Matrix LED Basic settings
gabrjel
Luxembourg
C?ID=306473
Hi
I readjusted my front beams.
After Basic settings there are as I wanted (higher).
But I got issue with Matrix LEDs
   Part No SW: 4H4 907 357 D    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0081
   Coding: 04FA02202A170A00
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005003
   VCID: 33301665EBBE72EFBFA-8066
   Coding: E01F00
   Coding: E01F00
   Matrix Headlamp Powermodule 1 Left:
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo li.  H03 0031
   Coding: E01F00
   Matrix Headlamp Powermodule 1 Right:
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo re.  H03 0031
   Coding: E01F00
5350720 - Left Matrix High Beam
          C1175 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 196
5350976 - Right Matrix High Beam
          C1176 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 196
MasterTommy
Amsterdam
C?ID=295586
Is there an ‘acknowledge basic setting’ channel in those control units? If so, run that once.
gabrjel
Luxembourg
C?ID=306473
Sure it's working for High Beam but not for Matrix LED.
Error above is not gone after Basic Settings, and Acknowledge Settings...
gabrjel
Luxembourg
C?ID=306473
Finally service made a magic for 80€....
Pity that I need to spent money on service than doing the stuff with Ross Tech Cable....
notch
CZ
C?ID=337903
Same issue here. Do you have any details regarding the "magic"?
gabrjel
Luxembourg
C?ID=306473
Yes go to service.... no one except service knows how to do it... or don't want to know
