Q7 4L US to UK tail lights
toolman617
C?ID=154292
Working on this for a friend who took their 2015 Q7 with them when they moved from the US to the UK. Everything was fine except for the tail light indicators, which need to be orange instead of red. I did some research, and it seems like just changing the coding in module 46 (comfort) to non-SAE won't do the trick (I tried). It would appear that either a) it's not doable without swapping tail lights, or b) it requires some more coding in the adaptation. When said friend took it to the Audi dealer in the UK, they said it was only a coding change, and that the tail lights were the same part number for both US and UK. Problem was they didn't know how to do the coding change (not sure how that's a thing, but whatever). The closest thing I could find here was this thread, which was for a B8 A4 and a few years ago. Anyone aware of if this is possible, and if so, what adaptation changes need to be done? I'd set out on trying to figure them out myself, but I haven't the slightest clue on how those numbers in the referenced thread are calculated or discovered. Or what the security code is.
PetrolDave
Westbury, UK
C?ID=1423
Please post an Auto-Scan of your friends Q7, without that we don't know what module hardware & software it has which makes any suggestions pure guesswork.
There are many VCDS owners in the UK, so if they sign-up to a Q7 or Audi owners website they can get the Auto-Scan done for beer tokens :D
toolman617
C?ID=154292
Scan below. There are a lot of DTCs in there because his battery was disconnected in shipping.
Wednesday,18,April,2018,17:03:11:61023
VIN: WA1LGAFE7FD007766   License Plate:
Mileage: 51490km-31994mi   Repair Order:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3C 42 46 47 4C 4F 52
          55 56 5F 62 6C 6D 6F 72
VIN: WA1LGAFE7FD007766   Mileage: 51490km-31994miles
4C-Tire Pressure II -- Status: Malfunction 0010
Address 01: Engine (CTW)       Labels: None
   Part No SW: 4L0 910 551 P    HW: 4L0 907 551 A
   Component: 3.0l V6 TFSI        0030
   Revision: --H08---    Serial number:
   Coding: 0121000A290F0128
   Shop #: WSC 31414 790 00001
   VCID: 3537DC19294F935F91E-8060
004260 - Intake Air Regulating Flap
               P10A4 - 000 - Mechanical Malfunction - Intermittent
                    Mileage: 51228 km
                    Date: 2017.11.09
                    Time: 16:09:56
                    RPM: 96 /min
                    Absolute Pres.: 1000.2 mbar
                    (no units): 0.00
                    (no units): 25.42
                    Voltage: 1.800 V
                    (no units): 100.0
               U1017 - 000 -  - Intermittent
                    Mileage: 51228 km
                    Date: 2018.01.25
                    Time: 16:27:50
                    RPM: 1408 /min
                    Mass Air / Rev.: 261.6 mg/str
                    Temperature: 7.5°C
                    Bin. Bits: 00000010
                    Load: 20.4 %
   Part No SW: 0C8 927 750 N    HW: 0C8 927 750 N
   Component: AL1000 AISIN  002 2441
   Coding: 001378
   Shop #: WSC 10396 002 1048576
   ROD: EV_TCMAL991031_002.rod
   VCID: 372BD6113FC3614F832-8062
   Revision: 00H02001
   Coding: 0099409
   VCID: 3431E11D22358A57A60-8060
            000 -  -  - Intermittent
                    Reset counter: 137
                    Mileage: 51228 km
                    Count: 192
                    Count: 9025
                    Count: 297
                    Count: 36096
                    Reset counter: 102
                    Mileage: 51228 km
                    Date: 2018.01.25
                    Time: 10:47:18
                    Count: 10305
                    Count: 128
                    Count: 25344
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 H
   Component: FBSAUDIC6 ELV   H08 0210
   Revision: 00H08000    Serial number: 10603902158545
   Coding: 0000135
   VCID: 25170C5999EFE3DF21E-8070
   Component: FBSAUDIC6 EZS   H04 0020
7 Faults Found:
00191 - Passenger's Door Handle Touch Sensor (G416)
                    Fault Status: 00110111
                    Fault Frequency: 7
                    Reset counter: 135
                    Mileage: 41882 km
                    Date: 2017.05.17
                    Time: 11:22:39
                    Fault Frequency: 13
                    Reset counter: 135
