2016 Audi Q5 3.0 TDI CPNB Reference scan
timbo
C?ID=327905
1 month post-dieselgate fix. Not happy with the transmission remap BTW. :(
Tuesday,24,April,2018,17:27:31:32531
VIN: WA1CVAFPXGA033966   License Plate:
Mileage: 54120km-33628mi   Repair Order:
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 47 52 53 56 5F
          62 69 6C 6D 72 AC
VIN: WA1CVAFPXGA033966   Mileage: 54120km-33628miles
Address 01: Engine (J623-CPNB)       Labels:. 059-907-401-V2.clb
   Part No SW: 8K5 907 401 AC    HW: 4G0 907 401 E
   Component: 3.0TDI FSA    H14 0008
   Revision: 58H14---
   Coding: 2A2A4032053603050000
   Shop #: WSC 58767 001 1048576
   ASAM Dataset: EV_ECM30TDI0118K5907401AC 002008
   ROD: EV_ECM30TDI0118K5907401AC_002.rod
   VCID: 71BF28B9D12EEBBF8D6-8024
9954 - NOx Reductant Consumption too Low
          P20F4 00 [032] - -
Readiness: 0 0 0 1 0
   Part No SW: 8R0 927 158 Q    HW: 0BK 927 156 AM
   Component: 0BK 30 TDIUSA H19 1007
   Revision: --H19---
   Coding: 000001
   VCID: 4BC39A519342E16FD7A-801E
12514 - Internal Control Module - Processor Performance Monitoring
          P060A 00 [032] - -
                    Mileage: 51433 km
                    Date: 2018.03.16
                    Time: 12:04:09
                    Unlearning counter according OBD: 5
                    Voltage terminal 30: 11.829 V
                    Engine speed: 668 /min
                    Transmission fluid temperature: 43 ∞C
                    Status of brake signals-Brake Light Switch: operated
                    Status of brake signals-Brake pressure switch: not activated
                    Status of brake signals-Validity of brake pressure information: valid
                    Status of brake signals-Validity of brake pedal information: valid
                    Driving position: P
                    Transmission output speed: 0.00 /min
                    M008_Torque Converter Lockup Clutch State-Shift Type / Mode: 0
                    M008_Torque Converter Lockup Clutch State-Torque Converter Lockup Clutch: Open
                    M008_Torque Converter Lockup Clutch State-Traction/Coasting Flag: Traction
                    Status electric parking lock holder solenoid-Desired State Solenoid Out 10: OFF
                    Status electric parking lock holder solenoid-Desired State Solenoid Out 11: OFF
                    Status electric parking lock holder solenoid-Desired State Solenoid Out 12: OFF
                    Status electric parking lock holder solenoid-Desired State Solenoid Out 13: OFF
                    Status electric parking lock holder solenoid-Desired State Solenoid Out 14: On
                    selected gear: without traction
                    Transmission input speed: 313.00 /min
                    Status of starter lock: OFF
                    Stop process prevented-Oil temperature too low: not active
                    Stop process prevented-Transmission fluid temperature too high: not active
                    Stop process prevented-Adaptation procedure active: not active
                    Stop process prevented-Pressure accumulator filling not completed: not active
                    Stop process prevented-Gear 1 or 2 not selected: not active
                    Start process requested-Driver intention: not active
                    Start-stop conditions: Stop prohibition: no start request
                    Start-stop enabling: No release by coordinator
                    M015_Time Normal Mode: 1123 s
                    M019_Time Since Reset: 7650 ms
                    M018_Time In Afterrun: 0 s
                    M014_Time Since Shift: 7650 ms
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
   Part No SW: 8R0 907 379 AS    HW: 8R0 907 379 AS
   Component: ESP8 quattro  H09 0020
   Coding: 23DD1C03
   Shop #: WSC 06335 123 12345
   VCID: 117F4839B16E8BBFED6-8044
   Part No SW: 8K0 907 064 KP    HW: 8K0 907 064 KP
   Component: BCM2 2.0      H15 0711
   Coding: 0D854040000000000000
   VCID: 0849655DC234CA773A8-805C
   Subsystem 1 - Part No SW: 8K0 959 754 B    HW: 8K0 959 754 B
   Serial number: 0815000088064019
   Subsystem 2 - Part No SW: 8K0 905 852 E    HW: 8K0 905 852 E
   Serial number: 3215000122947016
   Part No SW: 8K1 820 043 AR    HW: 8K1 820 043 AR
   Revision: C3000000    Serial number: 01160720152334
   Coding: 3621228280
   Shop #: WSC 06335 000 00000
   VCID: 78A9159DB2D4BAF74A8-802C
   Revision: 08016001    Serial number: 00001123248101
   Coding: 26000091863CAFE00100488000003D0D0F9CE608A6090225000008004000030100000034000000
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 150702  H12 0050
   Serial number: 90243014150624140620
   Coding: 01DD13
   Serial number: 20442295
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000207151649
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z0015F6FD
   Subsystem 5 - Part No SW: 8K0 959 772 E    HW: 8K0 959 772
   Component: SLR-B8  H06 0007
   Serial number:           0155891111
   Coding: 0F0000
   Serial number: 74984BB7000000000001
   Part No SW: 8K0 959 655 R    HW: 8K0 959 655 R
   Component: AirbagVW-AU10 H53 0812
   Serial number: 003NED153ZV%
   Coding: 303635313832383132304A55304C38523053
   ASAM Dataset: EV_AirbaECUVWAUDI010 003114
   VCID: 4CC1994D964CE657DE0-8018
   Subsystem 1 - Part No SW: 8R0 959 339 A    HW: 8R0 959 339 A
   Serial number: 5810000R150000MV9R
   Serial number: 6334MSME532D41034
   Serial number: 6344MSME532D2C03E
   Serial number: 6352QSME49594C7A.
