Edition 30, can someone please explain how to check boost logs!!!
Edition30#1536
C?ID=326067
Edition 30 recently fitted a anti surge turbo core, so needed to take the actuator off to split the unit itself. Could somebody please tell me how to check n75 is within it values? Also actual boost pressure & anything else I need to check?
Thanks guy's đź‘Ť
This car?
MVB 115.3 should be specified manifold pressure (what the ECU is requesting from the turbo).
MVB 115.4 should be actual manifold pressure (what the ECU is measuring)
Edition30#1536
C?ID=326067
Thanks for your reply, it's a golf gti edition 30 2.0 tfsi
Doesn't mean anything to me. ECU ID data is the only thing that's really definitive.
Edition30#1536
C?ID=326067
Auto scan below thanks you.
Wednesday,18,April,2018,18:06:53:34064
VIN: WVWZZZ1K   License Plate:
Chassis Type: 1K-VW35 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72 76 77
VIN: WVWZZZ1K   Mileage: 154980km-96300miles
   Part No SW: 1K0 907 115 T    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0010
   Revision: 5BH16---    Serial number: VWX7Z0GN3N58CF
   Coding: 040300031C070160
   Shop #: WSC 08708 803 00000
   VCID: 372ADBFEC345D5BF832-8062
Readiness: 0110 0101
   Part No SW: 02E 300 050 H    HW: 02E 927 770 AD
   Component: GSG DSG         082 1401
   Revision: 04808020    Serial number: 00000909040219
   Shop #: WSC 04940 001 00001
   VCID: 176A3B7EA385F5BFA32-8042
   Revision: 00H11001
   Coding: 0004738
   Shop #: WSC 01279 785 00200
   VCID: 73B22FEE97BD799F7FA-8026
   Part No SW: 1K0 907 044 CQ    HW: 1K0 907 044 CQ
   Component: ClimatronicPQ35 130 1212
   Revision: 00130022    Serial number: 00000000000000
   VCID: 78A818C28EDB1AC74A8-802C
   Revision: 00H54000    Serial number: 01000007715789
   Coding: E58D8F2700041500471400001400000000087F075C000100000000000000
   Shop #: WSC 00000 785 00200
   VCID: 71BE25E6EDA14B8F8D6-8024
   Component: Wischer 301007 021  0501
   Coding: 00038805
   Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
   Component: RLS     051107 046  0204
   Coding: 00208933
   Component: 38 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1JZW5C
   Coding: 0013112
   Shop #: WSC 01269 785 00200
   VCID: 3D26C9D6E179FFEF59E-8068
   Subsystem 1 - Serial number: 6332MSME3334644CA
   Subsystem 2 - Serial number: 6342MSME34040D130
   Subsystem 3 - Serial number: 6352QSME3F334303B
   Subsystem 4 - Serial number: 6362QSME3C501B75M
   Part No SW: 1K0 953 549 BG    HW: 1K0 953 549 BG
   Component: J0527           051 0100
   Coding: 0012122
   Part No SW: 1K6 920 974     HW: 1K6 920 974
   Component: KOMBIINSTRUMENT VDD 1216
   Revision: V0002000    Serial number: VWX7Z0GN3N58CF
   Coding: 0003403
   Shop #: WSC 01286 386 08256
   Component: J533  Gateway   H07 0052
   Revision:   H07 01    Serial number: 221007F1000867
   Coding: ED807F0E4006020003
   VCID: 3038E0E2262B0287C28-8064
   Component: IMMO            VDD 1216
   Shop #: WSC 00137 211 56823
00003 - Control Module
            014 - Defective
                    Fault Status: 01101110
                    Mileage: 149841 km
                    Time: 14:17:16
   Part No SW: 1T0 035 680 L    HW: 1T0 035 680 AX
   Component: RNS-MID       H04 5238
   Revision: AB001001    Serial number: VWZ6Z7G7318093
   Coding: 06000400040000120000
   Shop #: WSC 00671 210 95609
   VCID: 372ADBFECF45D5BF832-8062
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V14  8477
   Part No SW: 1K0 959 701 N    HW: 1K0 959 701 N
   Component: Tuer-SG         006 1204
   Coding: 0000694
   VCID: 392EDDC6F551C3CF756-806C
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.074 H08 1901
   Shop #: WSC 00000 028 00001
   VCID: 3634D6FAC44F2CB7984-8062
   Coding: 819002005103087F2D04840D7008DFC690FC00
   VCID: 03527F2EC71D491F6FA-8056
   Component: LIN BACKUP HORN H07 9001
   Subsystem 2 - Part No: 1K0 951 178 A
   Component: Neigungssensor  003 0203
   Subsystem 3 - Part No: 1K0 951 178 A
   Component: Innenraumueberw.003 0203
   Part No SW: 1K0 959 702 N    HW: 1K0 959 702 N
   Component: Tuer-SG         006 1220
   Coding: 0000950
   VCID: 3A2CC2CAF057C8D77CC-806E
   Component: Tuer-SG         006 1207
   Coding: 0000144
   Shop #: WSC 01279 785 1012552
   VCID: 3828D8C2CE5BDAC78A8-806C
   Component: Tuer-SG         006 1201
   Coding: 0000144
Address 76: Park Assist        Labels: 1K0-919-283.lbl
   Part No: 1K0 919 283 A
   Component: 22 Einparkhilfe     0101
   VCID: 2D06F99631196F6FE9E-8078
   Part No SW: 7P6 035 730 J    HW: 7P6 035 730 J
   Revision: 1B001001    Serial number: 00007663655809
   Coding: 0201000000010110
   Shop #: WSC 71912 210 94665
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 392EDDC6F9D1C3CF756-806C
End----------(Elapsed Time: 01:24, VBatt start/end: 12.2V/12.2V)-----------
Yep, same car I liked to above. Instructions I posted above apply.
