:35
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 844 HW: 5G0 035 844
Component: MU-S-S-US 014 0655
Serial number: V7B00405150080
Coding: 027302000000000021220002001800001F0100340100010002
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 6491516F6ED25E17F60-8030
Subsystem 1 - Part No SW: 5G0 919 605 H HW: 5G0 919 605 H
Component: ABT_Std_Plus H60 0030
Serial number: VWZ8Z9RS501W29
B11CF 53 [009] - Deactivated
Reset counter: 61
Mileage: 14322 km
Date: 2018.04.23
Time: 20:24:45
Voltage terminal 30: 12.3 V
7219 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Emergency call module (0x33) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 61
Mileage: 14322 km
Date: 2018.04.23
Time: 21:59:24
Voltage terminal 30: 12.0 V
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 5Q0 907 383 J HW: 5Q0 907 383 B
Component: Anhaenger H21 0204
Revision: 8C001003 Serial number: 0410657900
Coding: 0100000000000000
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0564
Coding: 02730202C0023A01000000000000
Shop #: WSC 00066 790 00322
ROD: EV_OCULowMQB.rod
End----------(Elapsed Time: 01:22, VBatt start/end: 11.9V/12.1V)-----------