                    Fault Status: 00111011
                    Fault Frequency: 7
                    Reset counter: 33
                    Mileage: 41882 km
                    Date: 2017.05.17
                    Time: 11:47:23
00230 - Transmission Park Selector Switch (F305)
                    Fault Status: 00101010
                    Reset counter: 160
                    Mileage: 42277 km
                    Date: 2017.05.25
                    Time: 16:47:31
00532 - Supply Voltage B+
                    Reset counter: 135
                    Mileage: 51228 km
                    Date: 2018.01.25
                    Time: 10:48:13
                    Reset counter: 136
                    Mileage: 51228 km
                    Date: 2018.01.05
                    Time: 11:25:45
00447 - Function Limitation due to Over-Voltage
                    Fault Status: 00100001
                    Reset counter: 136
                    Mileage: 51228 km
                    Date: 2013.02.27
                    Time: 00:18:49
   Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AP
   Revision: 00---031    Serial number: 00000000445422
   Coding: 000AC026
   VCID: 25170C5995EFE3DF21E-8070
   Part No SW: 4F0 910 279 AG    HW: 4F0 907 279 C
   Component: ILM Fahrer      H31 0400
   Coding: 0139123
   VCID: 6E8533750C99E087904-803A
   Component: Wischer AU716   H18 0110
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
                    Reset counter: 136
                    Mileage: 51228 km
                    Date: 2013.02.27
                    Time: 00:12:00
Address 10: Park/Steer Assist (J446)       Labels:| 4L0-919-475-7X2.clb
   Part No SW: 4L0 919 475 A    HW: 4H0 919 475 C
   Component: PARKHILFE 8K  H07 0011
   Revision: 11001001    Serial number: 55961424401195
   Coding: 24011E
   ASAM Dataset: EV_EPHVA18AU7160000 001001
   ROD: EV_EPHVA18AU7160000.rod
   VCID: 3431E11D2EB58A57A60-8060
   Component: 73 AIRBAG AUDI8RH45 0230
   Revision: 09H45000    Serial number: 0038QD90A80Y
   Coding: 0014131
   VCID: 2B03FA61FF0BD5AFF7A-807E
   Subsystem 1 - Part No: 4L0 959 339 C
   Component: BF-Gewichtsens. H05 0040
   Subsystem 2 - Serial number: 6332QSME4E441478L
   Subsystem 3 - Serial number: 6342QSME4E443864N
   Subsystem 4 - Serial number: 6352QSME644224504
   Subsystem 5 - Serial number: 6362QSME544434428
   Subsystem 6 - Serial number: 63734SME7944537A7
   Subsystem 7 - Serial number: 63834SME7F442978F
   Part No SW: 4F0 910 549 B    HW: 4F0 953 549 E
   Component: J0527               0830
   Revision: 00H09000    Serial number: 90026142190149
   Coding: 0012042
   VCID: 2809056DEEFDFEB71A8-807C
   Component: E0221           H03 0040
                    Reset counter: 40
                    Mileage: 51228 km
                    Date: 2018.01.25
                    Time: 10:47:18
                    Reset counter: 40
                    Mileage: 51228 km
                    Date: 2018.01.25
                    Time: 10:48:13
                    Reset counter: 136
                    Mileage: 51228 km
                    Date: 2013.02.27
                    Time: 00:18:51
   Part No SW: 4L0 920 985 S    HW: 4L0 920 985 S
   Component: KOMBIINSTR.   H35 0332
   Revision: 00000000    Serial number: X2R42L89F
   Coding: 8BD663040100CF05020205
   VCID: 44D1B1DD7E953AD7160-8010
                    Reset counter: 136
                    Mileage: 51228 km
                    Date: 2013.02.27
                    Time: 00:02:15
                    Reset counter: 136
                    Mileage: 51228 km
                    Date: 2013.02.27
                    Time: 00:02:17
   Part No SW: 4F0 907 468 S    HW: 4F0 907 468 G
   Component: GW-BEM 5CAN-M H06 0058
   Revision: MB800038    Serial number: 3800M14819005E
   Coding: 00C303
   VCID: 3FDBBE311773590F4B2-806A
   Component: J367-BDM  H07 0125
   Serial number: 31230J49474121635334
02256 - Quiescent Current
                    Fault Frequency: 111
                    Reset counter: 134
                    Mileage: 43828 km
                    Date: 2017.05.27
                    Time: 16:26:00
                    Fault Frequency: 126
                    Reset counter: 102
                    Mileage: 43828 km
                    Date: 2017.05.27
                    Time: 19:26:00
                    Bin. Bits:    00000
                    Voltage: 12.40 V
                    Count: 18