   Serial number: 6362QSME49592678S
   Serial number: 63732SME52592748+
   Serial number: 63832SME5C5921483
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862OGL000C0
   Coding: 000037
   VCID: 48C9A55D82B40A77FA8-801C
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 982 A    HW: 8R0 920 982 A
   Component: KOMBIINSTR.   H35 0567
   Revision: 00200000    Serial number: 03K47XE7G
   Coding: 83B622000301D705020000
   VCID: 392FD099C95E63FF756-806C
   Part No SW: 8R0 907 468 AA    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0070
   Revision: 1Z130032    Serial number: 3241Z15616087B
   Coding: 80CF07FF00
   VCID: 7EA5038590F084C7004-802A
   Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
   Component: J367-BDMHella  H07 8043
   Serial number: 9700287303
   Serial number: 15195001100011200410
   Part No SW: 8R0 959 760 E    HW: 8R0 959 760 C
   Component: MEM-FS        H07 0077
   Revision: AA000000    Serial number: 00000153085367
   Coding: C1581B000F0000000000
   VCID: 43D3B271BB92292F2FA-8016
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Component: SWA Master    H05 0071
   Serial number: 0374769434
   Coding: 010211
   Shop #: WSC 06334 000 00000
   VCID: 3FDBBE81D7FA4DCF4B2-806A
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
   Component: SWA Slave  H05 0071
   Serial number: 0374837545
   Coding: 010211
   Component: TSG FA        H02 0511
   Revision:             Serial number: 0000158699036
   Coding: 011D13215E00440004
   VCID: 4FFB8E4167DADD4FBB2-801A
   Part No SW: 8R0 909 144 P    HW: 8R0 909 144 B
   Component: RCEPS         H43 0510
   Revision: 00001000    Serial number: 0010016624
   Coding: 100000010001
   ASAM Dataset: EV_RCEPSAU48X 008018
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 45D7AC69B526171F01E-8010
   Revision: 00002001    Serial number: 0374391760
   Coding: 0126023A20FA709784A0053A20040047
   Shop #: WSC 06334 123 12345
   Component: GTO BF  H01 0080
   Serial number: 00000000000001027333
   Subsystem 3 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H04 0090
   Subsystem 4 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H04 0090
   Revision: 00005001    Serial number: 94813047092507
   VCID: 2D07F4C90D16CF5FE9E-8078
   Component: TSG BF        H02 0511
   Revision:             Serial number: 0000158966212
   VCID: 4EC5934560D0D447B04-801A
   Part No SW: 8K0 907 801 N    HW: 8K0 907 801 J
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 00000001692332
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A2DCF95CCD868E77CC-806E
   Component: Radio U SIRIU H66 0133
   Revision: AB001007    Serial number: 156G20F8295245
   Coding: 020007010000000001
   VCID: 241111ED5EDC0E17360-8070
   Part No SW: 8R1 035 746 H    HW: 8R1 035 746 G
   Component: H-BNT-NA      H43 0937
   Revision: --------    Serial number: 523G 0F7577400
   Coding: 160200060005A1EF55028B5E00000403140000000000000000
   VCID: 3C21C98DC66C56D76E0-8068
   Subsystem 1 - Part No: 8R0 060 884 CS
   Component: NAR 2015  1201
   Component: DU7 High  H42 0104
   Serial number: A130GR0F3415309
   Serial number: 00000002310507
   Component: CD-Database  6208
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000158943507
   Coding: 010C13204000240004
   VCID: 46D5AB6588A01C07084-8012
Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
   Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
   Component: Anhaenger     H12 0100
   Revision: 1A001001    Serial number: 00000410004278
   Coding: 0200000000000000
   VCID: 3635DBA5F8408C87984-8062
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H09---    Serial number: 525PA8-JA5A179
   Coding: 1010010
   VCID: 3431E1ADE23C9E97A60-8060
   Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
   Component: J605  Master  H56 0330
   Revision: --------    Serial number: 8R0827851D
   VCID: 3D27C489DD765FDF59E-8068
   Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
   Component: J756  Slave  H56 0330
   Serial number: 8R0827852D
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000158775725
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 151841820
   ROD: EV_RDCMA00100_008.rod
   VCID: 2F3BEEC1079ABD4FDB2-807A
End----(Elapsed Time: 02:16, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
