Wednesday,18,April,2018,17:03:11:61023
VCDS Version: 18.2.0.3 (x64) HEX-V2 CB: 0.4411.4
VIN: WA1LGAFE7FD007766 License Plate:
Mileage: 51490km-31994mi Repair Order:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3C 42 46 47 4C 4F 52
55 56 5F 62 6C 6D 6F 72
VIN: WA1LGAFE7FD007766 Mileage: 51490km-31994miles
4C-Tire Pressure II -- Status: Malfunction 0010
Address 01: Engine (CTW) Labels: None
Part No SW: 4L0 910 551 P HW: 4L0 907 551 A
Component: 3.0l V6 TFSI 0030
Revision: --H08--- Serial number:
Coding: 0121000A290F0128
Shop #: WSC 31414 790 00001
VCID: 3537DC19294F935F91E-8060
004260 - Intake Air Regulating Flap
P10A4 - 000 - Mechanical Malfunction - Intermittent
Mileage: 51228 km
Date: 2017.11.09
Time: 16:09:56
RPM: 96 /min
Absolute Pres.: 1000.2 mbar
(no units): 0.00
(no units): 25.42
Voltage: 1.800 V
(no units): 100.0
053271 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 - 000 - - Intermittent
Mileage: 51228 km
Date: 2018.01.25
Time: 16:27:50
RPM: 1408 /min
Mass Air / Rev.: 261.6 mg/str
Temperature: 7.5°C
Bin. Bits: 00000010
Load: 20.4 %
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 N HW: 0C8 927 750 N
Component: AL1000 AISIN 002 2441
Coding: 001378
Shop #: WSC 10396 002 1048576
ASAM Dataset: EV_TCMAL991031 002112
ROD: EV_TCMAL991031_002.rod
VCID: 372BD6113FC3614F832-8062
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 0099409
VCID: 3431E11D22358A57A60-8060
Reset counter: 137
Mileage: 51228 km
Count: 192
Count: 9025
Count: 297
Count: 36096
Reset counter: 102
Mileage: 51228 km
Date: 2018.01.25
Time: 10:47:18
Count: 10305
Count: 128
Count: 25344
Part No SW: 4F0 910 852 B HW: 4F0 905 852 H
Component: FBSAUDIC6 ELV H08 0210
Revision: 00H08000 Serial number: 10603902158545
Coding: 0000135
VCID: 25170C5999EFE3DF21E-8070
Subsystem 1 - Part No: 4F0 910 132 L
Component: FBSAUDIC6 EZS H04 0020
Subsystem 2 - Part No: 4F0 910 335 B
Component: FBSAUDIC6 KSG H03 0020
7 Faults Found:
00191 - Passenger's Door Handle Touch Sensor (G416)
Fault Status: 00110111
Fault Frequency: 7
Reset counter: 135
Mileage: 41882 km
Date: 2017.05.17
Time: 11:22:39
00193 - Rear Right Door Handle Touch Sensor (G418)
Fault Frequency: 13
Reset counter: 135
Fault Status: 00111011
Fault Frequency: 7
Reset counter: 33
Mileage: 41882 km
Date: 2017.05.17
Time: 11:47:23
00230 - Transmission Park Selector Switch (F305)
Fault Status: 00101010
Reset counter: 160
Mileage: 42277 km
Date: 2017.05.25
Time: 16:47:31
00532 - Supply Voltage B+
Reset counter: 135
Mileage: 51228 km
Date: 2018.01.25
Time: 10:48:13
Reset counter: 136
Mileage: 51228 km
Date: 2018.01.05
Time: 11:25:45
Fault Status: 00100001
Reset counter: 136
Mileage: 51228 km
Date: 2013.02.27
Time: 00:18:49
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AP
Component: KLIMA 4 ZONEN H15 0070
Revision: 00---031 Serial number: 00000000445422
Coding: 000AC026
VCID: 25170C5995EFE3DF21E-8070
Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C
Component: ILM Fahrer H31 0400
Coding: 0139123
VCID: 6E8533750C99E087904-803A
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H18 0110
Coding: 00064792
Shop #: WSC 31414
Coding: 00150059
Shop #: WSC 31414
Reset counter: 136
Mileage: 51228 km
Date: 2013.02.27
Time: 00:12:00
Address 10: Park/Steer Assist (J446) Labels:| 4L0-919-475-7X2.clb
Part No SW: 4L0 919 475 A HW: 4H0 919 475 C
Component: PARKHILFE 8K H07 0011
Revision: 11001001 Serial number: 55961424401195
Coding: 24011E
ASAM Dataset: EV_EPHVA18AU7160000 001001
ROD: EV_EPHVA18AU7160000.rod
VCID: 3431E11D2EB58A57A60-8060
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH45 0230
Revision: 09H45000 Serial number: 0038QD90A80Y
Coding: 0014131
VCID: 2B03FA61FF0BD5AFF7A-807E