                    Reset counter: 135
                    Mileage: 51228 km
                    Date: 2018.01.25
                    Time: 10:48:14
                    Bin. Bits:    00000
                    Voltage: 5.70 V
                    Count: 12
   Part No SW: 4L0 910 158     HW: 4L0 919 158 AD
   Revision: 00---011    Serial number: 00000030349427
   Coding: 0000006
   VCID: 6889456D2E7D3EB7DA8-803C
00003 - Control Module
                    Fault Status: 00100011
                    Mileage: 44317 km
                    Date: 2017.06.08
                    Time: 08:20:52
   Part No SW: 4F0 959 760 D    HW: 4F0 959 760 D
   Component: MEM-FS        H08 0065
   Revision: AA000000    Serial number: 00000114286488
   Coding: 00581B00000011110000
   VCID: 323DE705D4218467B4C-8066
                    Reset counter: 135
                    Mileage: 51228 km
                    Date: 2018.01.25
                    Time: 10:48:13
   Component: J0769_SWA_MasterH03 0050
   Revision: 00H03000    Serial number: 6PZ 009 014-10
   VCID: 2E05F375CC19A087D04-807A
   Component: J0770_SWA_Slave_H03 0050
   Subsystem 3 - Serial number: 5F12.08.1400H03000AMS15189ÿ
   Subsystem 4 - Serial number: S15189ÿ
   Component: TSG FA        H12 0362
   Revision:             Serial number: 0000116021217
   Coding: 011F57205E40440004
   VCID: 48C9A5ED42BD1EB7FA8-801C
01705 - Selection Switch for Mirror-Adjust (E48)
                    Reset counter: 114
                    Mileage: 50981 km
                    Date: 2017.10.11
                    Time: 07:57:18
                    Reset counter: 135
                    Mileage: 51228 km
                    Date: 2018.01.25
                    Time: 10:47:21
                    Reset counter: 136
                    Mileage: 51228 km
                    Date: 2013.02.27
                    Time: 00:18:53
   Part No SW: 4L0 910 289 K    HW: 4L0 907 289 K
   Component: Komfortgeraet   H12 0130
   Revision: 0130 ---    Serial number: 82007933360000
   Coding: 3565853
   VCID: 3829D52D3E5D6E378A8-806C
                    Reset counter: 136
                    Mileage: 51228 km
                    Date: 2013.02.27
                    Time: 00:00:02
01134 - Alarm Horn (H12)
                    Reset counter: 136
                    Mileage: 51228 km
                    Date: 2013.02.27
                    Time: 00:00:03
Address 47: Sound System
   Part No SW: 4F0 910 274 B    HW: 4F0 907 274
   Component: J793  RKA+      H04 0110
   Revision: 00000519    Serial number: 00005191068227
   Coding: 0693965
   VCID: 2313124197DB1DEF4FA-8076
                    Fault Status: 00101101
                    Reset counter: 137
                    Mileage: 51228 km
                    Date: 2018.01.05
                    Time: 11:18:03
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0001
                    Voltage: 9.40 V
                    Temperature: 12.0°C
                    (no units): 0.0
                    Reset counter: 137
                    Mileage: 51228 km
                    Date: 2017.12.28
                    Time: 16:03:30
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0001
                    Voltage: 10.50 V
                    Temperature: 12.0°C
                    (no units): 0.0
   Component: ILM Beifahrer   H16 0100
   Revision:             Serial number: 00000000195555
   Coding: 0012001
   VCID: 5EE563B5FC397007204-800A
                    Fault Status: 00110010
                    Reset counter: 135
                    Mileage: 51228 km
                    Date: 2018.01.25
                    Time: 10:48:00
                    Voltage: 6.100 V
                    Temperature: 14.0°C
                    Reset counter: 135
                    Mileage: 51228 km
                    Date: 2018.01.25
                    Time: 10:47:00
                    Voltage: 6.300 V
                    Temperature: 14.0°C
                    Reset counter: 136
                    Mileage: 51228 km
                    Date: 2013.02.27
                    Time: 00:18:00
                    Voltage: 17.300 V
                    Temperature: 77.0°C
   Component: TSG BF        H12 0362
   Revision:             Serial number: 0000115359815
   VCID: 47CBA6D14FA311CFF32-8012
                    Fault Frequency: 47
                    Reset counter: 102
                    Mileage: 43540 km
                    Date: 2017.05.26
                    Time: 22:11:10
                    Reset counter: 135
                    Mileage: 51228 km
                    Date: 2018.01.25
                    Time: 10:47:21
                    Reset counter: 136
                    Mileage: 51228 km
                    Date: 2013.02.27
                    Time: 00:04:19
   Serial number: 140908-0002-011
   Coding: 1147A71010020400
   ROD: EV_HeadlRegulBasic.rod
   VCID: 42DDB7C5640134E724C-8016
0079 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [Fehlerhaftes Signal in CAN-Message mBremse_3 (0x4A0)]
                    Reset counter: 136
                    Mileage: 51228 km
                    Date: 2013.02.27
                    Time: 00:00:03
764928 - Left/Right Driving Switch-Over Active
          C1080 00 [009] -  -
                    Reset counter: 101
                    Mileage: 51484 km
                    Date: 2013.03.26
                    Time: 00:56:14
Address 56: Radio
   Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
   Component: TSG HL        H11 0362
   Revision:             Serial number: 0000116988983
   Coding: 010E57204040230004
   VCID: 46D5ABD548A908C7084-8012
                    Reset counter: 135
                    Mileage: 51228 km
                    Date: 2018.01.25
                    Time: 10:47:20
                    Reset counter: 136
                    Mileage: 51228 km
                    Date: 2013.02.27
                    Time: 00:18:52
   Revision: --H09---    Serial number: 525PA8-J4840KB
   Coding: 1021201
                    Reset counter: 135
                    Mileage: 51228 km
                        Reverse OFF
                    Count: 3
                    Reset counter: 135
                    Mileage: 51228 km
                        Reverse OFF
                    Count: 3
                    Reset counter: 136
                    Mileage: 51228 km
                    Date: 2013.02.27
                    Time: 00:18:46
                        Term 15 Off
                        Reverse OFF
                    Count: 3
   Part No SW: 4L0 910 945     HW: 4L0 827 851 F
   Component: ValeoHeckdeckel H58 0500
   Revision: --H58001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6C81397D3A851297BE0-8038
   Subsystem 2 - Serial number: 4ó
   Subsystem 3 - Serial number: RD04.09.14--H58001002G0258ÿ
   Subsystem 4 - Serial number: 2G0258ÿ
02242 - Rear Lid Lock Button in Luggage Compartment (E406)
                    Reset counter: 124
                    Mileage: 51051 km
                    Date: 2017.10.14
                    Time: 16:41:34
   Component: ILM HINTEN 2    H08 0080
   Revision: AAH08080    Serial number: 0114947545----
   Coding: 0003595
   VCID: 26150B55E4E9E8C7284-8072
   Component: J_245_EE16_SKB10H15 0220
   Component: J_394_EE16_SKB10H15 0220
   Component: J_392_EE16_SKB10H15 0220
                    Reset counter: 135
                    Mileage: 51228 km
                    Date: 2018.01.25
                    Time: 10:48:13
   Component: TSG HR        H11 0362
   Revision:             Serial number: 0000116989214
                    Reset counter: 135
                    Mileage: 51228 km
                    Date: 2018.01.25
                    Time: 10:47:21
                    Reset counter: 136
                    Mileage: 51228 km
                    Date: 2013.02.27
                    Time: 00:18:52
End----(Elapsed Time: 02:07, VBatt start/end: 10.6V/10.5V. VIgn 10.5V)-----
rlarsen
Copenhagen, Denmark
C?ID=78998
Can you create a Controller Channels Map - choose CSV as output, and post it here ?? - because it is there the changes need to be made.
And Yes, you need new RoW tail lights, because the NA are with red signals, and RoW with yellow signals.
Maybe you also need to do some re-wiring - depending on how many pins you have access to.
I don’t have access to the wiring diagram, so I can’t help here.
toolman617
C?ID=154292
Is there a way to tell what code I need to log in? The 12345 referenced in your linked process doesn't work.
rlarsen
Copenhagen, Denmark
C?ID=78998
If you mean the thread you link to your self, then the login code is written as "Login code to unit 46 is: 16017" in post #8 - and again in post #10
toolman617
C?ID=154292
Sorry, the login code for the controller channels map.