Subsystem 1 - Part No: 4L0 959 339 C
Component: BF-Gewichtsens. H05 0040
Subsystem 2 - Serial number: 6332QSME4E441478L
Subsystem 3 - Serial number: 6342QSME4E443864N
Subsystem 4 - Serial number: 6352QSME644224504
Subsystem 5 - Serial number: 6362QSME544434428
Subsystem 6 - Serial number: 63734SME7944537A7
Subsystem 7 - Serial number: 63834SME7F442978F
Part No SW: 4F0 910 549 B HW: 4F0 953 549 E
Component: J0527 0830
Revision: 00H09000 Serial number: 90026142190149
Coding: 0012042
VCID: 2809056DEEFDFEB71A8-807C
Component: E0221 H03 0040
Reset counter: 40
Mileage: 51228 km
Date: 2018.01.25
Time: 10:47:18
Reset counter: 40
Mileage: 51228 km
Date: 2018.01.25
Time: 10:48:13
Reset counter: 136
Mileage: 51228 km
Date: 2013.02.27
Time: 00:18:51
Address 17: Instruments (J285) Labels:. 4L0-920-xxx-17.clb
Part No SW: 4L0 920 985 S HW: 4L0 920 985 S
Component: KOMBIINSTR. H35 0332
Revision: 00000000 Serial number: X2R42L89F
Coding: 8BD663040100CF05020205
VCID: 44D1B1DD7E953AD7160-8010
01316 - ABS Control Module
Reset counter: 136
Mileage: 51228 km
Date: 2013.02.27
Time: 00:02:15
Reset counter: 136
Mileage: 51228 km
Date: 2013.02.27
Time: 00:02:17
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 S HW: 4F0 907 468 G
Component: GW-BEM 5CAN-M H06 0058
Revision: MB800038 Serial number: 3800M14819005E
Coding: 00C303
VCID: 3FDBBE311773590F4B2-806A
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 31230J49474121635334
02256 - Quiescent Current
Fault Frequency: 111
Reset counter: 134
Mileage: 43828 km
Date: 2017.05.27
Time: 16:26:00
Fault Frequency: 126
Reset counter: 102
Mileage: 43828 km
Date: 2017.05.27
Time: 19:26:00
Bin. Bits: 00000
Voltage: 12.40 V
Count: 18
Reset counter: 135
Mileage: 51228 km
Date: 2018.01.25
Time: 10:48:14
Bin. Bits: 00000
Voltage: 5.70 V
Count: 12
Part No SW: 4L0 910 158 HW: 4L0 919 158 AD
Component: KLIMABETAETIGUNGH06 0060
Revision: 00---011 Serial number: 00000030349427
Coding: 0000006
VCID: 6889456D2E7D3EB7DA8-803C
00003 - Control Module
Fault Status: 00100011
Mileage: 44317 km
Date: 2017.06.08
Time: 08:20:52
Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
Component: MEM-FS H08 0065
Revision: AA000000 Serial number: 00000114286488
Coding: 00581B00000011110000
VCID: 323DE705D4218467B4C-8066
Reset counter: 135
Mileage: 51228 km
Date: 2018.01.25
Time: 10:48:13
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 C HW: 4L0 907 566 B
Component: J0769_SWA_MasterH03 0050
Revision: 00H03000 Serial number: 6PZ 009 014-10
Coding: 0000001
VCID: 2E05F375CC19A087D04-807A
Subsystem 1 - Part No: 4L0 910 568 C
Component: J0770_SWA_Slave_H03 0050
Subsystem 2 - Serial number: 6PZ 009 014-30
Subsystem 3 - Serial number: 5F12.08.1400H03000AMS15189ÿ
Subsystem 4 - Serial number: S15189ÿ
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0000116021217
Coding: 011F57205E40440004
VCID: 48C9A5ED42BD1EB7FA8-801C
01705 - Selection Switch for Mirror-Adjust (E48)
Fault Frequency: 6
Reset counter: 114
Mileage: 50981 km
Date: 2017.10.11
Time: 07:57:18
Reset counter: 135
Mileage: 51228 km
Date: 2018.01.25
Time: 10:47:21
Reset counter: 136
Mileage: 51228 km
Date: 2013.02.27
Time: 00:18:53
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 K HW: 4L0 907 289 K
Component: Komfortgeraet H12 0130
Revision: 0130 --- Serial number: 82007933360000
Coding: 3565853
VCID: 3829D52D3E5D6E378A8-806C
Reset counter: 136
Mileage: 51228 km
Date: 2013.02.27
Time: 00:00:02
01134 - Alarm Horn (H12)
Reset counter: 136
Mileage: 51228 km
Date: 2013.02.27
Time: 00:00:03
Address 47: Sound System
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 B HW: 4F0 907 274
Component: J793 RKA+ H04 0110
Revision: 00000519 Serial number: 00005191068227
Coding: 0693965
VCID: 2313124197DB1DEF4FA-8076
Fault Status: 00101101
Reset counter: 137
Mileage: 51228 km
Date: 2018.01.05
Time: 11:18:03
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0001
Voltage: 9.40 V
Temperature: 12.0°C
(no units): 0.0
Reset counter: 137
Mileage: 51228 km
Date: 2017.12.28
Time: 16:03:30
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0001
Voltage: 10.50 V
Temperature: 12.0°C
(no units): 0.0
Part No SW: 4F0 910 280 HW: 4F0 907 280 D
Component: ILM Beifahrer H16 0100
Revision: Serial number: 00000000195555
Coding: 0012001
VCID: 5EE563B5FC397007204-800A
Fault Status: 00110010
Reset counter: 135
Mileage: 51228 km
Date: 2018.01.25
Time: 10:48:00
Voltage: 6.100 V
Temperature: 14.0°C
Reset counter: 135
Mileage: 51228 km
Date: 2018.01.25
Time: 10:47:00
Voltage: 6.300 V
Temperature: 14.0°C
Reset counter: 136
Mileage: 51228 km
Date: 2013.02.27
Time: 00:18:00
Voltage: 17.300 V
Temperature: 77.0°C
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0362
Revision: Serial number: 0000115359815
VCID: 47CBA6D14FA311CFF32-8012
Fault Status: 01101100
Fault Frequency: 47
Reset counter: 102
Mileage: 43540 km
Date: 2017.05.26
Time: 22:11:10
Reset counter: 135
Mileage: 51228 km
Date: 2018.01.25
Time: 10:47:21
Reset counter: 136
Mileage: 51228 km
Date: 2013.02.27
Time: 00:04:19
Part No SW: 8X0 907 357 C HW: 8X0 907 357 B
Serial number: 140908-0002-011
Coding: 1147A71010020400
ROD: EV_HeadlRegulBasic.rod
VCID: 42DDB7C5640134E724C-8016
0079 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[Fehlerhaftes Signal in CAN-Message mBremse_3 (0x4A0)]
Reset counter: 136
Mileage: 51228 km
Date: 2013.02.27
Time: 00:00:03
764928 - Left/Right Driving Switch-Over Active
C1080 00 [009] - -
Reset counter: 101
Mileage: 51484 km
Date: 2013.03.26
Time: 00:56:14
Address 56: Radio
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0362
Revision: Serial number: 0000116988983
Coding: 010E57204040230004
VCID: 46D5ABD548A908C7084-8012
Reset counter: 135
Mileage: 51228 km
Date: 2018.01.25
Time: 10:47:20
Reset counter: 136
Mileage: 51228 km
Date: 2013.02.27
Time: 00:18:52
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 B HW: 4L0 907 441 B
Component: J772__Rearview 0030
Revision: --H09--- Serial number: 525PA8-J4840KB
Coding: 1021201
Reset counter: 135
Mileage: 51228 km
Term 15 On
Reverse OFF
Count: 3
Reset counter: 135
Mileage: 51228 km
Term 15 On
Reverse OFF
Count: 3
Reset counter: 136
Mileage: 51228 km
Date: 2013.02.27
Time: 00:18:46
Term 15 Off
Reverse OFF
Count: 3
Address 6D: Trunk Elect. Labels: None
Part No SW: 4L0 910 945 HW: 4L0 827 851 F
Component: ValeoHeckdeckel H58 0500
Revision: --H58001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6C81397D3A851297BE0-8038
Subsystem 2 - Serial number: 4ó
Subsystem 3 - Serial number: RD04.09.14--H58001002G0258ÿ
Subsystem 4 - Serial number: 2G0258ÿ
02242 - Rear Lid Lock Button in Luggage Compartment (E406)
Reset counter: 124
Mileage: 51051 km
Date: 2017.10.14
Time: 16:41:34
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H08 0080
Revision: AAH08080 Serial number: 0114947545----
Coding: 0003595
VCID: 26150B55E4E9E8C7284-8072
Component: J_245_EE16_SKB10H15 0220
Subsystem 2 - Part No: 4L0 910 591 A
Component: J_394_EE16_SKB10H15 0220
Subsystem 3 - Part No: 4L0 910 591 A
Component: J_392_EE16_SKB10H15 0220
Reset counter: 135
Mileage: 51228 km
Date: 2018.01.25
Time: 10:48:13
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0362
Revision: Serial number: 0000116989214
Reset counter: 135
Mileage: 51228 km
Date: 2018.01.25
Time: 10:47:21
Reset counter: 136
Mileage: 51228 km
Date: 2013.02.27
Time: 00:18:52
End----(Elapsed Time: 02:07, VBatt start/end: 10.6V/10.5V. VIgn 10.5V)-----
